Vulkan not supported on lutris
That’s definitely not right.
This is my output on my laptop with AMD Radeon Vega 8 Graphics:
  driver: loaded: amdgpu unloaded: modesetting alternate: ati,fbdev,vesa
What’s the output of:
mhwd --listinstalled
Only video-linux should be listed.
At first I thought he was using the radeon driver, but his inxi shows the driver used is amdgpu and I also didn’t see extra grub parameter for the video, but I didn’t see that on the X11 server the driver was different, probably a good lead to his issue.
What I saw on the other side is that he’s using a non standard Manjaro installation: Desktop: herbstluftwm 0.9.3 info: polybar
They installed that afterwards : Remove desktop enviroment
I did spot other irregularities though.
Comparing to mine:
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=71bd23f7-486c-40be-9340-bb3466e941d1 rw quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Too much tinkering?
:exploding_head:
Yeah something is really fishy, it gets weirder and weirder
:mag: :male_detective: :mag_right:
Yeah manjaro is just the name of my pc and i have few of it’s package I have terminal of gradua linux, de of arco linux and i will try all this after 6 hr due to my exam
Just checking: what repositories are you pointing to?
cat /etc/pacman.d/mirrorlist
i have 2 repo manjaro and acrolinux repos
ok i change the kernel to 4.19 of manjaro and it worked it weird that i cant have vulkan on 5.10 lts and amd has given support for lower series of APU’s
its was just a small answer but i made it too big sorry for this
Thank you for your support
more over it takes ldm as my de my system is really confused and does manjaro have i3 themes so that i can remove arcolinux stuff and make my system 90% manjaro ??
or any cool tilling window manager
From what i see, Arco doesn’t seem to provide overriding packages, so it may not be incompatible with Manjaro.
But i’d like the repositories listed in the file anyway, to be certain.
arcolinux provide some core package too and i have 2 mirrorlist one from arco and one manjro
pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
[arcolinux_repo]
Include = /etc/pacman.d/arcolinux-mirrorlist
[arcolinux_repo_3party]
[arcolinux_repo_xlarge]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
# Europe Netherlands Amsterdam
Server = https://ant.seedhost.eu/arcolinux/$repo/$arch
# Gitlab United States
Server = https://gitlab.com/arcolinux/$repo/-/raw/master/$arch
# Europe Belgium Brussels
Server = https://ftp.belnet.be/arcolinux/$repo/$arch
# Australia
Server = https://mirror.aarnet.edu.au/pub/arcolinux/$repo/$arch
# United States San Francisco - no xlarge repo here
Server = https://arcolinux.github.io/$repo/$arch
manjaro-mirrorlist
## Manjaro Linux default mirrorlist
## Generated on 2021-11-17 09:19
## Please use 'pacman-mirrors -f [NUMBER] [NUMBER]' to modify mirrorlist
## (Use 0 for all mirrors)
## Country : Ukraine
Server = https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
## Country : Canada
Server = https://mirror.0xem.ma/manjaro/stable/$repo/$arch
## Country : Poland
Server = http://ftp.vectranet.pl/manjaro/stable/$repo/$arch
## Country : United_States
Server = https://mirrors.sonic.net/manjaro/stable/$repo/$arch
## Country : Indonesia
Server = http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
and a third one two from archlinux
mirrorlist
## Arch Linux repository mirrorlist
## Generated on 2021-04-05
# Worldwide
Server = https://mirror.osbeck.com/archlinux/$repo/os/$arch
Server = http://mirrors.evowise.com/archlinux/$repo/os/$arch
Server = http://mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://mirror.rackspace.com/archlinux/$repo/os/$arch
# Australia
Server = https://mirror.aarnet.edu.au/pub/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.digitalpacific.com.au/$repo/os/$arch
Server = https://archlinux.mirror.digitalpacific.com.au/$repo/os/$arch
Server = http://ftp.iinet.net.au/pub/archlinux/$repo/os/$arch
Server = http://mirror.internode.on.net/pub/archlinux/$repo/os/$arch
Server = http://mirror.launtel.net.au/repo/arch/$repo/os/$arch
Server = https://mirror.launtel.net.au/repo/arch/$repo/os/$arch
Server = http://arch.lucassymons.net/$repo/os/$arch
Server = https://arch.lucassymons.net/$repo/os/$arch
Server = http://syd.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://syd.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = http://ftp.swin.edu.au/archlinux/$repo/os/$arch
# Austria
Server = http://mirror.digitalnova.at/archlinux/$repo/os/$arch
Server = http://mirror.easyname.at/archlinux/$repo/os/$arch
Server = http://mirror.reisenbauer.ee/archlinux/$repo/os/$arch
Server = https://mirror.reisenbauer.ee/archlinux/$repo/os/$arch
# Bangladesh
Server = http://mirror.xeonbd.com/archlinux/$repo/os/$arch
# Belarus
Server = http://ftp.byfly.by/pub/archlinux/$repo/os/$arch
Server = http://mirror.datacenter.by/pub/archlinux/$repo/os/$arch
# Belgium
Server = http://archlinux.cu.be/$repo/os/$arch
Server = http://archlinux.mirror.kangaroot.net/$repo/os/$arch
Server = http://mirror.tiguinet.net/arch/$repo/os/$arch
# Bosnia and Herzegovina
Server = http://archlinux.mirror.ba/$repo/os/$arch
# Brazil
Server = http://br.mirror.archlinux-br.org/$repo/os/$arch
