Great! Thanks for the pointers! I appreciate the help, but would appreciate more. After running through that, auto-connect still fails. Hereās what Iāve attempted based on the linked post:
sudo vim /etc/modprobe.d/r8169_blacklist.conf
sudo vim /etc/modprobe.d/blacklist.conf
yay -S r8168-dkms
sudo reboot now
When this failed, I found Realtek WiFi Driver Installation (AUR) - Tutorials - Manjaro Linux Forum in a search and attempted some of the suggestions there.
pamac build r8168-dkms
sudo depmod -a
sudo mkinitcpio -P
sudo systemctl stop NetworkManager
MODULE=$(hwinfo --wlan | grep "Driver Activation Cmd" | cut -d " " -f9 | tr -d '"') && sudo modprobe $MODULE
DEVICE=$(hwinfo --wlan | grep "Device File" | cut -d " " -f5) && sudo ip link set $DEVICE up
sudo rfkill unblock all
sudo systemctl start NetworkManager
sudo reboot now
But still no change. The wifi daemon starts but the network does not autoconnect; connecting to the network works flawlessly.
I then attempted the following based on Laptop stopped going to sleep when lid close Clevo NH55 - Newbie Corner - Manjaro Linux Forum
sudo pacman -S git --needed
sudo git clone https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
cd linux-firmware
sudo cp iwlwifi-* /lib/firmware/
But no change. I also tried iw reg set US according to [SOLVED] Intel 7265 Wireless Network is way too slow - Networking - Manjaro Linux Forum but no change. I then tried:
echo "options iwlwifi lar_disable=1" | sudo tee -a /etc/modprobe.d/iwlwifi.conf
I have not tried changing the kernel according to this post yet. Reading onward into that archived thread, info they suggest providing is below. Should I attempt to change the kernel (and if so to which?) or is there something else that I should consider trying first?
inxi -Fxxxz
Summary
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: G752VL v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G752VL v: 1.0 serial: <filter>
UEFI: American Megatrends v: G752VL.307 date: 04/26/2019
ID-1: BAT0 charge: 16.5 Wh condition: 50.6/67.5 Wh (75%) volts: 11.2/11.2
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging
cycles: 41
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S rev: 3 L2 cache: 6 MiB
bogomips: 41621
Speed: 874 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 874 2: 894
3: 900 4: 869 5: 856 6: 883 7: 863 8: 878
Device-1: NVIDIA GM204M [GeForce GTX 965M] vendor: ASUSTeK driver: nvidia
v: 460.39 bus ID: 01:00.0 chip ID: 10de:1619 class ID: 0300
Device-2: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-4:2 chip ID: 04f2:b414 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia resolution: 1920x1080~75Hz s-dpi: 128
OpenGL: renderer: GeForce GTX 965M/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
class ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb
class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:095a class ID: 0280
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI port: d000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus ID: 1-9:4 chip ID: 8087:0a2a class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.82 TiB used: 926.49 GiB (49.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 1B2QEXM7 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB
speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: P3CR010
temp: 34.9 C scheme: GPT
ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / size: 453.51 GiB used: 20.94 GiB (4.6%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 3.99 GiB used: 312 KiB (0.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 457.38 GiB used: 169.11 GiB (37.0%) fs: ext4
dev: /dev/nvme1n1p1
System Temperatures: cpu: 52.5 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): cpu: 2900
Processes: 307 Uptime: 7m wakeups: 16820 Memory: 43.07 GiB
used: 3.49 GiB (8.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: 1592 pacman: 1572 flatpak: 20 Shell: Bash v: 5.1.0
running in: terminator inxi: 3.3.01
lsmod | sort
Summary
ac 16384 0
acpi_thermal_rel 16384 1 int3400_thermal
aesni_intel 372736 8
af_alg 32768 6 algif_hash,algif_skcipher
