Hello community, today I just received a wireless mouse, I have put the batteries at 100%, connect the bluetooth adapter to the PC and I can’t get the mouse to work, it doesn’t turn on, it doesn’t do anything, check that the mouse button is in on but still does nothing, do I need a driver? when I go to the bluetooth option in manjaro it tells me (no bluetooth adapters found)
Welcome to the forum! ![]()
Then that’s your real issue. The BlueTooth mouse not working is symptom.
Please post your system info as outlined here:
Please also see:
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=36419e1f-4002-4747-8ac0-97794a302f92 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ECS model: H61H2-CM v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 02/28/2013
RAM: total: 7.73 GiB used: 2.74 GiB (35.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-2400 bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1596 min/max: 1600/3400 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1596 2: 1596 3: 1596 4: 1596 bogomips: 24753
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
disabled
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Oland [Radeon HD 8570 / R5 430 OEM R7 240/340 Radeon 520 OEM]
vendor: Dell driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-I-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 1002:6611
class-ID: 0300
Device-2: EC2U200 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:5
chip-ID: cce3:3884 class-ID: 0102
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: DVI-I-1 mapped: DVI-0 res: 1440x900 hz: 60 size: N/A modes:
max: 1024x768 min: 640x480
OpenGL: renderer: AMD OLAND (LLVM 14.0.6 DRM 2.50 5.15.65-1-MANJARO) v: 4.5
Mesa 22.1.7 direct render: Yes
vendor: Elite Systems driver: snd_hda_intel bus-ID: 1-1.4:5 v: kernel
bus-ID: 00:1b.0 chip-ID: cce3:3884 chip-ID: 8086:1c20 class-ID: 0102
class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: EC2U200 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
vendor: Elite Systems driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 577.55 GiB used: 64.6 GiB (11.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst Elite 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAKX-221CA1 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1H17
scheme: MBR
ID-1: / raw-size: 111.79 GiB size: 109.47 GiB (97.93%) used: 24.57 GiB
(22.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 36419e1f-4002-4747-8ac0-97794a302f92
ID-2: /home/<filter>/pCloudDrive raw-size: N/A size: 7 GiB used: 188.7 MiB
(2.6%) fs: fuse source: ERR-102
ID-3: /mnt/HDD_Linux raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 39.85 GiB (8.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: b36560c9-67c3-4fdf-b801-05052cb8f49f
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:4 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
Device-2: 1-1.2:3 info: China Resource Semico Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1a2c:0021 class-ID: 0300
Device-3: 1-1.4:5 info: EC2U200 type: Video,Audio
power: 200mA chip-ID: cce3:3884 class-ID: 0102
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 2-1.3:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 2-1.3.2:4 info: Genesys Logic SD/MMC card reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05e3:0722 class-ID: 0806
serial: <filter>
Device-2: 2-1.3.3:6 info: YICHIP Wireless Device type: Keyboard,Mouse
power: 100mA chip-ID: 3151:3020 class-ID: 0301
System Temperatures: cpu: 40.0 C mobo: N/A gpu: radeon temp: 37.0 C
Processes: 224 Uptime: 1h 1m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1436 pm: pacman pkgs: 1426 libs: 401 tools: pamac pm: flatpak
pkgs: 10 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.21
What wireless mouse? Brand and model?
It appears you’re using a desktop PC. How does it have BlueTooth support? A USB adapter?
Please post the output of the following command while the mouse (and if applicable, the BlueTooth adapter) is connected:
lsusb
The box doesn’t really say much about the brand, the most information I can get is that it says 2.4Ghz Wireless OPtical Mouse, as for the command here it is
Bus 002 Device 006: ID 3151:3020 YICHIP Wireless Device
Bus 002 Device 004: ID 05e3:0722 Genesys Logic, Inc. SD/MMC card reader
Bus 002 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID cce3:3884 EC2U200 EC2U200
Bus 001 Device 003: ID 1a2c:0021 China Resource Semico Co., Ltd Keyboard
Bus 001 Device 004: ID 18f8:0f97 [Maxxter] Optical Gaming Mouse [Xtrem]
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
what I can notice is that it detects the usb adapter because it shows it here
[quote=“UrsuloCD, post:6, topic:123303”]Bus 001 Device 004: ID 18f8:0f97 [Maxxter] Optical Gaming Mouse [Xtrem]
[/quote]
It seems it works on Arch and Garuda: [Maxxter] Optical Gaming Mouse [Xtrem]
However, Maxxter mouse support · Issue #615 · libratbag/libratbag · GitHublibratbag (piper backend) does not support it:
Tip: Buy hardware from reputable brands, not no-name generic junk.
EDIT: Wrong device
no that is the mouse i am using by usb cable
