Webcam logitech 720p stopped working
Hello, my webcam no longer works in Manjaro. I couldn’t tell which update caused it. It is a logitech webcam (Logitech C270 HD Webcam, 720p Video with Noise Reducing Mic).
When I run: dmesg | tail, I get this result, but I don’t know how to interpret it :
[ 4545.735246] uvcvideo: Found UVC 1.00 device <unnamed> (046d:080c)
[ 4545.784645] input: UVC Camera (046d:080c) as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/input/input19
[ 4551.868905] usb 1-2: reset high-speed USB device number 13 using xhci_hcd
[ 4556.047246] audit: type=1334 audit(1635322113.102:352): prog-id=70 op=LOAD
[ 4556.137704] audit: type=1130 audit(1635322113.192:353): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4560.622883] audit: type=1100 audit(1635322117.678:354): pid=62020 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=? acct="kapu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=failed'
[ 4568.879676] audit: type=1100 audit(1635322125.935:355): pid=62020 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="kapu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 4568.881026] audit: type=1101 audit(1635322125.935:356): pid=62020 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="kapu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 4568.882239] audit: type=1110 audit(1635322125.938:357): pid=62020 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 4568.885131] audit: type=1105 audit(1635322125.938:358): pid=62020 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Edit : my kernel is 5.10.70-1 LTS.
The light on my webcam lights up.
I tried with different video conferencing software and Cheese too (I use GNOME), without success.
Thank you for your help !
Hi @Kapu, @thorsten79!
  1. Please see How to provide good information
    1.1. If applicable, please see [HowTo] post screenshots and links
  2. Have you tried with ab older kernel? Version 5.4 is an LTS version.
Ok, thank you for the links.
Here are my specs :
  Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=090bee44-8c2b-46ea-a8c7-3816bf6b2b41 ro quiet splash apparmor=1
  Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0 serial: <filter>
  Chassis: type: 9 v: Mac-937CB26E2E02BB01 serial: <filter>
  Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2 serial: <filter>
  UEFI: Apple v: 193.0.0.0.0 date: 02/05/2020
  ID-1: BAT0 charge: 42.9 Wh (87.2%) condition: 49.2/54.3 Wh (90.5%)
  volts: 8.1 min: 7.6 model: DP bq20z451 type: Li-ion serial: N/A
  status: Discharging cycles: 949
  RAM: total: 7.67 GiB used: 4.27 GiB (55.6%)
  Info: Dual Core model: Intel Core i7-5650U bits: 64 type: MT MCP
  arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache:
  L2: 4 MiB bogomips: 17604
  Speed: 2201 MHz min/max: 500/3200 MHz Core speeds (MHz): 1: 2201 2: 2200
  3: 2203 4: 2198
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx
  avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
  ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
  fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
  pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
  pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse
  sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:1626 class-ID: 0300
  Device-2: Logitech type: USB driver: uvcvideo bus-ID: 1-2:7
  chip-ID: 046d:080c class-ID: 0e02
  Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4")
  s-diag: 449mm (17.7")
  Monitor-1: XWAYLAND0 res: 1440x900 hz: 60 dpi: 126
  size: 290x180mm (11.4x7.1") diag: 341mm (13.4")
  OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3) v: 4.6 Mesa 21.2.3
  direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
  v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel
  v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  Device-3: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 02:00.0
  chip-ID: 14e4:1570 class-ID: 0480
  Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
  driver: wl v: kernel modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:43a0
  class-ID: 0280
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
  bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 465.92 GiB used: 252.01 GiB (54.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512G
  size: 465.92 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 3A0Q scheme: GPT
  ID-1: / raw-size: 412.48 GiB size: 405 GiB (98.19%) used: 251.98 GiB (62.2%)
  fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 090bee44-8c2b-46ea-a8c7-3816bf6b2b41
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
  used: 27.5 MiB (14.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
  uuid: 67E3-17ED
  ID-1: swap-1 type: partition size: 16 GiB used: 256 KiB (0.0%) priority: -2
  dev: /dev/sda4 maj-min: 8:4 label: N/A
  uuid: 9816dde6-827b-4440-9a96-e28c2aba1c9f
  ID-1: /dev/sda2 maj-min: 8:2 size: 37.25 GiB fs: apfs label: N/A
  uuid: ccb065b9-ebbd-4c50-a2c6-cd493edfaba3
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
  Device-1: 1-2:7 info: Logitech type: Video driver: uvcvideo interfaces: 2
  rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 046d:080c class-ID: 0e02
  Hub-2: 1-3:2
  info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
  rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 1-3.3:6 info: Apple Bluetooth USB Host Controller type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:828f
  class-ID: fe01
  Device-2: 1-5:3 info: Apple Apple Internal Keyboard / Trackpad
  type: HID,Keyboard,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 05ac:0291 class-ID: 0301
  serial: <filter>
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 256 Uptime: 2d 17h 46m wakeups: 4 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1764 apt: 0 pacman: 1748
  lib: 449 flatpak: 9 snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal
  inxi: 3.3.08
Here is what my dsmeg|tail (with sudo) gives :
[ 8271.394132] USB Video Class driver (1.1.1)
[ 8279.655216] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:fb:00:04:74:23:0c:de:08:00 SRC=192.168.1.10 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=44037 PROTO=2
[ 8310.433913] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:08:87:c6:41:00:00:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x80 TTL=1 ID=0 DF PROTO=2
[ 8318.080018] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:fb:00:04:74:23:0c:de:08:00 SRC=192.168.1.10 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=44040 PROTO=2
[ 8342.739112] audit: type=1334 audit(1635928355.939:278): prog-id=46 op=LOAD
[ 8342.859658] audit: type=1130 audit(1635928356.059:279): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8348.626442] audit: type=1100 audit(1635928361.826:280): pid=18043 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="kapu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 8348.629818] audit: type=1101 audit(1635928361.829:281): pid=18043 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="kapu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 8348.630103] audit: type=1110 audit(1635928361.829:282): pid=18043 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 8348.633750] audit: type=1105 audit(1635928361.836:283): pid=18043 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Here is my consol when I launch Cheese through it :
(cheese:18842): cheese-WARNING **: 09:35:44.124: Internal data stream error.: ../gstreamer/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin35/GstPipeWireSrc:pipewiresrc1:
streaming stopped, reason not-negotiated (-4)
Could it be from a pipewire update ? I use Wayland with Gnome.
