When I run my python code on vscode 3/4 of the screen goes black for a few seconds then it works normal but I want to know why this happens.
if you run wayland maybe try with X11 session?
Is it a fullscreen application?
No, it is an 800x600 SDL window
I am using x org already. I didn’t change it
Tell us more about your system: [HowTo] Find system information
~ mhwd -li ![]()
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
~ mhwd-kernel -li ![]()
Currently running: 5.15.32-1-MANJARO (linux515)
linux515
~ lsb_release -sirc
ManjaroLinux 21.2.6 Qonos ✔
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /var/lib/snapd/snap/bare/5
loop1
squash 4.0 0 100% /var/lib/snapd/snap/core20/1405
loop2
squash 4.0 0 100% /var/lib/snapd/snap/core18/2344
loop3
squash 4.0 0 100% /var/lib/snapd/snap/core/12834
loop4
squash 4.0 0 100% /var/lib/snapd/snap/code/94
loop5
squash 4.0 0 100% /var/lib/snapd/snap/discord/132
loop6
squash 4.0 0 100% /var/lib/snapd/snap/g-assist/2
loop7
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
loop8
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-38-2004/99
loop9
squash 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1519
loop10
squash 4.0 0 100% /var/lib/snapd/snap/snap-store/558
loop11
squash 4.0 0 100% /var/lib/snapd/snap/snapd/15534
loop12
sda
├─sda1
│ vfat FAT32 SYSTEM
│ C632-F156 69,9M 27% /boot/efi
├─sda2
│ vfat FAT32 C82D-CAD6
├─sda3
├─sda4
│ vfat FAT32 NO_LABEL
│ FA46-A4E5
├─sda5
│ swap 1 7ffdc910-cbb0-4d52-a0e6-87b19fda5500 [SWAP]
├─sda6
│ ext4 1.0 b0a283cc-3d5a-4c8f-8f36-570e5dbb1204
├─sda7
│ ext4 1.0 43003dcd-89a5-4f4e-a515-d3cfeedd520e 538,4G 3% /
├─sda8
│ ntfs 02F62814F6280B0D
└─sda9
ntfs F2A2D87CA2D8472F
sr0
total used free shared buff/cache available
Mem: 7834 3409 1117 589 3307 3569
Swap: 7648 0 7648
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=HDMI,DEV=0
HDA Intel HDMI, HDMI 0
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA Intel HDMI, HDMI 1
HDMI Audio Output
hdmi:CARD=HDMI,DEV=2
HDA Intel HDMI, HDMI 2
HDMI Audio Output
hdmi:CARD=HDMI,DEV=3
HDA Intel HDMI, HDMI 3
HDMI Audio Output
hdmi:CARD=HDMI,DEV=4
HDA Intel HDMI, HDMI 4
HDMI Audio Output
usbstream:CARD=HDMI
HDA Intel HDMI
USB Stream Output
sysdefault:CARD=PCH
HDA Intel PCH, ALC3236 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
I cant post links and photos and forum identififes it as a link because of dots
You won’t have that issue with preformatting – hence my quote.
What do you mean with preformatting? Do you mean reinstall manjaro?
