WiFi not working after suspending properly
WiFi does not seem to work after suspending my laptop. I’ve used a couple different Arch based distributions in the past, and this happens with all of them. I usually suspend my laptop by closing the lid, or, in XFCE, Whisker Menu > Log Out Icon > Suspend. After I open the lid again, I have to restart my system to be able to use WiFi again.
inxi:
  Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=a260f330-e133-4867-ad68-6a09f51598ed rw quiet udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: HP product: HP Laptop 15s-du2xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 85F3 v: 40.33 serial: <filter> UEFI: Insyde v: F.43
  date: 03/31/2021
  ID-1: BAT1 charge: 23.6 Wh (60.2%) condition: 39.2/41.0 Wh (95.5%)
  volts: 11.3 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
  serial: <filter> status: Discharging
  RAM: total: 3.62 GiB used: 1.29 GiB (35.5%)
  Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
  arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
  L2: 4 MiB bogomips: 9524
  Speed: 1012 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1012 2: 1001
  3: 983 4: 1000
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
  avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
  avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
  hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
  intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
  movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
  pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
  rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1
  tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
  x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 13d3:56c9 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.3
  direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
  bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
  port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c822 class-ID: 0280
  Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
  bus-ID: 1-10:5 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 931.51 GiB used: 6.13 GiB (0.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  type: HDD rpm: 5400 serial: <filter> rev: RTM2 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 6.13 GiB (0.7%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: a260f330-e133-4867-ad68-6a09f51598ed
  used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 13B1-8756
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Logitech Wireless Receiver type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
  chip-ID: 046d:c542 class-ID: 0301
  Device-2: 1-5:3 info: IMC Networks HP TrueVision HD Camera type: Video
  Device-3: 1-6:4 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 04f3:0c00 class-ID: 0000
  Device-4: 1-10:5 info: Realtek 802.11ac WLAN Adapter type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 27.8 C mobo: 10.0 C
  Processes: 193 Uptime: 21m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 883 lib: 267 Shell: Zsh v: 5.8
  running-in: xfce4-terminal inxi: 3.3.08
sudo dmesg:
[    0.000000] microcode: microcode updated early to revision 0xa6, date = 2020-11-01
[    0.000000] Linux version 5.14.10-1-MANJARO (builduser@fv-az72-723) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Oct 7 06:43:34 UTC 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=a260f330-e133-4867-ad68-6a09f51598ed rw quiet udev.log_priority=3
[    0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[5]:  832, xstate_sizes[5]:   64
[    0.000000] x86/fpu: xstate_offset[6]:  896, xstate_sizes[6]:  512
[    0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[    0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]:    8
[    0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
[    0.000000] signal: max sigframe size: 3632
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000033eddfff] usable
[    0.000000] BIOS-e820: [mem 0x0000000033ede000-0x0000000033edefff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000033edf000-0x0000000033f34fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000033f35000-0x0000000033f35fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000033f36000-0x0000000042a2efff] usable
[    0.000000] BIOS-e820: [mem 0x0000000042a2f000-0x0000000042dfefff] type 20
[    0.000000] BIOS-e820: [mem 0x0000000042dff000-0x000000004518efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000004518f000-0x0000000045f7efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000045f7f000-0x0000000045ffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000045fff000-0x0000000045ffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000046000000-0x0000000049ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000004a200000-0x000000004a3fffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000004b000000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fc800000-0x00000000fe7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed17fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feda0000-0x00000000feda1fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
sudo dmesg | grep usb:
[    0.478376] usbcore: registered new interface driver usbfs
[    0.478376] usbcore: registered new interface driver hub
[    0.478376] usbcore: registered new device driver usb
[    0.614245] usbcore: registered new interface driver usbserial_generic
[    0.614252] usbserial: USB Serial support registered for generic
[    1.223472] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.14
[    1.223474] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.223476] usb usb1: Product: xHCI Host Controller
[    1.223477] usb usb1: Manufacturer: Linux 5.14.10-1-MANJARO xhci-hcd
[    1.223478] usb usb1: SerialNumber: 0000:00:14.0
[    1.225135] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.14
[    1.225138] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.225140] usb usb2: Product: xHCI Host Controller
[    1.225141] usb usb2: Manufacturer: Linux 5.14.10-1-MANJARO xhci-hcd
[    1.225143] usb usb2: SerialNumber: 0000:00:14.0
[    1.226049] usb: port power management may be unreliable
[    1.473767] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[    1.618015] usb 1-2: New USB device found, idVendor=046d, idProduct=c542, bcdDevice= 3.02
[    1.618024] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.618028] usb 1-2: Product: Wireless Receiver
[    1.618030] usb 1-2: Manufacturer: Logitech
[    1.626626] input: Logitech Wireless Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C542.0001/input/input4
[    1.626775] hid-generic 0003:046D:C542.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech Wireless Receiver] on usb-0000:00:14.0-2/input0
[    1.626843] usbcore: registered new interface driver usbhid
[    1.626847] usbhid: USB HID core driver
[    1.740394] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[    1.899691] usb 1-5: New USB device found, idVendor=13d3, idProduct=56c9, bcdDevice=18.03
[    1.899699] usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    1.899703] usb 1-5: Product: HP TrueVision HD Camera
[    1.899705] usb 1-5: Manufacturer: Azurewave
[    1.899708] usb 1-5: SerialNumber: 0001
[    2.023971] usb 1-6: new full-speed USB device number 4 using xhci_hcd
[    2.165337] usb 1-6: New USB device found, idVendor=04f3, idProduct=0c00, bcdDevice= 2.56
[    2.165340] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.165342] usb 1-6: Product: ELAN:ARM-M4
[    2.165343] usb 1-6: Manufacturer: ELAN
[    2.290556] usb 1-10: new full-speed USB device number 5 using xhci_hcd
[    2.431846] usb 1-10: New USB device found, idVendor=0bda, idProduct=b00c, bcdDevice= 0.00
[    2.431856] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.431859] usb 1-10: Product: 802.11ac WLAN Adapter
[    2.431862] usb 1-10: Manufacturer: Realtek
[    2.431865] usb 1-10: SerialNumber: 00e04c000001
[   15.240886] usbcore: registered new interface driver btusb
[   15.471103] usb 1-5: Found UVC 1.00 device HP TrueVision HD Camera (13d3:56c9)
[   15.474986] input: HP TrueVision HD Camera: HP Tru as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input23
[   15.475071] usbcore: registered new interface driver uvcvideo
sudo dmesg --level emerg,alert,crit,err,warn:
[    0.124278] x86/cpu: SGX disabled by BIOS.
