Updated system via pacman, all ok; but when I updated AUR and flatpaks it failed to compile electron24 and an audio related AUR package
(brightness-controller-git and opera did compile sucessfuly), flatpaks were updated.
When I rebooted the system even tho showing it was connected to the internet, I could not acess it with any program.
Rolled back with Timeshift, proceed to update via pacman again, then flatpaks but skipped AUR for now!
I just deleted “electron24” from AUR because there are no dependencies. It’s probably left over from the old packages. Maybe you have the same thing.
electron24 and lib32-faudio were the AUR packages that failed to compile, brightness-controller-git and opera were compiled with sucess, I think it was electron24 failure to compile (something related to non existent landmines.py file I think)
that borked my system, do I really need them? I can just ignore them to update tho, it’s easy on pamac (I just use it to update AUR and flatpaks).
There was another thread here today with a very similar topic (electron 24).
If you need it, you can likely just use the binary version electron24-bin, which is also in the AUR, which would save you the compiling.
Only you will know. You’re the one who installed them, and they are AUR packages, which means that a stock Manjaro installation has no need for them.
Either way, electron24 has been broken for a while already, judging by the comments on its AUR page, while the maintainer doesn’t appear to be interested in fixing his PKGBUILD. So I’d remove it if I were you.
But that’s the thing, the only AUR package that I installed was brightness-controller-git nothing else, even opera I had it from the manjaro repo and now appears from AUR.
Someone suggested me to install electron24-bin to substitute electron24 but what about lib32-faudio ?
Ok, thank you very much for the advice Aragorn !!!
Thanks to Timeshift it was easy to revert the borked system and everything is working correctly now!
