Hello,
first of all. This is my first time trying to install/use linux. So be patient.
I erased the driver of my 2010 macbook pro.
I downloaded the Manjaro 250-5-manjaro (manjaro-gnome-21.2.1-220103-linux515) and checked, that it was not corrupted and flashed it from an SD Card.
I managed to install Manjaro but already had an issue: It took about estimated 20 minutes to half an hour until the dock in the liveOS and the installation menu appeared.
After I managed to install Manjaro the system boots in normal time but when i log in it takes a similar time for the dock to appear.
Furthermore the system sometimes wakes up after it went to sleep because of inactivity but most times not. Also most times it doesn’t find Wifi.
I would really appreciate to be able to fix this issues but am already thinking about trying another gnu/linuxOS…
So thanks for your help!
Hey,
You could try running in console systemd-analyze blame and systemd-analyze blame --user, which shows which services are taking the longest to start up.
That might give some ideas what is happening and possible further steps.
Example how mine looks like
1.797s systemd-random-seed.service
949ms systemd-modules-load.service
661ms ufw.service
565ms dev-loop3.device
563ms dev-loop2.device
556ms dev-loop1.device
552ms dev-loop0.device
534ms systemd-swap.service
441ms dev-sdb2.device
336ms cups.service
316ms snapd.service
230ms polkit.service
200ms systemd-tmpfiles-clean.service
187ms user@120.service
168ms systemd-udevd.service
155ms ModemManager.service
135ms NetworkManager.service
131ms smb.service
129ms systemd-logind.service
125ms user@1000.service
123ms upower.service
122ms udisks2.service
95ms lvm2-monitor.service
91ms systemd-sysctl.service
80ms systemd-journal-flush.service
66ms lm_sensors.service
66ms systemd-udev-trigger.service
63ms boot-efi.mount
56ms media-myssd_ntfs.mount
50ms accounts-daemon.service
42ms systemd-tmpfiles-setup.service
42ms home.mount
40ms media-myssd.mount
39ms systemd-fsck@dev-disk-by\x2duuid-c49dcd3e\x2d18a1\x2d4086\x2d88c2\x2d89671dcfdf93.service
38ms systemd-timesyncd.service
32ms colord.service
31ms gdm.service
31ms systemd-journald.service
29ms var-lib-snapd-snap-core-11993.mount
24ms systemd-tmpfiles-setup-dev.service
23ms var-lib-snapd-snap-core-12603.mount
21ms systemd-fsck@dev-disk-by\x2duuid-07AD\x2dCDAD.service
21ms modprobe@fuse.service
20ms wpa_supplicant.service
20ms var-lib-snapd-snap-snapd-14295.mount
17ms var-lib-snapd-snap-snapd-14549.mount
15ms power-profiles-daemon.service
13ms tmp.mount
11ms dev-hugepages.mount
11ms sys-kernel-config.mount
10ms dev-mqueue.mount
10ms systemd-binfmt.service
10ms sys-kernel-debug.mount
9ms sys-kernel-tracing.mount
8ms alsa-restore.service
8ms kmod-static-nodes.service
7ms user-runtime-dir@120.service
7ms systemd-user-sessions.service
6ms systemd-remount-fs.service
6ms modprobe@configfs.service
6ms modprobe@drm.service
6ms linux-module-cleanup.service
5ms user-runtime-dir@1000.service
4ms systemd-update-utmp.service
4ms proc-sys-fs-binfmt_misc.mount
2ms rtkit-daemon.service
2ms sys-fs-fuse-connections.mount
329us snapd.socket
1.527s xdg-desktop-portal.service
1.233s org.gnome.Shell@x11.service
720ms xdg-desktop-portal-gtk.service
483ms pulseaudio.service
370ms tracker-miner-fs-3.service
341ms xdg-desktop-portal-gnome.service
326ms org.gnome.SettingsDaemon.XSettings.service
170ms gvfs-udisks2-volume-monitor.service
104ms evolution-source-registry.service
95ms evolution-calendar-factory.service
94ms gnome-terminal-server.service
89ms org.gnome.SettingsDaemon.MediaKeys.service
85ms org.gnome.SettingsDaemon.Color.service
83ms org.gnome.SettingsDaemon.Keyboard.service
82ms org.gnome.SettingsDaemon.Power.service
82ms org.gnome.SettingsDaemon.Wacom.service
68ms gnome-session-manager@gnome.service
32ms org.gnome.SettingsDaemon.PrintNotifications.service
31ms evolution-addressbook-factory.service
30ms org.gnome.SettingsDaemon.Datetime.service
25ms org.gnome.SettingsDaemon.Housekeeping.service
24ms org.gnome.SettingsDaemon.ScreensaverProxy.service
24ms org.gnome.SettingsDaemon.Sound.service
22ms org.gnome.SettingsDaemon.Sharing.service
20ms org.gnome.SettingsDaemon.UsbProtection.service
19ms org.gnome.SettingsDaemon.Rfkill.service
16ms org.gnome.SettingsDaemon.Smartcard.service
14ms org.gnome.SettingsDaemon.A11ySettings.service
11ms gnome-session-signal-init.service
10ms gvfs-daemon.service
9ms gvfs-mtp-volume-monitor.service
9ms flatpak-session-helper.service
7ms xdg-document-portal.service
7ms org.gnome.Shell@wayland.service
6ms gvfs-goa-volume-monitor.service
5ms gvfs-afc-volume-monitor.service
5ms at-spi-dbus-bus.service
4ms gvfs-metadata.service
3ms dbus.socket
3ms gnome-session-monitor.service
3ms dconf.service
Thank you for your help!
