~ yay -S chromium-wayland-vaapi
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1] chromium-wayland-vaapi-97.0.4692.99-1
1 chromium-wayland-vaapi (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> n
:: PKGBUILD up to date, Skipping (1/0): chromium-wayland-vaapi
==> Diffs to show?
==> n
:: (1/1) Parsing SRCINFO: chromium-wayland-vaapi
==> Making package: chromium-wayland-vaapi 97.0.4692.99-1 (Wed Apr 13 18:28:30 2022)
==> Retrieving sources...
-> Found chromium-97.0.4692.99.tar.xz
-> Found chromium-launcher-8.tar.gz
-> Found chromium-97-patchset-4.tar.xz
-> Found sql-make-VirtualCursor-standard-layout-type.patch
-> Found chromium-93-ffmpeg-4.4.patch
-> Found unbundle-ffmpeg-av_stream_get_first_dts.patch
-> Found unexpire-accelerated-video-decode-flag.patch
-> Found use-oauth2-client-switches-as-default.patch
-> Found 0001-ozone-wayland-add-VA-API-support.patch
chromium-97.0.4692.99.tar.xz ... Passed
chromium-launcher-8.tar.gz ... Passed
chromium-97-patchset-4.tar.xz ... Passed
sql-make-VirtualCursor-standard-layout-type.patch ... Passed
chromium-93-ffmpeg-4.4.patch ... Passed
unbundle-ffmpeg-av_stream_get_first_dts.patch ... Passed
unexpire-accelerated-video-decode-flag.patch ... Passed
use-oauth2-client-switches-as-default.patch ... Passed
0001-ozone-wayland-add-VA-API-support.patch ... Passed
==> Making package: chromium-wayland-vaapi 97.0.4692.99-1 (Wed Apr 13 18:28:32 2022)
yuyh]jbnbnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnb^[[C==> Extracting sources...
-> Extracting chromium-97.0.4692.99.tar.xz with bsdtar
-> Extracting chromium-launcher-8.tar.gz with bsdtar
-> Extracting chromium-97-patchset-4.tar.xz with bsdtar
==> Starting prepare()...
patching file google_apis/google_api_keys.cc
Hunk #1 succeeded at 164 (offset 10 lines).
patching file media/filters/ffmpeg_demuxer.cc
Hunk #1 succeeded at 405 (offset -22 lines).
Hunk #2 succeeded at 421 (offset -22 lines).
Hunk #3 succeeded at 482 (offset -22 lines).
patching file build/linux/unbundle/ffmpeg.gn
patching file chrome/browser/flag-metadata.json
Hunk #1 succeeded at 1365 (offset 80 lines).
patching file sql/recover_module/btree.cc
Hunk #1 succeeded at 136 (offset 1 line).
patching file sql/recover_module/btree.h
Hunk #1 succeeded at 103 (offset 1 line).
Hunk #2 succeeded at 151 (offset 1 line).
Hunk #3 succeeded at 173 (offset 1 line).
patching file sql/recover_module/cursor.cc
Hunk #1 succeeded at 28 (offset 2 lines).
Hunk #2 succeeded at 38 (offset 2 lines).
Hunk #3 succeeded at 101 (offset 2 lines).
Hunk #4 succeeded at 115 (offset 2 lines).
patching file sql/recover_module/cursor.h
patching file sql/recover_module/pager.cc
patching file sql/recover_module/pager.h
Hunk #1 succeeded at 5 with fuzz 1.
Hunk #2 succeeded at 72 (offset 1 line).
Hunk #3 succeeded at 139 (offset 1 line).
patching file media/gpu/vaapi/vaapi_picture_factory.cc
Hunk #1 succeeded at 101 (offset -1 lines).
patching file media/gpu/vaapi/vaapi_picture_native_pixmap.cc
patching file media/gpu/vaapi/vaapi_video_decode_accelerator.cc
patching file ui/ozone/platform/wayland/gpu/gbm_pixmap_wayland.cc
patching file ui/ozone/platform/wayland/gpu/gbm_pixmap_wayland.h
patching file ui/ozone/platform/wayland/ozone_platform_wayland.cc
Hunk #1 succeeded at 312 with fuzz 1 (offset -2 lines).
==> Sources are ready.
==> Making package: chromium-wayland-vaapi 97.0.4692.99-1 (Wed Apr 13 18:30:01 2022)
==> WARNING: Using existing $srcdir/ tree
==> Removing existing $pkgdir/ directory...
