Wifi not available Qualcomm Atheros QCA6174 Kernel
I`m using a dual boot Samsung Galaxy Book 10.6 with the last version of Manjaro Gnome 21.2.2
It is a beautiful system! Thank you to the community to develop it!
I have a problem with Wifi Network Adapter.
Because I tried all of the recommendations from Manjaro Forum to Ubuntu Forum I guest the problem is the regulatory issue
ath: EEPROM regdomain: 0x5f
ath: EEPROM indicates we should expect a direct regpair map
ath: invalid regulatory domain/country code 0x5f
ath: Invalid EEPROM contents
I`m not a developer to path the Kernel or make a new firmware.
Is there an easy solution for this problem?
Thank you!
Current configuration
lspci
Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
uname -r
5.15.21-1-MANJARO
sudo dmesg|grep ath
[ 2.007150] systemd[1]: Reached target Path Units.
[ 2.022303] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 2.112549] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 3.368657] ath10k_pci 0000:01:00.0: enabling device (0000 → 0002)
[ 3.370750] ath10k_pci 0000:01:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 3.640458] ath10k_pci 0000:01:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 144d:c150
[ 3.640466] ath10k_pci 0000:01:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 3.641107] ath10k_pci 0000:01:00.0: firmware ver WLAN.RM.4.4.1-00157-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 90eebefb
[ 3.714729] ath10k_pci 0000:01:00.0: board_file api 2 bmi_id N/A crc32 706c395e
[ 3.810741] ath10k_pci 0000:01:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 3.892456] ath: EEPROM regdomain: 0x5f
[ 3.892461] ath: EEPROM indicates we should expect a direct regpair map
[ 3.892463] ath: invalid regulatory domain/country code 0x5f
[ 3.892464] ath: Invalid EEPROM contents
[ 3.892467] ath10k_pci 0000:01:00.0: failed to initialise regulatory: -22
[ 3.892471] ath10k_pci 0000:01:00.0: could not register to mac80211 (-22)
How to increase your chances of solving your issue:
Please provide Information:
