Vulkan not supported on lutris
Hi, i am gunit, trying and trying to get epic-games working
from lutris site i got epic games launcher script and then message came
Vulkan is not available or your system isn’t Vulkan capable
I am using amd apu processor neofetch tells this AMD ATI Radeon R2/R3/R4/R5 Graphics
as my gpu
i also followed this topic
https://bbs.archlinux.org/viewtopic.php?id=265351
according to this i need to run VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.i686.json:/usr/share/vulkan/icd.d/radeon_icd.x86_64.json lutris
Error: couldn’t find RGB GLX visual or fbconfig
2021-11-16 15:09:52,152: Invalid glxinfo received
2021-11-16 15:09:52,407: Starting Lutris 0.5.9.1
2021-11-16 15:09:52,457: No cores found
2021-11-16 15:09:56,554: Startup complete
2021-11-16 15:09:56,556: glxinfo is not available on your system, unable to detect driver version
2021-11-16 15:09:56,556: GPU: 1002:98E4 17AA:39F3 (amdgpu drivers)
2021-11-16 15:09:56,560: Vulkan is not available or your system isn’t Vulkan capable
2021-11-16 15:10:02,192: Unable to load libGLX_nvidia.so.0
2021-11-16 15:10:02,193: Unable to locate libGLX_nvidia
i tried to install dxvk from winetricks in lutris but nothing works
It also says 2021-11-16 15:14:54,826: The game doesn't have an executable
but checking lutris config it has one
it also tells me to refer
but what to do i dont understand as i have done
sudo pacman -S --needed lib32-mesa vulkan-radeon lib32-vulkan-radeon vulkan-icd-loader lib32-vulkan-icd-loader
I dont even have nvidia libs and nvidia-utils
i previously approx a year ago i installed it and it worked fine even games were working without error and after that i did a reinstall
plz help me fix this problem
i installed vulkan runtime from winetricks and here is non ending error when running epicgames.exe
info:  OpenVR: could not open registry key, status 2
info:  OpenVR: Failed to locate module
info:  Game: EpicGamesLauncher.exe
info:  DXVK: v1.9.2
info:  Built-in extension providers:
info:    Win32 WSI
info:    OpenVR
info:    OpenXR
info:  DXVK: v1.9.2
info:    Win32 WSI
info:    OpenVR
info:    OpenXR
info:  DXVK: v1.9.2
info:    Win32 WSI
info:    OpenVR
info:    OpenXR
it is never ending error
running lutris give this
Error: couldn't find RGB GLX visual or fbconfig
2021-11-16 16:21:22,876: Invalid glxinfo received
2021-11-16 16:21:23,250: Starting Lutris 0.5.9.1
2021-11-16 16:21:23,347: No cores found
2021-11-16 16:21:28,411: Failed to read content length on response from https://api.github.com/repos/lutris/dxvk/releases
2021-11-16 16:21:29,871: Failed to read content length on response from https://api.github.com/repos/lutris/dxvk-nvapi/releases
2021-11-16 16:21:31,027: Failed to read content length on response from https://api.github.com/repos/lutris/vkd3d/releases
2021-11-16 16:21:51,282: Failed to get url https://api.github.com/repos/lutris/d3d_extras/releases: Unable to connect to server https://api.github.com/repos/lutris/d3d_extras/releases: <urlopen error [Errno -2] Name or service not known>
2021-11-16 16:21:51,283: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:51,284: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:51,285: Startup complete
2021-11-16 16:21:51,288: glxinfo is not available on your system, unable to detect driver version
2021-11-16 16:21:51,289: GPU: 1002:98E4 17AA:39F3 (amdgpu drivers)
2021-11-16 16:21:51,324: Vulkan is not available or your system isn't Vulkan capable
2021-11-16 16:21:52,677: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,678: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,685: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,686: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,693: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,694: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,706: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,750: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,751: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,761: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,762: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,770: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,771: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:52,780: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,194: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,201: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,202: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,210: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,219: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,220: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,377: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,380: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,382: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,397: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,398: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,406: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,418: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,419: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,425: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,426: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,433: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,434: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,456: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,457: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,583: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:56,584: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:21:57,392: Unable to load libGLX_nvidia.so.0
2021-11-16 16:21:57,393: Unable to locate libGLX_nvidia
2021-11-16 16:22:05,402: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:22:05,403: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:22:05,425: Loading of D3D Extras versions failed, defaulting to locally available versions
2021-11-16 16:22:07,113: Shutting down Lutris
vulkaninfo gives
ERROR: [Loader Message] Code 0 : libLLVM-13.so: cannot open shared object file: No such file or directory
Cannot create Vulkan instance.
This problem is often caused by a faulty installation of the Vulkan driver or attempting to use a GPU that does not support Vulkan.
ERROR at /build/vulkan-tools/src/Vulkan-Tools-1.2.194/vulkaninfo/vulkaninfo.h:687:vkCreateInstance failed with ERROR_INCOMPATIBLE_DRIVER
Provide your system information How to provide good information
inxi --admin --verbosity=7 --filter --width
  Kernel: 5.10.78-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
  root=UUID=26a8c1a1-9aa2-4739-9e21-7cdc5405f6e4 rw quiet loglevel=3 audit=0
  Desktop: herbstluftwm 0.9.3 info: polybar vt: 7 dm: LightDM 1.30.0
  Distro:Manjaro base: Manjaro
  Type: Laptop System: LENOVO product: 81D6 v: Lenovo ideapad 330-15AST
  serial: <filter> Chassis: type: 10 v: Lenovo ideapad 330-15AST
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724WIN serial: <filter>
  UEFI: LENOVO v: 8UCN19WW date: 05/14/2021
  ID-1: BAT0 charge: 26.5 Wh (94.6%) condition: 28.0/30.6 Wh (91.4%)
  volts: 8.4 min: 7.6 model: CPT-COS L16C2PB2 type: Li-poly serial: <filter>
  status: Unknown
  RAM: total: 6.67 GiB used: 1.76 GiB (26.4%)
  Info: Dual Core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
  type: MCP arch: Excavator family: 15 (21) model-id: 70 (112) stepping: 0
  microcode: 6006705 cache: L2: 1024 KiB bogomips: 10399
  Speed: 2631 MHz min/max: 1300/2600 MHz boost: enabled Core speeds (MHz):
  1: 4000 2: 4000
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
  bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
  cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4 fpu
  fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca mce
  misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse pse36 ptsc
  rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
  svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
  vmmcall wdt xop xsave xsaveopt
  disabled, RSB filling
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
  driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
  Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:5
  chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.21.1.1 compositor: picom v: git-dac85 driver:
  loaded: modesetting display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: N/A v: N/A direct render: N/A
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1
  chip-ID: 1002:15b3 class-ID: 0403
  Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
  Sound Server-1: ALSA v: k5.10.78-1-lts running: yes
  Sound Server-4: PipeWire v: 0.3.39 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000
  bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
  driver: r8169 v: kernel port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-1.2:4 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
  Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 3 state: down
  bt-service: disabled rfk-block: hardware: no software: yes address: N/A
  Local Storage: total: 931.51 GiB used: 119.22 GiB (12.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  type: HDD rpm: 5400 serial: <filter> rev: LCM2 temp: 40 C scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE0N rev: T.02
  dev-links: cdrom
  ID-1: / raw-size: 315.05 GiB size: 309.04 GiB (98.09%)
  used: 119.1 GiB (38.5%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
  uuid: 26a8c1a1-9aa2-4739-9e21-7cdc5405f6e4
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
  used: 114 MiB (11.4%) fs: vfat dev: /dev/sda14 maj-min: 8:14 label: N/A
  uuid: 9604-07C2
  ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda8 maj-min: 8:8 label: N/A
  uuid: b6b04b23-0477-4459-a870-9c714febfac2
  ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
  uuid: 6C8C-D247
  ID-2: /dev/sda10 maj-min: 8:10 size: 195.31 GiB fs: ntfs label: New Volume
  uuid: EEFE8A31FE89F25F
  ID-3: /dev/sda11 maj-min: 8:11 size: 19.29 GiB fs: ntfs label: New Volume
  uuid: 00AC900EAC8FFC7A
  ID-4: /dev/sda12 maj-min: 8:12 size: 2.93 GiB fs: swap label: N/A
  uuid: d491e39d-bb42-43fe-82ab-39fa21701fe8
  ID-5: /dev/sda13 maj-min: 8:13 size: 25 GiB fs: ntfs label: LENOVO
  uuid: 4244764544763C2B
  ID-6: /dev/sda15 maj-min: 8:15 size: 173.09 GiB fs: btrfs label: N/A
  uuid: e7a21b7a-3f64-4fad-89ff-71f881ab13c1
  ID-7: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-8: /dev/sda3 maj-min: 8:3 size: 172.84 GiB fs: ntfs label: Windows
  uuid: 02A48FFDA48FF209
  ID-9: /dev/sda4 maj-min: 8:4 size: 1024 KiB fs: <superuser required>
  ID-10: /dev/sda5 maj-min: 8:5 size: 1.5 GiB fs: ntfs label: New Volume
  uuid: 9EFA3429FA33FBD9
  ID-11: /dev/sda6 maj-min: 8:6 size: 954 MiB fs: vfat label: N/A
  uuid: 2D1E-B69F
  ID-12: /dev/sda7 maj-min: 8:7 size: 500 MiB fs: vfat label: N/A
  uuid: 361C-712A
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
  Device-1: 1-1.1:3 info: Maxxter Telink Wireless Receiver
  type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 12 Mb/s power: 50mA chip-ID: 248a:8367 class-ID: 0301
  Device-2: 1-1.2:4 info: Realtek Bluetooth Radio type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Device-3: 1-1.3:5 info: IMC Networks EasyCamera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5a02
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 73.0 C mobo: N/A gpu: amdgpu temp: 73.0 C
  Processes: 185 Uptime: 8m wakeups: 1 Init: systemd v: 249
  target: graphical.target tool: systemctl Compilers: gcc: 11.1.0
  clang: 13.0.0 Packages: 1674 apt: 2 lib: 2 pacman: 1672 lib: 404 flatpak: 0
  Shell: Bash v: 5.1.8 default: fish v: 3.3.1 running-in: urxvt inxi: 3.3.08
vulkaninfo
Xlib:  extension "GLX" missing on display ":0".
Can't open bumblebee display.
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Could not get 'vkCreateInstance' via 'vk_icdGetInstanceProcAddr' for ICD libGLX_nvidia.so.0
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: ICD libnv_vulkan_wrapper.so.1 doesn't support interface version compatible with loader, skip this ICD.
WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Failed to CreateInstance in ICD 0.  Skipping ICD.
vulkan: No DRI3 support detected - required for presentation
Note: you can probably enable DRI3 in your Xorg config
VULKANINFO
Vulkan Instance Version: 1.2.194
Instance Extensions: count = 19
	VK_EXT_acquire_drm_display             : extension revision 1
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 10
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 12
VK_LAYER_AMD_switchable_graphics_32 (AMD switchable graphics layer) Vulkan version 1.2.195, layer version 1:
	Layer Extensions: count = 0
	Devices: count = 1
		GPU id = 0 (AMD RADV STONEY)
		Layer-Device Extensions: count = 0
VK_LAYER_AMD_switchable_graphics_64 (AMD switchable graphics layer) Vulkan version 1.2.195, layer version 1:
	Devices: count = 1
VK_LAYER_INTEL_nullhw (INTEL NULL HW) Vulkan version 1.1.73, layer version 1:
	Devices: count = 1
VK_LAYER_KHRONOS_validation (Khronos Validation Layer) Vulkan version 1.2.194, layer version 1:
	Layer Extensions: count = 3
		VK_EXT_debug_report        : extension revision 9
		VK_EXT_debug_utils         : extension revision 1
		VK_EXT_validation_features : extension revision 2
	Devices: count = 1
		Layer-Device Extensions: count = 3
			VK_EXT_debug_marker     : extension revision 4
			VK_EXT_tooling_info     : extension revision 1
			VK_EXT_validation_cache : extension revision 1
VK_LAYER_LUNARG_api_dump (LunarG API dump layer) Vulkan version 1.2.189, layer version 2:
	Devices: count = 1
		Layer-Device Extensions: count = 1
VK_LAYER_LUNARG_device_simulation (LunarG device simulation layer) Vulkan version 1.2.189, layer version 1:
	Devices: count = 1
VK_LAYER_LUNARG_monitor (Execution Monitoring Layer) Vulkan version 1.2.189, layer version 1:
	Devices: count = 1
VK_LAYER_LUNARG_screenshot (LunarG image capture layer) Vulkan version 1.2.189, layer version 1:
	Devices: count = 1
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.2.73, layer version 1:
	Devices: count = 1
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.1.73, layer version 1:
	Devices: count = 1
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.186, layer version 1:
	Devices: count = 1
VK_LAYER_PRIMUS_PrimusVK (Primus-vk - https://github.com/felixdoerre/primus_vk) Vulkan version 1.2.0, layer version 1:
	Devices: count = 1
Presentable Surfaces:
GPU id : 0 (AMD RADV STONEY):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_SRGB
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_UNORM
	Present Modes: count = 4
		PRESENT_MODE_IMMEDIATE_KHR
		PRESENT_MODE_MAILBOX_KHR
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount = 3
		maxImageCount = 0
		currentExtent:
			width = 256
			height = 256
		minImageExtent:
			width = 256
			height = 256
		maxImageExtent:
			width = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 2
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
			COMPOSITE_ALPHA_INHERIT_BIT_KHR
		supportedUsageFlags: count = 5
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters:
			None
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
Device Groups:
Group 0:
	Properties:
		physicalDevices: count = 1
			AMD RADV STONEY (ID: 0)
		subsetAllocation = 0
	Present Capabilities:
		AMD RADV STONEY (ID: 0):
			Can present images from the following devices: count = 1
		Present modes: count = 1
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion        = 4202678 (1.2.182)
	driverVersion     = 88088581 (0x5402005)
	vendorID          = 0x1002
	deviceID          = 0x98e4
	deviceType        = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
	deviceName        = AMD RADV STONEY
	pipelineCacheUUID = 1a2aaa3a-a9f9-0a94-9f8a-a44ba90d515b
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 16384
	maxImageDimension2D                             = 16384
	maxImageDimension3D                             = 2048
	maxImageDimensionCube                           = 16384
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 4294967295
	maxUniformBufferRange                           = 4294967295
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 128
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 65536
	bufferImageGranularity                          = 0x00000040
	sparseAddressSpaceSize                          = 0xfffffffc
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 8388606
