I have been using autorandr for some time now. Everything seemed to work fine until an update yesterday,.
When i try to check for my configuration using the command autorandr i get this response
File "/home/wangui/.local/bin/autorandr", line 33, in <module>
sys.exit(load_entry_point('autorandr==1.11.post1', 'console_scripts', 'autorandr')())
File "/home/wangui/.local/bin/autorandr", line 22, in importlib_load_entry_point
for entry_point in distribution(dist_name).entry_points
File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 919, in distribution
return Distribution.from_name(distribution_name)
File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 518, in from_name
raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: No package metadata was found for autorandr
I have tried reinstalling autorandr but that doesn’t fix anything. Any help is appreciated. Thanks.
