Hello, everyone!
After installing Manjaro xfce, I immediately noticed that internet speed via wifi was a lot slower than on my Windows partition (I’m dual booting).
Running speed tests showed that on Windows it’s ~30-40 Mbit/s, whereas on Manjaro it was ~1-2 Mbit/s.
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=1f82b52e-3ea1-4aa2-b2f7-fd13c2679f47 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-bw0xx v: Type1ProductConfigId
Mobo: HP model: 8333 v: 28.33 serial: <superuser required> UEFI: Insyde
v: F.30 date: 05/17/2018
ID-1: BAT1 charge: 38.5 Wh (100.0%) condition: 38.5/41.6 Wh (92.5%)
volts: 16.7 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
RAM: total: 5.39 GiB used: 1.24 GiB (22.9%)
RAM Report:
Info: model: AMD A12-9720P RADEON R7 12 COMPUTE CORES 4C+8G bits: 64
type: MT MCP arch: Excavator family: 0x15 (21) model-id: 0x65 (101)
stepping: 1 microcode: 0x600611A
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1777 high: 2317 min/max: 1400/2700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1438 2: 2317
3: 1867 4: 1487 bogomips: 21571
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vgif
vmcb_clean vme vmmcall wdt xop xsave xsaveopt
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:9874 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile]
vendor: Hewlett-Packard driver: amdgpu v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 05:00.0 chip-ID: 1002:6900 class-ID: 0380
Device-3: Realtek HP Webcam type: USB driver: uvcvideo bus-ID: 2-1:2
chip-ID: 0bda:58ed class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0687 built: 2015
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:3 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Local Storage: total: 465.76 GiB used: 8.59 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-1: / raw-size: 265.76 GiB size: 260.53 GiB (98.03%) used: 8.56 GiB (3.3%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 1f82b52e-3ea1-4aa2-b2f7-fd13c2679f47
used: 25.3 MiB (26.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: BA5E-79EA
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 199.89 GiB fs: ntfs label: N/A
uuid: A4DE82A6DE826FFA
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.4:3 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 2-1:2 info: Realtek HP Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:58ed
Device-2: 2-4:3 info: A4Tech USB Device type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 09da:5f0f class-ID: 0300
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 77.0 C mobo: 20.0 C
GPU: device: amdgpu temp: 54.0 C device: amdgpu temp: 76.0 C
Processes: 221 Uptime: 0m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1099 lib: 320
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.14
Any help is very appreciated.
EDIT
I’ve found solution here
Hello friends , I am new to linux .I installed manjaro alongside with windows 4 days ago. Everything is fine except that I face low internet speed everytime from the time of installation .
I searched on web but I was not able to fix it. Internet works fine in windows but whenever I switch to manjaro it gets very slow .Here are the screenshots.
Windows
[Screenshot_20220221-151634_DuckDuckGo]
and Manjaro
[manjaro]
Here is my laptop specs
~ inxi --admin --verbosity=7 --filter --wi…
cat /etc/modprobe.d/rtw_8723de.conf
options rtw_8723de swcrypto=1 # enables software crypto
options rtw_8723de power_save=0 # disables power management
options rtw_8723de 11n_disable=8 # disables 11n connections
options rtw_8723de disable_11ac=1 # disables 11ac connections
options rtw_8723de disable_11ax=1 # disables 11ax connections
cat /etc/NetworkManager/conf.d/wifi-powersave-off.conf
[connection]
wifi.powersave = 2
Not sure what exactly does the trick, but it works.
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Hi @neotune , and welcome!
This, and have you installed/tried the rtl8723de-dkms-git from the AUR?
pamac build rtl8723de-dkms-git
Maybe it works? Hopefully it does.
Note:
I don’t really like suggesting -git packages, because they’re usually development versions and thus more prone to breakage. But that’s all dkms package I could find for this adapter in the AUR. So if you stick with it, remember to check it every update.
Hi, I tried installing rtl8723de-dkms-git as you suggested. It doesn’t seem to install properly. No change in download speed either.
Also I forgot to mention, the upload speed is fine.
Preparing...
Cloning rtl8723de-dkms-git build files...
Generating rtl8723de-dkms-git information...
Checking rtl8723de-dkms-git dependencies...
Warning: rtl8723de-dkms-git-7b7fc22-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (1):
rtl8723de-dkms-git 7b7fc22-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building rtl8723de-dkms-git...