	maxPerStageDescriptorUniformBuffers             = 8388606
	maxPerStageDescriptorStorageBuffers             = 8388606
	maxPerStageDescriptorSampledImages              = 8388606
	maxPerStageDescriptorStorageImages              = 8388606
	maxPerStageDescriptorInputAttachments           = 8388606
	maxPerStageResources                            = 8388606
	maxDescriptorSetSamplers                        = 8388606
	maxDescriptorSetUniformBuffers                  = 8388606
	maxDescriptorSetUniformBuffersDynamic           = 16
	maxDescriptorSetStorageBuffers                  = 8388606
	maxDescriptorSetStorageBuffersDynamic           = 8
	maxDescriptorSetSampledImages                   = 8388606
	maxDescriptorSetStorageImages                   = 8388606
	maxDescriptorSetInputAttachments                = 8388606
	maxVertexInputAttributes                        = 32
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 4294967295
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4096
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 127
	maxGeometryInputComponents                      = 64
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 256
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 8
	maxComputeSharedMemorySize                      = 65536
	maxComputeWorkGroupCount: count = 3
		65535
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		1024
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 16
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		16384
		16384
	viewportBoundsRange: count = 2
		-32768
		32767
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 4096
	minTexelBufferOffsetAlignment                   = 0x00000004
	minUniformBufferOffsetAlignment                 = 0x00000004
	minStorageBufferOffsetAlignment                 = 0x00000004
	minTexelOffset                                  = -32
	maxTexelOffset                                  = 31
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -2
	maxInterpolationOffset                          = 2
	subPixelInterpolationOffsetBits                 = 8
	maxFramebufferWidth                             = 16384
	maxFramebufferHeight                            = 16384
	maxFramebufferLayers                            = 1024
	framebufferColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferNoAttachmentsSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	storageImageSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 20.8333
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		0
		8191.88
	lineWidthRange: count = 2
		0
		8191.88
	pointSizeGranularity                            = 0.125
	lineWidthGranularity                            = 0.125
	strictLines                                     = false
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000080
	optimalBufferCopyRowPitchAlignment              = 0x00000080
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = false
	residencyStandard2DMultisampleBlockShape = false
	residencyStandard3DBlockShape            = false
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = false
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
	maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes: count = 4
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 3
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 67108863
	shaderUniformBufferArrayNonUniformIndexingNative     = false
	shaderSampledImageArrayNonUniformIndexingNative      = false
	shaderStorageBufferArrayNonUniformIndexingNative     = false
	shaderStorageImageArrayNonUniformIndexingNative      = false
	shaderInputAttachmentArrayNonUniformIndexingNative   = false
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = false
	maxPerStageDescriptorUpdateAfterBindSamplers         = 8388606
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 8388606
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 8388606
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 8388606
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 8388606
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 8388606
	maxPerStageUpdateAfterBindResources                  = 8388606
	maxDescriptorSetUpdateAfterBindSamplers              = 8388606
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 8388606
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 8388606
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindSampledImages         = 8388606
	maxDescriptorSetUpdateAfterBindStorageImages         = 8388606
	maxDescriptorSetUpdateAfterBindInputAttachments      = 8388606
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
	maxDiscardRectangles = 4
VkPhysicalDeviceDriverProperties:
	driverID           = DRIVER_ID_MESA_RADV
	driverName         = radv
	driverInfo         = Mesa 21.2.5
	conformanceVersion = 1.2.3.0
VkPhysicalDeviceDrmPropertiesEXT:
	hasPrimary   = true
	hasRender    = true
	primaryMajor = 226
	primaryMinor = 0
	renderMajor  = 226
	renderMinor  = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	shaderSignedZeroInfNanPreserveFloat16 = false
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = false
	shaderDenormPreserveFloat32           = true
	shaderDenormPreserveFloat64           = true
	shaderDenormFlushToZeroFloat16        = false
	shaderDenormFlushToZeroFloat32        = true
	shaderDenormFlushToZeroFloat64        = true
	shaderRoundingModeRTEFloat16          = false
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = false
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = 00000000-0000-0000-0100-000000000000
	driverUUID      = 414d442d-4d45-5341-2d44-525600000000
	deviceNodeMask  = 0
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
	maxInlineUniformBlockSize                               = 4194304
	maxPerStageDescriptorInlineUniformBlocks                = 134217728
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 134217728
	maxDescriptorSetInlineUniformBlocks                     = 64
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 64
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 22369621
	maxMemoryAllocationSize = 0xfffffffc
VkPhysicalDeviceMultiDrawPropertiesEXT:
	maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 8
	maxMultiviewInstanceIndex = 2147483647
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 0
	pciDevice   = 1
	pciFunction = 0
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
	provokingVertexModePerPipeline                       = true
	transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000004
	robustUniformBufferAccessSizeAlignment = 0x00000004
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts: count = 3
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleLocationGridSize:
		width  = 2
		height = 2
	sampleLocationCoordinateRange: count = 2
		0
		0.9375
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = false
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = false
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 64
	supportedStages: count = 8
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
		SHADER_STAGE_ALL_GRAPHICS
		SHADER_STAGE_ALL
	supportedOperations: count = 8
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_ARITHMETIC_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_CLUSTERED_BIT
		SUBGROUP_FEATURE_QUAD_BIT
	quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
	minSubgroupSize              = 64
	maxSubgroupSize              = 64
	maxComputeWorkgroupSubgroups = 4294967295
	requiredSubgroupSizeStages:
		None
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000004
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000004
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffff
	maxTransformFeedbackStreamDataSize         = 512
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 512
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = true
	transformFeedbackRasterizationStreamSelect = false
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 0
	subgroupSize                      = 64
	subgroupSupportedStages: count = 8
		SHADER_STAGE_ALL
	subgroupSupportedOperations: count = 8
	subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
	driverName                                           = radv