[    0.157032] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.348740] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.DGPV], AE_NOT_FOUND (20210604/psargs-330)
[    0.348751] ACPI Error: Aborting method \_SB.PCI0.RP05.PCRP._ON due to previous error (AE_NOT_FOUND) (20210604/psparse-529)
[    0.478111] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.DGPV], AE_NOT_FOUND (20210604/psargs-330)
[    0.478122] ACPI Error: Aborting method \_SB.PCI0.RP05.PCRP._OFF due to previous error (AE_NOT_FOUND) (20210604/psparse-529)
[    1.223103] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[   11.265489] intel-spi 0000:00:1f.5: invalid resource
[   11.265493] intel-spi: probe of 0000:00:1f.5 failed with error -22
[   11.615882] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[   11.618643] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[   11.618667] wmi_bus wmi_bus-PNP0C14:03: WQBJ data block query control method not found
[   12.083270] r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
[   13.371742] hp_wmi: query 0x4c returned error 0x6
[   15.391673] kauditd_printk_skb: 9 callbacks suppressed
[   20.447869] kauditd_printk_skb: 4 callbacks suppressed
[   27.693896] kauditd_printk_skb: 11 callbacks suppressed
journalctl --catalog --priority=3 --boot=-1:
-- Journal begins at Thu 2021-11-04 09:03:37 IST, ends at Thu 2021-11-04 13:13:02 IST. --
Nov 04 12:14:55 15s-du2004tu kernel: x86/cpu: SGX disabled by BIOS.
Nov 04 12:14:55 15s-du2004tu kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.DGPV], AE_NOT_FOUND (20210604/psargs-330)
Nov 04 12:14:55 15s-du2004tu kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PCRP._ON due to previous error (AE_NOT_FOUND) (20210604/psparse-529)
Nov 04 12:14:55 15s-du2004tu kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PCRP._OFF due to previous error (AE_NOT_FOUND) (20210604/psparse-529)
Nov 04 12:14:59 15s-du2004tu kernel: intel-spi 0000:00:1f.5: invalid resource
Nov 04 12:19:25 15s-du2004tu sudo[1529]: pam_unix(sudo:auth): conversation failed
Nov 04 12:19:25 15s-du2004tu sudo[1529]: pam_unix(sudo:auth): auth could not identify password for [samarth]
Nov 04 12:19:25 15s-du2004tu sudo[1530]: pam_unix(sudo:auth): conversation failed
Nov 04 12:19:25 15s-du2004tu sudo[1530]: pam_unix(sudo:auth): auth could not identify password for [samarth]
Nov 04 13:02:12 15s-du2004tu sudo[2841]: pam_unix(sudo:auth): conversation failed
Nov 04 13:02:12 15s-du2004tu sudo[2841]: pam_unix(sudo:auth): auth could not identify password for [samarth]
Nov 04 13:02:14 15s-du2004tu sudo[2841]:  samarth : 2 incorrect password attempts ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg
Nov 04 13:02:49 15s-du2004tu sudo[2922]:  samarth : 3 incorrect password attempts ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg
Nov 04 13:03:33 15s-du2004tu sudo[2937]:  samarth : 3 incorrect password attempts ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg
Nov 04 13:04:09 15s-du2004tu sudo[2946]:  samarth : 3 incorrect password attempts ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg
Nov 04 13:04:23 15s-du2004tu sudo[2951]: pam_unix(sudo:auth): conversation failed
Nov 04 13:04:23 15s-du2004tu sudo[2951]: pam_unix(sudo:auth): auth could not identify password for [samarth]
Nov 04 13:04:23 15s-du2004tu sudo[2951]: pam_systemd_home(sudo:auth): Failed to query user record: Interrupted system call
Nov 04 13:04:24 15s-du2004tu sudo[2951]:  samarth : 2 incorrect password attempts ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg
Nov 04 13:06:22 15s-du2004tu sudo[3026]: pam_unix(sudo:auth): conversation failed
Nov 04 13:06:22 15s-du2004tu sudo[3026]: pam_unix(sudo:auth): auth could not identify password for [samarth]
Nov 04 13:06:24 15s-du2004tu sudo[3026]:  samarth : 1 incorrect password attempt ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg
Nov 04 13:06:53 15s-du2004tu sudo[3079]:  samarth : 3 incorrect password attempts ; TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/su
Nov 04 13:07:02 15s-du2004tu pulseaudio[783]: Error opening PCM device front:0: No such file or directory
Nov 04 13:07:03 15s-du2004tu kernel: watchdog: watchdog0: watchdog did not stop!
journalctl --follow:
-- Journal begins at Thu 2021-11-04 09:03:37 IST. --
Nov 04 13:13:02 15s-du2004tu audit[1458]: CRED_REFR pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Nov 04 13:13:02 15s-du2004tu sudo[1458]:  samarth : TTY=pts/0 ; PWD=/home/samarth ; USER=root ; COMMAND=/usr/bin/dmesg --level emerg,alert,crit,err,warn
Nov 04 13:13:02 15s-du2004tu sudo[1458]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Nov 04 13:13:02 15s-du2004tu audit[1458]: USER_START pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Nov 04 13:13:02 15s-du2004tu kernel: audit: type=1105 audit(1636011782.823:91): pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Nov 04 13:13:02 15s-du2004tu sudo[1458]: pam_unix(sudo:session): session closed for user root
Nov 04 13:13:02 15s-du2004tu audit[1458]: USER_END pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Nov 04 13:13:02 15s-du2004tu audit[1458]: CRED_DISP pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Nov 04 13:13:02 15s-du2004tu kernel: audit: type=1106 audit(1636011782.836:92): pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Nov 04 13:13:02 15s-du2004tu kernel: audit: type=1104 audit(1636011782.836:93): pid=1458 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
cat /var/log/Xorg.0.log:
[    18.421]
X.Org X Server 1.20.13
[    18.421] Build Operating System: Linux Manjaro Linux
[    18.421] Current Operating System: Linux 15s-du2004tu 5.14.10-1-MANJARO #1 SMP PREEMPT Thu Oct 7 06:43:34 UTC 2021 x86_64
[    18.421] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=a260f330-e133-4867-ad68-6a09f51598ed rw quiet udev.log_priority=3
[    18.421] Build Date: 24 August 2021  10:21:29AM
[    18.421]
[    18.421] Current version of pixman: 0.40.0
[    18.421] 	Before reporting problems, check http://wiki.x.org
[    18.421] Markers: (--) probed, (**) from config file, (==) default setting,
[    18.421] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov  4 13:07:37 2021
[    18.425] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    18.426] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    18.454] (==) No Layout section.  Using the first Screen section.
