The output of amixer
Card sysdefault:0 'sofessx8336'/'MultilaserIndustrial-UB23X-SHG47-UB235'
Mixer name : 'Intel Geminilake HDMI'
Components : 'HDA:8086280d,80860101,00100000'
Controls : 67
Simple ctrls : 46
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 3
Mono:
Front Left: Playback 3 [100%] [0.00dB] [off]
Front Right: Playback 3 [100%] [0.00dB] [off]
Simple mixer control 'Headphone Mixer',0
Capabilities: volume
Limits: 0 - 11
Front Left: 2 [18%] [-9.00dB]
Front Right: 2 [18%] [-9.00dB]
Simple mixer control 'Speaker',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Mic Boost',0
Mono: Playback [on]
Simple mixer control 'IEC958',0
Mono: Playback [off]
Simple mixer control 'IEC958',1
Simple mixer control 'IEC958',2
Simple mixer control 'Playback Polarity',0
Capabilities: enum
Items: 'Normal' 'R Invert' 'L Invert' 'L + R Invert'
Item0: 'Normal'
Simple mixer control 'Capture Polarity',0
Capabilities: enum
Items: 'Normal' 'Invert'
Item0: 'Normal'
Simple mixer control 'ADC',0
Capabilities: cvolume cvolume-joined
Capture channels: Mono
Limits: Capture 0 - 192
Mono: Capture 192 [100%] [0.00dB]
Simple mixer control 'ADC Double Fs',0
Simple mixer control 'ADC PGA Gain',0
Capabilities: volume volume-joined
Limits: 0 - 10
Mono: 10 [100%] [24.00dB]
Simple mixer control 'ADC Soft Ramp',0
Mono: Playback [on]
Simple mixer control 'ALC',0
Capabilities: cswitch cswitch-joined
Mono: Capture [off]
Simple mixer control 'ALC Capture Attack Time',0
Limits: 0 - 10
Mono: 2 [20%]
Simple mixer control 'ALC Capture Decay Time',0
Limits: 0 - 10
Mono: 3 [30%]
Simple mixer control 'ALC Capture Hold Time',0
Limits: 0 - 10
Mono: 0 [0%]
Simple mixer control 'ALC Capture Max',0
Limits: 0 - 28
Mono: 28 [100%] [35.50dB]
Simple mixer control 'ALC Capture Min',0
Limits: 0 - 28
Mono: 0 [0%] [-12.00dB]
Simple mixer control 'ALC Capture Noise Gate',0
Simple mixer control 'ALC Capture Noise Gate Threshold',0
Limits: 0 - 31
Mono: 0 [0%]
Simple mixer control 'ALC Capture Noise Gate Type',0
Capabilities: enum
Items: 'Constant PGA Gain' 'Mute ADC Output'
Item0: 'Constant PGA Gain'
Simple mixer control 'ALC Capture Target',0
Limits: 0 - 11
Mono: 11 [100%] [-1.50dB]
Simple mixer control 'DAC',0
Limits: Playback 0 - 192
Mono:
Front Left: Playback 192 [100%] [0.00dB]
Front Right: Playback 192 [100%] [0.00dB]
Simple mixer control 'DAC Double Fs',0
Simple mixer control 'DAC Mono Mix',0
Simple mixer control 'DAC Notch Filter',0
Simple mixer control 'DAC Soft Ramp',0
Simple mixer control 'DAC Soft Ramp Rate',0
Limits: 0 - 4
Mono: 4 [100%]
Simple mixer control 'DAC Source Mux',0
Capabilities: enum
Items: 'LDATA TO LDAC, RDATA TO RDAC' 'LDATA TO LDAC, LDATA TO RDAC' 'RDATA TO LDAC, RDATA TO RDAC' 'RDATA TO LDAC, LDATA TO RDAC'
Item0: 'LDATA TO LDAC, RDATA TO RDAC'
Simple mixer control 'DAC Stereo Enhancement',0
Limits: 0 - 7
Mono: 0 [0%]
Simple mixer control 'Differential Mux',0
Capabilities: enum
Items: 'lin1-rin1' 'lin2-rin2' 'lin1-rin1 with 20db Boost' 'lin2-rin2 with 20db Boost'
Item0: 'lin1-rin1'
Simple mixer control 'Digital Mic Mux',0
Capabilities: enum
Items: 'dmic disable' 'dmic data at high level' 'dmic data at low level'
Item0: 'dmic disable'
Simple mixer control 'Headset Mic',0
Simple mixer control 'Internal Mic',0
Mono: Playback [on]
Simple mixer control 'Left Headphone Mixer LLIN',0
Simple mixer control 'Left Headphone Mixer Left DAC',0
Mono: Playback [on]
Simple mixer control 'Left Headphone Mux',0
Capabilities: enum
Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA'
Item0: 'lin1-rin1'
Simple mixer control 'PGA1.0 1 Master',0
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 PCM 0',0
Limits: Capture 0 - 40
Front Left: Capture 32 [80%] [0.00dB]
Front Right: Capture 32 [80%] [0.00dB]
Simple mixer control 'PGA5.0 5 Master',0
Mono:
Simple mixer control 'PGA6.0 6 Master',0
Mono:
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'Right Headphone Mixer RLIN',0
Simple mixer control 'Right Headphone Mixer Right DAC',0
Mono: Playback [on]
Simple mixer control 'Right Headphone Mux',0
Capabilities: enum
Item0: 'lin1-rin1'
