Will I ever get Bluetooth to work on this laptop in Linux
I have had this laptop for a few years now and Bluetooth has always worked in Windows, never in Linux.
I’ve tried various distros , kernels, firmware updates, etc nothing seems to work.
I have given up.
Is this hardware so complicated it can’t be figured out?
The answers I always get is get an external device or something to that effect.
It is not a show stopper and I love the laptop other than this little issue.
Sorry just venting I guess.
  Host: manjaro Kernel: 5.19.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.0 Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
    v: F.26 date: 07/09/2021
  ID-1: BAT0 charge: 64.5 Wh (100.0%) condition: 64.5/64.5 Wh (100.0%)
    volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: SerialNumber
    status: full cycles: 177
  Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
    serial: N/A charge: N/A status: N/A
  Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
    smt: enabled arch: Comet/Whiskey Lake note: check level: v3 rev: C cache:
    L1: 256 KiB L2: 1024 KiB L3: 8 MiB
  Speed (MHz): avg: 1513 high: 2300 min/max: 400/4900 cores: 1: 2300 2: 759
    3: 2300 4: 715 5: 2300 6: 731 7: 701 8: 2300 bogomips: 36812
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,DP-2
    bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
    driver: nvidia v: 515.76 arch: Pascal pcie: speed: 2.5 GT/s lanes: 4
    bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
  Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
    bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: 200901010001
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
    s-diag: 582mm (22.9")
  Monitor-1: eDP-1 model: AU Optronics 0x30eb res: 1920x1080 hz: 60
    dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 3840x2160
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
    direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
    class-ID: 0401
  Sound Server-1: ALSA v: k5.19.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.58 running: yes
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF: wlp0s20f3 state: up mac: 0c:dd:24:ab:82:13
  Local Storage: total: 931.51 GiB used: 201.58 GiB (21.6%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
    size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: S59ANS0N809758J rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
  ID-1: / size: 234.94 GiB used: 70.81 GiB (30.1%) fs: ext4
    dev: /dev/nvme0n1p11
  ID-2: /boot/efi size: 96 MiB used: 66.8 MiB (69.6%) fs: vfat
    dev: /dev/nvme0n1p2
  ID-3: /home size: 319.4 GiB used: 130.7 GiB (40.9%) fs: ext4
    dev: /dev/nvme0n1p7
  System Temperatures: cpu: 48.0 C pch: 47.0 C mobo: N/A
  Processes: 251 Uptime: 2h 10m wakeups: 1147 Memory: 15.26 GiB used: 3.76
  GiB (24.6%) Init: systemd v: 251 default: graphical Compilers:
  gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1562 Shell: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.21
Rants are not beneficial to anyone. Please revew: Forum Rules - Manjaro
Please see:
You already have a topic open, please continue there for support.