	framebufferIntegerColorSampleCounts: count = 1
		SAMPLE_COUNT_1_BIT
Device Extensions: count = 120
	VK_AMD_buffer_marker                        : extension revision 1
	VK_AMD_device_coherent_memory               : extension revision 1
	VK_AMD_draw_indirect_count                  : extension revision 2
	VK_AMD_gcn_shader                           : extension revision 1
	VK_AMD_memory_overallocation_behavior       : extension revision 1
	VK_AMD_mixed_attachment_samples             : extension revision 1
	VK_AMD_shader_ballot                        : extension revision 1
	VK_AMD_shader_core_properties               : extension revision 2
	VK_AMD_shader_core_properties2              : extension revision 1
	VK_AMD_shader_explicit_vertex_parameter     : extension revision 1
	VK_AMD_shader_fragment_mask                 : extension revision 1
	VK_AMD_shader_image_load_store_lod          : extension revision 1
	VK_AMD_shader_info                          : extension revision 1
	VK_AMD_shader_trinary_minmax                : extension revision 1
	VK_AMD_texture_gather_bias_lod              : extension revision 1
	VK_EXT_4444_formats                         : extension revision 1
	VK_EXT_buffer_device_address                : extension revision 2
	VK_EXT_calibrated_timestamps                : extension revision 2
	VK_EXT_color_write_enable                   : extension revision 1
	VK_EXT_conditional_rendering                : extension revision 2
	VK_EXT_custom_border_color                  : extension revision 12
	VK_EXT_depth_clip_enable                    : extension revision 1
	VK_EXT_depth_range_unrestricted             : extension revision 1
	VK_EXT_descriptor_indexing                  : extension revision 2
	VK_EXT_discard_rectangles                   : extension revision 1
	VK_EXT_display_control                      : extension revision 1
	VK_EXT_extended_dynamic_state               : extension revision 1
	VK_EXT_extended_dynamic_state2              : extension revision 1
	VK_EXT_external_memory_dma_buf              : extension revision 1
	VK_EXT_external_memory_host                 : extension revision 1
	VK_EXT_global_priority                      : extension revision 2
	VK_EXT_global_priority_query                : extension revision 1
	VK_EXT_host_query_reset                     : extension revision 1
	VK_EXT_image_robustness                     : extension revision 1
	VK_EXT_index_type_uint8                     : extension revision 1
	VK_EXT_inline_uniform_block                 : extension revision 1
	VK_EXT_line_rasterization                   : extension revision 1
	VK_EXT_memory_budget                        : extension revision 1
	VK_EXT_memory_priority                      : extension revision 1
	VK_EXT_multi_draw                           : extension revision 1
	VK_EXT_pci_bus_info                         : extension revision 2
	VK_EXT_physical_device_drm                  : extension revision 1
	VK_EXT_pipeline_creation_cache_control      : extension revision 3
	VK_EXT_pipeline_creation_feedback           : extension revision 1
	VK_EXT_private_data                         : extension revision 1
	VK_EXT_provoking_vertex                     : extension revision 1
	VK_EXT_queue_family_foreign                 : extension revision 1
	VK_EXT_robustness2                          : extension revision 1
	VK_EXT_sample_locations                     : extension revision 1
	VK_EXT_sampler_filter_minmax                : extension revision 2
	VK_EXT_scalar_block_layout                  : extension revision 1
	VK_EXT_shader_atomic_float                  : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation   : extension revision 1
	VK_EXT_shader_image_atomic_int64            : extension revision 1
	VK_EXT_shader_stencil_export                : extension revision 1
	VK_EXT_shader_subgroup_ballot               : extension revision 1
	VK_EXT_shader_subgroup_vote                 : extension revision 1
	VK_EXT_shader_viewport_index_layer          : extension revision 1
	VK_EXT_subgroup_size_control                : extension revision 2
	VK_EXT_texel_buffer_alignment               : extension revision 1
	VK_EXT_transform_feedback                   : extension revision 1
	VK_EXT_vertex_attribute_divisor             : extension revision 3
	VK_EXT_ycbcr_image_arrays                   : extension revision 1
	VK_GOOGLE_decorate_string                   : extension revision 1
	VK_GOOGLE_hlsl_functionality1               : extension revision 1
	VK_GOOGLE_user_type                         : extension revision 1
	VK_KHR_16bit_storage                        : extension revision 1
	VK_KHR_8bit_storage                         : extension revision 1
	VK_KHR_bind_memory2                         : extension revision 1
	VK_KHR_buffer_device_address                : extension revision 1
	VK_KHR_copy_commands2                       : extension revision 1
	VK_KHR_create_renderpass2                   : extension revision 1
	VK_KHR_dedicated_allocation                 : extension revision 3
	VK_KHR_deferred_host_operations             : extension revision 4
	VK_KHR_depth_stencil_resolve                : extension revision 1
	VK_KHR_descriptor_update_template           : extension revision 1
	VK_KHR_device_group                         : extension revision 4
	VK_KHR_draw_indirect_count                  : extension revision 1
	VK_KHR_driver_properties                    : extension revision 1
	VK_KHR_external_fence                       : extension revision 1
	VK_KHR_external_fence_fd                    : extension revision 1
	VK_KHR_external_memory                      : extension revision 1
	VK_KHR_external_memory_fd                   : extension revision 1
	VK_KHR_external_semaphore                   : extension revision 1
	VK_KHR_external_semaphore_fd                : extension revision 1
	VK_KHR_get_memory_requirements2             : extension revision 1
	VK_KHR_image_format_list                    : extension revision 1
	VK_KHR_imageless_framebuffer                : extension revision 1
	VK_KHR_incremental_present                  : extension revision 2
	VK_KHR_maintenance1                         : extension revision 2
	VK_KHR_maintenance2                         : extension revision 1
	VK_KHR_maintenance3                         : extension revision 1
	VK_KHR_multiview                            : extension revision 1
	VK_KHR_pipeline_executable_properties       : extension revision 1
	VK_KHR_push_descriptor                      : extension revision 2
	VK_KHR_relaxed_block_layout                 : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge         : extension revision 3
	VK_KHR_sampler_ycbcr_conversion             : extension revision 14
	VK_KHR_separate_depth_stencil_layouts       : extension revision 1
	VK_KHR_shader_atomic_int64                  : extension revision 1
	VK_KHR_shader_clock                         : extension revision 1
	VK_KHR_shader_draw_parameters               : extension revision 1
	VK_KHR_shader_float16_int8                  : extension revision 1
	VK_KHR_shader_float_controls                : extension revision 4
	VK_KHR_shader_non_semantic_info             : extension revision 1
	VK_KHR_shader_subgroup_extended_types       : extension revision 1
	VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
	VK_KHR_shader_terminate_invocation          : extension revision 1
	VK_KHR_spirv_1_4                            : extension revision 1
	VK_KHR_storage_buffer_storage_class         : extension revision 1
	VK_KHR_swapchain                            : extension revision 70
	VK_KHR_swapchain_mutable_format             : extension revision 1
	VK_KHR_timeline_semaphore                   : extension revision 2
	VK_KHR_uniform_buffer_standard_layout       : extension revision 1
	VK_KHR_variable_pointers                    : extension revision 1
	VK_KHR_vulkan_memory_model                  : extension revision 3
	VK_KHR_workgroup_memory_explicit_layout     : extension revision 1
	VK_KHR_zero_initialize_workgroup_memory     : extension revision 1
	VK_NV_compute_shader_derivatives            : extension revision 1