Server = http://archlinux.c3sl.ufpr.br/$repo/os/$arch
Server = http://www.caco.ic.unicamp.br/archlinux/$repo/os/$arch
Server = https://www.caco.ic.unicamp.br/archlinux/$repo/os/$arch
Server = http://linorg.usp.br/archlinux/$repo/os/$arch
Server = http://archlinux.pop-es.rnp.br/$repo/os/$arch
Server = http://mirror.ufam.edu.br/archlinux/$repo/os/$arch
Server = http://mirror.ufscar.br/archlinux/$repo/os/$arch
# Bulgaria
Server = https://mirror.darklinux.uk/archlinux/$repo/os/$arch
Server = http://mirror.host.ag/archlinux/$repo/os/$arch
Server = http://mirrors.netix.net/archlinux/$repo/os/$arch
Server = http://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = http://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
Server = https://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
# Canada
Server = https://mirror.0xem.ma/arch/$repo/os/$arch
Server = http://mirror.cedille.club/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.colo-serv.net/$repo/os/$arch
Server = http://mirror.csclub.uwaterloo.ca/archlinux/$repo/os/$arch
Server = https://mirror.csclub.uwaterloo.ca/archlinux/$repo/os/$arch
Server = http://mirror2.evolution-host.com/archlinux/$repo/os/$arch
Server = https://mirror2.evolution-host.com/archlinux/$repo/os/$arch
Server = http://mirror.its.dal.ca/archlinux/$repo/os/$arch
Server = http://muug.ca/mirror/archlinux/$repo/os/$arch
Server = https://muug.ca/mirror/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.rafal.ca/$repo/os/$arch
Server = http://mirror.scd31.com/arch/$repo/os/$arch
Server = https://mirror.scd31.com/arch/$repo/os/$arch
Server = http://mirror.sergal.org/archlinux/$repo/os/$arch
Server = https://mirror.sergal.org/archlinux/$repo/os/$arch
# Chile
Server = http://mirror.anquan.cl/archlinux/$repo/os/$arch
Server = http://mirror.archlinux.cl/$repo/os/$arch
Server = http://mirror1.cl.netactuate.com/archlinux/$repo/os/$arch
Server = https://mirror1.cl.netactuate.com/archlinux/$repo/os/$arch
Server = http://mirror.ufro.cl/archlinux/$repo/os/$arch
Server = https://mirror.ufro.cl/archlinux/$repo/os/$arch
# China
Server = http://mirrors.163.com/archlinux/$repo/os/$arch
Server = http://mirrors.bfsu.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.bfsu.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.cqu.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.cqu.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.dgut.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.dgut.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.hit.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.hit.edu.cn/archlinux/$repo/os/$arch
Server = http://mirror.lzu.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.neusoft.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.neusoft.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.nju.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.nju.edu.cn/archlinux/$repo/os/$arch
Server = http://mirror.redrock.team/archlinux/$repo/os/$arch
Server = https://mirror.redrock.team/archlinux/$repo/os/$arch
Server = https://mirrors.sjtug.sjtu.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.tuna.tsinghua.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.tuna.tsinghua.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.ustc.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.ustc.edu.cn/archlinux/$repo/os/$arch
Server = https://mirrors.xjtu.edu.cn/archlinux/$repo/os/$arch
Server = http://mirrors.zju.edu.cn/archlinux/$repo/os/$arch
# Colombia
Server = http://mirrors.udenar.edu.co/archlinux/$repo/os/$arch
# Croatia
Server = http://archlinux.iskon.hr/$repo/os/$arch
# Czechia
Server = http://mirror.dkm.cz/archlinux/$repo/os/$arch
Server = https://mirror.dkm.cz/archlinux/$repo/os/$arch
Server = https://europe.mirror.pkgbuild.com/$repo/os/$arch
Server = http://ftp.fi.muni.cz/pub/linux/arch/$repo/os/$arch
Server = http://ftp.linux.cz/pub/linux/arch/$repo/os/$arch
Server = http://gluttony.sin.cvut.cz/arch/$repo/os/$arch
Server = https://gluttony.sin.cvut.cz/arch/$repo/os/$arch
Server = http://mirrors.nic.cz/archlinux/$repo/os/$arch
Server = http://ftp.sh.cvut.cz/arch/$repo/os/$arch
Server = https://ftp.sh.cvut.cz/arch/$repo/os/$arch
Server = http://mirror.vpsfree.cz/archlinux/$repo/os/$arch
# Denmark
Server = http://mirrors.dotsrc.org/archlinux/$repo/os/$arch
Server = https://mirrors.dotsrc.org/archlinux/$repo/os/$arch
Server = http://mirror.one.com/archlinux/$repo/os/$arch
Server = https://mirror.one.com/archlinux/$repo/os/$arch
# Ecuador
Server = http://mirror.cedia.org.ec/archlinux/$repo/os/$arch
Server = http://mirror.espoch.edu.ec/archlinux/$repo/os/$arch
Server = http://mirror.uta.edu.ec/archlinux/$repo/os/$arch
# Estonia
Server = http://mirror.cspacehostings.com/archlinux/$repo/os/$arch
Server = https://mirror.cspacehostings.com/archlinux/$repo/os/$arch
# Finland
Server = https://arch.mcstrugs.org/$repo/os/$arch
Server = http://arch.mirror.far.fi/$repo/os/$arch
Server = http://mirror.hosthink.net/archlinux/$repo/os/$arch
Server = https://mirror.srv.fail/archlinux/$repo/os/$arch
Server = http://mirror.wuki.li/archlinux/$repo/os/$arch
Server = https://mirror.wuki.li/archlinux/$repo/os/$arch
