○ haveged.service - Entropy Daemon based on the HAVEGE algorithm
Loaded: loaded (/usr/lib/systemd/system/haveged.service; enabled; preset: disabled)
Active: inactive (dead)
Condition: start condition unmet at Wed 2023-11-01 15:17:20 WAT; 22min ago
└─ ConditionKernelVersion=<5.6 was not met
Docs: man:haveged(8)
http://www.issihosts.com/haveged/
Nov 01 15:17:20 codewhizperer-xps159500 systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped >
lines 1-10/10 (END)
So it’s installed but not running. sudo systemctl start haveged to start it during the current session sudo systemctl enable haveged --now to start it automatically at boot
Btw, that service starts if ConditionKernelVersion=<5.6
If kernel 5.4 booted normally then you might need haveged after all. Just edit /usr/lib/systemd/system/haveged.service so ConditionKernelVersion=>5.6
This video is absolutely not helpful. We need to see what’s going on under the hood, not look at the black screen. The working hypothesis right now is that the problem is a lack of entropy.
Provide output of systemctl status haveged once again
condition: start condition unmet at Wed 2023-11-01 20:12:32 WAT; 3min 46s ago
L ConditionkernelVersion=<5.6 was not met
Nov 01 20:12:29 codewhizperer-xps159500 systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped
Nov 01 20:12:30 codewhizperer-xps159500 systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped
Nov 01 20:12:32 codewhizperer-xps159500 systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped
lines 1-11/11 (END
systemctl status haveged ✔
● haveged.service - Entropy Daemon based on the HAVEGE algorithm
Active: active (running) since Wed 2023-11-01 20:36:20 WAT; 4min 8s ago
Main PID: 356 (haveged)
Tasks: 1 (limit: 38177)
Memory: 6.6M
CPU: 191ms
CGroup: /system.slice/haveged.service
└─356 /usr/bin/haveged -w 1024 -v 1 --Foreground -v 64
Nov 01 20:36:20 codewhizperer-xps159500 haveged[356]: haveged: command socket is listening at fd 3
Nov 01 20:36:20 codewhizperer-xps159500 haveged[356]: haveged: fills: 1, generated: 512 K bytes, RNDADDENTROP>
Notice: journal has been rotated since unit was started, output may be incomplete.
Please do you know the Kernel version that works well with Dell XPS 15, all kernel version works but the boot process is slow and sometimes it shows a black screen while booting. Kernel version 5.4.0 works perfectly well but wifi and Bluetooth do not work. what can I do, please?
