I’ve been having problems with my built in mic not being detected.
I am using a System76 Gazelle I think it’s 15th generation. Here is some of the information to start with about the hardware:
KDE Plasma Version: 5.23.5
KDE Frameworks Version: 5.90.0
Qt Version: 5.15.2
Kernel Version: 5.16.5-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × Intel® Core™ i7-10870H CPU @ 2.20GHz
Memory: 62.5 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics
Not sure if I was dong my research correctly, but some of the things I tried is replacing PulseAudio with manjaro-pipewire. But that didn’t seem to help.
I guess the first thing is of course, is what information you need to start with.
Thank you for your input. This is going to be very helpful. While some things I can say that I have done; I have a huge amount of weak spots. One of my worst, is my lack of patience.
I have bookmark the howto’s for later use, and It has helped me. I will use a separate reply for the issue at hand.
So what drawing from what I read about system information, I have this from my terminal.
~ inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=4ab500a8-bf4b-48ee-bbef-2b6ac3011690 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: System76 product: Gazelle v: gaze15
serial: <superuser required>
Mobo: System76 model: Gazelle v: gaze15 serial: <superuser required>
UEFI: INSYDE v: 1.07.11a date: 12/02/2020
ID-1: BAT0 charge: 44.9 Wh (100.0%) condition: 44.9/48.0 Wh (93.4%)
volts: 16.5 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter>
charge: 70% rechargeable: yes status: Discharging
RAM: total: 62.51 GiB used: 7.99 GiB (12.8%)
RAM Report:
Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1418 high: 3502 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2405 2: 3502 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 3438 12: 2527
13: 1855 14: 971 15: 801 16: 800 bogomips: 70421
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: CLEVO/KAPOK driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 128
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.45 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 08:00.1
IF: enp8s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 8.19 TiB used: 2.01 TiB (24.6%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD easystore 2647 size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1020 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 187.34 GiB (10.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4ab500a8-bf4b-48ee-bbef-2b6ac3011690
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 525E-13A9
ID-3: /run/media/fuzzy/2c9a7512-307f-46cf-8ed3-378f33596e6d
raw-size: 92.95 GiB size: 90.99 GiB (97.89%) used: 60 MiB (0.1%) fs: ext4
dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A
uuid: 2c9a7512-307f-46cf-8ed3-378f33596e6d
ID-4: /run/media/fuzzy/Alternate raw-size: 838.56 GiB
size: 824.4 GiB (98.31%) used: 76 MiB (0.0%) fs: ext4 dev: /dev/nvme1n1p1
maj-min: 259:2 label: Alternate uuid: 30843b13-3a2e-4bb9-9040-bc8527a66ebf
ID-5: /run/media/fuzzy/Backup raw-size: 1.91 TiB size: 1.91 TiB (100.00%)
used: 1.83 TiB (96.0%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: Backup
uuid: 879ea826-b529-4c48-957e-df0ae3081a77
ID-6: /run/media/fuzzy/Meatballs raw-size: 653.59 GiB
size: 653.59 GiB (100.00%) used: 3.8 MiB (0.0%) fs: btrfs dev: /dev/sdb3
maj-min: 8:19 label: Meatballs uuid: bddaae39-38c3-4cd0-8c47-5a5ae271b36c
ID-7: /run/media/fuzzy/Spaghetti raw-size: 1.91 TiB
size: 1.91 TiB (100.00%) used: 3.8 MiB (0.0%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18 label: Spaghetti uuid: b7bf2a02-6a97-451f-99e9-4e6817de4e1a
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-6:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 1-6.1:4 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-8:3 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
class-ID: 0e02
Device-3: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Western Digital easystore 2647 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 1058:2647 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 55.0 C pch: 67.0 C mobo: N/A
Processes: 533 Uptime: 2d 21h 13m wakeups: 71 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1732 apt: 0
pacman: 1675 lib: 412 flatpak: 42 snap: 15 Shell: Zsh v: 5.8 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.12
A System 76 laptop should not have any compatibility issues with Linux and I could not find any mention of audio issues on System76 or PopOS fora, so this might be a mis-configuration in ALSA if it does not work in both sound servers
I suggest you check ALSA audio capture settings:
alsamixer -c0 --view=Capture
(press F1 to see list of keyboard controls)
Check settings for Capture and Internal Mic have audio capture enabled and adjust audio capture level if needed
You might also want to disable capture and zero the level for the Front Mic and Headset Mic jack sockets if they are not in use
If any of the settings are changed, use this command to save ALSA settings
sudo alsactl store
Thank your for responding. So far it still doesn’t show capture devices.
Not sure if this helps, but looking else where there is also this:
~ sudo arecord -l ✔
[sudo] password for fuzzy:
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC293 Analog [ALC293 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
~ pacmd list-sources | grep -e index -e name: -e muted -e device.description ✔ 6s
index: 0
muted: yes
device.description = "Monitor of Built-in Audio Analog Stereo"
* index: 1
muted: no
device.description = "Monitor Source of Simultaneous output to Built-in Audio Analog Stereo"
~ sudo dmesg | grep snd— ✔
~ 0|1 ✘
I now have audio capture. I haven’t found apps that could record though.
PulseAudio data is showing 2 sources but neither are for microphone input
Monitor of Built-in Audio Analog Stereo is the monitor of audio playing to headphones/speakers
Monitor Source of Simultaneous output is the monitor for simultaneous output to play audio to 2 or more output sinks (which is redundant when only one other output sink is available)
I suggest turning off the simultaneous output option in KDE audio controls
Change the Profile for Built-in Audio from Analog Stereo Output to Off
(this should clear any user settings for the device)
Then change Profile to Analog Stereo Duplex to enable output sink and input source
And set the microphone input as default source:
pacmd set-default-source alsa_input.pci-0000_00_1f.3.analog-stereo
To check if card profiles and defaults are set correctly:
pacmd dump | grep -C1 -E 'card-profile|set-default'
I was about t post an update on inxi but I have looked at everything that you said above. Both sound and mic are now working. Thank you very much for your help.
system
Closed
17 February 2022 15:26
10