# France
Server = http://archlinux.de-labrusse.fr/$repo/os/$arch
Server = http://mirror.archlinux.ikoula.com/archlinux/$repo/os/$arch
Server = https://archlinux.vi-di.fr/$repo/os/$arch
Server = http://mirror.arctic.lol/ArchMirror/$repo/os/$arch
Server = http://archlinux.mirrors.benatherton.com/$repo/os/$arch
Server = http://mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = http://archlinux.datagr.am/$repo/os/$arch
Server = https://mirrors.eric.ovh/arch/$repo/os/$arch
Server = http://mirror.ibcp.fr/pub/archlinux/$repo/os/$arch
Server = http://mirror.lastmikoi.net/archlinux/$repo/os/$arch
Server = https://arch-mirror.cloud.louifox.house/$repo/os/$arch
Server = http://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = http://mir.archlinux.fr/$repo/os/$arch
Server = http://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
Server = https://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
Server = http://arch.nimukaito.net/$repo/os/$arch
Server = https://arch.nimukaito.net/$repo/os/$arch
Server = http://mirror.oldsql.cc/archlinux/$repo/os/$arch
Server = https://mirror.oldsql.cc/archlinux/$repo/os/$arch
Server = http://archlinux.mirrors.ovh.net/archlinux/$repo/os/$arch
Server = http://archlinux.polymorf.fr/$repo/os/$arch
Server = http://archlinux.rezopole.net/$repo/os/$arch
Server = https://mirrors.slaanesh.org/archlinux/$repo/os/$arch
Server = http://mirrors.standaloneinstaller.com/archlinux/$repo/os/$arch
Server = https://mirror.sysa.tech/archlinux/$repo/os/$arch
Server = https://mirror.thekinrar.fr/archlinux/$repo/os/$arch
Server = http://ftp.u-strasbg.fr/linux/distributions/archlinux/$repo/os/$arch
Server = https://mirror.wormhole.eu/archlinux/$repo/os/$arch
Server = http://mirroir.wptheme.fr/archlinux/$repo/os/$arch
Server = https://mirroir.wptheme.fr/archlinux/$repo/os/$arch
Server = http://arch.yourlabs.org/$repo/os/$arch
Server = https://arch.yourlabs.org/$repo/os/$arch
# Georgia
Server = http://archlinux.grena.ge/$repo/os/$arch
Server = https://archlinux.grena.ge/$repo/os/$arch
# Germany
Server = http://mirror.23media.com/archlinux/$repo/os/$arch
Server = https://mirror.23media.com/archlinux/$repo/os/$arch
Server = http://ftp.agdsn.de/pub/mirrors/archlinux/$repo/os/$arch
Server = https://ftp.agdsn.de/pub/mirrors/archlinux/$repo/os/$arch
Server = https://appuals.com/archlinux/$repo/os/$arch
Server = http://artfiles.org/archlinux.org/$repo/os/$arch
Server = https://mirror.bethselamin.de/$repo/os/$arch
Server = http://mirror.chaoticum.net/arch/$repo/os/$arch
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
Server = http://mirror.checkdomain.de/archlinux/$repo/os/$arch
Server = https://mirror.checkdomain.de/archlinux/$repo/os/$arch
Server = http://mirror.clientvps.com/archlinux/$repo/os/$arch
Server = https://mirror.clientvps.com/archlinux/$repo/os/$arch
Server = https://mirror.dogado.de/archlinux/$repo/os/$arch
Server = http://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = http://ftp.fau.de/archlinux/$repo/os/$arch
Server = https://ftp.fau.de/archlinux/$repo/os/$arch
Server = https://pkg.fef.moe/archlinux/$repo/os/$arch
Server = https://dist-mirror.fem.tu-ilmenau.de/archlinux/$repo/os/$arch
Server = http://mirror.fsrv.services/archlinux/$repo/os/$arch
Server = https://mirror.fsrv.services/archlinux/$repo/os/$arch
Server = https://mirror.gnomus.de/$repo/os/$arch
Server = http://www.gutscheindrache.com/mirror/archlinux/$repo/os/$arch
Server = http://ftp.gwdg.de/pub/linux/archlinux/$repo/os/$arch
Server = http://archlinux.honkgong.info/$repo/os/$arch
Server = http://ftp.hosteurope.de/mirror/ftp.archlinux.org/$repo/os/$arch
Server = http://ftp-stud.hs-esslingen.de/pub/Mirrors/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.iphh.net/$repo/os/$arch
Server = http://arch.jensgutermuth.de/$repo/os/$arch
Server = https://arch.jensgutermuth.de/$repo/os/$arch
Server = http://mirror.kumi.systems/archlinux/$repo/os/$arch
Server = https://mirror.kumi.systems/archlinux/$repo/os/$arch
Server = http://mirror.fra10.de.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.fra10.de.leaseweb.net/archlinux/$repo/os/$arch
Server = http://mirror.metalgamer.eu/archlinux/$repo/os/$arch
Server = https://mirror.metalgamer.eu/archlinux/$repo/os/$arch
Server = http://mirror.mikrogravitation.org/archlinux/$repo/os/$arch
Server = https://mirror.mikrogravitation.org/archlinux/$repo/os/$arch
Server = https://mirror.pkgbuild.com/$repo/os/$arch
Server = http://mirrors.n-ix.net/archlinux/$repo/os/$arch
Server = https://mirrors.n-ix.net/archlinux/$repo/os/$arch
Server = http://mirror.netcologne.de/archlinux/$repo/os/$arch
Server = https://mirror.netcologne.de/archlinux/$repo/os/$arch
Server = http://mirrors.niyawe.de/archlinux/$repo/os/$arch
Server = https://mirrors.niyawe.de/archlinux/$repo/os/$arch
Server = http://mirror.orbit-os.com/archlinux/$repo/os/$arch
Server = https://mirror.orbit-os.com/archlinux/$repo/os/$arch
Server = http://packages.oth-regensburg.de/archlinux/$repo/os/$arch
Server = https://packages.oth-regensburg.de/archlinux/$repo/os/$arch
Server = http://phinau.de/arch/$repo/os/$arch
Server = https://phinau.de/arch/$repo/os/$arch
Server = https://mirror.pseudoform.org/$repo/os/$arch
Server = https://www.ratenzahlung.de/mirror/archlinux/$repo/os/$arch
