Hi, first, sorry for my english, i’m from brazil
i bought a notebook and installed manjaro xfce, lastest version. But I have no sound at all, even when i plug my head phone I got nothing. What can I do?
someone, please save me
Welcome,
To see what is wrong, it needs some technical information.
inxi -v7azy
** Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0**
** parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64**
** root=UUID=0e4c0a1b-0612-4a03-b765-4e89d3690e07 rw quiet apparmor=1**
** security=apparmor udev. log_priority=3**
** Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm**
** v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux**
** Type: Laptop System: Positivo Tecnologia SA product: Harrison v: N/A**
** serial: Chassis: type: 10 serial: **
** Mobo: Positivo Tecnologia SA model: N14DP7-V2 v: 11173397**
** serial: UEFI: N/A v: 1.12.X date: 06/30/2021**
** ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/37.0 Wh (100.0%)**
** volts: 8.7 min: N/A model: WB SR 1 WB Lion Battery type: Li-ion**
** serial: status: charging**
** RAM: total: 3.65 GiB used: 2.39 GiB (65.5%)**
** RAM Report: permissions: Unable to run dmidecode. Root privileges**
** required.**
** Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus**
** level: v3 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)**
** stepping: 8 microcode: 0x20**
** Topology: cpus: 1x cores: 2 smt: cache: L1: 112 KiB**
** desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB**
** Speed (MHz): avg: 1921 high: 2118 min/max: 800/2800 scaling:**
** driver: intel_cpufreq governor: schedutil cores: 1: 2118 2: 1725**
** bogomips: 4378**
** Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities**
** arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc**
** cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est**
** flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt**
** lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc**
** nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse**
** pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap**
** smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow**
** tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid**
** x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr**
** Vulnerabilities:**
** Type: itlb_multihit status: Not affected**
** Type: l1tf status: Not affected**
** Type: mds status: Not affected**
** Type: meltdown status: Not affected**
** Type: mmio_stale_data status: Not affected**
** Type: retbleed status: Not affected**
** Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via**
** prctl and seccomp**
** Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer**
** sanitization**
** Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF**
** Type: srbds status: Not affected**
** Type: tsx_async_abort status: Not affected**
** Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel**
** arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1**
** empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300**
** Device-2: SunplusIT MTD camera type: USB driver: snd-usb-audio,uvcvideo**
** bus-ID: 1-8:3 chip-ID: 735f:2223 class-ID: 0102 serial: **
** Display: x11 server: X. Org v: 21.1.4 with: Xwayland v: 22.1.3**
** compositor: xfwm v: 4.16.1 driver: X: loaded: modesetting**
** alternate: fbdev,vesa gpu: i915 display-ID: :0.0 screens: 1**
** Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")**
** s-diag: 414mm (16.31")**
** Monitor-1: eDP-1 model: AU Optronics 0x2e3c built: 2013 res: 1366x768**
** hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")**
** ratio: 16:9 modes: 1366x768**
** Message: Unable to show GL data. Required tool glxinfo missing.**
** Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio**
** driver: sof-audio-pci-intel-apl**
** alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 1-8:3**
** chip-ID: 735f:2223 class-ID: 0102 serial: **
** Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes**
** Sound Server-2: JACK v: 1.9.21 running: no**
** Sound Server-3: PulseAudio v: 16.1 running: yes**
** Sound Server-4: PipeWire v: 0.3.57 running: yes**
^[[1;2A^[[1;2A^[[1;2A^[[1;2A^[[1;2A^[[1;2A^[[1;5Network:
** Message: No PCI device data found.**
** IF-ID-1: wlp0s21f0u7i2 state: up mac: **
** IP v4: type: dynamic noprefixroute scope: global**
** broadcast: **
** IP v6: type: noprefixroute scope: link**
** WAN IP: **
** Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB**
** driver: btusb,rtl8xxxu bus-ID: 1-7:2 chip-ID: 0bda:b720 class-ID: e001**
** serial: **
** Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends**
** Message: No logical block device data found.**
** Message: No RAID data found.**
** Local Storage: total: 126.74 GiB used: 22.35 GiB (17.6%)**
** SMART Message: Unable to run smartctl. Root privileges required.**
** ID-1: /dev/sda maj-min: 8:0 vendor: BIWIN model: C6370 128GB**
** size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s**
** type: SSD serial: rev: 1A0 scheme: GPT**
** ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: USB Flash**
** size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD**
** serial: rev: 0.00 scheme: MBR**
** SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?**
** Message: No optical or floppy data found.**
** ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%) used: 19.51 GiB**
** (16.