[    18.454] (==) No screen section available. Using defaults.
[    18.454] (**) |-->Screen "Default Screen Section" (0)
[    18.454] (**) |   |-->Monitor "<default monitor>"
[    18.454] (==) No monitor specified for screen "Default Screen Section".
[    18.454] (==) Automatically adding devices
[    18.454] (==) Automatically enabling devices
[    18.454] (==) Automatically adding GPU devices
[    18.454] (==) Automatically binding GPU devices
[    18.454] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    18.499] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    18.499] 	Entry deleted from font path.
[    18.499] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    18.499] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    18.499] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    18.499] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    18.499] (==) ModulePath set to "/usr/lib/xorg/modules"
[    18.499] (II) The server relies on udev to provide the list of input devices.
[    18.499] (II) Module ABI versions:
[    18.499] 	X.Org ANSI C Emulation: 0.4
[    18.499] 	X.Org Video Driver: 24.1
[    18.499] 	X.Org XInput driver : 24.1
[    18.499] 	X.Org Server Extension : 10.0
[    18.499] (++) using VT number 7
[    18.499] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    18.500] (II) xfree86: Adding drm device (/dev/dri/card0)
[    18.507] (--) PCI:*(0@0:2:0) 8086:8a56:103c:85f3 rev 7, Mem @ 0x6000000000/16777216, 0x4000000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[    18.507] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    18.507] (II) LoadModule: "glx"
[    18.560] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    18.653] (II) Module glx: vendor="X.Org Foundation"
[    18.653] 	compiled for 1.20.13, module version = 1.0.0
[    18.653] 	ABI class: X.Org Server Extension, version 10.0
[    18.653] (==) Matched modesetting as autoconfigured driver 0
[    18.653] (==) Matched fbdev as autoconfigured driver 1
[    18.653] (==) Matched vesa as autoconfigured driver 2
[    18.653] (==) Assigned the driver to the xf86ConfigLayout
[    18.653] (II) LoadModule: "modesetting"
[    18.653] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    18.663] (II) Module modesetting: vendor="X.Org Foundation"
[    18.663] 	compiled for 1.20.13, module version = 1.20.13
[    18.663] 	Module class: X.Org Video Driver
[    18.663] 	ABI class: X.Org Video Driver, version 24.1
[    18.663] (II) LoadModule: "fbdev"
[    18.663] (WW) Warning, couldn't open module fbdev
[    18.664] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    18.664] (II) LoadModule: "vesa"
[    18.664] (WW) Warning, couldn't open module vesa
[    18.664] (EE) Failed to load module "vesa" (module does not exist, 0)
[    18.664] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    18.688] (II) modeset(0): using drv /dev/dri/card0
[    18.688] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    18.688] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    18.688] (==) modeset(0): RGB weight 888
[    18.688] (==) modeset(0): Default visual is TrueColor
[    18.688] (II) Loading sub module "glamoregl"
[    18.688] (II) LoadModule: "glamoregl"
[    18.688] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    18.745] (II) Module glamoregl: vendor="X.Org Foundation"
[    18.745] 	compiled for 1.20.13, module version = 1.0.1
[    18.745] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    21.222] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (ICL GT1)
[    21.222] (II) modeset(0): glamor initialized
[    21.224] (II) modeset(0): Output eDP-1 has no monitor section
[    21.224] (II) modeset(0): Output HDMI-1 has no monitor section
[    21.224] (II) modeset(0): Output DP-1 has no monitor section
[    21.224] (II) modeset(0): Output HDMI-2 has no monitor section
[    21.224] (II) modeset(0): Output DP-2 has no monitor section
[    21.224] (II) modeset(0): Output DP-3 has no monitor section
[    21.224] (II) modeset(0): Output DP-4 has no monitor section
[    21.226] (II) modeset(0): EDID for output eDP-1
[    21.226] (II) modeset(0): Manufacturer: AUO  Model: 61ed  Serial#: 0
[    21.226] (II) modeset(0): Year: 2018  Week: 0
[    21.226] (II) modeset(0): EDID Version: 1.4
[    21.226] (II) modeset(0): Digital Display Input
[    21.226] (II) modeset(0): 6 bits per channel
[    21.226] (II) modeset(0): Digital interface is DisplayPort
[    21.226] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    21.226] (II) modeset(0): Gamma: 2.20
[    21.226] (II) modeset(0): No DPMS capabilities specified
[    21.226] (II) modeset(0): Supported color encodings: RGB 4:4:4
[    21.226] (II) modeset(0): First detailed timing is preferred mode
[    21.226] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[    21.226] (II) modeset(0): Display is continuous-frequency
[    21.226] (II) modeset(0): redX: 0.562 redY: 0.336   greenX: 0.344 greenY: 0.574
[    21.226] (II) modeset(0): blueX: 0.163 blueY: 0.126   whiteX: 0.313 whiteY: 0.329
[    21.226] (II) modeset(0): Manufacturer's mask: 0
[    21.226] (II) modeset(0): Supported detailed timing:
[    21.226] (II) modeset(0): clock: 141.0 MHz   Image Size:  344 x 194 mm
[    21.226] (II) modeset(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2100 h_border: 0
[    21.226] (II) modeset(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1118 v_border: 0
[    21.226] (II) modeset(0): clock: 94.0 MHz   Image Size:  344 x 194 mm
[    21.226] (II) modeset(0): Unknown vendor-specific block 2
[    21.226] (II) modeset(0): EDID (in hex):
[    21.226] (II) modeset(0): 	00ffffffffffff0006afed6100000000
[    21.226] (II) modeset(0): 	001c01049522137803c0d58f56589329
[    21.226] (II) modeset(0): 	20505400000001010101010101010101
[    21.226] (II) modeset(0): 	010101010101143780b4703826406c30
[    21.226] (II) modeset(0): 	aa0058c210000018b82480b470382640
[    21.226] (II) modeset(0): 	6c30aa0058c210000018000000000000
[    21.226] (II) modeset(0): 	00000000000000000000000000000002
[    21.226] (II) modeset(0): 	001048ff0f3c6e5513226e2020200016
[    21.227] (II) modeset(0): Printing probed modes for output eDP-1
[    21.227] (II) modeset(0): Modeline "1920x1080"x60.1  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    21.227] (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[    21.227] (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    21.227] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    21.227] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    21.227] (II) modeset(0): Modeline "1920x1080"x40.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[    21.227] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    21.227] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    21.227] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    21.227] (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    21.227] (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    21.227] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    21.227] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    21.227] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    21.227] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    21.227] (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    21.227] (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    21.227] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    21.227] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    21.227] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    21.227] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    21.227] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    21.227] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    21.227] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    21.227] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    21.227] (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    21.227] (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    21.227] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    21.227] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    21.227] (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    21.227] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    21.227] (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    21.227] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    