agpgart 53248 1 drm
algif_hash 16384 1
algif_skcipher 16384 1
asus_nb_wmi 32768 0
asus_wireless 20480 0
asus_wmi 45056 2 asus_nb_wmi,hid_asus
atkbd 36864 0
battery 20480 1 asus_wmi
bluetooth 741376 43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 28672 2
btbcm 20480 1 btusb
btintel 32768 1 btusb
btrtl 24576 1 btusb
btusb 69632 0
ccm 20480 6
cdrom 77824 1 sr_mod
cec 73728 1 drm_kms_helper
cfg80211 913408 3 iwlmvm,iwlwifi,mac80211
cmac 16384 3
coretemp 20480 0
crc16 16384 2 bluetooth,ext4
crc32c_generic 16384 0
crc32c_intel 24576 5
crc32_pclmul 16384 0
crct10dif_pclmul 16384 1
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 16384 0
drm 585728 16 drm_kms_helper,nvidia_drm
drm_kms_helper 266240 1 nvidia_drm
ecc 36864 1 ecdh_generic
ecdh_generic 16384 2 bluetooth
ee1004 20480 0
elan_i2c 53248 0
evdev 28672 20
ext4 815104 3
fat 86016 1 vfat
fb_sys_fops 16384 1 drm_kms_helper
fuse 139264 5
ghash_clmulni_intel 16384 0
glue_helper 16384 1 aesni_intel
hid 147456 4 i2c_hid,usbhid,hid_generic,hid_asus
hid_asus 28672 0
hid_generic 16384 0
i2c_hid 32768 0
i2c_i801 36864 0
i2c_smbus 20480 1 i2c_i801
i8042 32768 1 asus_nb_wmi
idma64 20480 0
input_leds 16384 0
int3400_thermal 20480 0
int340x_thermal_zone 16384 1 processor_thermal_device
intel_cstate 20480 0
intel_lpss 16384 1 intel_lpss_pci
intel_lpss_pci 24576 0
intel_pch_thermal 16384 0
intel_pmc_bxt 16384 1 iTCO_wdt
intel_powerclamp 20480 0
intel_rapl_common 32768 2 intel_rapl_msr,processor_thermal_device
intel_rapl_msr 20480 0
intel_soc_dts_iosf 20480 1 processor_thermal_device
intel_uncore 172032 0
intel_wmi_thunderbolt 20480 0
ip_tables 32768 0
irqbypass 16384 1 kvm
iTCO_vendor_support 16384 1 iTCO_wdt
iTCO_wdt 16384 0
iwlmvm 462848 0
iwlwifi 401408 1 iwlmvm
jbd2 139264 1 ext4
joydev 28672 0
kvm 856064 1 kvm_intel
kvm_intel 323584 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libarc4 16384 1 mac80211
libps2 20480 1 atkbd
mac80211 1056768 1 iwlmvm
mac_hid 16384 0
mbcache 16384 1 ext4
mc 61440 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mei 126976 3 mei_hdcp,mei_me
mei_hdcp 24576 0
mei_me 49152 1
Module Size Used by
mousedev 24576 0
msr 16384 0
nls_cp437 20480 1
nls_iso8859_1 16384 1
nvidia 34140160 1977 nvidia_modeset
nvidia_drm 65536 13
nvidia_modeset 1232896 33 nvidia_drm
pcspkr 16384 0
processor_thermal_device 24576 0
r8168 569344 0
rapl 16384 0
rc_core 61440 1 cec
rfcomm 90112 16
rfkill 28672 10 asus_wmi,bluetooth,cfg80211
rng_core 16384 1 tpm
serio 28672 4 serio_raw,atkbd,i8042
serio_raw 20480 0
sg 40960 0
snd 114688 16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
snd_hda_codec 167936 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 73728 1
snd_hda_codec_realtek 143360 1
snd_hda_core 106496 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hda_intel 57344 4
snd_hwdep 16384 1 snd_hda_codec
snd_intel_dspcfg 24576 1 snd_hda_intel
snd_pcm 147456 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 45056 1 snd_pcm
soundcore 16384 1 snd
sparse_keymap 16384 1 asus_wmi
sr_mod 28672 0
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
tpm 77824 3 tpm_tis,tpm_crb,tpm_tis_core
tpm_crb 20480 0
tpm_tis 16384 0
tpm_tis_core 32768 1 tpm_tis
uinput 20480 0
usbhid 65536 1 hid_asus
uvcvideo 114688 0
vfat 24576 1
videobuf2_common 61440 2 videobuf2_v4l2,uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 32768 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 274432 3 videobuf2_v4l2,uvcvideo,videobuf2_common
wmi 36864 2 intel_wmi_thunderbolt,asus_wmi
x86_pkg_temp_thermal 20480 0
xhci_hcd 286720 1 xhci_pci
xhci_pci 20480 0
x_tables 53248 1 ip_tables
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
dkms status
r8168, 8.048.03, 5.9.16-1-MANJARO, x86_64: installed
dmesg | grep -i 'error\|seg\|fail\|broke\|warn\|dump\|denied\|rtl\|wl'
Summary
[ 0.311754] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.311795] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 0.777384] Segment Routing with IPv6
[ 0.777385] RPL Segment Routing with IPv6
[ 0.788637] RAS: Correctable Errors collector initialized.