Server = http://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
Server = https://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
Server = http://linux.rz.rub.de/archlinux/$repo/os/$arch
Server = http://mirror.satis-faction.de/archlinux/$repo/os/$arch
Server = https://mirror.satis-faction.de/archlinux/$repo/os/$arch
Server = http://mirror.selfnet.de/archlinux/$repo/os/$arch
Server = https://mirror.selfnet.de/archlinux/$repo/os/$arch
Server = http://ftp.spline.inf.fu-berlin.de/mirrors/archlinux/$repo/os/$arch
Server = https://ftp.spline.inf.fu-berlin.de/mirrors/archlinux/$repo/os/$arch
Server = http://archlinux.thaller.ws/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = http://ftp.tu-chemnitz.de/pub/linux/archlinux/$repo/os/$arch
Server = http://mirror.ubrco.de/archlinux/$repo/os/$arch
Server = https://mirror.ubrco.de/archlinux/$repo/os/$arch
Server = http://mirror.undisclose.de/archlinux/$repo/os/$arch
Server = https://mirror.undisclose.de/archlinux/$repo/os/$arch
Server = http://ftp.uni-bayreuth.de/linux/archlinux/$repo/os/$arch
Server = http://ftp.uni-hannover.de/archlinux/$repo/os/$arch
Server = http://ftp.uni-kl.de/pub/linux/archlinux/$repo/os/$arch
Server = http://mirror.united-gameserver.de/archlinux/$repo/os/$arch
Server = https://arch.unixpeople.org/$repo/os/$arch
Server = http://ftp.wrz.de/pub/archlinux/$repo/os/$arch
Server = https://ftp.wrz.de/pub/archlinux/$repo/os/$arch
Server = http://mirror.wtnet.de/arch/$repo/os/$arch
Server = https://mirror.wtnet.de/arch/$repo/os/$arch
Server = http://arch.mirror.zachlge.org/$repo/os/$arch
Server = https://arch.mirror.zachlge.org/$repo/os/$arch
# Greece
Server = http://ftp.cc.uoc.gr/mirrors/linux/archlinux/$repo/os/$arch
Server = https://repo.greeklug.gr/data/pub/linux/archlinux/$repo/os/$arch
Server = http://mirrors.myaegean.gr/linux/archlinux/$repo/os/$arch
Server = http://ftp.ntua.gr/pub/linux/archlinux/$repo/os/$arch
Server = http://ftp.otenet.gr/linux/archlinux/$repo/os/$arch
# Hong Kong
Server = https://asia.mirror.pkgbuild.com/$repo/os/$arch
Server = http://mirror-hk.koddos.net/archlinux/$repo/os/$arch
Server = https://mirror-hk.koddos.net/archlinux/$repo/os/$arch
Server = http://hkg.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://hkg.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://arch-mirror.wtako.net/$repo/os/$arch
Server = http://mirror.xtom.com.hk/archlinux/$repo/os/$arch
Server = https://mirror.xtom.com.hk/archlinux/$repo/os/$arch
# Hungary
Server = http://ftp.energia.mta.hu/pub/mirrors/ftp.archlinux.org/$repo/os/$arch
Server = http://archmirror.hbit.sztaki.hu/archlinux/$repo/os/$arch
Server = http://nova.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
Server = http://quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
Server = http://super.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
Server = https://nova.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
Server = https://quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
Server = https://super.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
# Iceland
Server = http://mirror.system.is/arch/$repo/os/$arch
Server = https://mirror.system.is/arch/$repo/os/$arch
# India
Server = http://mirror.cse.iitk.ac.in/archlinux/$repo/os/$arch
Server = http://mirrors.piconets.webwerks.in/archlinux-mirror/$repo/os/$arch
Server = https://mirrors.piconets.webwerks.in/archlinux-mirror/$repo/os/$arch
# Indonesia
Server = http://mirror.cloudweeb.com/archlinux/$repo/os/$arch
Server = http://mirror.faizuladib.com/archlinux/$repo/os/$arch
Server = http://mirror.gi.co.id/archlinux/$repo/os/$arch
Server = https://mirror.gi.co.id/archlinux/$repo/os/$arch
Server = http://vpsmurah.jagoanhosting.com/archlinux/$repo/os/$arch
Server = https://vpsmurah.jagoanhosting.com/archlinux/$repo/os/$arch
Server = http://mirror.labkom.id/archlinux/$repo/os/$arch
Server = http://mirror.papua.go.id/archlinux/$repo/os/$arch
Server = https://mirror.papua.go.id/archlinux/$repo/os/$arch
Server = http://mirror.poliwangi.ac.id/archlinux/$repo/os/$arch
Server = http://suro.ubaya.ac.id/archlinux/$repo/os/$arch
Server = http://mirror.telkomuniversity.ac.id/archlinux/$repo/os/$arch
Server = https://mirror.telkomuniversity.ac.id/archlinux/$repo/os/$arch
# Iran
Server = http://repo.iut.ac.ir/repo/archlinux/$repo/os/$arch
Server = http://mirror.nak-mci.ir/arch/$repo/os/$arch
Server = http://mirror.rasanegar.com/archlinux/$repo/os/$arch
Server = https://mirror.rasanegar.com/archlinux/$repo/os/$arch
# Ireland
Server = http://ftp.heanet.ie/mirrors/ftp.archlinux.org/$repo/os/$arch
Server = https://ftp.heanet.ie/mirrors/ftp.archlinux.org/$repo/os/$arch
# Israel
Server = http://mirror.isoc.org.il/pub/archlinux/$repo/os/$arch
Server = https://mirror.isoc.org.il/pub/archlinux/$repo/os/$arch
Server = https://archlinux.mivzakim.net/$repo/os/$arch
# Italy
Server = https://archmirror.it/repos/$repo/os/$arch
Server = http://archlinux.mirror.garr.it/archlinux/$repo/os/$arch
Server = http://mirrors.prometeus.net/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.server24.net/$repo/os/$arch
Server = https://archlinux.mirror.server24.net/$repo/os/$arch
# Japan
Server = http://mirrors.cat.net/archlinux/$repo/os/$arch