21.227] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    21.227] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    21.227] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    21.227] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    21.227] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    21.227] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    21.227] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    21.227] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    21.227] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    21.227] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    21.227] (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    21.227] (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    21.227] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    21.227] (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    21.227] (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    21.227] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    21.227] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    21.228] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    21.228] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    21.228] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    21.228] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    21.228] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    21.228] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    21.228] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    21.228] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    21.228] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    21.228] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    21.228] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    21.228] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    21.228] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    21.228] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    21.228] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    21.228] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    21.228] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    21.228] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    21.228] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    21.228] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    21.228] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    21.228] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    21.228] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    21.228] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    21.228] (II) modeset(0): EDID for output HDMI-1
[    21.228] (II) modeset(0): EDID for output DP-1
[    21.228] (II) modeset(0): EDID for output HDMI-2
[    21.228] (II) modeset(0): EDID for output DP-2
[    21.228] (II) modeset(0): EDID for output DP-3
[    21.228] (II) modeset(0): EDID for output DP-4
[    21.228] (II) modeset(0): Output eDP-1 connected
[    21.228] (II) modeset(0): Output HDMI-1 disconnected
[    21.228] (II) modeset(0): Output DP-1 disconnected
[    21.228] (II) modeset(0): Output HDMI-2 disconnected
[    21.228] (II) modeset(0): Output DP-2 disconnected
[    21.228] (II) modeset(0): Output DP-3 disconnected
[    21.228] (II) modeset(0): Output DP-4 disconnected
[    21.228] (II) modeset(0): Using exact sizes for initial modes
[    21.228] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[    21.228] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    21.228] (==) modeset(0): DPI set to (96, 96)
[    21.228] (II) Loading sub module "fb"
[    21.228] (II) LoadModule: "fb"
[    21.228] (II) Loading /usr/lib/xorg/modules/libfb.so
[    21.242] (II) Module fb: vendor="X.Org Foundation"
[    21.242] 	compiled for 1.20.13, module version = 1.0.0
[    21.242] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    21.458] (==) modeset(0): Backing store enabled
[    21.458] (==) modeset(0): Silken mouse disabled
[    21.537] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    21.538] (==) modeset(0): DPMS enabled
[    21.538] (II) modeset(0): [DRI2] Setup complete
[    21.538] (II) modeset(0): [DRI2]   DRI driver: iris
[    21.538] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    21.538] (II) Initializing extension Generic Event Extension
[    21.538] (II) Initializing extension SHAPE
[    21.538] (II) Initializing extension MIT-SHM
[    21.539] (II) Initializing extension XInputExtension
[    21.539] (II) Initializing extension XTEST
[    21.539] (II) Initializing extension BIG-REQUESTS
[    21.539] (II) Initializing extension SYNC
[    21.540] (II) Initializing extension XKEYBOARD
[    21.540] (II) Initializing extension XC-MISC
[    21.540] (II) Initializing extension SECURITY
[    21.540] (II) Initializing extension XFIXES
[    21.540] (II) Initializing extension RENDER
[    21.541] (II) Initializing extension RANDR
[    21.541] (II) Initializing extension COMPOSITE
[    21.541] (II) Initializing extension DAMAGE
[    21.542] (II) Initializing extension MIT-SCREEN-SAVER
[    21.542] (II) Initializing extension DOUBLE-BUFFER
[    21.542] (II) Initializing extension RECORD
[    21.542] (II) Initializing extension DPMS
[    21.543] (II) Initializing extension Present
[    21.543] (II) Initializing extension DRI3
[    21.543] (II) Initializing extension X-Resource
[    21.543] (II) Initializing extension XVideo
[    21.544] (II) Initializing extension XVideo-MotionCompensation
[    21.544] (II) Initializing extension GLX
[    21.555] (II) AIGLX: Loaded and initialized iris
[    21.555] (II) GLX: Initialized DRI2 GL provider for screen 0
[    21.555] (II) Initializing extension XFree86-VidModeExtension
[    21.555] (II) Initializing extension XFree86-DGA
[    21.555] (II) Initializing extension XFree86-DRI
[    21.555] (II) Initializing extension DRI2
[    21.556] (II) modeset(0): Damage tracking initialized
[    21.556] (II) modeset(0): Setting screen physical size to 508 x 285
[    21.828] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    21.828] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    21.828] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    21.828] (**) Power Button: Applying InputClass "system-keyboard"
[    21.828] (II) LoadModule: "libinput"
[    21.829] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    21.906] (II) Module libinput: vendor="X.Org Foundation"
[    21.907] 	compiled for 1.20.13, module version = 1.2.0
[    21.907] 	Module class: X.Org XInput Driver
[    21.907] 	ABI class: X.Org XInput driver, version 24.1
[    21.907] (II) Using input driver 'libinput' for 'Power Button'
[    21.907] (**) Power Button: always reports core events
[    21.907] (**) Option "Device" "/dev/input/event2"
[    21.907] (**) Option "_source" "server/udev"
[    21.983] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    21.983] (II) event2  - Power Button: device is a keyboard
[    21.983] (II) event2  - Power Button: device removed
[    22.016] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    22.016] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    22.016] (**) Option "xkb_layout" "us"
[    22.017] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    22.018] (II) event2  - Power Button: device is a keyboard
[    22.019] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[    22.019] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    22.019] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    22.019] (**) Video Bus: Applying InputClass "system-keyboard"
[    22.019] (II) Using input driver 'libinput' for 'Video Bus'
[    22.019] (**) Video Bus: always reports core events
[    22.019] (**) Option "Device" "/dev/input/event8"
[    22.019] (**) Option "_source" "server/udev"
[    22.020] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[    22.020] (II) event8  - Video Bus: device is a keyboard
[    22.021] (II) event8  - Video Bus: device removed
[    22.082] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13/event8"
[    22.083] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    22.083] (**) Option "xkb_layout" "us"
[    22.084] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[    22.085] (II) event8  - Video Bus: device is a keyboard
[    22.086] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    22.086] (II) No input driver specified, ignoring this device.