	VK_VALVE_mutable_descriptor_type            : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 1
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		timestampValidBits          = 64
		present support             = false
	queueProperties[1]:
		queueCount                  = 4
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 2
	memoryHeaps[0]:
		size   = 1431654400 (0x55555000) (1.33 GiB)
		budget = 1425510400 (0x54f79000) (1.33 GiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags:
			None
	memoryHeaps[1]:
		size   = 2863312896 (0xaaaab000) (2.67 GiB)
		budget = 2851012608 (0xa9ef0000) (2.66 GiB)
		flags: count = 1
			MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 4
	memoryTypes[0]:
		heapIndex     = 1
		propertyFlags = 0x0001: count = 1
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
			IMAGE_TILING_OPTIMAL:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D16_UNORM_S8_UINT
				FORMAT_D32_SFLOAT_S8_UINT
			IMAGE_TILING_LINEAR:
				color images
	memoryTypes[1]:
		heapIndex     = 0
		propertyFlags = 0x0006: count = 2
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[2]:
		heapIndex     = 1
		propertyFlags = 0x0007: count = 3
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[3]:
		heapIndex     = 0
		propertyFlags = 0x000e: count = 3
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = false
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = true
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = true
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = false
	sparseResidencyImage2D                  = false
	sparseResidencyImage3D                  = false
	sparseResidency2Samples                 = false
	sparseResidency4Samples                 = false
	sparseResidency8Samples                 = false
	sparseResidency16Samples                = false
	sparseResidencyAliased                  = false
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = true
	storageInputOutput16               = false
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = true
	bufferDeviceAddressMultiDevice   = false
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
	colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = false
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
	customBorderColors             = true
	customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
	extendedDynamicState2                   = true
	extendedDynamicState2LogicOp            = true
	extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesEXT:
	globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
	robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = false
	bresenhamLines           = true
	smoothLines              = false
	stippledRectangularLines = false
	stippledBresenhamLines   = true
	stippledSmoothLines      = false
VkPhysicalDeviceMemoryPriorityFeaturesEXT:
	memoryPriority = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
	multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrivateDataFeaturesEXT:
	privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
	provokingVertexLast                       = true
	transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = false
	shaderBufferFloat64Atomics   = true
	shaderBufferFloat64AtomicAdd = false
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = true
	shaderSharedFloat64Atomics   = true
	shaderSharedFloat64AtomicAdd = false
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = false
	sparseImageFloat32Atomics    = true
	sparseImageFloat32AtomicAdd  = false
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = false
	shaderInt8    = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
	shaderImageInt64Atomics = true
	sparseImageInt64Atomics = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
	shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = true
	descriptorIndexing                                 = true
	samplerFilterMinmax                                = true
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = false
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
	workgroupMemoryExplicitLayout                  = true
	workgroupMemoryExplicitLayoutScalarBlockLayout = true
	workgroupMemoryExplicitLayout8BitAccess        = true
	workgroupMemoryExplicitLayout16BitAccess       = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
	shaderZeroInitializeWorkgroupMemory = true
vulkaninfo --sumary
VULKANINFO
Instance Layers: count = 12
VK_LAYER_AMD_switchable_graphics_32 AMD switchable graphics layer                        1.2.195  version 1
VK_LAYER_AMD_switchable_graphics_64 AMD switchable graphics layer                        1.2.195  version 1
VK_LAYER_INTEL_nullhw               INTEL NULL HW                                        1.1.73   version 1
VK_LAYER_KHRONOS_validation         Khronos Validation Layer                             1.2.194  version 1
VK_LAYER_LUNARG_api_dump            LunarG API dump layer                                1.2.189  version 2
VK_LAYER_LUNARG_device_simulation   LunarG device simulation layer                       1.2.189  version 1
VK_LAYER_LUNARG_monitor             Execution Monitoring Layer                           1.2.189  version 1
VK_LAYER_LUNARG_screenshot          LunarG image capture layer                           1.2.189  version 1
VK_LAYER_MESA_device_select         Linux device selection layer                         1.2.73   version 1
VK_LAYER_MESA_overlay               Mesa Overlay layer                                   1.1.73   version 1
VK_LAYER_NV_optimus                 NVIDIA Optimus layer                                 1.2.186  version 1
VK_LAYER_PRIMUS_PrimusVK            Primus-vk - https://github.com/felixdoerre/primus_vk 1.2.0    version 1
Devices:
GPU0:
	vendorID           = 0x1002
	deviceID           = 0x98e4
	driverName         = radv
Just putting this here.
https://wiki.archlinux.org/title/Vulkan
already tried using this i got LIBGL_ALWAYS_SOFTWARE=1 __GLX_VENDOR_LIBRARY_NAME=mesa VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/lvp_icd.i686.json:/usr/share/vulkan/icd.d/lvp_icd.x86_64.json vulkaninfo
ERROR: [Loader Message] Code 0 : loader_get_json: Failed to open JSON file /usr/share/vulkan/icd.d/lvp_icd.i686.json
ERROR: [Loader Message] Code 0 : loader_get_json: Failed to open JSON file /usr/share/vulkan/icd.d/lvp_icd.x86_64.json
as error where `Error: couldn't find RGB GLX visual or fbconfig`
is of glxinfo
Tried to start game with AMD_VULKAN_ICD=RADV?
AMD_VULKAN_ICD=RADV lutris
        17:31:19
2021-11-16 17:31:24,311: Invalid glxinfo received
2021-11-16 17:31:24,581: Starting Lutris 0.5.9.1
2021-11-16 17:31:24,634: No cores found
2021-11-16 17:31:27,807: Startup complete
2021-11-16 17:31:27,809: glxinfo is not available on your system, unable to detect driver version
2021-11-16 17:31:27,809: GPU: 1002:98E4 17AA:39F3 (amdgpu drivers)
Started initial process 21462 from /home/gunit/.local/share/lutris/runners/wine/lutris-fshack-6.21-3-x86_64/bin/wine /home/gunit/Games/epic-games-store/drive_c/Program Files (x86)/Epic Games/Launcher/Portal/Binaries/Win32/EpicGamesLauncher.exe -opengl -SkipBuildPatchPrereq
Start monitoring process.
esync: up and running.
LogInit: Display: Command Line: "C:\Program Files (x86)\Epic Games\Launcher\Portal\Binaries\Win32\EpicGamesLauncher.exe" -opengl -SkipBuildPatchPrereq -SaveToUserDir -Messaging
LogWindows: Error: === Critical error: ===
LogWindows: Error:
LogWindows: Error: Assertion failed: PixelFormat [File:D:/build/++Portal/Sync/Engine/Source/Developer/StandaloneRenderer/Private/Windows/OpenGL/SlateOpenGLContext.cpp] [Line: 100]
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
LogWindows: Error: [Callstack] 0x000000007b011026 kernelbase.dll!RaiseException() []
LogWindows: Error: [Callstack] 0x000000000065034e EpicGamesLauncher.exe!PrintScriptCallstack() []
LogWindows: Error:
Initial process has exited (return code: 256)
Install it?
sudo pacman -S mesa-demos
already installed
it gives error Error: couldn't find RGB GLX visual or fbconfig
yeah i have mesa-demos
pacman -Q mesa-demos
mesa-demos 8.4.0-4
glxinfo
name of display: :0
how do i enable DRI3 running vulkaninfo gives
how do i enable it??