Server = https://mirrors.cat.net/archlinux/$repo/os/$arch
Server = http://ftp.tsukuba.wide.ad.jp/Linux/archlinux/$repo/os/$arch
Server = http://ftp.jaist.ac.jp/pub/Linux/ArchLinux/$repo/os/$arch
Server = https://ftp.jaist.ac.jp/pub/Linux/ArchLinux/$repo/os/$arch
# Kazakhstan
Server = http://mirror.hoster.kz/archlinux/$repo/os/$arch
Server = https://mirror.hoster.kz/archlinux/$repo/os/$arch
Server = http://mirror.ps.kz/archlinux/$repo/os/$arch
Server = https://mirror.ps.kz/archlinux/$repo/os/$arch
# Kenya
Server = http://archlinux.mirror.liquidtelecom.com/$repo/os/$arch
Server = https://archlinux.mirror.liquidtelecom.com/$repo/os/$arch
# Latvia
Server = http://archlinux.koyanet.lv/archlinux/$repo/os/$arch
Server = https://archlinux.koyanet.lv/archlinux/$repo/os/$arch
# Lithuania
Server = http://mirrors.atviras.lt/archlinux/$repo/os/$arch
Server = https://mirrors.atviras.lt/archlinux/$repo/os/$arch
Server = http://mirrors.ims.nksc.lt/archlinux/$repo/os/$arch
Server = https://mirrors.ims.nksc.lt/archlinux/$repo/os/$arch
# Luxembourg
Server = http://archlinux.mirror.root.lu/$repo/os/$arch
# Mexico
Server = https://arch.mirror.jsc.mx/$repo/os/$arch
# Moldova
Server = http://mirror.ihost.md/archlinux/$repo/os/$arch
Server = https://mirror.ihost.md/archlinux/$repo/os/$arch
# Monaco
Server = http://archlinux.qontinuum.space/$repo/os/$arch
Server = https://archlinux.qontinuum.space:4443/$repo/os/$arch
# Netherlands
Server = https://archlinux.beccacervello.it/archlinux/$repo/os/$arch
Server = https://mirrors.daan.vodka/archlinux/$repo/os/$arch
Server = http://mirror.easylee.nl/archlinux/$repo/os/$arch
Server = https://mirror.easylee.nl/archlinux/$repo/os/$arch
Server = http://mirror.i3d.net/pub/archlinux/$repo/os/$arch
Server = https://mirror.i3d.net/pub/archlinux/$repo/os/$arch
Server = https://arch.jeweet.net/$repo/os/$arch
Server = http://mirror.koddos.net/archlinux/$repo/os/$arch
Server = https://mirror.koddos.net/archlinux/$repo/os/$arch
Server = http://arch.mirrors.lavatech.top/$repo/os/$arch
Server = https://arch.mirrors.lavatech.top/$repo/os/$arch
Server = http://mirror.ams1.nl.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.ams1.nl.leaseweb.net/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.liteserver.nl/$repo/os/$arch
Server = https://archlinux.mirror.liteserver.nl/$repo/os/$arch
Server = http://mirror.lyrahosting.com/archlinux/$repo/os/$arch
Server = https://mirror.lyrahosting.com/archlinux/$repo/os/$arch
Server = http://mirror.mijn.host/archlinux/$repo/os/$arch
Server = https://mirror.mijn.host/archlinux/$repo/os/$arch
Server = http://mirror.neostrada.nl/archlinux/$repo/os/$arch
Server = https://mirror.neostrada.nl/archlinux/$repo/os/$arch
Server = http://ftp.nluug.nl/os/Linux/distr/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.pcextreme.nl/$repo/os/$arch
Server = https://archlinux.mirror.pcextreme.nl/$repo/os/$arch
Server = http://mirror.serverion.com/archlinux/$repo/os/$arch
Server = https://mirror.serverion.com/archlinux/$repo/os/$arch
Server = http://ftp.snt.utwente.nl/pub/os/linux/archlinux/$repo/os/$arch
Server = http://mirror.tarellia.net/distr/archlinux/$repo/os/$arch
Server = https://mirror.tarellia.net/distr/archlinux/$repo/os/$arch
Server = http://archlinux.mirror.wearetriple.com/$repo/os/$arch
Server = https://archlinux.mirror.wearetriple.com/$repo/os/$arch
Server = http://mirror-archlinux.webruimtehosting.nl/$repo/os/$arch
Server = https://mirror-archlinux.webruimtehosting.nl/$repo/os/$arch
Server = http://mirrors.xtom.nl/archlinux/$repo/os/$arch
Server = https://mirrors.xtom.nl/archlinux/$repo/os/$arch
# New Caledonia
Server = http://mirror.lagoon.nc/pub/archlinux/$repo/os/$arch
Server = http://archlinux.nautile.nc/archlinux/$repo/os/$arch
Server = https://archlinux.nautile.nc/archlinux/$repo/os/$arch
# New Zealand
Server = http://mirror.fsmg.org.nz/archlinux/$repo/os/$arch
Server = https://mirror.fsmg.org.nz/archlinux/$repo/os/$arch
Server = http://mirror.smith.geek.nz/archlinux/$repo/os/$arch
Server = https://mirror.smith.geek.nz/archlinux/$repo/os/$arch
# North Macedonia
Server = http://arch.softver.org.mk/archlinux/$repo/os/$arch
Server = http://mirror.onevip.mk/archlinux/$repo/os/$arch
Server = http://mirror.t-home.mk/archlinux/$repo/os/$arch
Server = https://mirror.t-home.mk/archlinux/$repo/os/$arch
# Norway
Server = http://mirror.archlinux.no/$repo/os/$arch
Server = https://mirror.archlinux.no/$repo/os/$arch
Server = http://archlinux.uib.no/$repo/os/$arch
Server = http://mirror.neuf.no/archlinux/$repo/os/$arch
Server = https://mirror.neuf.no/archlinux/$repo/os/$arch
Server = http://mirror.terrahost.no/linux/archlinux/$repo/os/$arch
# Pakistan
Server = http://repo.inara.pk/archlinux/$repo/os/$arch
Server = https://repo.inara.pk/archlinux/$repo/os/$arch
# Paraguay
Server = http://archlinux.mirror.py/archlinux/$repo/os/$arch
# Philippines
Server = http://mirror.rise.ph/archlinux/$repo/os/$arch
# Poland
Server = http://ftp.icm.edu.pl/pub/Linux/dist/archlinux/$repo/os/$arch
Server = https://ftp.icm.edu.pl/pub/Linux/dist/archlinux/$repo/os/$arch
Server = http://mirror.juniorjpdj.pl/archlinux/$repo/os/$arch
Server = https://mirror.juniorjpdj.pl/archlinux/$repo/os/$arch
