Here is some more information. Please tell me if you need something else.
inxi -v7azy (trimmed to keep only relevant info)
Kernel: 6.2.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Graphics part on a wayland session without nvidia_drm:
Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: none bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Lenovo
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
Device-3: Bison EasyCamera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 5986:06b0 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: 0
Monitor-1: eDP-1 res: 1280x720 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 630 (KBL
GT2) direct-render: Yes
Same with nvidia_drm:
speed: 8 GT/s ports: active: none empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
compositor: kwin_wayland driver: X: loaded: modesetting unloaded: nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris,nouveau gpu: i915,nvidia
display-ID: 0
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
xrandr
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 60.05*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.52
1680x1050 59.95
1440x900 60.03
1280x800 59.99
1152x720 59.97
960x600 59.96
928x580 59.88
800x500 59.50
768x480 59.90
720x480 59.71
640x400 59.95
320x200 58.96
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
/etc/X11/mhwd.d/nvidia.conf is empty.
