yakuake
Segmentation fault (core dumped)
sudo dmesg | grep -E 'yakuake'
[ 4480.365708] yakuake[5785]: segfault at 0 ip 00007f987ed4b734 sp 00007ffde44963e0 error 6 in libQt5Gui.so.5.15.2[7f987ecd3000+4e5000]
Hi @Dark_iaji,
That doesnât help much, or even at all. Please see How to provide good information and, if applicable, [HowTo] post screenshots and links.
Also, please post some logs for Yakuake, so that an effort can be made to see what is the matter:
sudo journalctl -p err..alert -f
Do this wile starting yakuake.
NOTE: This can be quite long, but unfortunately I donât know how to be more specific for Yakuake.
Also, are you able to launch konsole
Mine is working flawlessly after the latest stable update, for what itâs worth.
Konsol has no faults. In fact, if I donât update the system, there will be no yakuake related errors in the kernel log.
Well, see the rest of my post and provide the required information, please.
sudo journalctl -b -p err..alert --no-pager > yakuake.log
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=028de0c1-3902-4ef2-98bf-441bc81f5544 rw rootflags=subvol=@
bluetooth.disable_ertm=1 systemd.unified_cgroup_hierarchy=1 amd_iommu=on
iommu=pt quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.E0
date: 05/13/2021
RAM: total: 31.27 GiB used: 4.72 GiB (15.1%)
Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L1: 768 KiB L2: 6 MiB L3: 64 MiB bogomips: 182472
Speed: 2852 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2291 2: 2190 3: 2194 4: 2198 5: 3213 6: 3283 7: 2079 8: 2199 9: 2199
10: 2199 11: 2192 12: 2198 13: 3529 14: 2385 15: 2267 16: 2098 17: 2166
18: 2199 19: 2199 20: 2200 21: 2121 22: 2122 23: 2853 24: 2848
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Baffin [Radeon RX 550 640SP / RX 560/560X]
vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 2d:00.0
chip-ID: 1002:67ff class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: vfio-pci v: N/A
alternate: nouveau bus-ID: 2e:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: HDMI-A-0 res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 2d:00.1
chip-ID: 1002:aae0 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: vfio-pci
alternate: snd_hda_intel bus-ID: 2e:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 30:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-4: Conexant Systems (Rockwell) Hi-Res Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:3 chip-ID: 0572:1b08
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: d000 bus-ID: 26:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp38s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: c000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IP v4: <filter> type: dynamic scope: global
IP v6: <filter> type: temporary dynamic scope: global
IP v6: <filter> type: mngtmpaddr noprefixroute scope: global
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
IP v6: <filter> scope: link
IF-ID-2: virbr0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
Local Storage: total: 4.71 TiB used: 1.44 TiB (30.5%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: MZWLJ3T8HBLS-00007
size: 2.5 TiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: EPK9AB5Q scheme: GPT
ID-2: /dev/nvme0n2 maj-min: 259:5 vendor: Samsung model: MZWLJ3T8HBLS-00007
size: 1022 GiB block-size: physical: 512 B logical: 512 B type: SSD
ID-3: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKHB340G4M 118000041
size: 316.72 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: EM05 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 2.49 TiB size: 2.49 TiB (100.00%) used: 1.44 TiB (57.6%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3 label: N/A
uuid: 028de0c1-3902-4ef2-98bf-441bc81f5544
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
uuid: ABF4-9F67
ID-3: /home raw-size: 2.49 TiB size: 2.49 TiB (100.00%)
used: 1.44 TiB (57.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
label: N/A uuid: 028de0c1-3902-4ef2-98bf-441bc81f5544
ID-4: /var/cache raw-size: 2.49 TiB size: 2.49 TiB (100.00%)
ID-5: /var/log raw-size: 2.49 TiB size: 2.49 TiB (100.00%)
ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
ID-1: /dev/nvme0n2p1 maj-min: 259:6 size: 1021.99 GiB fs: ntfs
label: VM_Data uuid: 5E840EC0C2E3B61B
ID-2: /dev/sda1 maj-min: 8:1 size: 316.72 GiB fs: ntfs label: VM_Win10
uuid: B73A77C3FCE22EAB
ID-3: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: xfs label: N/A
uuid: c458f826-38ad-4242-a263-fea42bd0e068
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3:3 info: Conexant Systems (Rockwell) Hi-Res Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 0572:1b08 class-ID: 0300
serial: <filter>
Device-2: 1-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 1-6:5 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Genesys Logic All-in-One Cardreader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 05e3:0748 class-ID: 0806 serial: <filter>
Hub-5: 2-2:3 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: Elecom M-HT1DRBK HUGE Wireless Optical TrackBall
type: Mouse driver: elecom,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 056e:010d class-ID: 0301
Device-2: 3-5:3 info: Micro Star MEG X570 ACE type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c35 class-ID: 0300 serial: <filter>
Hub-7: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-10: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-2:3 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Hub-11: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-12: 6-1:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Message: No sensor data found. Is lm-sensors configured?
