Hello,
like I said in the title, after 5-30 minutes I lose the WIFI-connection and I get a prompt to retype the password.
If I just click on “cancel” and then go to my WIFI-settings and click on connect, everything works fine (until I lose connection again).
Typing in the password or executing sudo systemctl restart NetworkManager does not help either.
This happens on a fresh installed KDE-Manjaro (newest stable version).
I also reinstalled it and checked the hash and gpg-signature.
An example of a journal log is here:
Dez 27 15:52:56 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=9999 txrate=117000
Dez 27 15:53:01 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-82 noise=9999 txrate=175500
Dez 27 15:53:55 Pavilion wpa_supplicant[931]: wlo1: SME: Trying to authenticate with 44:4e:6d:cd:29:29 (SSID='FRITZ!Box 7590 GU' freq=5180 MHz)
Dez 27 15:53:55 Pavilion kernel: wlo1: disconnect from AP 46:4e:6d:cd:29:29 for new auth to 44:4e:6d:cd:29:29
Dez 27 15:53:55 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 46:4e:6d:cd:29:29 with macid 0 left
Dez 27 15:53:55 Pavilion kernel: wlo1: authenticate with 44:4e:6d:cd:29:29
Dez 27 15:53:56 Pavilion NetworkManager[523]: <info> [1640616836.0239] device (wlo1): supplicant interface state: completed -> authenticating
Dez 27 15:53:56 Pavilion kernel: wlo1: send auth to 44:4e:6d:cd:29:29 (try 1/3)
Dez 27 15:53:56 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dez 27 15:53:56 Pavilion NetworkManager[523]: <info> [1640616836.0244] device (wlo1): DHCPv4 lease renewal requested
Dez 27 15:53:56 Pavilion NetworkManager[523]: <info> [1640616836.0652] dhcp4 (wlo1): canceled DHCP transaction
Dez 27 15:53:56 Pavilion NetworkManager[523]: <info> [1640616836.0653] dhcp4 (wlo1): state changed bound -> terminated
Dez 27 15:53:56 Pavilion NetworkManager[523]: <info> [1640616836.0661] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Dez 27 15:53:56 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:53:56 Pavilion kernel: wlo1: send auth to 44:4e:6d:cd:29:29 (try 2/3)
Dez 27 15:53:57 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:53:57 Pavilion kernel: wlo1: send auth to 44:4e:6d:cd:29:29 (try 3/3)
Dez 27 15:53:58 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:53:58 Pavilion kernel: wlo1: authentication with 44:4e:6d:cd:29:29 timed out
Dez 27 15:53:58 Pavilion NetworkManager[523]: <info> [1640616838.9260] device (wlo1): supplicant interface state: authenticating -> disconnected
Dez 27 15:53:59 Pavilion NetworkManager[523]: <info> [1640616839.5055] device (wlo1): supplicant interface state: disconnected -> scanning
Dez 27 15:53:59 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Dez 27 15:53:59 Pavilion wpa_supplicant[931]: wlo1: SME: Trying to authenticate with 46:4e:6d:cd:29:2a (SSID='FRITZ!Box 7590 GU' freq=2462 MHz)
Dez 27 15:53:59 Pavilion kernel: wlo1: authenticate with 46:4e:6d:cd:29:2a
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3133] device (wlo1): supplicant interface state: scanning -> authenticating
Dez 27 15:54:00 Pavilion kernel: wlo1: send auth to 46:4e:6d:cd:29:2a (try 1/3)
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: Trying to associate with 46:4e:6d:cd:29:2a (SSID='FRITZ!Box 7590 GU' freq=2462 MHz)
Dez 27 15:54:00 Pavilion kernel: wlo1: authenticated
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3228] device (wlo1): supplicant interface state: authenticating -> associating
Dez 27 15:54:00 Pavilion kernel: wlo1: associate with 46:4e:6d:cd:29:2a (try 1/3)
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: Associated with 46:4e:6d:cd:29:2a
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Dez 27 15:54:00 Pavilion kernel: wlo1: RX AssocResp from 46:4e:6d:cd:29:2a (capab=0x1431 status=0 aid=1)
Dez 27 15:54:00 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 46:4e:6d:cd:29:2a joined with macid 0
Dez 27 15:54:00 Pavilion kernel: wlo1: associated
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3462] device (wlo1): supplicant interface state: associating -> associated
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3464] device (wlo1): DHCPv4 lease renewal requested
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3686] dhcp4 (wlo1): canceled DHCP transaction
