[victorevans@victorevans ~]$ amixer --card=0
Simple mixer control ‘Mic’,0
Capabilities: cvolume cvolume-joined cswitch cswitch-joined
Capture channels: Mono
Limits: Capture 0 - 4096
Mono: Capture 2816 [69%] [11.00dB] [on]
guys!!! could you explain that to me, like, in command line, a step-by-step to do this??
Passo 1: Se tiver recém-formatado, dê um apt update e depois um upgrade pra atualizar tudo direitin e evitar erros
Passo 2: Clone com o git esse repositório .
Passo 3: Instale o .deb da pasta raiz (firmware-sof-signed_1.7-1_all.deb)
Passo 4: Após isso, vá na pasta kernel e instale cada um dos .deb lá
Passo 5: Volte, e agora vá na pasta tplg e copie todos os arquivos de lá para a pasta raiz (custom-kernel)
Passo 6: Entre como administrador com o sudo su, dê permissão para executar no arquivo make.sh com o chmod +x , e então execute-o ./make.sh
Passo 7: Após o processo ter terminado, reinicie o seu PC, e provavelmente o áudio estará funcionando.
it is the same notebook i have.
please, save me. it is the solution. but idk how to do this steps
you all could see this link and see the exact model.
i’m thinking to swtich to linux mint xfce in order to do this
apparently i need to install this kernel custom-kernel/README.md at main · yangxiaohua2009/custom-kernel · GitHub
but, I could try on manjaro xfce first, if you tell me how, i’m really a noob…
update: my bluetooth headphones works via bluetooth
New ALSA data in previous post is better than before. ALSA is now able to detect the onboard audio codec as playback and capture device
card 1: sofessx8336 [sof-essx8336], device 0: ES8336 (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
amixer --card=0 in post #21 is showing ALSA Mic control for USB webcam
ALSA mixer controls for onboard audio card 1 show Headphone and Speaker controls are both muted
Simple mixer control 'Headphone',0
Front Left: Playback 3 [100%] [0.00dB] [off]
Front Right: Playback 3 [100%] [0.00dB] [off]
Simple mixer control 'Speaker',0
Mono: Playback [off]
use this command to unmute both controls
amixer -c1 sset Headphone unmute; amixer -c1 sset Speaker unmute
http://alsa-project.org/db/?f=5319510e7d7b1c80816dbbc9f6f8231276704d1c
I did a new upload.
amixer: Unable to find simple control ‘Headphone’,0
amixer: Unable to find simple control ‘Speaker’,0
Latest ALSA data shows onboard audio now detected as card 0 and USB webcam as card 1
card 0: sofessx8336 [sof-essx8336], device 0: ES8336 (*) []
Subdevices: 1/1
card 0: sofessx8336 [sof-essx8336], device 5: HDMI 1 (*) []
Subdevices: 1/1
card 0: sofessx8336 [sof-essx8336], device 6: HDMI 2 (*) []
Subdevices: 1/1
card 0: sofessx8336 [sof-essx8336], device 7: HDMI 3 (*) []
Subdevices: 1/1
Use this command with card name rather than number to unmute Headphone and Speaker
amixer -c sofessx8336 sset Headphone unmute; amixer -c sofessx8336 sset Speaker unmute
still no sound. ok, I think i’ll switch to mint and try that solution anyway…