==> Making package: rtl8723de-dkms-git 7b7fc22-1 (Thu 31 Mar 2022 02:14:07 MSK)
==> Retrieving sources...
-> Updating rtl8723de git repo...
Fetching origin
-> Found dkms.conf
==> Validating source files with md5sums...
rtl8723de ... Skipped
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of rtl8723de git repo...
Cloning into 'rtl8723de'...
done.
==> Starting build()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl8723de-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl8723de-dkms-git 7b7fc22-1 (Thu 31 Mar 2022 02:14:22 MSK)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading package files... [1/1]
Checking file conflicts... [1/1]
Checking available disc space... [1/1]
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade... [1/2]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules [2/2]
==> dkms remove rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414
Reinstalling rtl8723de-dkms-git (7b7fc22-1)... [1/1]
Arming ConditionNeedsUpdate... [1/2]
Install DKMS modules [2/2]
==> dkms install --no-depmod rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414 -k 5.15.28-1-MANJARO
Error! Bad return status for module build on kernel: 5.15.28-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414 -k 5.15.28-1-MANJARO' exited 10
Hi @neotune I think you need to install kernel headers first if they weren’t before building the package. Do it for all the kernels you’ve installed.
sudo pacman -S linux515-headers
Hi, @raguse I have already installed them. No change in speed
To install most, if not any package you need the installed kernel’s headers, and this
sort of says they’re missing. Install the headers for all installed kernels using:
pamac install $(pamac list --quiet --installed | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
And try building the drivers again:
And see what happens.
I have only one kernel installed
mhwd-kernel -li
Currently running: 5.15.28-1-MANJARO (linux515)
* linux515
Preparing...
Warning: linux515-headers-5.15.28-1 is up to date -- skipping
Nothing to do.
Preparing...
To build (1):
==> Making package: rtl8723de-dkms-git 7b7fc22-1 (Thu 31 Mar 2022 14:05:44 MSK)
Fetching origin
-> Found dkms.conf
done.
==> Finished making: rtl8723de-dkms-git 7b7fc22-1 (Thu 31 Mar 2022 14:06:00 MSK)
==> Cleaning up...
So please provide a new
after a reboot, please.
Apparently ipx is not supported since kernel 5.15
/var/lib/dkms/rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414/build/core/rtw_br_ext.c:25:18: fatal error: net/ipx.h: No such file or directory
25 | #include <net/ipx.h>
compilation terminated.
make[2]: *** [scripts/Makefile.build:277: /var/lib/dkms/rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414/build/core/rtw_br_ext.o] Error 1
make[1]: *** [Makefile:1868: /var/lib/dkms/rtl8723de-5.1.1.8_21285.20171026_COEX20170111/1414/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.15.28-1-MANJARO/build'
make: *** [Makefile:1886: modules] Error 2
Windows
and Manjaro
[manjaro]
I was wondering, since I’ve got similar issues, are there any similar commands/options for my driver like in this post?
You could write a config file…
Create a file here: /etc/modprobe.d/wifi.conf and open an editor:
sudo nano /etc/modprobe.d/wifi.conf
Add there:
options iwlwifi swcrypto=1 # enables software crypto
options iwlwifi power_save=0 # disables power management
options iwlwifi 11n_disable=1 # disables 11n connections
options iwlwifi disable_11ac=1 # disables 11ac connections
options iwlwifi disable_11ax=1 # disables 11ax connections
Save it and exit.
Save: CTRL + S
Close: CTRL + X
Reboot you…
OK, the way I see it, you could either:
Install and use an older kernel then. 5.10 is also recent as well as LTS; or
buy and use a newer, different dongle and see what happens.
Edit:
I have NO other ideas.
Thanks for your help, I hope there’s a simpler option)
@neotune I have no further clue, however, some more info that could help:
Is there a choice 2.4 or 5 GHz on your Wifi and have you tried speed for both?
In AUR there is alternative package RTW88-dkms-git. According to github page it supports (read github and archlinux AUR comments first to see if it could be solution for you):
This repository includes drivers for the following cards:
RTL8822BE, RTL8822CE, RTL8821CE, and RTL8723DE
I might get blacklisted for posting this other forum link ( =:| I hope not) but please also read it.
Another solution after trying above does not help could be to try kernel internally provided driver rtl8xxx . To do so you would need to blacklist the current installed one and enforce rtl8xxx. I can’t help you with that but maybe someone more knowledgeable can help by picking up this thread. Thanks.
Thanks, for your input. See the first post)