Processes: 473 Uptime: 9m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1345 lib: 356 flatpak: 0 Shell: Zsh
v: 5.8 running-in: konsole inxi: 3.3.09
And yakuake is not working. Even if yakuake is started, it will not appear on my monitor.
Check which shortcut set for Yakuake in âShortcutsâ page of system settings.
I use xbindkeys to map yakuakeâs startup command to the mouse button, and KDE hotkeys seem to be of little use to me.
same here, yakuake will not appear when launching it. tried manjaro reset via timeshift 2 times, reinstalled yakuake some timesâŚetc
damn
Well, I removed yakuake and installed guake. at least it is immediately and properly working. I should have done this right awayâŚ
Itâs great to have alternatives, but I still want to use yakuake.
#0 0x00007f19973b1734 _ZN12QKeySequenceaSERKS_ (libQt5Gui.so.5 + 0x15a734)
Based on this you have some crash in QKeySequence thus a problem with shortcut it seems? I donât really know where to look.
https://bugs.archlinux.org/task/48447#comment145211
This thread mentioned that yakuake has some debugging interfaces, but I donât know where to get the kde-base-debug package.
sudo pacman -Syyu
core 169.2 KiB 498 KiB/s 00:00 [###############################################################################################################################] 100%
extra 1918.6 KiB 8.40 MiB/s 00:00 [###############################################################################################################################] 100%
community 6.8 MiB 21.5 MiB/s 00:00 [###############################################################################################################################] 100%
multilib 177.7 KiB 3.47 MiB/s 00:00 [###############################################################################################################################] 100%
:: Replace breath2-icon-themes with community/plasma5-themes-breath? [Y/n] y
:: Replace plasma5-themes-breath2 with community/plasma5-themes-breath? [Y/n] y
resolving dependencies...
Packages (4) breath2-icon-themes-1.0.18-5 [removal] manjaro-kde-settings-20211211-1 plasma5-themes-breath-21.2.0-2 plasma5-themes-breath2-1.0.18-5 [removal]
Total Installed Size: 35.05 MiB
Net Upgrade Size: -29.36 MiB
When I update these packages, yakuake does not seem to work. Seems to be the problem of deleting these two packages?
It seems to be a problem with the /etc/xdg/yakuakerc
configuration file.
The following parameters seem to be required.
[Dialogs]
FirstRun=false
After adding this parameter in the /etc/xdg/yakuakerc
configuration file, yakuake seems to work.
It seems that the /etc/xdg/yakuakerc
configuration file was modified after the package manjaro-kde-settings
was updated, which made yakuake unusable.
So the problem is a dialog asking you to choose a shortcut? Thatâs interesting indeedâŚ
P.S. Just add
[Dialogs]
FirstRun=false
to ~/.config/yakuakerc
to bypass this dialog for current user and then update normally.
In fact, I didnât see the dialog box. Could this be a bug?