[    22.086] (II) This device may have been added with another device file.
[    22.086] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    22.086] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    22.086] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    22.086] (**) Power Button: Applying InputClass "system-keyboard"
[    22.086] (II) Using input driver 'libinput' for 'Power Button'
[    22.086] (**) Power Button: always reports core events
[    22.086] (**) Option "Device" "/dev/input/event1"
[    22.086] (**) Option "_source" "server/udev"
[    22.088] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    22.088] (II) event1  - Power Button: device is a keyboard
[    22.088] (II) event1  - Power Button: device removed
[    22.123] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    22.123] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    22.123] (**) Option "xkb_layout" "us"
[    22.124] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    22.124] (II) event1  - Power Button: device is a keyboard
[    22.126] (II) config/udev: Adding input device Logitech Wireless Receiver Mouse (/dev/input/event4)
[    22.126] (**) Logitech Wireless Receiver Mouse: Applying InputClass "evdev pointer catchall"
[    22.126] (**) Logitech Wireless Receiver Mouse: Applying InputClass "libinput pointer catchall"
[    22.126] (II) Using input driver 'libinput' for 'Logitech Wireless Receiver Mouse'
[    22.126] (**) Logitech Wireless Receiver Mouse: always reports core events
[    22.126] (**) Option "Device" "/dev/input/event4"
[    22.127] (**) Option "_source" "server/udev"
[    22.184] (II) event4  - Logitech Wireless Receiver Mouse: is tagged by udev as: Mouse
[    22.185] (II) event4  - Logitech Wireless Receiver Mouse: device is a pointer
[    22.185] (II) event4  - Logitech Wireless Receiver Mouse: device removed
[    22.242] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C542.0001/input/input4/event4"
[    22.243] (II) XINPUT: Adding extended input device "Logitech Wireless Receiver Mouse" (type: MOUSE, id 9)
[    22.243] (**) Option "AccelerationScheme" "none"
[    22.243] (**) Logitech Wireless Receiver Mouse: (accel) selected scheme none/0
[    22.243] (**) Logitech Wireless Receiver Mouse: (accel) acceleration factor: 2.000
[    22.243] (**) Logitech Wireless Receiver Mouse: (accel) acceleration threshold: 4
[    22.301] (II) event4  - Logitech Wireless Receiver Mouse: is tagged by udev as: Mouse
[    22.301] (II) event4  - Logitech Wireless Receiver Mouse: device is a pointer
[    22.303] (II) config/udev: Adding input device Logitech Wireless Receiver Mouse (/dev/input/mouse0)
[    22.303] (II) No input driver specified, ignoring this device.
[    22.303] (II) This device may have been added with another device file.
[    22.304] (II) config/udev: Adding input device HP TrueVision HD Camera: HP Tru (/dev/input/event19)
[    22.304] (**) HP TrueVision HD Camera: HP Tru: Applying InputClass "evdev keyboard catchall"
[    22.304] (**) HP TrueVision HD Camera: HP Tru: Applying InputClass "libinput keyboard catchall"
[    22.304] (**) HP TrueVision HD Camera: HP Tru: Applying InputClass "system-keyboard"
[    22.304] (II) Using input driver 'libinput' for 'HP TrueVision HD Camera: HP Tru'
[    22.304] (**) HP TrueVision HD Camera: HP Tru: always reports core events
[    22.304] (**) Option "Device" "/dev/input/event19"
[    22.304] (**) Option "_source" "server/udev"
[    22.306] (II) event19 - HP TrueVision HD Camera: HP Tru: is tagged by udev as: Keyboard
[    22.306] (II) event19 - HP TrueVision HD Camera: HP Tru: device is a keyboard
[    22.306] (II) event19 - HP TrueVision HD Camera: HP Tru: device removed
[    22.362] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input23/event19"
[    22.363] (II) XINPUT: Adding extended input device "HP TrueVision HD Camera: HP Tru" (type: KEYBOARD, id 10)
[    22.363] (**) Option "xkb_layout" "us"
[    22.365] (II) event19 - HP TrueVision HD Camera: HP Tru: is tagged by udev as: Keyboard
[    22.365] (II) event19 - HP TrueVision HD Camera: HP Tru: device is a keyboard
[    22.366] (II) config/udev: Adding input device ELAN0709:00 04F3:30A0 Touchpad (/dev/input/event6)
[    22.366] (**) ELAN0709:00 04F3:30A0 Touchpad: Applying InputClass "evdev touchpad catchall"
[    22.366] (**) ELAN0709:00 04F3:30A0 Touchpad: Applying InputClass "libinput touchpad catchall"
[    22.366] (II) Using input driver 'libinput' for 'ELAN0709:00 04F3:30A0 Touchpad'
[    22.366] (**) ELAN0709:00 04F3:30A0 Touchpad: always reports core events
[    22.366] (**) Option "Device" "/dev/input/event6"
[    22.366] (**) Option "_source" "server/udev"
[    22.368] (II) event6  - ELAN0709:00 04F3:30A0 Touchpad: is tagged by udev as: Touchpad
[    22.370] (II) event6  - ELAN0709:00 04F3:30A0 Touchpad: device is a touchpad
[    22.370] (II) event6  - ELAN0709:00 04F3:30A0 Touchpad: device removed
[    22.430] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0709:00/0018:04F3:30A0.0002/input/input11/event6"
[    22.430] (II) XINPUT: Adding extended input device "ELAN0709:00 04F3:30A0 Touchpad" (type: TOUCHPAD, id 11)
[    22.431] (**) Option "AccelerationScheme" "none"
[    22.431] (**) ELAN0709:00 04F3:30A0 Touchpad: (accel) selected scheme none/0
[    22.431] (**) ELAN0709:00 04F3:30A0 Touchpad: (accel) acceleration factor: 2.000
[    22.431] (**) ELAN0709:00 04F3:30A0 Touchpad: (accel) acceleration threshold: 4
[    22.433] (II) event6  - ELAN0709:00 04F3:30A0 Touchpad: is tagged by udev as: Touchpad
[    22.435] (II) event6  - ELAN0709:00 04F3:30A0 Touchpad: device is a touchpad
[    22.437] (II) config/udev: Adding input device ELAN0709:00 04F3:30A0 Touchpad (/dev/input/mouse2)
[    22.437] (II) No input driver specified, ignoring this device.
