Fresh Manjaro downloaded yesterday installed on a desktop without builtin wifi adapter. Two wifi dongles at hand.
Dongle 1: inxi gives me “Realtek 802.11ac NIC” with chip-ID=0bda:c811, but the wifi setting page remains “No Wi-Fi Adapter Found”. But this dongle works on Ubuntu out of the box, without rtl8821cu or any such random drivers.
Dongle 2: it works for like 30s, during which I could connect to a network and open Firefox, but suddenly the system halts and responds to absolutely nothing. Caplock/numlock indicator on the keyboard doesn’t respond. The magic REISUB no longer works either. Again, the dongle works on Ubuntu without problem.
Any help on either dongle is appreciated.
Developers might be interested in the second one, cuz it seems to me an indicator of a serious bug deep down, in which case I’d like to help the debugging.
Manjaro: 22.0, kernel=6.1.1-1
Ubuntu for comparison: 21.10, kernel=5.13.0-52
(I recommend installing the`dkms1one, as that will be rebuilt on kernel updates, where the other ones wouldn’t.
So you can install it with:
pamac buid rtl8821cu-dkms-git
And reboot. If everything worked according to plan, your wireless should now work.
If, however, it doesn’t reply to this thread and provide the info according to:
also, then provide the output of:
lsmod
Hope this helps!
Edit:
Regarding:
All I can say is
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Thanks for the help, but it seems that brektrou/rtl8821CU is incompatible with the latest kernel.
Is there any way to see in Ubuntu which driver is in use for the dongle? I think it should not be this rtl8821CU, as lsmod shows nothing matching *8821*.