[ 2.128222] systemd[1]: Listening on Process Core Dump Socket.
[ 2.426480] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.613080] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
[ 2.737893] iwlwifi: unknown parameter 'lar_disable' ignored
[ 2.767504] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 2.767506] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 2.767702] iwlwifi 0000:03:00.0: loaded firmware version 29.4063824552.0 7265D-29.ucode op_mode iwlmvm
[ 3.094336] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0x210
[ 3.107948] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 3.108322] iwlwifi 0000:03:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 3.118432] iwlwifi 0000:03:00.0: base HW address: 18:5e:0f:b8:17:c6
[ 3.179179] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.181371] thermal thermal_zone5: failed to read out thermal zone (-61)
[ 3.187567] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 3.438642] random: 1 urandom warning(s) missed due to ratelimiting
[ 4.876374] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.892412] ACPI Warning: \_SB.PCI0.PEG0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[ 4.956376] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.957892] iwlwifi 0000:03:00.0: FW already configured (0) - re-configuring
[ 5.000486] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 5.082186] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 5.083592] iwlwifi 0000:03:00.0: FW already configured (0) - re-configuring
[ 8.277835] audit: type=1103 audit(1615921348.002:61): pid=1035 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 16.221959] audit: type=1100 audit(1615921355.945:75): pid=1094 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="user" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 16.223194] audit: type=1103 audit(1615921355.948:77): pid=1094 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="user" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 16.246309] audit: type=1103 audit(1615921355.972:81): pid=1096 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="user" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 23.291045] pipewire-media-[1786]: segfault at 10 ip 00005559d681103b sp 00007ffde33f4920 error 4 in pipewire-media-session[5559d67fd000+29000]
[ 23.304599] audit: type=1130 audit(1615921363.028:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1807-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.413679] audit: type=1131 audit(1615921363.138:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1807-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 28.744556] audit: type=1130 audit(1615921368.468:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-2202-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.400943] audit: type=1131 audit(1615921369.125:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-2202-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.954500] audit: type=1130 audit(1615921377.678:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2252-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.417118] wlp3s0: authenticate with b6:fb:e4:d8:af:94
[ 39.423480] wlp3s0: send auth to b6:fb:e4:d8:af:94 (try 1/3)
[ 39.428508] wlp3s0: authenticated
[ 39.435348] wlp3s0: associate with b6:fb:e4:d8:af:94 (try 1/3)
[ 39.440122] wlp3s0: RX AssocResp from b6:fb:e4:d8:af:94 (capab=0x411 status=0 aid=3)
[ 39.441825] wlp3s0: associated
[ 39.466135] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 313.825265] EXT4-fs (sda1): error count since last fsck: 243
[ 313.825268] EXT4-fs (sda1): initial error at time 1592614880: ext4_lookup:1703: inode 43253812
[ 313.825270] EXT4-fs (sda1): last error at time 1614015994: ext4_mb_generate_buddy:805
[ 557.313624] audit: type=1100 audit(1615921897.038:129): pid=4068 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 557.315093] audit: type=1110 audit(1615921897.038:131): pid=4068 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
journalctl --no-pager -S "$(date +'%Y-%m-%d')" -u NetworkManager | grep -i 'discon\|error\|fail\|broke\|warn\|change\|wl\|rtl'
Mar 16 14:05:50 hostname NetworkManager[673]: <error> [1615917950.1549] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.2427] hostname: hostname changed from (none) to "hostname"
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.2437] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.2826] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.4533] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.4538] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.4547] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.5836] device (wlp3s0): set-hw-addr: set MAC address to EE:80:CD:B1:63:BA (scanning)
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.6987] ovsdb: disconnected from ovsdb
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.8013] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.8015] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.8025] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.8035] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.8059] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:05:50 hostname NetworkManager[673]: <warn> [1615917950.8081] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:05:50 hostname NetworkManager[673]: <info> [1615917950.8087] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:05:50 hostname NetworkManager[673]: <warn> [1615917950.8160] sup-iface[c56d618aacd88ff3,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.0600] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.0610] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.0669] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.0710] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.0721] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.0722] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.2406] device (wlp3s0): supplicant interface state: disconnected -> inactive
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.2407] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> inactive
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.3435] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.3450] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.3467] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.3935] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 14:07:07 hostname NetworkManager[673]: <info> [1615918027.3940] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.4636] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.4637] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5081] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5082] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5085] device (wlp3s0): supplicant interface state: associating -> 4way_handshake
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5086] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> 4way_handshake
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5560] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5561] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5562] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5567] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5582] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5762] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.5930] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.6688] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.6693] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.6732] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 14:07:08 hostname NetworkManager[673]: <info> [1615918028.6808] device (wlp3s0): Activation: successful, device activated.