[    22.437] (II) This device may have been added with another device file.
[    22.437] (II) config/udev: Adding input device ELAN0709:00 04F3:30A0 Mouse (/dev/input/event5)
[    22.437] (**) ELAN0709:00 04F3:30A0 Mouse: Applying InputClass "evdev pointer catchall"
[    22.437] (**) ELAN0709:00 04F3:30A0 Mouse: Applying InputClass "libinput pointer catchall"
[    22.437] (II) Using input driver 'libinput' for 'ELAN0709:00 04F3:30A0 Mouse'
[    22.437] (**) ELAN0709:00 04F3:30A0 Mouse: always reports core events
[    22.437] (**) Option "Device" "/dev/input/event5"
[    22.438] (**) Option "_source" "server/udev"
[    22.439] (II) event5  - ELAN0709:00 04F3:30A0 Mouse: is tagged by udev as: Mouse Pointingstick
[    22.440] (II) event5  - ELAN0709:00 04F3:30A0 Mouse: device is a pointer
[    22.441] (II) event5  - ELAN0709:00 04F3:30A0 Mouse: device removed
[    22.496] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0709:00/0018:04F3:30A0.0002/input/input9/event5"
[    22.496] (II) XINPUT: Adding extended input device "ELAN0709:00 04F3:30A0 Mouse" (type: MOUSE, id 12)
[    22.496] (**) Option "AccelerationScheme" "none"
[    22.496] (**) ELAN0709:00 04F3:30A0 Mouse: (accel) selected scheme none/0
[    22.496] (**) ELAN0709:00 04F3:30A0 Mouse: (accel) acceleration factor: 2.000
[    22.496] (**) ELAN0709:00 04F3:30A0 Mouse: (accel) acceleration threshold: 4
[    22.498] (II) event5  - ELAN0709:00 04F3:30A0 Mouse: is tagged by udev as: Mouse Pointingstick
[    22.499] (II) event5  - ELAN0709:00 04F3:30A0 Mouse: device is a pointer
[    22.501] (II) config/udev: Adding input device ELAN0709:00 04F3:30A0 Mouse (/dev/input/mouse1)
[    22.501] (II) No input driver specified, ignoring this device.
[    22.501] (II) This device may have been added with another device file.
[    22.501] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[    22.502] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event10)
[    22.502] (II) No input driver specified, ignoring this device.
[    22.502] (II) This device may have been added with another device file.
[    22.502] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[    22.503] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event12)
[    22.503] (II) No input driver specified, ignoring this device.
[    22.503] (II) This device may have been added with another device file.
[    22.503] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event13)
[    22.504] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event14)
[    22.504] (II) No input driver specified, ignoring this device.
[    22.504] (II) This device may have been added with another device file.
[    22.504] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event15)
[    22.505] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=11 (/dev/input/event16)
[    22.505] (II) No input driver specified, ignoring this device.
[    22.505] (II) This device may have been added with another device file.
[    22.505] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=12 (/dev/input/event17)
[    22.506] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    22.506] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    22.506] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    22.506] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    22.506] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    22.506] (**) AT Translated Set 2 keyboard: always reports core events
[    22.506] (**) Option "Device" "/dev/input/event3"
[    22.506] (**) Option "_source" "server/udev"
[    22.507] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    22.508] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    22.509] (II) event3  - AT Translated Set 2 keyboard: device removed
[    22.536] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    22.536] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[    22.536] (**) Option "xkb_layout" "us"
[    22.538] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    22.538] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    22.540] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[    22.540] (II) No input driver specified, ignoring this device.
[    22.540] (II) This device may have been added with another device file.
[    22.543] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event18)
[    22.543] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    22.543] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    22.543] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[    22.543] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[    22.543] (**) HP WMI hotkeys: always reports core events
[    22.543] (**) Option "Device" "/dev/input/event18"
[    22.543] (**) Option "_source" "server/udev"
[    22.544] (II) event18 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[    22.544] (II) event18 - HP WMI hotkeys: device is a keyboard
[    22.545] (II) event18 - HP WMI hotkeys: device removed
[    22.576] (**) Option "config_info" "udev:/sys/devices/virtual/input/input12/event18"
[    22.576] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 14)
[    22.576] (**) Option "xkb_layout" "us"
[    22.577] (II) event18 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[    22.577] (II) event18 - HP WMI hotkeys: device is a keyboard
[    27.421] (II) modeset(0): EDID vendor "AUO", prod id 25069
[    27.422] (II) modeset(0): Printing DDC gathered Modelines:
[    27.422] (II) modeset(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    27.422] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[    32.889] (II) modeset(0): EDID vendor "AUO", prod id 25069
[    32.889] (II) modeset(0): Printing DDC gathered Modelines:
[    32.889] (II) modeset(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    32.889] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[    34.037] (II) modeset(0): EDID vendor "AUO", prod id 25069
[    34.037] (II) modeset(0): Printing DDC gathered Modelines:
[    34.037] (II) modeset(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    34.037] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[    48.997] (II) modeset(0): EDID vendor "AUO", prod id 25069
[    48.998] (II) modeset(0): Printing DDC gathered Modelines:
[    48.998] (II) modeset(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    48.998] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[    74.003] (II) modeset(0): EDID vendor "AUO", prod id 25069
[    74.003] (II) modeset(0): Printing DDC gathered Modelines:
[    74.003] (II) modeset(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    74.003] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
less /var/log/Xorg.0.log.old:
[    19.572]
[    19.572] Build Operating System: Linux Manjaro Linux
[    19.572] Current Operating System: Linux 15s-du2004tu 5.14.10-1-MANJARO #1 SMP PREEMPT Thu Oct 7 06:43:34 UTC 2021 x86_64
[    19.572] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=a260f330-e133-4867-ad68-6a09f51598ed rw quiet udev.log_priority=3
[    19.572] Build Date: 24 August 2021  10:21:29AM
[    19.572]
[    19.572] Current version of pixman: 0.40.0
[    19.572]    Before reporting problems, check http://wiki.x.org
[    19.572] Markers: (--) probed, (**) from config file, (==) default setting,
[    19.572] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov  4 12:15:05 2021
[    19.586] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    19.586] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    19.615] (==) No Layout section.  Using the first Screen section.