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A**
** uuid: 0e4c0a1b-0612-4a03-b765-4e89d3690e07**
** ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB**
** (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL**
** uuid: AC32-5B33**
** ID-3: /run/media/victorevans/EVANS raw-size: 7.5 GiB size: 7.48 GiB**
** (99.80%) used: 2.84 GiB (37.9%) fs: vfat dev: /dev/sdb1 maj-min: 8:17**
** label: EVANS uuid: E458-AB5C**
** Alert: No swap data was found.**
** Message: No unmounted partitions found.**
** Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0**
** speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900**
** Device-1: 1-4:6 info: Integrated Express USB Mass Storage Device**
** type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0**
** speed: 480 Mb/s power: 480mA chip-ID: 048d:1176 class-ID: 0806**
** Device-2: 1-7:2 info: Realtek RTL8723BU 802.11b/g/n WLAN Adapter**
** type: Bluetooth driver: btusb,rtl8xxxu interfaces: 3 rev: 2.1**
** speed: 480 Mb/s power: 500mA chip-ID: 0bda:b720 class-ID: e001**
** serial: **
** Device-3: 1-8:3 info: SunplusIT MTD camera type: Video,Audio**
** driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s**
** power: 500mA chip-ID: 735f:2223 class-ID: 0102 serial: **
** Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s**
** chip-ID: 1d6b:0003 class-ID: 0900**
** System Temperatures: cpu: 60.0 C mobo: N/A**
** Fan Speeds (RPM): N/A**
** Processes: 203 Uptime: 47m wakeups: 1 Init: systemd v: 251**
** default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6**
** Packages: pm: pacman pkgs: 1413 libs: 357 tools: pamac pm: flatpak pkgs: 0**
** Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.21**
But apart from that I noticed a serious issue:
Your hardware only has the minimum of ram necessary to run xfce smoothly, 3,6GB. Unsurprisingly, you’re running out of ram but you have no swap set up. This is bound to go wrong very soon.
To fix that:
sudo swapon /dev/sda3
inxi -v7azy again to check if it’s properly recognisedI will format again and set a swap space, for me that way is easier.
but I have no sound at all and this options don’t show in my laptop
i want to send a screenshot, but this forum don’t let me do it
New users do not have permission to post screenshots or active links to prevent spam
Posting screenshots of audio controls is usually not much use for troubleshooting audio problems
Please post response to this command to show more information about audio device(s) detected in ALSA
sudo alsa-info.sh --upload
This command will upload detailed ALSA information to alsa-project.org. You will need to post response in preformatted text format to avoid forum spam prevention
(Use Ctrl+E or </> button)
http://alsa-project.org/db/?f=7addc4ea790f3709dc5b310ac41638c8a5fd6d43
could be my hardware? i was thinking about install win10 just to see if my sound work.
it’s a new fresh laptop, just bought last Sunday
Maybe a step too far…
, first try booting manjaro or any other popular distro like Mint from usb and see if the sound works on the live system.
Pipewire and Pulse Audio both running? I only have Pulse running here on Manjaro and also on a fresh install (xfce) this past weekend Pulse was default, though my .iso may not have been the most current.
I have EndeavourOS in a VM and xfce there runs pipewire by default and inxi ( for Audio) looks like:
Device-1: Intel 82801AA AC97 Audio driver: snd_intel8x0 v: kernel
bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
Sound Server-1: ALSA v: k5.19.10-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Is sof-firmware installed?
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=978bc290-46ff-45f3-83ed-585ebe0eeae0 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
ID-1: BAT0 charge: 35.5 Wh (95.9%) condition: 37.0/37.0 Wh (100.0%)
volts: 8.1 min: N/A model: WB SR 1 WB Lion Battery type: Li-ion
serial: status: discharging
RAM: total: 3.65 GiB used: 2.1 GiB (57.4%)
required.
built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 8
microcode: 0x20
Speed (MHz): avg: 1518 high: 2224 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 813 2: 2224
bogomips: 4378
prctl and seccomp
bus-ID: 1-8:4 chip-ID: 735f:2223 class-ID: 0102 serial:
Display: x11 server: X Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 1-8:4
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
broadcast:
WAN IP:
driver: btusb,rtl8xxxu bus-ID: 1-7:3 chip-ID: 0bda:b720 class-ID: e001
serial:
Local Storage: total: 119.24 GiB used: 8.77 GiB (7.4%)
ID-1: / raw-size: 109.18 GiB size: 106.91 GiB (97.92%) used: 8.77 GiB (8.2%)
uuid: 978bc290-46ff-45f3-83ed-585ebe0eeae0
uuid: 18B4-04C9
ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: bc13589c-7592-4fb0-8c71-43ee825c5167
Device-1: 1-4:2 info: Wacom CTL-490 [Intuos Draw (S)] type: HID,Mouse
driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 498mA
chip-ID: 056a:033b class-ID: 0301
Device-2: 1-7:3 info: Realtek RTL8723BU 802.11b/g/n WLAN Adapter
serial:
Device-3: 1-8:4 info: SunplusIT MTD camera type: Video,Audio
Processes: 196 Uptime: 11m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1080 lib: 324 flatpak: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.20
yes
i tested with win10 - initially the sound wasnt working but, after 15min, the system found the driver automatically, so, it is not my machine.