added kate /etc/X11/xorg.conf.d/20-amdgpu.conf by refering AMDGPU - ArchWiki
but nothing works
show:
ls /usr/share/vulkan/icd.d/
clang -v
cat /etc/pacman-mirrors.conf | grep “Branch =”
Sorry for late reply @Monarc
amd_icd32.json  amd_icd64.json  nvidia_icd.json  nv_vulkan_wrapper.json  radeon_icd.i686.json  radeon_icd.x86_64.json
clang -v
clang version 13.0.0
Target: x86_64-pc-linux-gnu
Thread model: posix
InstalledDir: /usr/bin
Found candidate GCC installation: /usr/bin/../lib/gcc/i586-suse-linux/2.95.3
Found candidate GCC installation: /usr/bin/../lib/gcc/x86_64-pc-linux-gnu/11.1.0
Found candidate GCC installation: /usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/11.1.0
Selected GCC installation: /usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/11.1.0
Candidate multilib: .;@m64
Candidate multilib: 32;@m32
Selected multilib: .;@m64
and cat /etc/pacman-mirrors.conf | grep “Branch =” gives error
cat: /etc/pacman-mirrors.conf: No such file or directory
grep: =”: No such file or directory
well after all previous edit like one in xorg here are are result i dont when these error will go and how plz help me
lutris
2021-11-16 19:17:53,791: Starting Lutris 0.5.9.1
2021-11-16 19:17:54,307: No cores found
2021-11-16 19:17:57,784: Failed to read content length on response from https://api.github.com/repos/lutris/dxvk/releases
2021-11-16 19:17:59,081: Failed to read content length on response from https://api.github.com/repos/lutris/dxvk-nvapi/releases
2021-11-16 19:17:59,934: Startup complete
2021-11-16 19:17:59,936: Running AMD Mesa driver 21.2.5 on AMD STONEY (DRM 3.40.0, 5.10.78-1-lts, LLVM 13.0.0) (0x98e4)
2021-11-16 19:17:59,937: GPU: 1002:98E4 17AA:39F3 (amdgpu drivers)
Started initial process 4961 from /home/gunit/.local/share/lutris/runners/wine/lutris-fshack-6.21-3-x86_64/bin/wine /home/gunit/Games/epic-games-store/drive_c/Program Files (x86)/Epic Games/Launcher/Portal/Binaries/Win32/EpicGamesLauncher.exe -opengl -SkipBuildPatchPrereq
libGL error: MESA-LOADER: failed to open radeonsi: libLLVM-13.so: wrong ELF class: ELFCLASS64 (search paths /usr/lib32/dri, suffix _dri)
libGL error: failed to load driver: radeonsi
libGL error: MESA-LOADER: failed to open swrast: libLLVM-13.so: wrong ELF class: ELFCLASS64 (search paths /usr/lib32/dri, suffix _dri)
libGL error: failed to load driver: swrast
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
wine: Unhandled page fault on execute access to F75A99B0 at address F75A99B0 (thread 011c), starting debugger...
Unhandled exception: page fault on execute access to 0xf75a99b0 in 32-bit code (0xf75a99b0).
Register dump:
 CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
 EIP:f75a99b0 ESP:0204b62c EBP:7daef460 EFLAGS:00210216(  R- --  I   -A-P- )
 EAX:f75a99b0 EBX:00000002 ECX:7daef464 EDX:00000000
 ESI:0204b78c EDI:00000000
Stack dump:
0x0204b62c:  7d846abc 7da63130 00000002 7daef464
0x0204b63c:  0204b78c 00002000 00002000 00000000
0x0204b64c:  00000000 00000000 00000000 7da63130
0x0204b65c:  7d97a470 00000000 00320000 00000000
0x0204b66c:  00000000 00000000 00000000 00000000
0x0204b67c:  00000000 00000000 00000000 0204b6ac
Backtrace:
=>0 0xf75a99b0 (0x7daef460)
  1 0x0000000b (0x7daf59f0)
  2 0x0000000a (0x7dada5c0)
  3 0x00000009 (0x7dad2f50)
  4 0x00000008 (0x7da80530)
  5 0x00000007 (0x7da7fe50)
  6 0x00000006 (0x7da74220)
  7 0x00000005 (0x7da76b30)
  8 0x00000004 (0x7da76370)
  9 0x00000003 (0x7da75f70)
  10 0x00000002 (0x7da74c20)
  11 0x00000001 (0x7da61b00)
0xf75a99b0: -- no code accessible --
Modules:
Module	Address			Debug info	Name (97 modules)
PE	  140000-  1c0000	Deferred        setupapi
PE	  1c0000-  1d3000	Deferred        vcruntime140
PE	  1e0000-  1e4000	Deferred        api-ms-win-crt-runtime-l1-1-0
PE	  1f0000-  1f3000	Deferred        api-ms-win-crt-heap-l1-1-0
PE	  400000- 1a7d000	Deferred        epicgameslauncher
PE	 2580000- 26b1000	Deferred        ole32
PE	 26c0000- 30b3000	Deferred        shell32
PE	 30c0000- 31ed000	Deferred        oleaut32
PE	 31f0000- 3419000	Deferred        dxgi
PE	 3420000- 3627000	Deferred        d3dcompiler_43
PE	 3630000- 369f000	Deferred        msvcp140
PE	 36a0000- 36a4000	Deferred        api-ms-win-crt-stdio-l1-1-0
PE	 36b0000- 36b3000	Deferred        api-ms-win-crt-locale-l1-1-0
PE	 36c0000- 36c5000	Deferred        api-ms-win-crt-math-l1-1-0
PE	 36d0000- 36d3000	Deferred        api-ms-win-crt-time-l1-1-0
PE	 36e0000- 36e3000	Deferred        api-ms-win-crt-utility-l1-1-0
PE	10000000-10123000	Deferred        ucrtbase
PE	61500000-6152f000	Deferred        iphlpapi
PE	61680000-61683000	Deferred        api-ms-win-core-processthreads-l1-1-0
PE	61740000-61783000	Deferred        advapi32
PE	61f00000-61f04000	Deferred        api-ms-win-crt-convert-l1-1-0
PE	621c0000-621c3000	Deferred        api-ms-win-core-interlocked-l1-1-0
PE	62280000-62283000	Deferred        api-ms-win-core-libraryloader-l1-1-0
PE	62840000-62843000	Deferred        api-ms-win-core-processenvironment-l1-1-0
PE	62940000-62943000	Deferred        api-ms-win-core-synch-l1-1-0
PE	62980000-62983000	Deferred        api-ms-win-core-util-l1-1-0
PE	62b80000-62b88000	Deferred        api-ms-win-core-localization-l1-2-1
PE	62d40000-62d43000	Deferred        api-ms-win-crt-environment-l1-1-0
PE	62fc0000-6304d000	Deferred        rpcrt4
PE	63480000-6348c000	Deferred        version
PE	63bc0000-63bda000	Deferred        shcore
PE	63e00000-63e03000	Deferred        api-ms-win-core-debug-l1-1-0
PE	64080000-64083000	Deferred        api-ms-win-core-processthreads-l1-1-1
PE	64a00000-64a03000	Deferred        api-ms-win-core-localization-l1-2-0
PE	64a40000-64a94000	Deferred        shlwapi
PE	64f00000-64f03000	Deferred        api-ms-win-core-sysinfo-l1-1-0
PE	651c0000-651d6000	Deferred        xinput1_3
PE	65d40000-65d43000	Deferred        api-ms-win-crt-filesystem-l1-1-0
PE	66240000-66258000	Deferred        bcrypt
PE	663c0000-66474000	Deferred        winspool
PE	66640000-66643000	Deferred        api-ms-win-core-file-l2-1-0
PE	666c0000-666cf000	Deferred        hid
PE	66b00000-66b3d000	Deferred        win32u
PE	676c0000-676e5000	Deferred        explorerframe
PE	67800000-67803000	Deferred        api-ms-win-core-string-l1-1-0