[    19.615] (==) No screen section available. Using defaults.
[    19.615] (**) |-->Screen "Default Screen Section" (0)
[    19.615] (**) |   |-->Monitor "<default monitor>"
[    19.615] (==) No monitor specified for screen "Default Screen Section".
[    19.615] (==) Automatically adding devices
[    19.615] (==) Automatically enabling devices
[    19.615] (==) Automatically adding GPU devices
[    19.615] (==) Automatically binding GPU devices
[    19.615] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    19.650] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    19.650]    Entry deleted from font path.
[    19.650] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    19.650] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    19.650] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    19.650] (==) FontPath set to:
[    19.650] (==) ModulePath set to "/usr/lib/xorg/modules"
[    19.650] (II) The server relies on udev to provide the list of input devices.
less /var/log/Xorg.1.log:
[  7006.957]
[  7006.957] Build Operating System: Linux Manjaro Linux
[  7006.957] Current Operating System: Linux 15s-du2004tu 5.14.10-1-MANJARO #1 SMP PREEMPT Thu Oct 7 06:43:34 UTC 2021 x86_64
[  7006.957] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=a260f330-e133-4867-ad68-6a09f51598ed rw quiet udev.log_priority=3
[  7006.957] Build Date: 24 August 2021  10:21:29AM
[  7006.957]
[  7006.957] Current version of pixman: 0.40.0
[  7006.957]    Before reporting problems, check http://wiki.x.org
[  7006.957] Markers: (--) probed, (**) from config file, (==) default setting,
[  7006.957] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Nov  4 12:13:08 2021
[  7006.958] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  7006.958] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  7006.958] (==) No Layout section.  Using the first Screen section.
[  7006.958] (==) No screen section available. Using defaults.
[  7006.958] (**) |-->Screen "Default Screen Section" (0)
[  7006.958] (**) |   |-->Monitor "<default monitor>"
[  7006.958] (==) No monitor specified for screen "Default Screen Section".
[  7006.958] (==) Automatically adding devices
[  7006.958] (==) Automatically enabling devices
[  7006.958] (==) Automatically adding GPU devices
[  7006.958] (==) Automatically binding GPU devices
[  7006.958] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  7006.958] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  7006.958]    Entry deleted from font path.
[  7006.958] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  7006.958] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  7006.958] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  7006.958] (==) FontPath set to:
[  7006.958] (==) ModulePath set to "/usr/lib/xorg/modules"
[  7006.958] (II) The server relies on udev to provide the list of input devices.
cat /var/log/pacman.log:
[2021-11-04T08:51:58+0530] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -Sy xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau'
[2021-11-04T08:51:58+0530] [PACMAN] synchronizing package lists
[2021-11-04T08:51:59+0530] [ALPM] transaction started
[2021-11-04T08:51:59+0530] [ALPM] installed xf86-video-ati (1:19.1.0-2)
[2021-11-04T08:51:59+0530] [ALPM] installed xf86-video-amdgpu (21.0.0-1)
[2021-11-04T08:51:59+0530] [ALPM] installed libxvmc (1.0.12-3)
[2021-11-04T08:51:59+0530] [ALPM] installed xf86-video-intel (1:2.99.917+916+g31486f40-1)
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET] >>> This driver now uses DRI3 as the default Direct Rendering
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]     Infrastructure. You can try falling back to DRI2 if you run
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]     into trouble. To do so, save a file with the following
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]     content as /etc/X11/xorg.conf.d/20-intel.conf :
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]       Section "Device"
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]         Identifier  "Intel Graphics"
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]         Driver      "intel"
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]         Option      "DRI" "2"             # DRI3 is now default
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]         #Option      "AccelMethod"  "sna" # default
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]         #Option      "AccelMethod"  "uxa" # fallback
[2021-11-04T08:52:00+0530] [ALPM-SCRIPTLET]       EndSection
[2021-11-04T08:52:00+0530] [ALPM] installed xf86-video-nouveau (1.0.17-1)
[2021-11-04T08:52:00+0530] [ALPM] installed vulkan-intel (21.2.3-1)
[2021-11-04T08:52:00+0530] [ALPM] installed vulkan-radeon (21.2.3-1)
[2021-11-04T08:52:00+0530] [ALPM] installed mesa-vdpau (21.2.3-1)
[2021-11-04T08:52:00+0530] [ALPM] installed lib32-vulkan-intel (21.2.3-1)
[2021-11-04T08:52:00+0530] [ALPM] installed lib32-vulkan-radeon (21.2.3-1)
[2021-11-04T08:52:00+0530] [ALPM] installed lib32-mesa-vdpau (21.2.3-1)
[2021-11-04T08:52:21+0530] [ALPM] transaction completed
[2021-11-04T08:52:21+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T08:52:21+0530] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -D --asexplicit xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau'
[2021-11-04T08:54:12+0530] [PACMAN] Running 'pacman -Syy'
[2021-11-04T08:54:12+0530] [PACMAN] synchronizing package lists
[2021-11-04T08:54:17+0530] [PACMAN] Running 'pacman -R --noconfirm amd-ucode'
[2021-11-04T08:54:17+0530] [ALPM] transaction started
[2021-11-04T08:54:21+0530] [ALPM] removed amd-ucode (20210919.d526e04-1)
[2021-11-04T08:54:21+0530] [ALPM] transaction completed
[2021-11-04T08:54:21+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T09:09:07+0530] [PAMAC] synchronizing package lists
[2021-11-04T09:09:13+0530] [ALPM] running '00-timeshift-autosnap.hook'...