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3687] dhcp4 (wlo1): state changed unknown -> terminated
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3696] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.3707] device (wlo1): supplicant interface state: associated -> 4way_handshake
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: WPA: Key negotiation completed with 46:4e:6d:cd:29:2a [PTK=CCMP GTK=CCMP]
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-CONNECTED - Connection to 46:4e:6d:cd:29:2a completed [id=0 id_str=]
Dez 27 15:54:00 Pavilion kernel: wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by 46:4e:6d:cd:29:2a
Dez 27 15:54:00 Pavilion NetworkManager[523]: <info> [1640616840.4113] device (wlo1): supplicant interface state: 4way_handshake -> completed
Dez 27 15:54:00 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-94 noise=9999 txrate=39000
Dez 27 15:54:00 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:54:02 Pavilion kernel: wlo1: disassociated from 46:4e:6d:cd:29:2a (Reason: 33=DISASSOC_QAP_NO_BANDWIDTH)
Dez 27 15:54:02 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 46:4e:6d:cd:29:2a with macid 0 left
Dez 27 15:54:02 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-DISCONNECTED bssid=46:4e:6d:cd:29:2a reason=33
Dez 27 15:54:02 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dez 27 15:54:02 Pavilion NetworkManager[523]: <info> [1640616842.3900] device (wlo1): supplicant interface state: completed -> disconnected
Dez 27 15:54:02 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:54:02 Pavilion NetworkManager[523]: <info> [1640616842.9656] device (wlo1): supplicant interface state: disconnected -> scanning
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: nl80211: send_and_recv->nl_recvmsgs failed: -33
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: wlo1: SME: Trying to authenticate with 44:4e:6d:cd:29:2a (SSID='FRITZ!Box 7590 GU' freq=2462 MHz)
Dez 27 15:54:03 Pavilion kernel: wlo1: authenticate with 44:4e:6d:cd:29:2a
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.7573] device (wlo1): supplicant interface state: scanning -> authenticating
Dez 27 15:54:03 Pavilion kernel: wlo1: send auth to 44:4e:6d:cd:29:2a (try 1/3)
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: wlo1: Trying to associate with 44:4e:6d:cd:29:2a (SSID='FRITZ!Box 7590 GU' freq=2462 MHz)
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.7677] device (wlo1): supplicant interface state: authenticating -> associating
Dez 27 15:54:03 Pavilion kernel: wlo1: authenticated
Dez 27 15:54:03 Pavilion kernel: wlo1: associate with 44:4e:6d:cd:29:2a (try 1/3)
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: wlo1: Associated with 44:4e:6d:cd:29:2a
Dez 27 15:54:03 Pavilion kernel: wlo1: RX AssocResp from 44:4e:6d:cd:29:2a (capab=0x1431 status=0 aid=3)
Dez 27 15:54:03 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 44:4e:6d:cd:29:2a joined with macid 0
Dez 27 15:54:03 Pavilion kernel: wlo1: associated
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Dez 27 15:54:03 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.7914] device (wlo1): supplicant interface state: associating -> associated
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.7915] device (wlo1): DHCPv4 lease renewal requested
Dez 27 15:54:03 Pavilion kernel: wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by 44:4e:6d:cd:29:2a
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.8153] dhcp4 (wlo1): canceled DHCP transaction
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.8154] dhcp4 (wlo1): state changed unknown -> terminated
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.8162] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Dez 27 15:54:03 Pavilion NetworkManager[523]: <info> [1640616843.8175] device (wlo1): supplicant interface state: associated -> 4way_handshake
Dez 27 15:54:04 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:54:07 Pavilion kernel: wlo1: disassociated from 44:4e:6d:cd:29:2a (Reason: 2=PREV_AUTH_NOT_VALID)
Dez 27 15:54:07 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-DISCONNECTED bssid=44:4e:6d:cd:29:2a reason=2