Server = http://arch.midov.pl/arch/$repo/os/$arch
Server = https://arch.midov.pl/arch/$repo/os/$arch
Server = http://arch.nixlab.pl/$repo/os/$arch
Server = https://arch.nixlab.pl/$repo/os/$arch
Server = http://mirror.onet.pl/pub/mirrors/archlinux/$repo/os/$arch
Server = http://piotrkosoft.net/pub/mirrors/ftp.archlinux.org/$repo/os/$arch
Server = http://mirror.sfinae.tech/pub/mirrors/archlinux/$repo/os/$arch
Server = https://mirror.sfinae.tech/pub/mirrors/archlinux/$repo/os/$arch
Server = http://repo.skni.umcs.pl/archlinux/$repo/os/$arch
Server = https://repo.skni.umcs.pl/archlinux/$repo/os/$arch
Server = http://ftp.vectranet.pl/archlinux/$repo/os/$arch
# Portugal
Server = http://glua.ua.pt/pub/archlinux/$repo/os/$arch
Server = https://glua.ua.pt/pub/archlinux/$repo/os/$arch
Server = http://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
Server = https://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
# Romania
Server = http://mirrors.chroot.ro/archlinux/$repo/os/$arch
Server = https://mirrors.chroot.ro/archlinux/$repo/os/$arch
Server = http://mirror.efect.ro/archlinux/$repo/os/$arch
Server = https://mirror.efect.ro/archlinux/$repo/os/$arch
Server = http://mirrors.go.ro/archlinux/$repo/os/$arch
Server = https://mirrors.go.ro/archlinux/$repo/os/$arch
Server = http://mirrors.hostico.ro/archlinux/$repo/os/$arch
Server = https://mirrors.hostico.ro/archlinux/$repo/os/$arch
Server = http://archlinux.mirrors.linux.ro/$repo/os/$arch
Server = http://mirrors.m247.ro/archlinux/$repo/os/$arch
Server = http://mirrors.nav.ro/archlinux/$repo/os/$arch
Server = http://mirrors.nxthost.com/archlinux/$repo/os/$arch
Server = https://mirrors.nxthost.com/archlinux/$repo/os/$arch
Server = http://mirrors.pidginhost.com/arch/$repo/os/$arch
Server = https://mirrors.pidginhost.com/arch/$repo/os/$arch
# Russia
Server = http://mirror.surf/archlinux/$repo/os/$arch
Server = https://mirror.surf/archlinux/$repo/os/$arch
Server = http://mirror.nw-sys.ru/archlinux/$repo/os/$arch
Server = https://mirror.nw-sys.ru/archlinux/$repo/os/$arch
Server = http://mirrors.powernet.com.ru/archlinux/$repo/os/$arch
Server = http://mirror.rol.ru/archlinux/$repo/os/$arch
Server = https://mirror.rol.ru/archlinux/$repo/os/$arch
Server = http://mirror.truenetwork.ru/archlinux/$repo/os/$arch
Server = https://mirror.truenetwork.ru/archlinux/$repo/os/$arch
Server = http://mirror.yandex.ru/archlinux/$repo/os/$arch
Server = https://mirror.yandex.ru/archlinux/$repo/os/$arch
Server = http://archlinux.zepto.cloud/$repo/os/$arch
# Serbia
Server = http://arch.petarmaric.com/$repo/os/$arch
Server = http://mirror.pmf.kg.ac.rs/archlinux/$repo/os/$arch
# Singapore
Server = http://mirror.0x.sg/archlinux/$repo/os/$arch
Server = https://mirror.0x.sg/archlinux/$repo/os/$arch
Server = http://mirror.aktkn.sg/archlinux/$repo/os/$arch
Server = https://mirror.aktkn.sg/archlinux/$repo/os/$arch
Server = https://download.nus.edu.sg/mirror/archlinux/$repo/os/$arch
Server = http://mirror.guillaumea.fr/archlinux/$repo/os/$arch
Server = https://mirror.guillaumea.fr/archlinux/$repo/os/$arch
Server = http://mirror.nus.edu.sg/archlinux/$repo/os/$arch
# Slovakia
Server = http://mirror.lnx.sk/pub/linux/archlinux/$repo/os/$arch
Server = https://mirror.lnx.sk/pub/linux/archlinux/$repo/os/$arch
Server = http://tux.rainside.sk/archlinux/$repo/os/$arch
# Slovenia
Server = http://archimonde.ts.si/archlinux/$repo/os/$arch
Server = https://archimonde.ts.si/archlinux/$repo/os/$arch
# South Africa
Server = http://archlinux.za.mirror.allworldit.com/archlinux/$repo/os/$arch
Server = https://archlinux.za.mirror.allworldit.com/archlinux/$repo/os/$arch
Server = http://za.mirror.archlinux-br.org/$repo/os/$arch
Server = http://mirror.is.co.za/mirror/archlinux.org/$repo/os/$arch
Server = http://arch.opnmirror.co.za/$repo/os/$arch
Server = https://arch.opnmirror.co.za/$repo/os/$arch
Server = http://mirrors.urbanwave.co.za/archlinux/$repo/os/$arch
Server = https://mirrors.urbanwave.co.za/archlinux/$repo/os/$arch
# South Korea
Server = http://mirror.anigil.com/archlinux/$repo/os/$arch
Server = https://mirror.anigil.com/archlinux/$repo/os/$arch
Server = http://ftp.harukasan.org/archlinux/$repo/os/$arch
Server = https://ftp.harukasan.org/archlinux/$repo/os/$arch
Server = http://ftp.lanet.kr/pub/archlinux/$repo/os/$arch
Server = https://ftp.lanet.kr/pub/archlinux/$repo/os/$arch
Server = http://mirror.premi.st/archlinux/$repo/os/$arch
Server = https://mirror.premi.st/archlinux/$repo/os/$arch
# Spain
Server = https://mirror.cloroformo.org/archlinux/$repo/os/$arch
Server = http://mirror.librelabucm.org/archlinux/$repo/os/$arch
Server = https://mirror.librelabucm.org/archlinux/$repo/os/$arch
Server = http://ftp.rediris.es/mirror/archlinux/$repo/os/$arch
Server = http://sharing.thelinuxsect.com/archlinux/$repo/os/$arch
# Sweden
Server = http://ftp.acc.umu.se/mirror/archlinux/$repo/os/$arch
Server = https://ftp.acc.umu.se/mirror/archlinux/$repo/os/$arch
Server = http://archlinux.dynamict.se/$repo/os/$arch
Server = https://archlinux.dynamict.se/$repo/os/$arch
Server = http://ftpmirror.infania.net/mirror/archlinux/$repo/os/$arch
Server = http://ftp.lysator.liu.se/pub/archlinux/$repo/os/$arch
Server = https://ftp.lysator.liu.se/pub/archlinux/$repo/os/$arch