[2021-11-04T09:09:13+0530] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2021-11-04T09:09:13+0530] [ALPM] transaction started
[2021-11-04T09:09:13+0530] [ALPM] upgraded inxi (3.3.07.1-1 -> 3.3.08.1-1)
[2021-11-04T09:09:14+0530] [ALPM] transaction completed
[2021-11-04T09:09:14+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T09:13:07+0530] [PACMAN] Running 'pacman -Syyu'
[2021-11-04T09:13:07+0530] [PACMAN] synchronizing package lists
[2021-11-04T09:13:11+0530] [PACMAN] starting full system upgrade
[2021-11-04T09:14:57+0530] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux514'
[2021-11-04T09:15:11+0530] [ALPM] transaction started
[2021-11-04T09:15:11+0530] [ALPM] installed linux514 (5.14.10-1)
[2021-11-04T09:15:12+0530] [ALPM] transaction completed
[2021-11-04T09:15:12+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T09:15:12+0530] [ALPM] running '60-depmod.hook'...
[2021-11-04T09:15:19+0530] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-11-04T09:15:19+0530] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux514.preset: 'default'
[2021-11-04T09:15:19+0530] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.14-x86_64.img
[2021-11-04T09:15:20+0530] [ALPM-SCRIPTLET] ==> Starting build: 5.14.10-1-MANJARO
[2021-11-04T09:15:20+0530] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2021-11-04T09:15:20+0530] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-11-04T09:15:21+0530] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.14-x86_64.img
[2021-11-04T09:15:22+0530] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-11-04T09:15:22+0530] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux514.preset: 'fallback'
[2021-11-04T09:15:22+0530] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.14-x86_64-fallback.img -S autodetect
[2021-11-04T09:15:22+0530] [ALPM-SCRIPTLET] ==> Starting build: 5.14.10-1-MANJARO
[2021-11-04T09:15:22+0530] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2021-11-04T09:15:23+0530] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2021-11-04T09:15:23+0530] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2021-11-04T09:15:23+0530] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2021-11-04T09:15:26+0530] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2021-11-04T09:15:26+0530] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2021-11-04T09:15:26+0530] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2021-11-04T09:15:26+0530] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2021-11-04T09:15:26+0530] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2021-11-04T09:15:27+0530] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2021-11-04T09:15:29+0530] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-11-04T09:15:29+0530] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.14-x86_64-fallback.img
[2021-11-04T09:15:34+0530] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-11-04T09:15:34+0530] [ALPM] running '99-grub.hook'...
[2021-11-04T09:15:37+0530] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-11-04T09:15:40+0530] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2021-11-04T09:15:41+0530] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.14-x86_64
[2021-11-04T09:15:41+0530] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.14-x86_64.img
[2021-11-04T09:15:43+0530] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.14-x86_64-fallback.img
[2021-11-04T09:15:44+0530] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-11-04T09:15:44+0530] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-11-04T09:15:44+0530] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-11-04T09:15:44+0530] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-11-04T09:15:44+0530] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2021-11-04T09:15:46+0530] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-11-04T09:15:47+0530] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-11-04T09:15:48+0530] [ALPM-SCRIPTLET] done
[2021-11-04T09:45:45+0530] [PACMAN] Running 'pacman -S yay'
[2021-11-04T09:45:59+0530] [ALPM] transaction started
[2021-11-04T09:45:59+0530] [ALPM] installed yay (11.0.1-1)
[2021-11-04T09:45:59+0530] [ALPM] transaction completed
[2021-11-04T09:45:59+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T09:50:23+0530] [PACMAN] Running 'pacman -Syu'
[2021-11-04T09:50:23+0530] [PACMAN] synchronizing package lists
[2021-11-04T09:50:26+0530] [PACMAN] starting full system upgrade
[2021-11-04T09:55:59+0530] [PAMAC] synchronizing package lists
[2021-11-04T09:58:48+0530] [ALPM] transaction started
[2021-11-04T09:58:49+0530] [ALPM] installed brave-browser (1.30.87-1)
[2021-11-04T09:58:49+0530] [ALPM] transaction completed
[2021-11-04T09:58:49+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T09:58:49+0530] [ALPM] running 'update-desktop-database.hook'...
[2021-11-04T11:01:01+0530] [PACMAN] Running 'pacman -S neofetch'
[2021-11-04T11:01:07+0530] [ALPM] transaction started
[2021-11-04T11:01:07+0530] [ALPM] installed neofetch (7.1.0-2)
[2021-11-04T11:01:07+0530] [ALPM] transaction completed
[2021-11-04T11:01:07+0530] [ALPM] running '30-systemd-update.hook'...
[2021-11-04T13:09:03+0530] [PACMAN] Running 'pacman -Syu'
[2021-11-04T13:09:03+0530] [PACMAN] synchronizing package lists
Hi @anon30931146,
  1. Please see How to provide good information
    1.1. If applicable, please see [HowTo] post screenshots and links
  2. Does this happen if you suspend improperly?
No. It happens whenever I suspend using any method. I haven’t tried sudo systemctl suspend though.
:grin:
But see point 1 please:
Would you please mind telling me what to do? I’m relatively new and don’t know much about Linux at all. I switched to Manjaro after looking at the state Windows is in right now. Please go easy on me?
@anon30931146,
I have been going easy. None of us knows everything, so I pointed you to two carefully typed, very polite pages to provide those who are more ab;e to help, with the required information to do so. And I’ll give 'em again:
I’ll not b e able to help, I suspect, but that information would be necessary for anyone else to be able to help you.
Should I give the output of everything in https://forum.manjaro.org/t/how-to-provide-good-information/874/15?
That’s what the guide specified, is it not?
My bad. I’m kinda dumb, so it took a while to hit me.
Nonsense. Whoever told you that it talking pure rubbish.
Thanks. And I’ve also added the output of every single command here: https://forum.manjaro.org/t/how-to-provide-good-information/874
Never mind, I fixed it myself. Go to XFCE Power Manager > System > Change 'When laptop lid is closed' to Suspend. You can also do this for all the other settings.
