Window Compositor always turning off after reboot
hello how do I change the setting to have the window manager compositor retain it’s on state over a reboot?
[zirnit@zirnit-pc ~]$ inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=0bc33de2-959d-433a-8788-244c33b2697f rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4021
    date: 08/09/2021
  RAM: total: 15.6 GiB used: 7.1 GiB (45.5%)
  RAM Report:
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3134 high: 4178 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4178 2: 3897
    3: 4120 4: 2196 5: 2196 6: 2152 7: 4158 8: 4175 9: 4129 10: 2015 11: 2196
    12: 2196 bogomips: 86275
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    conditional, RSB filling
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 0a:00.0
    chip-ID: 1002:731f class-ID: 0300
  Device-2: KYE Systems (Mouse Systems) PC-LM1E Camera type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 5-4:3 chip-ID: 0458:6006
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
    loaded: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
    s-diag: 777mm (30.6")
  Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 109
    size: 597x336mm (23.5x13.2") diag: 685mm (27")
  OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0
    5.15.12-1-MANJARO LLVM 13.0.0)
    v: 4.6 Mesa 21.3.2 direct render: Yes
  Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
    bus-ID: 0a:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: KYE Systems (Mouse Systems) PC-LM1E Camera type: USB
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.42 running: no
    vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
    bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.18 TiB used: 104.11 GiB (3.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A80 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 465.47 GiB size: 457.09 GiB (98.20%)
    used: 56.94 GiB (12.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 0bc33de2-959d-433a-8788-244c33b2697f
    used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 6D5F-3BC0
  ID-3: /mnt/Fast Library raw-size: 915.89 GiB size: 900.51 GiB (98.32%)
    used: 47.15 GiB (5.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: Fast Library uuid: 6a9f3a32-0b2d-47db-a750-49ff7315f9f0
  ID-4: /mnt/Slow Archive raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 28 KiB (0.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Slow Archive
    uuid: f3e28752-bf8b-44b3-9ec9-5befd5a00509
  ID-1: /dev/sdb2 maj-min: 8:18 size: 15.62 GiB fs: swap label: N/A
    uuid: 9a48c4a1-7a4a-4f3a-82b0-888ec862a47d
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-4:2 info: Genesys Logic All-in-One Cardreader
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 05e3:0732 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-3:2 info: tshort Dactyl-Manuform (5x6) type: Keyboard,HID
    power: 500mA chip-ID: 444d:3536 class-ID: 0300
  Device-2: 3-4:3 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
    serial: <filter>
  Device-3: 3-6:4 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Prusa Original Prusa i3 MK3
    type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 2c99:0002 class-ID: 0a00
    serial: <filter>
  Device-2: 5-4:3 info: KYE Systems (Mouse Systems) PC-LM1E Camera
    type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s power: 256mA chip-ID: 0458:6006 class-ID: 0102
    serial: <filter>
  Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 53.0 C mem: 52.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 326 Uptime: 3h 7m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1301 pacman: 1291 lib: 399 flatpak: 5
  snap: 5 Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
Hi @Zirnit,
Which compositor doe you use? How is normally turned on?
The more information you can give us, the better the chance of we being able to assist you.
Increase your chances of solving your issue:
Provide basic Information:
Does xfsettingsd (Settings Daemon ?) starts automatically?
https://docs.xfce.org/xfce/xfce4-session/preferences#application_autostart
yes but thanks to you I found a workaround by saving my current session and setting it as default the compositor stays on
nevermind didn’t work
Try:
systemctl enable --now xfwm4.service
And reboot and see if it works.
That’s all I can think of right now. Hope it helps!
https://wiki.archlinux.org/title/Xfwm
xfconf-query -c xfwm4 -p /general/use_compositing -s true
Check GUI controls for compositor - Settings > Window Manager Tweaks > Compositor tab
xfce:xfwm4:wmtweaks [Xfce Docs]
Or use xfconf-query command in previous post to turn compositing on
Xfwm - Composite_manager | ArchWiki
I added this now into a script file which runs on startup should work, though its probably not the most efficient solution.