Dez 27 15:54:07 Pavilion wpa_supplicant[931]: wlo1: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Dez 27 15:54:07 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="FRITZ!Box 7590 GU" auth_failures=1 duration=10 reason=WRONG_KEY
Dez 27 15:54:07 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 44:4e:6d:cd:29:2a with macid 0 left
Dez 27 15:54:07 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dez 27 15:54:07 Pavilion NetworkManager[523]: <info> [1640616847.9105] device (wlo1): supplicant interface state: 4way_handshake -> disconnected
Dez 27 15:54:07 Pavilion NetworkManager[523]: <info> [1640616847.9107] device (wlo1): Activation: (wifi) disconnected during association, asking for new key
Dez 27 15:54:07 Pavilion NetworkManager[523]: <info> [1640616847.9109] device (wlo1): state change: activated -> need-auth (reason 'supplicant-disconnect', sys-iface-state: 'managed')
Dez 27 15:54:07 Pavilion NetworkManager[523]: <info> [1640616847.9553] dhcp4 (wlo1): canceled DHCP transaction
Dez 27 15:54:07 Pavilion NetworkManager[523]: <info> [1640616847.9555] dhcp4 (wlo1): state changed unknown -> terminated
Dez 27 15:54:07 Pavilion NetworkManager[523]: <info> [1640616847.9571] manager: NetworkManager state is now CONNECTING
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: Unhandled active connection state change: 1
Dez 27 15:54:07 Pavilion dbus-daemon[522]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=523 comm="/usr/bin/NetworkManager --no-daemon ")
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: Network connectivity limited, scheduling notification
Dez 27 15:54:07 Pavilion systemd[1]: Starting Network Manager Script Dispatcher Service...
░░ Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit NetworkManager-dispatcher.service has begun execution.
░░ The job identifier is 2733.
Dez 27 15:54:07 Pavilion dbus-daemon[522]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/1"
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: Setting name: "802-11-wireless-security"
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: Hints: ()
Dez 27 15:54:07 Pavilion kded5[1429]: plasma-nm: Flags: 7
Dez 27 15:54:07 Pavilion audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 27 15:54:07 Pavilion systemd[1]: Started Network Manager Script Dispatcher Service.
░░ Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
░░ A start job for unit NetworkManager-dispatcher.service has finished successfully.
Dez 27 15:54:07 Pavilion kernel: audit: type=1130 audit(1640616847.970:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 27 15:54:08 Pavilion NetworkManager[523]: <info> [1640616848.0099] device (wlo1): supplicant interface state: disconnected -> inactive
Dez 27 15:54:18 Pavilion systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
Dez 27 15:54:18 Pavilion audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 27 15:54:18 Pavilion kernel: audit: type=1131 audit(1640616858.460:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6234] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6242] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6250] device (wlo1): Activation: (wifi) connection 'FRITZ!Box 7590 GU' has security, and secrets exist. No new secrets needed.
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6251] Config: added 'ssid' value 'FRITZ!Box 7590 GU'
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6251] Config: added 'scan_ssid' value '1'
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6252] Config: added 'bgscan' value 'simple:30:-70:86400'
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6252] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6252] Config: added 'auth_alg' value 'OPEN'
Dez 27 15:54:28 Pavilion NetworkManager[523]: <info> [1640616868.6253] Config: added 'psk' value '<hidden>'
Dez 27 15:54:28 Pavilion kdeconnectd[1504]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Dez 27 15:54:28 Pavilion plasmashell[1476]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Dez 27 15:54:29 Pavilion NetworkManager[523]: <info> [1640616869.1322] device (wlo1): supplicant interface state: inactive -> scanning
Dez 27 15:54:30 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Dez 27 15:54:33 Pavilion wpa_supplicant[931]: wlo1: SME: Trying to authenticate with 44:4e:6d:cd:29:29 (SSID='FRITZ!Box 7590 GU' freq=5180 MHz)