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.1409] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.1412] manager: NetworkManager state is now DISCONNECTING
Mar 16 14:14:15 hostname NetworkManager[673]: <warn> [1615918455.1424] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.1425] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.1950] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.1951] dhcp4 (wlp3s0): state changed bound -> done
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.3080] manager: NetworkManager state is now DISCONNECTED
Mar 16 14:14:15 hostname NetworkManager[673]: <info> [1615918455.3192] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:14:33 hostname NetworkManager[699]: <error> [1615918473.1651] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.3584] hostname: hostname changed from (none) to "hostname"
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.3609] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.4264] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.7077] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.7086] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.7105] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.8342] device (wlp3s0): set-hw-addr: set MAC address to 3A:A3:D8:48:85:65 (scanning)
Mar 16 14:14:33 hostname NetworkManager[699]: <info> [1615918473.9516] ovsdb: disconnected from ovsdb
Mar 16 14:14:34 hostname NetworkManager[699]: <info> [1615918474.0581] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:14:34 hostname NetworkManager[699]: <info> [1615918474.0582] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:14:34 hostname NetworkManager[699]: <info> [1615918474.0584] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:14:34 hostname NetworkManager[699]: <info> [1615918474.0586] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:14:34 hostname NetworkManager[699]: <info> [1615918474.0590] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:14:34 hostname NetworkManager[699]: <warn> [1615918474.0595] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:14:34 hostname NetworkManager[699]: <info> [1615918474.0597] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:14:34 hostname NetworkManager[699]: <warn> [1615918474.0599] sup-iface[f1e25add4ac54826,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.6434] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.6448] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.6543] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.6580] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.6593] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.6594] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.7222] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.7223] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> interface_disabled
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.7238] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.7239] device (p2p-dev-wlp3s0): supplicant management interface state: interface_disabled -> inactive
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.9011] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.9024] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.9031] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.9449] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 14:17:01 hostname NetworkManager[699]: <info> [1615918621.9450] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.8857] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.8858] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9207] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9207] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9841] device (wlp3s0): supplicant interface state: associating -> completed
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9842] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9843] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> completed
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9894] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:04 hostname NetworkManager[699]: <info> [1615918624.9908] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 14:17:05 hostname NetworkManager[699]: <info> [1615918625.0148] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 14:17:05 hostname NetworkManager[699]: <info> [1615918625.0235] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:05 hostname NetworkManager[699]: <info> [1615918625.1038] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:05 hostname NetworkManager[699]: <info> [1615918625.1044] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 14:17:05 hostname NetworkManager[699]: <info> [1615918625.1085] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 14:17:05 hostname NetworkManager[699]: <info> [1615918625.1156] device (wlp3s0): Activation: successful, device activated.
