Dear all. I am facing a bit of a strange issue:
Wifi is sometimes not working when using a Manjaro notebook plugged-in an external screen (via USB-C/Thunderbolt3 that serves as well for supplying power).
For now I am unable to determine when exactly the issue is appearing, it often happens often when connecting a running notebook computer but disconnects as well after it has been connected for several hours. Once the computer is disconnected from the screen, it captures again Wifi signal.
Often (but not always) when the connection is cut Wifi indicator turns into a question mark.
MY system is an up-to-date Manjaro Gnome. My notebook computer is a Lenovo T480s, the screen is a Dell p2720dc. But the problem already appeared on the predecessor model (T470s) with the same screen. All firmware is up to date. The issue is not related to unavailable internet.
I am facing this issue already for several months. It took me some time to figure out that is not related to a bad internet connection at all. For the moment it is really a big annoyment.
May this be a driver issue?
Is there anyone out there with a guess or even a pathway for a solution?
Thanks in advance.
Kernel: 5.10.96-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bbcb79bf-b4e6-4ac4-b049-9c73365aa6c4 rw quiet splash apparmor=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 20L7001SGE v: ThinkPad T480s
Mobo: LENOVO model: 20L7001SGE v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N22ET72W (1.49 )
date: 11/17/2021
ID-1: BAT0 charge: 49.7 Wh (100.0%) condition: 49.7/57.0 Wh (87.1%)
volts: 12.8 min: 11.6 model: LGC 01AV478 type: Li-poly serial: <filter>
status: Full cycles: 118
Device-1: hid-0003:17EF:60EE.0007-battery
model: Lenovo TrackPoint Keyboard II serial: N/A charge: N/A status: N/A
RAM: total: 15.4 GiB used: 14.05 GiB (91.2%)
RAM Report:
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1243 high: 2708 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2708 2: 1734 3: 1101
4: 800 5: 800 6: 800 7: 802 8: 1200 bogomips: 28808
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:8 chip-ID: 5986:2113 class-ID: 0e02
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.96-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 3d:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
IF-ID-1: wwp0s20f0u6 state: down mac: <filter>
Local Storage: total: 2.75 TiB used: 1.27 TiB (46.3%)
model: PC SN730 SDBPNTY-1T00-1101 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170001 temp: 39.9 C scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: JMicron Tech model: Generic
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0208
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 52.36 GiB (53.5%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: bbcb79bf-b4e6-4ac4-b049-9c73365aa6c4
used: 2.5 MiB (0.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: B480-72A9
ID-3: /home raw-size: 350 GiB size: 343.44 GiB (98.13%)
used: 312.45 GiB (91.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 698c1dac-9ef8-4ac2-b3b1-6b3d863cefc3
ID-4: /run/media/ralph/SSD MySilverMini raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 761.18 GiB (40.9%) fs: ntfs dev: /dev/sdb
maj-min: 8:16 label: SSD MySilverMini uuid: 261D7BA34B9CE6F0
ID-5: /run/timeshift/backup raw-size: 323.73 GiB size: 317.58 GiB (98.10%)
used: 171.18 GiB (53.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 9f5b2e88-a28a-4ab5-91a7-3288555b3e43
ID-1: swap-1 type: partition size: 23.39 GiB used: 8.11 GiB (34.7%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 67c1d045-a522-475c-8e7e-79cb42566d39
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 156.25 GiB fs: ntfs label: N/A
uuid: 4BEE2B5E0F28C7EC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Hub-2: 1-4:18 info: Dell ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 413c:8442 class-ID: 0900
Device-1: 1-4.1:19 info: Lenovo TrackPoint Keyboard II
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 17ef:60ee class-ID: 0300
Device-2: 1-4.2:21 info: Xiaomi Mi Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 2717:5013 class-ID: 0301
Device-3: 1-4.3:22
info: JMicron / JMicron USA JMS583Gen 2 to PCIe Gen3x2 Bridge
type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 152d:0583 class-ID: 0806 serial: <filter>
Device-4: 1-4.5:25 info: Texas Instruments type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0451:82ff class-ID: 0300
Device-5: 1-6:27 info: Fibocom L830-EB-00 LTE WWAN Modem
type: Communication,CDC-Data,Abstract (modem) driver: cdc_acm,cdc_mbim
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 2cb7:0210
class-ID: 0a00 serial: <filter>
Device-6: 1-8:8 info: Acer SunplusIT Integrated Camera type: Video
Device-7: 1-9:26 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
Hub-4: 2-4:4 info: Dell ports: 2 rev: 3.2 speed: 5 Gb/s chip-ID: 413c:8440
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.0 C pch: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 432 Uptime: 21h 48m wakeups: 48200 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1470
pacman: 1389 lib: 355 flatpak: 60 snap: 21 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.12