Server = http://ftp.myrveln.se/pub/linux/archlinux/$repo/os/$arch
Server = https://ftp.myrveln.se/pub/linux/archlinux/$repo/os/$arch
Server = http://tedwall.se/archlinux/$repo/os/$arch
Server = https://tedwall.se/archlinux/$repo/os/$arch
# Switzerland
Server = http://pkg.adfinis.com/archlinux/$repo/os/$arch
Server = https://pkg.adfinis.com/archlinux/$repo/os/$arch
Server = http://mirror.init7.net/archlinux/$repo/os/$arch
Server = https://mirror.init7.net/archlinux/$repo/os/$arch
Server = http://mirror.puzzle.ch/archlinux/$repo/os/$arch
Server = https://mirror.puzzle.ch/archlinux/$repo/os/$arch
Server = https://theswissbay.ch/archlinux/$repo/os/$arch
Server = https://mirror.ungleich.ch/mirror/packages/archlinux/$repo/os/$arch
# Taiwan
Server = http://archlinux.ccns.ncku.edu.tw/archlinux/$repo/os/$arch
Server = http://free.nchc.org.tw/arch/$repo/os/$arch
Server = https://free.nchc.org.tw/arch/$repo/os/$arch
Server = http://archlinux.cs.nctu.edu.tw/$repo/os/$arch
Server = http://shadow.ind.ntou.edu.tw/archlinux/$repo/os/$arch
Server = https://shadow.ind.ntou.edu.tw/archlinux/$repo/os/$arch
Server = http://ftp.tku.edu.tw/Linux/ArchLinux/$repo/os/$arch
Server = http://ftp.yzu.edu.tw/Linux/archlinux/$repo/os/$arch
Server = https://ftp.yzu.edu.tw/Linux/archlinux/$repo/os/$arch
# Thailand
Server = http://mirror.kku.ac.th/archlinux/$repo/os/$arch
Server = https://mirror.kku.ac.th/archlinux/$repo/os/$arch
Server = http://mirror2.totbb.net/archlinux/$repo/os/$arch
# Turkey
Server = http://ftp.linux.org.tr/archlinux/$repo/os/$arch
Server = http://mirror.veriteknik.net.tr/archlinux/$repo/os/$arch
# Ukraine
Server = http://archlinux.ip-connect.vn.ua/$repo/os/$arch
Server = https://archlinux.ip-connect.vn.ua/$repo/os/$arch
Server = http://mirror.mirohost.net/archlinux/$repo/os/$arch
Server = https://mirror.mirohost.net/archlinux/$repo/os/$arch
Server = http://mirrors.nix.org.ua/linux/archlinux/$repo/os/$arch
Server = https://mirrors.nix.org.ua/linux/archlinux/$repo/os/$arch
# United Kingdom
Server = http://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
Server = https://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
Server = http://mirror.bytemark.co.uk/archlinux/$repo/os/$arch
Server = https://mirror.bytemark.co.uk/archlinux/$repo/os/$arch
Server = http://mirrors.gethosted.online/archlinux/$repo/os/$arch
Server = https://mirrors.gethosted.online/archlinux/$repo/os/$arch
Server = http://mirrors.manchester.m247.com/arch-linux/$repo/os/$arch
Server = http://mirrors.melbourne.co.uk/archlinux/$repo/os/$arch
Server = https://mirrors.melbourne.co.uk/archlinux/$repo/os/$arch
Server = http://www.mirrorservice.org/sites/ftp.archlinux.org/$repo/os/$arch
Server = https://www.mirrorservice.org/sites/ftp.archlinux.org/$repo/os/$arch
Server = http://mirror.netweaver.uk/archlinux/$repo/os/$arch
Server = https://mirror.netweaver.uk/archlinux/$repo/os/$arch
Server = http://lon.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://lon.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = http://arch.serverspace.co.uk/arch/$repo/os/$arch
Server = http://archlinux.mirrors.uk2.net/$repo/os/$arch
Server = http://mirrors.ukfast.co.uk/sites/archlinux.org/$repo/os/$arch
Server = https://mirrors.ukfast.co.uk/sites/archlinux.org/$repo/os/$arch
# United States
Server = http://mirrors.acm.wpi.edu/archlinux/$repo/os/$arch
Server = http://mirrors.advancedhosters.com/archlinux/$repo/os/$arch
Server = http://mirrors.aggregate.org/archlinux/$repo/os/$arch
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
Server = http://ca.us.mirror.archlinux-br.org/$repo/os/$arch
Server = http://il.us.mirror.archlinux-br.org/$repo/os/$arch
Server = http://archlinux.surlyjake.com/archlinux/$repo/os/$arch
Server = https://archlinux.surlyjake.com/archlinux/$repo/os/$arch
Server = http://mirror.arizona.edu/archlinux/$repo/os/$arch
Server = https://mirror.arizona.edu/archlinux/$repo/os/$arch
Server = http://arlm.tyzoid.com/$repo/os/$arch
Server = https://arlm.tyzoid.com/$repo/os/$arch
Server = https://mirror.ava.dev/archlinux/$repo/os/$arch
Server = http://mirrors.cat.pdx.edu/archlinux/$repo/os/$arch
Server = http://mirror.cc.columbia.edu/pub/linux/archlinux/$repo/os/$arch
Server = http://arch.mirror.constant.com/$repo/os/$arch
Server = https://arch.mirror.constant.com/$repo/os/$arch
Server = http://mirror.cs.pitt.edu/archlinux/$repo/os/$arch
Server = http://mirror.cs.vt.edu/pub/ArchLinux/$repo/os/$arch
Server = http://mirror.cybersecurity.nmt.edu/archlinux/$repo/os/$arch
Server = https://mirror.cybersecurity.nmt.edu/archlinux/$repo/os/$arch
Server = http://distro.ibiblio.org/archlinux/$repo/os/$arch
Server = http://mirror.es.its.nyu.edu/archlinux/$repo/os/$arch
Server = http://mirror.ette.biz/archlinux/$repo/os/$arch
Server = https://mirror.ette.biz/archlinux/$repo/os/$arch
Server = http://mirrors.gigenet.com/archlinux/$repo/os/$arch
Server = http://www.gtlib.gatech.edu/pub/archlinux/$repo/os/$arch
Server = http://mirror.hackingand.coffee/arch/$repo/os/$arch
Server = https://mirror.hackingand.coffee/arch/$repo/os/$arch
Server = https://mirror.hodgepodge.dev/archlinux/$repo/os/$arch
Server = http://arch.hu.fo/archlinux/$repo/os/$arch