PE	67840000-6784a000	Deferred        psapi
PE	67980000-67983000	Deferred        api-ms-win-core-datetime-l1-1-0
PE	67c00000-67c03000	Deferred        api-ms-win-core-handle-l1-1-0
PE	68080000-680a0000	Deferred        jsproxy
PE	68140000-68143000	Deferred        api-ms-win-core-errorhandling-l1-1-0
PE	682c0000-682e7000	Deferred        winevulkan
PE	68300000-68303000	Deferred        api-ms-win-core-timezone-l1-1-0
PE	68500000-6855b000	Deferred        combase
PE	68700000-6872f000	Deferred        uxtheme
PE	68b00000-68b07000	Deferred        normaliz
PE	68e00000-68e11000	Deferred        aclui
PE	69600000-69647000	Deferred        winhttp
PE	69ac0000-69acc000	Deferred        vulkan-1
PE	6a040000-6a062000	Deferred        msacm32
PE	6a280000-6a32c000	Deferred        msvcrt
PE	6a340000-6a343000	Deferred        api-ms-win-core-file-l1-2-0
PE	6a400000-6a4bb000	Deferred        winmm
PE	6a540000-6a87e000	Deferred        d3d11
PE	6ac80000-6ac87000	Deferred        api-ms-win-core-fibers-l1-1-1
PE	6b500000-6b507000	Deferred        api-ms-win-core-localization-obsolete-l1-2-0
PE	6bb80000-6bb83000	Deferred        api-ms-win-core-console-l1-1-0
PE	6bc00000-6bc2c000	Deferred        sechost
PE	6bcc0000-6bcc3000	Deferred        api-ms-win-core-profile-l1-1-0
PE	6c9c0000-6ca45000	Deferred        gdi32
PE	6ca80000-6cad4000	Deferred        wldap32
PE	6cc40000-6cd9a000	Deferred        comctl32
PE	6cdc0000-6cdc3000	Deferred        api-ms-win-core-namedpipe-l1-1-0
PE	6d780000-6d7a7000	Deferred        ws2_32
PE	6de80000-6de83000	Deferred        api-ms-win-core-synch-l1-2-0
PE	6e1c0000-6e1c3000	Deferred        api-ms-win-core-rtlsupport-l1-1-0
PE	6e4c0000-6e4d6000	Deferred        dnsapi
PE	6e840000-6e844000	Deferred        api-ms-win-core-file-l1-1-0
PE	6e8c0000-6e995000	Deferred        crypt32
PE	6ebc0000-6ebc3000	Deferred        api-ms-win-core-memory-l1-1-0
PE	6ec40000-6ec4d000	Deferred        dwmapi
PE	6ed00000-6ef58000	Deferred        user32
PE	6f480000-6f48b000	Deferred        nsi
PE	6f4c0000-6f4e9000	Deferred        wintrust
PE	6f900000-6f93b000	Deferred        msctf
PE	6fa80000-6faf8000	Deferred        dbghelp
PE	6fe40000-6fe74000	Deferred        rsaenh
PE	6ff00000-6ff04000	Deferred        api-ms-win-crt-string-l1-1-0
PE	6ff80000-6ff87000	Deferred        api-ms-win-core-datetime-l1-1-1
PE	700c0000-700c8000	Deferred        api-ms-win-core-sysinfo-l1-2-1
PE	705c0000-705c3000	Deferred        api-ms-win-core-heap-l1-1-0
PE	70d00000-70e08000	Deferred        comdlg32
PE	71200000-7121c000	Deferred        imm32
PE	7a840000-7a844000	Deferred        opengl32
PE	7b000000-7b0ea000	Deferred        kernelbase
PE	7b600000-7b81a000	Deferred        kernel32
PE	7bc00000-7bca9000	Deferred        ntdll
PE	7d9c0000-7d9c4000	Deferred        winex11
Threads:
process  tid      prio (all id:s are in hex)
00000020 start.exe
	["C:\windows\syswow64\start.exe" /exec "/home/gunit/Games/epic-games-store/drive_c/Program Files (x86)/Epic Games/Launcher/Portal/Binaries/Win32/EpicGamesLauncher.exe" -opengl -SkipBuildPatchPrereq]
	00000024    0
00000038 services.exe
	0000003c    0
	00000040    0
	0000004c    0
	0000005c    0
	0000006c    0
	00000078    0
	00000094    0
	000000ac    0
	000000dc    0
00000044 winedevice.exe
	00000048    0
	00000054    0
	00000058    0
	00000060    0
	000000b8    0
00000064 winedevice.exe
	00000068    0
	00000070    0
	00000074    0
	00000080    0
	00000084    0
	00000088    0
0000008c plugplay.exe
	00000090    0
	00000098    0
	0000009c    0
	000000a0    0
000000a4 svchost.exe
	000000a8    0
	000000b0    0
	000000b4    0
000000d4 rpcss.exe
	000000d8    0
	000000e4    0
	000000e8    0
	000000ec    0
	000000f0    0
	00000114    0
000000fc conhost.exe
	00000100    0
00000104 explorer.exe
	00000108    0
	0000010c    0
	00000110    0
00000118 (D) C:\Program Files (x86)\Epic Games\Launcher\Portal\Binaries\Win32\EpicGamesLauncher.exe
	["C:\Program Files (x86)\Epic Games\Launcher\Portal\Binaries\Win32\EpicGamesLauncher.exe" -opengl -SkipBuildPatchPrereq]
	0000011c    1 <==
	00000124   -1
	00000128   -1
	0000012c    0
	00000130    0
	00000134   -2
	00000138   -2
	0000013c   -1
	00000140    2
	00000144    2
	00000148    2
	0000014c    2
	00000150   -1
	00000154   -1
	00000158    1
	0000015c    1
	00000160    1
	00000174    0
00000164 CrashReportClient.exe
	["../../../Engine/Binaries/Win32/CrashReportClient.exe" "C:/users/gunit/AppData/Local/EpicGamesLauncher/Saved/Crashes/UE4CC-Windows-49106E984D2AB8109015C88BD816BDA5_0000" -AppName=UE4-EpicGamesLauncher -CrashGUID=UE4CC-Windows-49106E984D2AB8109015C88BD816BDA5_0000 -DebugSymbols=..\..\..\Engine\Intermediate\Symbols]
	00000168    0
System information:
    Wine build: wine-6.21.r0.g63c3baa9 ( TkG Staging Esync Fsync )
    Platform: i386 (WOW64)
    Version: Windows 10
    Host system: Linux
    Host version: 5.10.78-1-lts
Initial process has exited (return code: 1280)
Monitored process exited.
Exit with return code 1280
2021-11-16 19:19:03,688: Game still running (state: running)
2021-11-16 19:19:03,689: Stopping Epic Games Store (wine)
i think errors have started loving me so they are not leaving :sweat_smile:
but atleast system now know its gpu
Now it’s really a problem I just uninstall nvidia-utlis idk how they came but i did reboot ldm failed to start this I fixed I installed sddm i found that nvidia-utlis removed xorg-server one command fix as I didn’t have any desktop environment
2021-11-16 21:41:26,692: Starting Lutris 0.5.9.1
2021-11-16 21:41:26,739: No cores found
2021-11-16 21:41:32,468: Startup complete
2021-11-16 21:41:32,469: Running AMD Mesa driver 21.2.5 on AMD STONEY (DRM 3.40.0, 5.10.78-1-lts, LLVM 13.0.0) (0x98e4)
2021-11-16 21:41:32,470: GPU: 1002:98E4 17AA:39F3 (amdgpu drivers)
2021-11-16 21:41:35,058: Unable to load libGLX_nvidia.so.0
2021-11-16 21:41:35,058: Unable to locate libGLX_nvidia
Started initial process 10620 from /home/gunit/.local/share/lutris/runners/wine/lutris-fshack-6.21-3-x86_64/bin/wine /home/gunit/Games/epic-games-store/drive_c/Program Files (x86)/Epic Games/Launcher/Portal/Binaries/Win32/EpicGamesLauncher.exe -opengl -SkipBuildPatchPrereq
wineserver: using server-side synchronization.
