Hello,
So I found this: Bluetooth_headset#Apple_AirPods_have_low_volume in the wiki (can’t include links)
to fix my airpods pro low volume probem.
The thing is that after turning off the laptop, I have to re-pair them in order to make it work again.
Is there a permanent solution for this?
Im using:
KDE Plasma Version: 5.24.6
KDE Frameworks Version: 5.96.0
Qt Version: 5.15.5
Kernel Version: 5.15.55-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 12 × Intel® Core™ i7-8750H CPU @ 2.20GHz
Memory: 31,2 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1060/PCIe/SSE2
Thanks!
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=033974d0-79d5-4040-b412-829d14155996 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TIMI product: TM1801 v: Mi Gaming Laptop 15.6
serial: <superuser required> Chassis: type: 10 v: Mi Gaming Laptop 15.6
Mobo: TIMI model: TM1801 serial: <superuser required> UEFI: TIMI
v: XMGCF500P0302 date: 07/02/2018
RAM: total: 31.22 GiB used: 7.56 GiB (24.2%)
RAM Report:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 900 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 52815
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Xiaomi
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Xiaomi
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c20 class-ID: 0300
Device-3: Chicony XiaoMi USB 2.0 Webcam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b59a class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: nvidia alternate: intel gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: eDP-1 mapped: HDMI-0 model: Najing CEC Panda LM156LF9L01
built: 2017 res: 2560x1440 hz: 144 dpi: 108 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1060/PCIe/SSE2 v: 4.6.0 NVIDIA 515.57
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Xiaomi driver: snd_hda_intel
Device-2: NVIDIA GP106 High Definition Audio vendor: Xiaomi
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
vendor: Xiaomi driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.14 TiB used: 114.89 GiB (9.8%)
model: MZVLB256HAHQ-00000 size: 238.47 GiB block-size: physical: 512 B
rev: EXD7101Q temp: 51.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
ID-1: / raw-size: 118.88 GiB size: 116.45 GiB (97.96%)
used: 36.62 GiB (31.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 033974d0-79d5-4040-b412-829d14155996
used: 27.3 MiB (28.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: E21B-AF67
ID-3: /run/media/jfght/Extra HDD raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 78.25 GiB (8.4%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: Extra HDD uuid: 301E19D81BB9B526
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 118.88 GiB fs: ntfs label: N/A
uuid: 78201CE4201CAAE0
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 617 MiB fs: ntfs label: N/A
uuid: 169CAFD59CAFADA5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Logitech G502 Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07d class-ID: 0300 serial: <filter>
Device-2: 1-6:3 info: Chicony XiaoMi USB 2.0 Webcam type: Video
Device-3: 1-10:4 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:8910 class-ID: 0301
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 63.0 C pch: 69.0 C mobo: N/A gpu: nvidia
temp: 63 C
Processes: 372 Uptime: 1h 56m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1269 pacman: 1248 lib: 332 flatpak: 0 snap: 21 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