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.1244] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.1246] manager: NetworkManager state is now DISCONNECTING
Mar 16 14:21:45 hostname NetworkManager[699]: <warn> [1615918905.1257] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.1257] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.1519] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.1519] dhcp4 (wlp3s0): state changed bound -> done
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.2765] manager: NetworkManager state is now DISCONNECTED
Mar 16 14:21:45 hostname NetworkManager[699]: <info> [1615918905.2814] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:22:03 hostname NetworkManager[698]: <error> [1615918923.0948] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.1613] hostname: hostname changed from (none) to "hostname"
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.1623] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.1985] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.3762] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.3769] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.3779] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.5048] device (wlp3s0): set-hw-addr: set MAC address to 3A:A8:65:E2:71:74 (scanning)
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.6269] ovsdb: disconnected from ovsdb
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.7464] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.7466] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.7471] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.7480] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:22:03 hostname NetworkManager[698]: <warn> [1615918923.7497] sup-iface[bf89f57fe8e626e6,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.7501] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:22:03 hostname NetworkManager[698]: <warn> [1615918923.7518] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:22:03 hostname NetworkManager[698]: <info> [1615918923.7522] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.5518] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.5528] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.5610] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.5644] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.5655] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.5655] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.6393] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.6394] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> interface_disabled
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.6401] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.6401] device (p2p-dev-wlp3s0): supplicant management interface state: interface_disabled -> inactive
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.8259] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.8271] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.8281] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.8698] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 14:23:08 hostname NetworkManager[698]: <info> [1615918988.8699] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.8485] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.8486] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9012] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9013] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9016] device (wlp3s0): supplicant interface state: associating -> 4way_handshake
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9017] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> 4way_handshake
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9298] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9299] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9300] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9305] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9316] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9534] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 14:23:09 hostname NetworkManager[698]: <info> [1615918989.9675] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:10 hostname NetworkManager[698]: <info> [1615918990.0559] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:10 hostname NetworkManager[698]: <info> [1615918990.0563] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 14:23:10 hostname NetworkManager[698]: <info> [1615918990.0599] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 14:23:10 hostname NetworkManager[698]: <info> [1615918990.0685] device (wlp3s0): Activation: successful, device activated.
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.7168] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.7170] manager: NetworkManager state is now DISCONNECTING
Mar 16 14:25:07 hostname NetworkManager[698]: <warn> [1615919107.7180] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.7181] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.7449] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.7449] dhcp4 (wlp3s0): state changed bound -> done
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.8637] manager: NetworkManager state is now DISCONNECTED
Mar 16 14:25:07 hostname NetworkManager[698]: <info> [1615919107.8727] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:25:24 hostname NetworkManager[629]: <error> [1615919124.9017] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:25:24 hostname NetworkManager[629]: <info> [1615919124.9809] hostname: hostname changed from (none) to "hostname"
Mar 16 14:25:24 hostname NetworkManager[629]: <info> [1615919124.9821] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.0279] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.2063] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.2071] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.2082] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.3389] device (wlp3s0): set-hw-addr: set MAC address to D2:27:E6:00:23:46 (scanning)
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.4621] ovsdb: disconnected from ovsdb
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.5913] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.5915] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.5923] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.5931] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:25:25 hostname NetworkManager[629]: <warn> [1615919125.5949] sup-iface[809d028cfec36517,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.5954] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:25:25 hostname NetworkManager[629]: <warn> [1615919125.5975] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:25:25 hostname NetworkManager[629]: <info> [1615919125.5980] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:26:18 hostname NetworkManager[629]: <info> [1615919178.6017] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:26:18 hostname NetworkManager[629]: <info> [1615919178.6066] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (unmanage)
Mar 16 14:26:18 hostname NetworkManager[629]: <info> [1615919178.6469] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:29:44 hostname NetworkManager[2855]: <error> [1615919384.0484] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2427] hostname: hostname changed from (none) to "hostname"
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2440] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2716] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2740] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2748] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2760] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.2917] device (wlp3s0): set-hw-addr: set MAC address to 02:09:9E:7C:D1:55 (scanning)
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.4543] ovsdb: disconnected from ovsdb
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.5598] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.5606] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.5616] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.5624] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:29:44 hostname NetworkManager[2855]: <warn> [1615919384.5946] sup-iface[b7cfed55c1360103,1,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.5980] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:29:44 hostname NetworkManager[2855]: <warn> [1615919384.6004] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:29:44 hostname NetworkManager[2855]: <info> [1615919384.6010] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:30:29 hostname NetworkManager[2855]: <info> [1615919429.3063] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:30:29 hostname NetworkManager[2855]: <info> [1615919429.3076] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (unmanage)