what can I do now? i want to use manjaro xfce…
Great, swap is fixed and you should have a stable system.
About the sound; searched for: arch linux Intel Celeron/Pentium Silver Processor High Definition Audio driver: sof-audio-pci-intel-apl at DuckDuckGo
This looks like the fix: No sound on Gemini Lake / Laptop Issues / Arch Linux Forums
PS: If you post terminal in/output please edit like that:
could you tell me exaclty what a i need to do?, i’m really a noob
First install alsa-ucm-conf and sof-firmware (which you said was already installed).
“Managed to fix it. I just changed my default sound card on ~/.asoundrc as the mic of the webcam is recognized as another sound card and is selected as default.”
home/.asoundrc — have a look at the options thereboth are installed already
home/.asoundrc i search for this file on etc and home, and config, and usr/share/alsa.
didn’t find it ![]()
Well, back to the search for now: arch linux Intel Celeron/Pentium Silver Processor High Definition Audio driver: sof-audio-pci-intel-apl at DuckDuckGo
One more thing since it’s a new machine; check for available bios updates. https://www.meupositivo.com.br/para-voce/suporte-tecnico/drivers?txtNumeroSerie=N14DP7#numeroSerie
i found asound on manjaro repo. and installed.
so… i found the asound config and change the default sound card to from “microphone” to “pulse audio”.
now i’m trying to run these commands
amixer cset name=‘Headphone Switch’ on
amixer cset name=‘Speaker Switch’ on
amixer cset name=‘Headphone Playback Volume’ 3,3
amixer cset name=‘Right Headphone Mixer Right DAC Switch’ on
amixer cset name=‘Left Headphone Mixer Left DAC Switch’ on
amixer cset name=‘DAC Playback Volume’ 999,999
amixer cset name=‘Headphone Mixer Volume’ 999,999
but it gives me “amixer: Cannot find the given element from control default”
"One more thing since it’s a new machine; check for available bios updates. "
only drivers for windows
maybe downgrade the kernel?
Data from a VM in another distribution with an emulated AC97 audio codec is not much help here
Package sof-firmware is included on all official ISOs since at least January 2022
Manjaro 21.2.2 released
And data in post #3 shows driver sof-audio-pci-intel-apl in use
Package alsa-ucm-conf was created as a separate package from alsa-lib to provide the Use Case Manager profiles and should be included on any Manjaro ISO
Package pulseaudio-alsa provides the ALSA configuration to set PulseAudio as default sound server and create virtual controls. This package is common to all Arch distributions and no additional asound.conf or .asoundrc configuration should be needed
ALSA data confirms that both PulseAudio and PipeWire appear to be running, But PipeWire is only partially installed and only capable of creating conflict problems for PulseAudio
PipeWire is not a required dependency like other DEs so Xfce users can uninstall pipewire and alsa-mixer-paths to use PulseAudio without conflict
But dealing with conflicting software servers will not help resolve hardware or driver issues in ALSA
ALSA data shows only HDMI devices detected for audio playback, no device detected for analog audio to speakers or headphones
The amixer commands are failing for 2 reasons:
no card number specified so amixer commands can only find default PulseAudio controls - usually 2 virtual audio controls for PulseAudio or PipeWire - Master for audio playback and Capture for audio capture
(amixer would usually show the default controls but they may not be present following changes to asound.conf)
even if the card number had been included, the commands would not work because the audio controls for Headphones, Speakers, DAC are not present in previous alsa-info data
and nothing since is likely to have made those controls appear
Please post response to this command to show all available audio controls for onboard audio device
amixer --card=0
Checking Manufacturer for BIOS updates is a good idea at this time
I suggest you update to the latest kernel version and hope it has a patch for the audio codec on this system
sudo mhwd-kernel -i linux519
If audio is still not working as expected, get ALSA information again to see if anything has changed
http://alsa-project.org/db/?f=c57ee399b7695152e233010d298953d3acaf8da1
i’m hopeless ahaha