Server = https://arch.hu.fo/archlinux/$repo/os/$arch
Server = http://repo.ialab.dsu.edu/archlinux/$repo/os/$arch
Server = https://repo.ialab.dsu.edu/archlinux/$repo/os/$arch
Server = http://mirrors.kernel.org/archlinux/$repo/os/$arch
Server = https://mirrors.kernel.org/archlinux/$repo/os/$arch
Server = http://mirror.dal10.us.leaseweb.net/archlinux/$repo/os/$arch
Server = http://mirror.mia11.us.leaseweb.net/archlinux/$repo/os/$arch
Server = http://mirror.sfo12.us.leaseweb.net/archlinux/$repo/os/$arch
Server = http://mirror.wdc1.us.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.dal10.us.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.mia11.us.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.sfo12.us.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.wdc1.us.leaseweb.net/archlinux/$repo/os/$arch
Server = http://mirrors.liquidweb.com/archlinux/$repo/os/$arch
Server = http://mirror.lty.me/archlinux/$repo/os/$arch
Server = https://mirror.lty.me/archlinux/$repo/os/$arch
Server = http://mirrors.lug.mtu.edu/archlinux/$repo/os/$arch
Server = https://mirrors.lug.mtu.edu/archlinux/$repo/os/$arch
Server = http://mirror.math.princeton.edu/pub/archlinux/$repo/os/$arch
Server = http://mirror.metrocast.net/archlinux/$repo/os/$arch
Server = http://mirror.kaminski.io/archlinux/$repo/os/$arch
Server = https://mirror.kaminski.io/archlinux/$repo/os/$arch
Server = http://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
Server = https://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
Server = http://repo.miserver.it.umich.edu/archlinux/$repo/os/$arch
Server = http://mirrors.mit.edu/archlinux/$repo/os/$arch
Server = https://mirrors.mit.edu/archlinux/$repo/os/$arch
Server = http://mirrors.ocf.berkeley.edu/archlinux/$repo/os/$arch
Server = https://mirrors.ocf.berkeley.edu/archlinux/$repo/os/$arch
Server = http://archmirror1.octyl.net/$repo/os/$arch
Server = https://archmirror1.octyl.net/$repo/os/$arch
Server = http://ftp.osuosl.org/pub/archlinux/$repo/os/$arch
Server = http://arch.mirrors.pair.com/$repo/os/$arch
Server = http://dfw.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = http://iad.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = http://ord.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://dfw.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://iad.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://ord.mirror.rackspace.com/archlinux/$repo/os/$arch
Server = http://plug-mirror.rcac.purdue.edu/archlinux/$repo/os/$arch
Server = https://plug-mirror.rcac.purdue.edu/archlinux/$repo/os/$arch
Server = http://mirrors.rit.edu/archlinux/$repo/os/$arch
Server = https://mirrors.rit.edu/archlinux/$repo/os/$arch
Server = https://arch.rrig.gs/$repo/os/$arch
Server = http://mirrors.rutgers.edu/archlinux/$repo/os/$arch
Server = https://mirrors.rutgers.edu/archlinux/$repo/os/$arch
Server = http://mirror.siena.edu/archlinux/$repo/os/$arch
Server = http://mirrors.sonic.net/archlinux/$repo/os/$arch
Server = https://mirrors.sonic.net/archlinux/$repo/os/$arch
Server = http://arch.mirror.square-r00t.net/$repo/os/$arch
Server = https://arch.mirror.square-r00t.net/$repo/os/$arch
Server = http://mirror.stephen304.com/archlinux/$repo/os/$arch
Server = https://mirror.stephen304.com/archlinux/$repo/os/$arch
Server = http://ftp.sudhip.com/archlinux/$repo/os/$arch
Server = https://ftp.sudhip.com/archlinux/$repo/os/$arch
Server = http://mirror.pit.teraswitch.com/archlinux/$repo/os/$arch
Server = https://mirror.pit.teraswitch.com/archlinux/$repo/os/$arch
Server = http://mirror.umd.edu/archlinux/$repo/os/$arch
Server = http://mirror.vtti.vt.edu/archlinux/$repo/os/$arch
Server = http://mirrors.xmission.com/archlinux/$repo/os/$arch
Server = http://mirrors.xtom.com/archlinux/$repo/os/$arch
Server = https://mirrors.xtom.com/archlinux/$repo/os/$arch
Server = https://zxcvfdsa.com/arch/$repo/os/$arch
# Vietnam
Server = http://f.archlinuxvn.org/archlinux/$repo/os/$arch
Server = http://mirror.bizflycloud.vn/archlinux/$repo/os/$arch
One of error message is:
You have mixed two distributions.
e.g. in manjaro stable llvm is at version 12
the error message shows that llvm 13 was installed from some repo.
that mixing seems to kill your installation.
yeah i fixed as its on archlinux and actually 4 mixed distro
→ shells and terminal from gradua
→ wm from from arcolinux
→ pkg from official archlinux
→ manjaro as system
will 2bwm work fine on kernel and system of manjaro as i need a reinstall with only manjaro as my system no mixing at all??
You can’t mix unaligned repositories and expect the system to run smoothly.
This also applies between Manjaro and AUR since the latter is aligned “ahead” with Arch; installing core packages from AUR is thus ill-advised on a Manjaro system.
Pointing only Manjaro will certainly improve the stability. Though if you intend to use many AUR packages or keep tweaking as much, i’d suggest you install Arch instead – or Arco since it claims to be aligned with Arch.
ohk will using wm from aur work??
On a Manjaro system, i’d advise against using a WM from AUR, unless you are willing to fix it regularly with little support…
I just use Steam and dont think about Vulkan, only if I want to disable it :stuck_out_tongue:
