I just installed Manjaro for my Dell XPS 15 Laptop but I noticed the boot process was slow, I found the fix mhwd-kernel -li and then sudo mhwd-kernel -i linux54 rmc
but when I restarted my pc wifi and bluetooth doesnt work. The network is connected to ethernet by default. How can I fix this?
Provide output of inxi -Fazy
Kernel: 5.4.257-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=5fb79814-3d82-41ad-9f16-1b68f5e3ecc5 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Dell product: XPS 15 9500 v: N/A
Mobo: Dell model: 0XWT2F v: A02 serial: <superuser required> UEFI: Dell
v: 1.22.0 date: 03/16/2023
ID-1: BAT0 charge: 74.0 Wh (87.8%) condition: 84.3/84.3 Wh (100.0%)
volts: 12.8 min: 11.4 model: SMP DELL 70N2F95 type: Li-poly serial: <filter>
status: charging
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3328 high: 3599 min/max: 800/5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3469 2: 3364 3: 3393
4: 3035 5: 3599 6: 3571 7: 3541 8: 3553 9: 3019 10: 3240 11: 3244 12: 3544
13: 2717 14: 3539 15: 2921 16: 3514 bogomips: 76816
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell
driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:3 chip-ID: 0bda:5510
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: Sharp 0x14d0 built: 2020 res: 3840x2400 dpi: 290
gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
modes: 3840x2400
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6 vendor: intel mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
es-v: 3.2 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 30.38 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: nvidia v: 535.129.03 device-ID: 10de:1f95
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
(CML GT2) driver: mesa intel v: 23.1.9-manjaro1.1 device-ID: 8086:9bc4
surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0403
API: ALSA v: k5.4.257-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Qualcomm QCA6390 Wireless Network Adapter vendor: Rivet Networks
driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max: gen: 3
speed: 8 GT/s bus-ID: 6c:00.0 chip-ID: 17cb:1101 class-ID: 0280
Local Storage: total: 476.94 GiB used: 9.43 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC601 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 80002111 scheme: GPT
ID-1: / raw-size: 282.42 GiB size: 276.92 GiB (98.05%) used: 9.43 GiB (3.4%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 300 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 348 Uptime: 9m wakeups: 616 Memory: total: 32 GiB note: est.
available: 31.11 GiB used: 1.68 GiB (5.4%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1122 libs: 317 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
The above is the output I get when I run the command inxi -Fazy
Provide output for
lsmod | grep 'ath11k'
sudo dmesg | grep 'ath11k'
Do i run the above command in the terminal or do I provide the output?
Run each of two commands and provide outputs for both
I just tried the two command. it did not give any output
Ok. Try this one
sudo modprobe ath11k_pci
If you won’t see any output check if wifi could be enabled
I got the output below:
modprobe: FATAL: Module ath11k_pci not found in directory /lib/modules/5.4.257-1-MANJARO
Interesting. Module ath11k_pci
was supposed to be build-in since kernel 5.1.
Try newer LTS kernel, 5.15 or 6.1. Your laptop has a pretty new hardware, no need to use kernel 5.4
Okay, I will try that. I should restart after installing right?
Yes, you should
I have installed kernel 6.5.1 and restarted my pc. So the wifi and Bluetooth are enabled back. But the boot process is slow and it takes time.
It takes time before it Dell icon load and show password screen , how can I fix this?
Provide output for systemd-analyze
Startup finished in 5.154s (firmware) + 2.940s (loader) + 2.406s (kernel) + 8.069s (userspace) = 18.569s
graphical.target reached after 8.068s in userspace.
This is the output
18 seconds is too long for you?
Let me restart it and see.
The behavior seems somehow
I just restarted it and the screen is all black. Something seems to be a miss, can’t just say what exactly.
If I may , what do you think the command below does:
sudo pacman -Syyu haveged
sudo systemctl enable haveged --now
I saw it as a fix to the boot issue: Manjaro hangs on Dell logo during boot - #19 by Aragorn
That was just a suggestion not a fix cause it didn’t work.
Those commands install and start haveged
service. But I believe it’s already installed and running on you system. Check
systemctl status haveged