Mar 16 14:30:29 hostname NetworkManager[2855]: <info> [1615919429.3204] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:30:47 hostname NetworkManager[707]: <error> [1615919447.0785] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.2199] hostname: hostname changed from (none) to "hostname"
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.2216] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.2546] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.4324] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.4331] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.4340] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.5609] device (wlp3s0): set-hw-addr: set MAC address to FE:F6:1D:A6:01:12 (scanning)
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.6876] ovsdb: disconnected from ovsdb
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.7909] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.7910] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.7916] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.7922] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:30:47 hostname NetworkManager[707]: <warn> [1615919447.7935] sup-iface[b9982f427abe6c73,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.7936] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:30:47 hostname NetworkManager[707]: <warn> [1615919447.7950] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:30:47 hostname NetworkManager[707]: <info> [1615919447.7953] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:22 hostname NetworkManager[707]: <info> [1615919482.9400] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 14:31:22 hostname NetworkManager[707]: <info> [1615919482.9407] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:22 hostname NetworkManager[707]: <info> [1615919482.9459] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 14:31:22 hostname NetworkManager[707]: <info> [1615919482.9506] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:22 hostname NetworkManager[707]: <info> [1615919482.9524] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 14:31:22 hostname NetworkManager[707]: <info> [1615919482.9530] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.0590] device (wlp3s0): supplicant interface state: disconnected -> inactive
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.0591] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> inactive
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.2369] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.2375] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.2379] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.2555] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 14:31:23 hostname NetworkManager[707]: <info> [1615919483.2555] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2130] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2157] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2483] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2505] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2597] device (wlp3s0): supplicant interface state: associating -> 4way_handshake
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2598] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> 4way_handshake
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2612] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2612] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2613] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2627] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2633] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2788] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.2849] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.3316] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.3320] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.3363] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 14:31:26 hostname NetworkManager[707]: <info> [1615919486.3434] device (wlp3s0): Activation: successful, device activated.
Mar 16 14:50:14 hostname NetworkManager[707]: <info> [1615920614.7450] manager: kernel firmware directory '/lib/firmware' changed
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.3308] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.3311] manager: NetworkManager state is now DISCONNECTING
Mar 16 14:53:32 hostname NetworkManager[707]: <warn> [1615920812.3325] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.3326] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.3884] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.3885] dhcp4 (wlp3s0): state changed bound -> done
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.5269] manager: NetworkManager state is now DISCONNECTED
Mar 16 14:53:32 hostname NetworkManager[707]: <info> [1615920812.5314] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:53:50 hostname NetworkManager[476]: <error> [1615920830.9484] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.0345] hostname: hostname changed from (none) to "hostname"
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.0362] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.0726] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.2511] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.2517] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.2579] ovsdb: disconnected from ovsdb
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.2592] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.3888] device (wlp3s0): set-hw-addr: set MAC address to 2A:B0:27:4F:16:04 (scanning)
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.6034] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.6037] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.6043] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.6050] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.6065] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:53:51 hostname NetworkManager[476]: <warn> [1615920831.6080] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:53:51 hostname NetworkManager[476]: <info> [1615920831.6084] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:53:51 hostname NetworkManager[476]: <warn> [1615920831.6132] sup-iface[fa9f46a9fcc888f4,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8029] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8052] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8123] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8170] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8186] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8187] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8536] device (wlp3s0): supplicant interface state: disconnected -> inactive
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.8537] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> inactive
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.9148] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.9151] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.9153] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.9298] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 14:54:40 hostname NetworkManager[476]: <info> [1615920880.9298] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.0469] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.0470] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.0872] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.0873] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1092] device (wlp3s0): supplicant interface state: associating -> completed
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1092] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1092] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> completed
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1098] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1101] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1248] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1302] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1512] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1515] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1538] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 14:54:42 hostname NetworkManager[476]: <info> [1615920882.1624] device (wlp3s0): Activation: successful, device activated.