~ systemd-analyze blame ✔
30.995s plymouth-quit-wait.service
12.611s snapd.service
9.222s dev-mapper-luks\x2d1b2ce4cc\x2d18ac\x2d4109\x2dac6f\x2dcafb21ea0de5.dev>
8.867s polkit.service
4.372s bluetooth.service
4.362s NetworkManager.service
4.339s systemd-logind.service
4.089s cups.service
4.072s ModemManager.service
3.092s udisks2.service
2.943s apparmor.service
2.702s accounts-daemon.service
2.256s systemd-udevd.service
2.007s systemd-journal-flush.service
1.683s systemd-vconsole-setup.service
1.527s systemd-sysusers.service
1.335s gdm.service
1.266s systemd-fsck@dev-disk-by\x2duuid-9DFD\x2dCA64.service
1.263s ldconfig.service
1.027s wpa_supplicant.service
865ms systemd-random-seed.service
732ms systemd-modules-load.service
688ms systemd-tmpfiles-setup.service
systemd-analyze blame --user ✔
10.585s org.gnome.Shell@x11.service
3.973s gvfs-udisks2-volume-monitor.service
2.897s evolution-source-registry.service
2.345s gvfs-goa-volume-monitor.service
2.159s evolution-calendar-factory.service
1.802s org.gnome.SettingsDaemon.XSettings.service
1.401s pulseaudio.service
1.050s org.gnome.SettingsDaemon.Power.service
1.009s org.gnome.SettingsDaemon.MediaKeys.service
873ms org.gnome.SettingsDaemon.Wacom.service
733ms evolution-addressbook-factory.service
626ms org.gnome.SettingsDaemon.Color.service
496ms org.gnome.SettingsDaemon.Datetime.service
474ms org.gnome.SettingsDaemon.Keyboard.service
339ms gnome-terminal-server.service
283ms org.gnome.SettingsDaemon.A11ySettings.service
258ms gnome-session-signal-init.service
251ms org.gnome.SettingsDaemon.Housekeeping.service
245ms gnome-session-manager@gnome.service
208ms org.gnome.SettingsDaemon.Rfkill.service
208ms org.gnome.SettingsDaemon.Sound.service
194ms org.gnome.SettingsDaemon.PrintNotifications.service
194ms org.gnome.SettingsDaemon.Smartcard.service
Wollie
27 January 2022 15:57
5
Have you encrypted the disk or partitions? Decryption could take quite a while.
More helpful would be output of
systemd-analyze critical-chain
Yes, i encrypted the disk.
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target at52.881s
└─multi-user.target at52.881s
└─plymouth-quit-wait.service at21.084s +31.796s
└─systemd-user-sessions.service at20.973s +101ms
└─nss-user-lookup.target at23.785s
Sorry. I had to replace @ with “at” because I’m only allowed to mention two users.
Welcome to the forum!
Tip: When pasting terminal output on Discourse forums, one can either…
Use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
I’ve done it for you this time.
In the future, please edit your previous post rather than posting multiple times in a row. This is a support forum, not an instant messenger.
I would remove plymouth and also remove the entry from /etc/mkinitcpio.conf and then run
sudo mkinitcpio -P
sudo update-grub
You can also
systemctl mask ModemManager.service
Thank you! I renmoved Plymouth with
systemctl disable plymouth….service
Nothing changed.
But how can I remove it from the file? Sorry I’m a real noob. I opened the file but there is nothing to find so I guess I have to do this per commands in terminal?!