no he means preformating your text; click this icon: </> and inside put the output from:
inxi -Fazy
mhwd -l
mhwd -li
Please open and read the guide i linked above…
~ inxi -Fazy ✔
mhwd -l
mhwd -li
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=43003dcd-89a5-4f4e-a515-d3cfeedd520e rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: X550LN v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X550LN v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X550LN.301 date: 04/14/2014
ID-1: BAT0 charge: 16.4 Wh (98.8%) condition: 16.6/38.5 Wh (43.3%)
volts: 14.8 min: 14.8 model: ASUSTeK X550A26 type: Li-ion serial: N/A
status: charging cycles: 300
Info: model: Intel Core i7-4500U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2424 high: 2694 min/max: 800/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1796 2: 2514 3: 2694
4: 2694 bogomips: 19162
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 840M] vendor: ASUSTeK driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 2 speed: 5 GT/s bus-ID: 04:00.0 chip-ID: 10de:1341
class-ID: 0302
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 2-5:3 chip-ID: 04f2:b40a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: LG Display 0x039f built: 2012 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.3.8 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f1 state: down mac: <filter>
Device-2: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Foxconn
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 1814:3290 class-ID: 0280
IF: wlp3s0f0 state: up mac: <filter>
Device-1: Ralink RT3290 Bluetooth vendor: Foxconn driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.1 chip-ID: 1814:3298 class-ID: 0d11
Local Storage: total: 931.51 GiB used: 16.36 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 594.73 GiB size: 584.32 GiB (98.25%)
used: 16.33 GiB (2.8%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
used: 26.1 MiB (27.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 7.47 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 50.0 C pch: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
^[[BInfo:
Processes: 230 Uptime: 9m wakeups: 1 Memory: 7.65 GiB used: 2.39 GiB (31.2%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: 1246 pacman: 1226 lib: 335 flatpak: 7 snap: 13 Shell: Zsh v: 5.8.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
^[[B^[[B> 0000:02:00.1 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:04:00.0 (0302:10de:1341) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
> 0000:00:02.0 (0300:8086:0a16) Display controller Intel Corporation:
video-vesa 2017.03.12 true PCI
From your description, and your use of the PRIME driver, this may be relevant: PRIME - ArchWiki
~ sudo mhwd -a pci nonfree 0300 ✔
[sudo] password for atssen:
> Skipping already installed config 'video-hybrid-intel-nvidia-prime' for device: 0000:00:02.0 (0300:8086:0a16) Display controller Intel Corporation Haswell-ULT Integrated Graphics Controller
~ sudo mhwd -a pci free 0300 ✔ 5s
> Skipping already installed config 'video-linux' for device: 0000:00:02.0 (0300:8086:0a16) Display controller Intel Corporation Haswell-ULT Integrated Graphics Controller
~ mhwd -l -d ✔
> PCI Device: /devices/pci0000:00/0000:00:1c.2/0000:02:00.1 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:1c.4/0000:04:00.0 (0302:10de:1341)
Display controller nVidia Corporation GM108M [GeForce 840M]
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: video-modesetting
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:0a16)
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
So i tried to install/update both free and nonfree drivers according to manjaro wiki’s “Configure graphics card” page but it seems like i already have latest ones and this log says i have prime
So what i must do now?
run the pygame, after the black screen close the program and open ksystemlog app and check for logs related to the troublesome program
1.05.2022 20:39 anacron Job `cron.daily' started
1.05.2022 20:39 anacron Job `cron.daily' terminated
1.05.2022 20:39 anacron Job `cron.weekly' started
1.05.2022 20:39 anacron Job `cron.weekly' terminated
1.05.2022 20:39 anacron Normal exit (2 jobs run)
1.05.2022 20:39 rtkit-daemon Supervising 6 threads of 3 processes of 1 users.
1.05.2022 20:39 rtkit-daemon Successfully made thread 20007 of process 20003 owned by '1000' high priority at nice level -15.
1.05.2022 20:39 rtkit-daemon Supervising 7 threads of 4 processes of 1 users.
1.05.2022 20:39 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10388, resource id: 52428814, major code: 15 (QueryTree), minor code: 0
1.05.2022 20:39 kwin_x11 WobblyWindowsConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 GlideConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 BlurConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 ZoomConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 SlidingPopupsConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 SlideConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 PresentWindowsConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 MagicLampConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 KscreenConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 DesktopGridConfig::instance called after the first use - ignoring
1.05.2022 20:39 kwin_x11 kwin_core: XCB error: 10 (BadAccess), sequence: 10482, resource id: 754, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
this is the log when i open a pygame sdl window
looks like a kwin but who knows… disable compositor with this shortcut: alt + shift + f12 run the troublesome program again, and check if you get black screen … you can enable compositor again, by pressing the shortcut…
yeah it is working perfect now btw this is how my desktop looks when sdl window open
It is an issue too