Mar 16 14:56:25 hostname NetworkManager[476]: <info> [1615920985.9032] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:56:25 hostname NetworkManager[476]: <info> [1615920985.9035] manager: NetworkManager state is now DISCONNECTING
Mar 16 14:56:25 hostname NetworkManager[476]: <warn> [1615920985.9046] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
Mar 16 14:56:25 hostname NetworkManager[476]: <info> [1615920985.9047] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Mar 16 14:56:25 hostname NetworkManager[476]: <info> [1615920985.9715] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 16 14:56:25 hostname NetworkManager[476]: <info> [1615920985.9716] dhcp4 (wlp3s0): state changed bound -> done
Mar 16 14:56:26 hostname NetworkManager[476]: <info> [1615920986.0746] manager: NetworkManager state is now DISCONNECTED
Mar 16 14:56:26 hostname NetworkManager[476]: <info> [1615920986.0946] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 14:56:42 hostname NetworkManager[417]: <error> [1615921002.7384] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 14:56:42 hostname NetworkManager[417]: <info> [1615921002.8324] hostname: hostname changed from (none) to "hostname"
Mar 16 14:56:42 hostname NetworkManager[417]: <info> [1615921002.8802] ovsdb: disconnected from ovsdb
Mar 16 14:56:42 hostname NetworkManager[417]: <info> [1615921002.8819] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.3260] device (wlan0): driver supports Access Point (AP) mode
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.3267] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.3287] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.3586] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.3643] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.4918] device (wlp3s0): set-hw-addr: set MAC address to B2:BB:83:BE:B0:80 (scanning)
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.6870] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.6871] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.6876] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.6880] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 14:56:43 hostname NetworkManager[417]: <warn> [1615921003.6890] sup-iface[2091f33f107b35b8,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.6893] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 14:56:43 hostname NetworkManager[417]: <warn> [1615921003.6903] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 14:56:43 hostname NetworkManager[417]: <info> [1615921003.6905] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.4624] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.4629] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.4650] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.4683] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.4687] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.4687] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5323] device (wlp3s0): supplicant interface state: disconnected -> inactive
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5323] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> inactive
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5511] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5515] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5518] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5703] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 14:57:16 hostname NetworkManager[417]: <info> [1615921036.5704] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.6696] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.6696] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.6785] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.6786] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.6865] device (wlp3s0): supplicant interface state: associating -> 4way_handshake
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.6866] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> 4way_handshake
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7094] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7094] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7095] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7096] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7101] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7281] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7318] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7479] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7482] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7511] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 14:57:17 hostname NetworkManager[417]: <info> [1615921037.7576] device (wlp3s0): Activation: successful, device activated.
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.8177] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.8180] manager: NetworkManager state is now DISCONNECTING
Mar 16 14:59:46 hostname NetworkManager[417]: <warn> [1615921186.8191] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.8192] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.8683] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.8684] dhcp4 (wlp3s0): state changed bound -> done
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.9262] manager: NetworkManager state is now DISCONNECTED
Mar 16 14:59:46 hostname NetworkManager[417]: <info> [1615921186.9581] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 15:00:02 hostname NetworkManager[497]: <error> [1615921202.9319] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.0246] hostname: hostname changed from (none) to "hostname"
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.0256] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.0651] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.2402] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.2406] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.2441] ovsdb: disconnected from ovsdb
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.2455] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.3844] device (wlp3s0): set-hw-addr: set MAC address to CE:C7:8A:65:4A:30 (scanning)
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.5960] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.5961] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.5964] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.5966] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 15:00:03 hostname NetworkManager[497]: <warn> [1615921203.5972] sup-iface[3fb9123761279ab2,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.5974] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 15:00:03 hostname NetworkManager[497]: <warn> [1615921203.5980] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 15:00:03 hostname NetworkManager[497]: <info> [1615921203.5982] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:05 hostname NetworkManager[497]: <info> [1615921325.3445] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Mar 16 15:02:05 hostname NetworkManager[497]: <info> [1615921325.3458] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (unmanage)
Mar 16 15:02:05 hostname NetworkManager[497]: <info> [1615921325.3622] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 16 15:02:24 hostname NetworkManager[718]: <error> [1615921344.3135] session-monitor: failed to create systemd-logind monitor: -2
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.3791] hostname: hostname changed from (none) to "hostname"
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.3800] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.4149] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.5906] device (wlp3s0): driver supports Access Point (AP) mode
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.5911] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.5918] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.7163] device (wlp3s0): set-hw-addr: set MAC address to 76:59:8F:BA:1D:EF (scanning)
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.8392] ovsdb: disconnected from ovsdb
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.9162] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.9162] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.9164] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.9166] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 16 15:02:24 hostname NetworkManager[718]: <warn> [1615921344.9172] sup-iface[70969dbf7cb0b4e9,0,wlp3s0]: call-p2p-cancel: failed with P2P cancel failed
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.9172] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 16 15:02:24 hostname NetworkManager[718]: <warn> [1615921344.9177] device (wlp3s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 15:02:24 hostname NetworkManager[718]: <info> [1615921344.9179] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1118] device (wlp3s0): Activation: starting connection 'myWifi' (3d805c0d-23ca-4d3e-b693-41cfcb031dfb)
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1125] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1145] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:B8:17:C6 (preserve)
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1174] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1176] device (wlp3s0): Activation: (wifi) access point 'myWifi' has security, but secrets are required.