Dez 27 15:54:33 Pavilion kernel: wlo1: authenticate with 44:4e:6d:cd:29:29
Dez 27 15:54:33 Pavilion NetworkManager[523]: <info> [1640616873.5635] device (wlo1): supplicant interface state: scanning -> authenticating
Dez 27 15:54:33 Pavilion kernel: wlo1: send auth to 44:4e:6d:cd:29:29 (try 1/3)
Dez 27 15:54:34 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:54:34 Pavilion kernel: wlo1: send auth to 44:4e:6d:cd:29:29 (try 2/3)
Dez 27 15:54:34 Pavilion wpa_supplicant[931]: wlo1: Trying to associate with 44:4e:6d:cd:29:29 (SSID='FRITZ!Box 7590 GU' freq=5180 MHz)
Dez 27 15:54:34 Pavilion kernel: wlo1: authenticated
Dez 27 15:54:34 Pavilion NetworkManager[523]: <info> [1640616874.8859] device (wlo1): supplicant interface state: authenticating -> associating
Dez 27 15:54:34 Pavilion kernel: wlo1: associate with 44:4e:6d:cd:29:29 (try 1/3)
Dez 27 15:54:34 Pavilion wpa_supplicant[931]: wlo1: Associated with 44:4e:6d:cd:29:29
Dez 27 15:54:34 Pavilion kernel: wlo1: RX AssocResp from 44:4e:6d:cd:29:29 (capab=0x1511 status=0 aid=1)
Dez 27 15:54:34 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 44:4e:6d:cd:29:29 joined with macid 0
Dez 27 15:54:34 Pavilion kernel: wlo1: associated
Dez 27 15:54:34 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Dez 27 15:54:34 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Dez 27 15:54:34 Pavilion NetworkManager[523]: <info> [1640616874.9043] device (wlo1): supplicant interface state: associating -> associated
Dez 27 15:54:34 Pavilion NetworkManager[523]: <info> [1640616874.9160] device (wlo1): supplicant interface state: associated -> 4way_handshake
Dez 27 15:54:34 Pavilion kernel: wlo1: Limiting TX power to 20 (23 - 3) dBm as advertised by 44:4e:6d:cd:29:29
Dez 27 15:54:35 Pavilion kernel: rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
Dez 27 15:54:38 Pavilion kernel: wlo1: disassociated from 44:4e:6d:cd:29:29 (Reason: 2=PREV_AUTH_NOT_VALID)
Dez 27 15:54:39 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-DISCONNECTED bssid=44:4e:6d:cd:29:29 reason=2
Dez 27 15:54:39 Pavilion kernel: rtw_8821ce 0000:03:00.0: sta 44:4e:6d:cd:29:29 with macid 0 left
Dez 27 15:54:39 Pavilion wpa_supplicant[931]: wlo1: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Dez 27 15:54:39 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="FRITZ!Box 7590 GU" auth_failures=1 duration=10 reason=WRONG_KEY
Dez 27 15:54:39 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dez 27 15:54:39 Pavilion NetworkManager[523]: <info> [1640616879.0147] device (wlo1): supplicant interface state: 4way_handshake -> disconnected
Dez 27 15:54:39 Pavilion NetworkManager[523]: <info> [1640616879.0149] device (wlo1): Activation: (wifi) disconnected during association, asking for new key
Dez 27 15:54:39 Pavilion NetworkManager[523]: <info> [1640616879.0152] device (wlo1): state change: config -> need-auth (reason 'supplicant-disconnect', sys-iface-state: 'managed')
Dez 27 15:54:39 Pavilion kded5[1429]: plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)
Dez 27 15:54:39 Pavilion kded5[1429]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/1"
Dez 27 15:54:39 Pavilion kded5[1429]: plasma-nm: Setting name: "802-11-wireless-security"
Dez 27 15:54:39 Pavilion kded5[1429]: plasma-nm: Hints: ()
Dez 27 15:54:39 Pavilion kded5[1429]: plasma-nm: Flags: 7
Dez 27 15:54:39 Pavilion NetworkManager[523]: <info> [1640616879.1145] device (wlo1): supplicant interface state: disconnected -> inactive
Dez 27 15:54:41 Pavilion NetworkManager[523]: <warn> [1640616881.2678] device (wlo1): no secrets: User canceled the secrets request.
Dez 27 15:54:41 Pavilion NetworkManager[523]: <info> [1640616881.2679] device (wlo1): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Dez 27 15:54:41 Pavilion NetworkManager[523]: <info> [1640616881.2692] manager: NetworkManager state is now DISCONNECTED
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Interface wlo1.IPv6 no longer relevant for mDNS.
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::b32:bbfb:a385:9d01.
Dez 27 15:54:41 Pavilion kernel: rtw_8821ce 0000:03:00.0: stop vif 10:5b:ad:32:01:e7 on port 0
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Interface wlo1.IPv4 no longer relevant for mDNS.
