I have to manually disconnect and reconnect my wifi whenever this happens, and it will briefly continue downloading before losing connection again. My signal strength is somewhat mediocre, but I have no problems browsing the internet. Usually, only when loading pages can I experience a connection issue; otherwise, it’s somewhat normal. I’m new to Manjaro, and solutions stated as simply as possible are preferred.
Sounds like Real Time throttling. While downloading the files are there other applications/services using bandwith?
TBH there can be a myriad of reasons why this is happening so why don’t you go ahead and give us some specs in terms of hardware, connection speed etc.? Which wireless driver are you using?
Maybe this will help you get started.
Hi @XXYYXX ,
Welcome to the forum, I wonder whether you could read this post to gave us some useful information in order to solve your problem.
‘[HowTo] Provide System Information’
Regards
root=UUID=e746704a-966f-42d6-b82a-514406a901fa rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A115-32 v: V1.12
serial: <superuser required>
Mobo: JSL model: Camellia_JL v: V1.12 serial: <superuser required>
UEFI: Insyde v: 1.12 date: 09/15/2021
ID-1: BAT1 charge: 25.6 Wh (62.6%) condition: 40.9/41.6 Wh (98.3%)
volts: 11.6 min: 11.2 model: LGC AP19B8K type: Li-ion serial: <filter>
status: discharging
RAM: total: 3.64 GiB used: 1.88 GiB (51.8%)
Info: model: Intel Celeron N4500 bits: 64 type: MCP arch: Alder Lake
level: v2 built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0x9C (156) stepping: 0 microcode: 0x24000024
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1100 min/max: 800/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 1100 2: 1100 bogomips: 4456
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt clwb cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri
msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep
sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vme vmx vnmi vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel JasperLake [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:4e55
class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 04f2:b72b class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics (JSL)
direct-render: Yes
Device-1: Intel Jasper Lake HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:4dc8 class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
IP v6: <filter> type: dynamic mngtmpaddr scope: global
IP v6: <filter> scope: link
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-8:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 116.58 GiB used: 29.03 GiB (24.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: X29128
size: 116.58 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-1: / raw-size: 116.28 GiB size: 113.9 GiB (97.95%) used: 29.03 GiB (25.5%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
uuid: e746704a-966f-42d6-b82a-514406a901fa
used: 312 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1 label: N/A
uuid: 9F01-00EC
ID-1: /dev/mmcblk0boot0 maj-min: 179:8 size: 4 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/mmcblk0boot1 maj-min: 179:16 size: 4 MiB
fs: <superuser required> label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 8 rev: 2.0
Device-1: 1-6:2 info: Chicony HD User Facing type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b72b
Device-2: 1-8:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 180 Uptime: 4m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1141
pm: pacman pkgs: 1129 libs: 326 tools: pamac pm: flatpak pkgs: 12 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26```
What next? did i provide everything correctly?
To fix this issue, you can try various troubleshooting steps like resetting your Wi-Fi router, updating your network drivers, checking your router/modem settings, and reducing network congestion by disconnecting unused devices from the network. If the problem persists, you can contact to call center telephony solutions of your internet service provider or a qualified technician to resolve the issue.
Hi @XXYYXX ,
Maybe you can try to enable manually with this terminal command:
nmcli networking on
sudo modprobe iwlwifi
and check if you have this module blacklisted in /etc/modprobe.d/ or /usr/lib/modprobe.d/.
I found these solutions in the following post:
‘Manjaro Not Recognizing Intel Wi-Fi 6 AX201 - #7 by bugger2’
Please, post the output from the terminal:
sudo dmesg | grep iwlwifi
sudo rfkill list
Regards,
pported by driver
[ 8.367824] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Versio
n: 89.3.35.37
[ 8.368370] iwlwifi 0000:00:14.3: loaded firmware version 72.daa05
125.0 QuZ-a0-jf-b0-72.ucode op_mode iwlmvm
[ 8.991955] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 95
60 160MHz, REV=0x351
[ 9.314096] iwlwifi 0000:00:14.3: Detected RF JF, rfid=0x105110
[ 9.373462] iwlwifi 0000:00:14.3: base HW address: 5c:e4:2a:1c:7e:
92
[ 9.402305] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[15678.447956] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
:cf:e2:83:ca:70 on queue 2, stopping BA session on TID 0
[15697.354660] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[15718.774781] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[15786.944121] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[15788.006308] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[15813.396612] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
:cf:e2:83:ca:70 on queue 1, stopping BA session on TID 0
[15890.948795] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[15981.388556] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[16263.869853] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[21973.434863] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22020.998522] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22040.766574] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22120.793461] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22216.695347] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22252.755692] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22281.104065] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22364.586805] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22395.064184] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22526.695869] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22532.597974] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22532.598066] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22538.916247] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22538.916283] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22542.281934] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22542.281980] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22605.592534] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22850.768572] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22851.305990] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22858.785952] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22859.559368] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22866.789060] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[22977.954577] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23050.350826] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23174.259585] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23292.736850] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23323.178056] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23339.393873] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23344.146797] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23536.070308] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23540.149464] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23771.290956] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23856.810580] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23859.941586] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[23960.540256] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24498.223262] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24513.722029] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24535.021950] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24733.935952] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24750.225816] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24850.850833] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[24878.966053] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25108.979955] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25249.209904] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25260.785699] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25263.851493] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25369.536259] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25377.052555] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25387.494976] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25540.884598] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25653.926158] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25662.708144] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25665.333513] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25668.479573] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[25672.293521] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[27559.568347] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[27598.354671] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[27603.045200] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[27611.509491] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.513057] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.513671] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.513909] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.517834] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.518235] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.518664] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.519299] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.519709] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[27611.520137] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[29517.995318] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
:cf:e2:83:ca:75 on queue 1, stopping BA session on TID 0
[29525.268013] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[32560.633583] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[32589.813421] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
:cf:e2:83:ca:75 on queue 2, stopping BA session on TID 0
[32590.471983] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[34961.447228] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[34989.338179] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.338384] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.338639] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.338873] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.339135] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.339626] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.481537] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.481564] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.481572] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[34989.481577] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[46906.563162] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[50504.931770] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
[50568.779909] iwlwifi 0000:00:14.3: reached 20 old SN frames from 14
:cf:e2:83:ca:75 on queue 2, stopping BA session on TID 0```
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
4: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no```
Hi @XXYYXX ,
I could suggest you to verify that you have installed the latest linux-firmware on your machine.
sudo pacman -Qi linux-firmware
Another command you could run to unblock the bluethooth is the following, perhaps this could solve the problem.
sudo rfkill unblock all
Regards