==> Starting build()...
make: Entering directory '/home/kimiblock/.cache/yay/chromium-wayland-vaapi/src/chromium-launcher-8'
cc -o chromium -DLAUNCHER_VERSION=\"v8\" -DCHROMIUM_NAME=\"chromium\" -DCHROMIUM_BINARY=\"/usr/lib/chromium/chromium\" -DCHROMIUM_VENDOR="\"Manjaro Linux\"" -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -pthread -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now launcher.c -lglib-2.0
make: Leaving directory '/home/kimiblock/.cache/yay/chromium-wayland-vaapi/src/chromium-launcher-8'
Done. Made 16868 targets from 2943 files in 2895ms
ninja: Entering directory `out/Release'
[3375/48999] CXX obj/third_party/angle..._backend/vk_internal_shaders_autogen.o
../../third_party/angle/src/libANGLE/renderer/vulkan/vk_internal_shaders_autogen.cpp:13:9: warning: 'USE_SYSTEM_ZLIB' macro redefined [-Wmacro-redefined]
#define USE_SYSTEM_ZLIB
<command line>:33:9: note: previous definition is here
#define USE_SYSTEM_ZLIB 1
1 warning generated.
[4156/48999] CXX obj/third_party/breakpad/client/exception_handler.o
FAILED: obj/third_party/breakpad/client/exception_handler.o
clang++ -MMD -MF obj/third_party/breakpad/client/exception_handler.o.d -DUSE_UDEV -DUSE_AURA=1 -DUSE_GLIB=1 -DUSE_NSS_CERTS=1 -DUSE_OZONE=1 -DUSE_X11=1 -DOFFICIAL_BUILD -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -DNO_UNWIND_TABLES -D_GNU_SOURCE -DCR_CLANG_REVISION=\"llvmorg-14-init-8033-gabb2a91b-2\" -DNDEBUG -DNVALGRIND -DDYNAMIC_ANNOTATIONS_ENABLED=0 -I../../third_party/breakpad -I../../third_party/breakpad/breakpad/src -I../../third_party/breakpad/breakpad/src/client -I../../third_party/breakpad/breakpad/src/third_party/linux/include -I../.. -Igen -fno-delete-null-pointer-checks -fno-ident -fno-strict-aliasing --param=ssp-buffer-size=4 -fstack-protector -fno-unwind-tables -fno-asynchronous-unwind-tables -fPIC -pthread -fcolor-diagnostics -fmerge-all-constants -fcrash-diagnostics-dir=../../tools/clang/crashreports -mllvm -instcombine-lower-dbg-declare=0 -flto=thin -fsplit-lto-unit -fwhole-program-vtables -m64 -march=x86-64 -msse3 -ffile-compilation-dir=. -no-canonical-prefixes -O2 -fdata-sections -ffunction-sections -fno-unique-section-names -fno-omit-frame-pointer -g0 -ftrivial-auto-var-init=pattern -fprofile-instr-use=../../chrome/build/pgo_profiles/chrome-linux-4692-1641404809-2e9cd7e4fa1c8c41d8f32f8bc0dd52e2646c649a.profdata -Wno-profile-instr-unprofiled -Wno-profile-instr-out-of-date -Wno-backend-plugin -fsanitize=cfi-vcall -fsanitize-ignorelist=../../tools/cfi/ignores.txt -fsanitize=cfi-icall -fvisibility=hidden -Wheader-hygiene -Wstring-conversion -Wtautological-overlap-compare -Wall -Wno-unused-variable -Wno-c++11-narrowing -Wno-unused-but-set-variable -Wno-misleading-indentation -Wno-missing-field-initializers -Wno-unused-parameter -Wloop-analysis -Wno-unneeded-internal-declaration -Wenum-compare-conditional -Wno-psabi -Wno-ignored-pragma-optimize -std=c++14 -fno-trigraphs -Wno-trigraphs -fno-exceptions -fno-rtti -fvisibility-inlines-hidden -D__DATE__= -D__TIME__= -D__TIMESTAMP__= -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -Wno-builtin-macro-redefined -Wno-unknown-warning-option -c ../../third_party/breakpad/breakpad/src/client/linux/handler/exception_handler.cc -o obj/third_party/breakpad/client/exception_handler.o
../../third_party/breakpad/breakpad/src/client/linux/handler/exception_handler.cc:141:41: error: no matching function for call to 'max'
static const unsigned kSigStackSize = std::max(16384, SIGSTKSZ);
/usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/11.2.0/../../../../include/c++/11.2.0/bits/algorithmfwd.h:407:5: note: candidate template ignored: deduced conflicting types for parameter '_Tp' ('int' vs. 'long')
max(const _Tp&, const _Tp&);
/usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/11.2.0/../../../../include/c++/11.2.0/bits/stl_algo.h:3467:5: note: candidate template ignored: could not match 'initializer_list<type-parameter-0-0>' against 'int'
max(initializer_list<_Tp> __l, _Compare __comp)
/usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/11.2.0/../../../../include/c++/11.2.0/bits/stl_algo.h:3461:5: note: candidate function template not viable: requires single argument '__l', but 2 arguments were provided
max(initializer_list<_Tp> __l)
/usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/11.2.0/../../../../include/c++/11.2.0/bits/algorithmfwd.h:412:5: note: candidate function template not viable: requires 3 arguments, but 2 were provided
max(const _Tp&, const _Tp&, _Compare);
1 error generated.