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.179.2.
Dez 27 15:54:41 Pavilion NetworkManager[523]: <info> [1640616881.2726] device (wlo1): set-hw-addr: set MAC address to CA:9B:B7:A0:84:A5 (scanning)
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Withdrawing address record for fe80::b32:bbfb:a385:9d01 on wlo1.
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Withdrawing address record for 192.168.179.2 on wlo1.
Dez 27 15:54:41 Pavilion kwin_x11[1433]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18254, resource id: 12582943, major code: 15 (QueryTree), minor code: 0
Dez 27 15:54:41 Pavilion kwin_x11[1433]: kwin_core: XCB error: 152 (BadDamage), sequence: 18350, resource id: 14780618, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.179.2.
Dez 27 15:54:41 Pavilion kernel: rtw_8821ce 0000:03:00.0: start vif ca:9b:b7:a0:84:a5 on port 0
Dez 27 15:54:41 Pavilion avahi-daemon[520]: New relevant interface wlo1.IPv4 for mDNS.
Dez 27 15:54:41 Pavilion NetworkManager[523]: <warn> [1640616881.7621] device (wlo1): Activation: failed for connection 'FRITZ!Box 7590 GU'
Dez 27 15:54:41 Pavilion avahi-daemon[520]: Registering new address record for 192.168.179.2 on wlo1.IPv4.
Dez 27 15:54:41 Pavilion NetworkManager[523]: <info> [1640616881.7689] device (wlo1): supplicant interface state: inactive -> interface_disabled
Dez 27 15:54:41 Pavilion NetworkManager[523]: <info> [1640616881.7693] device (wlo1): supplicant interface state: interface_disabled -> inactive
Dez 27 15:54:41 Pavilion NetworkManager[523]: <info> [1640616881.7701] device (wlo1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Dez 27 15:54:42 Pavilion avahi-daemon[520]: Withdrawing address record for 192.168.179.2 on wlo1.
Dez 27 15:54:42 Pavilion avahi-daemon[520]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.179.2.
Dez 27 15:54:42 Pavilion avahi-daemon[520]: Interface wlo1.IPv4 no longer relevant for mDNS.
Dez 27 15:54:42 Pavilion wpa_supplicant[931]: wlo1: Reject scan trigger since one is already pending
Dez 27 15:54:43 Pavilion wpa_supplicant[931]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Dez 27 15:54:43 Pavilion wpa_supplicant[931]: wlo1: Reject scan trigger since one is already pending
Dez 27 15:54:44 Pavilion kwin_x11[1433]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22132, resource id: 31457795, major code: 20 (GetProperty), minor code: 0
Dez 27 15:54:44 Pavilion kwin_x11[1433]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22135, resource id: 31457795, major code: 15 (QueryTree), minor code: 0
Dez 27 15:54:44 Pavilion kwin_x11[1433]: kwin_core: XCB error: 152 (BadDamage), sequence: 22223, resource id: 14780795, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dez 27 15:54:48 Pavilion plasmashell[1476]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:228:9: QML Image: i.ytimg.com: Host not found
Dez 27 15:54:49 Pavilion kwin_x11[1433]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24464, resource id: 31457834, major code: 18 (ChangeProperty), minor code: 0
Dez 27 15:54:49 Pavilion systemd[1367]: Started Alacritty - Terminal.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 619.
Dez 27 15:54:49 Pavilion plasmashell[1476]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:377: Unable to assign [undefined] to QString
Dez 27 15:54:49 Pavilion kwin_x11[1433]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24924, resource id: 14781289, major code: 3 (GetWindowAttributes), minor code: 0
Dez 27 15:54:49 Pavilion kwin_x11[1433]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 24925, resource id: 14781289, major code: 14 (GetGeometry), minor code: 0
Dez 27 15:54:50 Pavilion wpa_supplicant[931]: nl80211: send_and_recv->nl_recvmsgs failed: -33
Dez 27 15:54:53 Pavilion kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dez 27 15:54:53 Pavilion kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Dez 27 15:54:53 Pavilion kernel: ata1.00: configured for UDMA/133
Dez 27 15:54:53 Pavilion kernel: sd 0:0:0:0: [sda] Starting disk
Thanks for your time!
Leonardo