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1176] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1651] device (wlp3s0): supplicant interface state: disconnected -> inactive
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1652] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> inactive
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1967] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1970] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.1973] device (wlp3s0): Activation: (wifi) connection 'myWifi' has security, and secrets exist. No new secrets needed.
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.2148] device (wlp3s0): supplicant interface state: inactive -> scanning
Mar 16 15:02:56 hostname NetworkManager[718]: <info> [1615921376.2149] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> scanning
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1680] device (wlp3s0): supplicant interface state: scanning -> authenticating
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1681] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1847] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1848] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1995] device (wlp3s0): supplicant interface state: associating -> completed
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1995] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "myWifi"
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.1996] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> completed
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2000] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2003] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2131] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.2.20
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2166] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2339] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2342] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2362] policy: set 'myWifi' (wlp3s0) as default for IPv4 routing and DNS
Mar 16 15:02:59 hostname NetworkManager[718]: <info> [1615921379.2426] device (wlp3s0): Activation: successful, device activated.
grep -r āblacklist|install|optionsā /etc/modprobe.d/ /etc/modules-load.d/ /usr/lib/modprobe.d/
Summary
/etc/modprobe.d/blacklist.conf:blacklist r8169
/etc/modprobe.d/iwlwifi.conf:options iwlwifi lar_disable=1
/etc/modprobe.d/r8169_blacklist.conf:blacklist r8169
/etc/modprobe.d/mhwd-gpu.conf:blacklist nouveau
/etc/modprobe.d/mhwd-gpu.conf:blacklist ttm
/etc/modprobe.d/mhwd-gpu.conf:blacklist drm_kms_helper
/usr/lib/modprobe.d/nvdimm-security.conf:install libnvdimm /usr/bin/ndctl load-keys ; /sbin/modprobe --ignore-install libnvdimm $CMDLINE_OPTS
/usr/lib/modprobe.d/uvesafb.conf:# options uvesafb mode=<xres>x<yres>[-<bpp>][@<refresh>] scroll=<ywrap|ypan|redraw> ...
/usr/lib/modprobe.d/uvesafb.conf:options uvesafb mode_option=1024x768-32 scroll=ywrap
/usr/lib/modprobe.d/bluetooth-usb.conf:options btusb reset=1
/usr/lib/modprobe.d/systemd.conf:options bonding max_bonds=0
/usr/lib/modprobe.d/systemd.conf:options dummy numdummies=0
pacman -Qsq linux | grep linux | grep -v -E ā(arch|util|sys|api|firmware)ā | grep -v nvidia
linux59
linux59-headers
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
Summary
Model: "Intel Dual Band Wireless-AC 7265"
Driver: "iwlwifi"
Device File: wlp3s0
Link detected: yes
Driver Status: iwlwifi is active
Driver Activation Cmd: "modprobe iwlwifi"
Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
Driver: "r8168"
Device File: enp4s0
Link detected: no
Driver Status: r8169 is not active
Driver Activation Cmd: "modprobe r8169"
Driver Status: r8168 is active
Driver Activation Cmd: "modprobe r8168"
Model: "Intel Bluetooth Device"
Driver: "btusb"
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