[4173/48999] ACTION //third_party/blin...uild/toolchain/linux/unbundle:default)
ninja: build stopped: subcommand failed.
==> ERROR: A failure occurred in build().
Aborting...
-> error making: chromium-wayland-vaapi
System info:
OS: Manjaro Linux x86_64
Host: ZenBook UX425UG_UM425UG 1.0
Kernel: 5.15.28-1-MANJARO
Uptime: 4 hours, 24 mins
Packages: 1390 (pacman)
Shell: zsh 5.8.1
Resolution: 1920x1080
DE: GNOME 41.4
WM: Mutter
WM Theme: Adwaita
Theme: Adwaita-maia-dark [GTK2/3]
Icons: Papirus-Dark [GTK2/3
Terminal: gnome-terminal
CPU: AMD Ryzen 7 5700U with Radeon Graphics (16
GPU: NVIDIA GeForce MX450
GPU: AMD ATI 05:00.0 Lucienne
Memory: 5469MiB / 15457MiB
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Sorry, I’m new to here
Here’s the output of inxi:
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=aef45bfc-6e4a-4be8-bd93-d15e5c9d6014 rw nvidia-drm.modeset=1
quiet splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: ASUSTeK product: ZenBook UX425UG_UM425UG v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX425UG v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: UX425UG.300 date: 05/25/2021
ID-1: BATT charge: 58.1 Wh (100.0%) condition: 58.1/63.1 Wh (92.1%)
volts: 12.0 min: 12.0 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: full cycles: 46
RAM: total: 15.1 GiB used: 6.99 GiB (46.3%)
RAM Report:
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1441 high: 1651 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1611 10: 1651 11: 1397
12: 1397 13: 1636 14: 1397 15: 1397 16: 1397 bogomips: 57504
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: NVIDIA TU117M [GeForce MX450] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.0
chip-ID: 10de:1f9c class-ID: 0302
Device-2: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c
class-ID: 0300
Device-3: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 0408:30c0 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa gpu: amdgpu
display-ID: 0
Monitor-1: eDP-1 model: Najing CEC Panda 0x0035 built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 37.56 GiB (3.9%)
model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 643.51 GiB size: 632.34 GiB (98.26%)
used: 37.53 GiB (5.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: aef45bfc-6e4a-4be8-bd93-d15e5c9d6014
used: 31.9 MiB (33.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 440E-8AD2
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 309.54 GiB fs: bitlocker
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 716 MiB fs: ntfs label: N/A
uuid: C4F4991AF4991032
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Quanta USB2.0 HD UVC WebCam type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Darfon HP Wireless Keyboard and Mouse
type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0d62:0d99 class-ID: 0301
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 0.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 403 Uptime: 5h 40m wakeups: 1764 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1390
lib: 456 flatpak: 0 Shell: Zsh v: 5.8.1 running-in: gnome-terminal
inxi: 3.3.15
Thanks for your reply!
I’ve installed base-devel correctly
I build the AUR package chromium-wayland-vaapi manually by running:
export LANG=C
git clone https://aur.archlinux.org/chromium-wayland-vaapi.git
cd chromium-wayland-vaapi
makepkg -si
Unfortunately it gives me a similiar error.
~/chromium-wayland-vaapi master ?1 makepkg -si ✔
==> Making package: chromium-wayland-vaapi 97.0.4692.99-1 (2022年04月13日 星期三 21时53分55秒)
-> Downloading chromium-launcher-8.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 141 0 141 0 0 133 0 --:--:-- 0:00:01 --:--:-- 133
100 4725 0 4725 0 0 2422 0 --:--:-- 0:00:01 --:--:-- 5826
-> Downloading chromium-97-patchset-4.tar.xz...
100 668 100 668 0 0 289 0 0:00:02 0:00:02 --:--:-- 289
100 4240 100 4240 0 0 426 0 0:00:09 0:00:09 --:--:-- 604
make: Entering directory '/home/kimiblock/chromium-wayland-vaapi/src/chromium-launcher-8'
make: Leaving directory '/home/kimiblock/chromium-wayland-vaapi/src/chromium-launcher-8'
Done. Made 16868 targets from 2943 files in 3167ms
[209/48999] CXX obj/third_party/breakpad/client/exception_handler.o
1 error generated.
[226/48999] CXX obj/skia/skia_opts_hsw/SkOpts_hsw.o
Aborting...