(lutris:10539): Gtk-WARNING **: 21:41:37.487: gtk_widget_size_allocate(): attempt to allocate widget with width -14 and height 40
(lutris:10539): Gtk-WARNING **: 21:41:37.487: Negative content width -17 (allocation 1, extents 9x9) while allocating gadget (node entry, owner GtkSearchEntry)
*** BUG ***
In pixman_region32_init_rect: Invalid rectangle passed
Set a breakpoint on '_pixman_log_error' to debug
*** BUG ***
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
LogWindows: Error:
wine: Unhandled page fault on execute access to F75AC9B0 at address F75AC9B0 (thread 00fc), starting debugger...
Unhandled exception: page fault on execute access to 0xf75ac9b0 in 32-bit code (0xf75ac9b0).
Register dump:
 EIP:f75ac9b0 ESP:0204b62c EBP:7dad3030 EFLAGS:00210216(  R- --  I   -A-P- )
 EAX:f75ac9b0 EBX:00000002 ECX:7dad3034 EDX:00000000
Stack dump:
0x0204b62c:  7d821abc 7da46dc0 00000002 7dad3034
0x0204b64c:  00000000 00000000 00000000 7da46dc0
0x0204b65c:  7d955470 00000000 00320000 00000000
Backtrace:
=>0 0xf75ac9b0 (0x7dad3030)
  1 0x0000000b (0x7dad8500)
  2 0x0000000a (0x7dabdca0)
  3 0x00000009 (0x7dab67c0)
  4 0x00000008 (0x7da64250)
  5 0x00000007 (0x7da63b70)
  6 0x00000006 (0x7da58770)
  7 0x00000005 (0x7da5a910)
  8 0x00000004 (0x7da5a150)
  9 0x00000003 (0x7da59d50)
  10 0x00000002 (0x7da59d00)
  11 0x00000001 (0x7da45760)
0xf75ac9b0: -- no code accessible --
Modules:
PE	7d980000-7d984000	Deferred        winex11
Threads:
00000020 start.exe
	00000024    0
	0000003c    0
	00000040    0
	0000004c    0
	00000068    0
	00000088    0
	000000a0    0
	000000d0    0
	00000048    0
	00000054    0
	00000058    0
	0000005c    0
	000000ac    0
00000060 winedevice.exe
	00000064    0
	0000006c    0
	00000070    0
	00000074    0
	00000078    0
	0000007c    0
00000080 plugplay.exe
	00000084    0
	0000008c    0
	00000090    0
	00000094    0
00000098 svchost.exe
	0000009c    0
	000000a4    0
	000000a8    0
000000b0 explorer.exe
	000000b4    0
	000000bc    0
	000000c0    0
000000c8 rpcss.exe
	000000cc    0
	000000d8    0
	000000dc    0
	000000e0    0
	000000e4    0
	000000e8    0
000000f0 conhost.exe
	000000f4    0
000000f8 (D) C:\Program Files (x86)\Epic Games\Launcher\Portal\Binaries\Win32\EpicGamesLauncher.exe
	000000fc    1 <==
	00000104   -1
	00000108   -1
	0000010c    0
	00000110    0
	00000114   -2
	00000118   -2
	0000011c   -1
	00000120    2
	00000124    2
	00000128    2
	0000012c    2
	00000130   -1
	00000134   -1
	00000138    1
	0000013c    1
	00000140    1
	00000154    0
00000144 CrashReportClient.exe
	["../../../Engine/Binaries/Win32/CrashReportClient.exe" "C:/users/gunit/AppData/Local/EpicGamesLauncher/Saved/Crashes/UE4CC-Windows-12A6FB71408D05148A088998246236C5_0000" -AppName=UE4-EpicGamesLauncher -CrashGUID=UE4CC-Windows-12A6FB71408D05148A088998246236C5_0000 -DebugSymbols=..\..\..\Engine\Intermediate\Symbols]
	00000148    0
System information:
    Version: Windows 10
    Host system: Linux
Caught signal 15
Killing PID 10622 with SIGTERM
Killing PID 10628 with SIGTERM
Killing PID 10631 with SIGTERM
Killing PID 10638 with SIGTERM
Killing PID 10646 with SIGTERM
Killing PID 10652 with SIGTERM
Killing PID 10658 with SIGTERM
Killing PID 10665 with SIGTERM
Killing PID 10707 with SIGTERM
--terminated processes--
2021-11-16 21:41:52,024: Shutting down Lutris
these are result of lutris and this time they loaded faster as i disable fsync
how i fix this??
Are you just running this APU? I don’t believe it supports Vulkan.
Per AMD Website, these are what supports Vulkan:
  • AMD Radeon™ RX 5700 Series
  • AMD Radeon™ R9 Series graphics
  • AMD Radeon™ R7 Series graphics
  • AMD Radeon™ R5 240 graphics
  • AMD Radeon™ HD 8000 Series graphics for OEM systems (HD 8570 and up)
  • AMD Radeon™ HD 8000M Series graphics for notebooks
  • AMD Radeon™ HD 7000 Series graphics (HD 7730 and up
  • AMD Radeon™ HD 7000M Series graphics for notebooks (HD 7730M and up)
  • AMD A4/A6/A8/A10-7000 Series APUs
  • AMD A6/A8/A10 PRO-7000 Series APUs
  • AMD A6/A8/A10/FX™ 8000 Series APUs
  • AMD E1/A4/A10 Micro-6000 Series APUs
  • AMD E1/E2/A4/A6/A8-6000 Series APUs
  • AMD A4-1200, A4-1300 and A6-1400 Series APUs
  • AMD E1-2000, E2-3000, A4-5000, A6-5000, and A4 Pro-3000 Series APUs
It doesn’t mention the AMD A6 9000 Series APU
https://www.amd.com/en/product/8231
Supported Technologies
Virtualization
DirectX® 12 Technology
AES
AMD App Acceleration
Catalyst Software
AMD Enduro™ Technology
FMA4
AMD Radeon™ Dual Graphics
Unified Video Decoder (UVD)
Video Code Engine (VCE)
The Vulkan® API
Switchable Graphics
AVFS
AMD HD3D Technology
AMD Mantle API
AMD Gaming Evolved Client
Now maybe support is not good enough to run Vulkan game on Proton/Wine.
AMD needs to add this APU series to their Vulkan page to mention it supports Vulkan! lol
Well… now rereading the opening post, they did say:
So it did use to work. So I guess there is an issue somewhere.
@GOD1 , try using kernel 5.14 to see if that does anything. Maybe there is more support for your APU there.