[edit] : I didn’t try yet to downgrade my kernel. If it comes from Wayland, wouldn’t be a better (safer) use just to switch to X ? (if the problem really comes from it).
Hi, so I tried to launch Gnome with Xorg, but it didn’t change my problem.
I rolled back to the 5.1.159-1 kernel but it didn’t change either, I put down my outputs :
inxi --admin --verbosity=7 --filter --width
gives :
  Kernel: 5.4.159-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
  serial: <superuser required> Chassis: type: 9 v: Mac-937CB26E2E02BB01
  serial: <superuser required> UEFI: Apple v: 193.0.0.0.0 date: 02/05/2020
  ID-1: BAT0 charge: 32.7 Wh (72.0%) condition: 45.4/54.3 Wh (83.5%)
  volts: 7.8 min: 7.6 model: DP bq20z451 type: Li-ion serial: N/A
  status: Discharging cycles: 978
  RAM: total: 7.68 GiB used: 3.4 GiB (44.2%)
  L1: 128 KiB L2: 512 KiB L3: 4 MiB bogomips: 17604
  Speed: 1267 MHz min/max: 500/3200 MHz Core speeds (MHz): 1: 1253 2: 868
  3: 812 4: 818
  Type: l1tf
  Display: wayland server: X.Org 1.21.1.3 compositor: gnome-shell driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Sound Server-1: ALSA v: k5.4.159-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  class-ID: 0280
  IP v6: <filter> virtual: stable-privacy scope: link
  Local Storage: total: 465.92 GiB used: 253.11 GiB (54.3%)
  ID-1: / raw-size: 412.48 GiB size: 405 GiB (98.19%) used: 253.08 GiB (62.5%)
  uuid: 67E3-17ED
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
  Hub-2: 1-3:2
  class-ID: fe01
  serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-3:2 info: Apple Internal Memory Card Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
  chip-ID: 05ac:8406 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 61.0 C pch: 55.5 C mobo: N/A
  Processes: 271 Uptime: 3m wakeups: 2 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1774 apt: 0 pacman: 1758 lib: 452
  flatpak: 9 snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.09
Where could I find more help about hits ? Visioconference are really needed nowadays ^^
EDIT :
  • I re installed the 5.10 LTS kernel, nothing changed.
  • Something is odd from the beginning, the LED on my webcam is always on, as soon as I plug the webcam, whereas before this problem, the LED was on only when the visio started.
Anyone ? How could I get more help about that ? Is there any chance that I could solve it by buying an other webcam ? (I can’t afford me to buy a new webcam that might not work)
Trying an UP for this post ^^
Well, dude.
According to this page:
If my search wasn’t right, please excuse me and provide the correct one, someone who knows better.
Your info also states that it is using the logitec driver already:
So it seems everything is in order. So all I can recommend you do is use it/try to set it up. For than you can use solaar. And it’s in the community repository:
$ pamac search solaar
solaar        1.1.0-1                 community
Linux device manager for a wide range of Logitech devices
So it can be easily installed with pamac:
pamac install solaar
I have no idea if this’ll work or not. And I also have no experience with webcams, or any camera for that matter. So the info given here is purely theoretical and it’s quite possible that it’s wrong. And that is why I didn’t answer earlier.
P.S.:
As much as I understand why you did it, bumping a topic is against the rules.
Edit:
Just saw this, :point_up_2: and it might, I have no idea. Try disabling pipewire:
sudo systemctl disable --now pipewire
I also don’t know if this’ll work, as in addition to not having any experience with any camera, I also don’t have any experience with sound.
Ok, thank you, I’ll try it later. I borrowed an other logitech webcam from a friend logitech and it worked with no problem. It’s not the same model. It’s very confusing for me.
It’s 2 different models, so 2 different drivers required. I’m guessing your friends is newer?
