As in the title - when I’m running my python code that requires GLIBCXX_3.4.29 I run into an error
File "e_tests.py", line 10, in <module>
import interface
ImportError: /home/ian/anaconda3/envs/crannog/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by X/so_file.so)
Looking around, the first step seems to be strings /usr/lib64/libstdc++.so.6 | grep GLIBCXX which details if the file is there. However, mine actually already exists…
... //misc entries
GLIBCXX_3.4.27
GLIBCXX_3.4.28
GLIBCXX_3.4.29// THIS IS IT
GLIBCXX_DEBUG_MESSAGE_LENGTH
_ZNKSt14basic_ifstreamIcSt11char_traitsIcEE7is_openEv@GLIBCXX_3.4
_ZNSt13basic_istreamIwSt11char_traitsIwEE6ignoreEv@@GLIBCXX_3.4.5
_ZNKSbIwSt11char_traitsIwESaIwEE11_M_disjunctEPKw@GLIBCXX_3.4
_ZNKSt14basic_ifstreamIwSt11char_traitsIwEE7is_openEv@@GLIBCXX_3.4.5
...... // many more entries
I saw someone mention a pacman.conf (or more like multilib) in some thread I’ve now lost but here’s my pacman.conf
[options]
CacheDir = /var/cache/pacman/pkg/
HoldPkg = pacman glibc manjaro-system
SyncFirst = manjaro-system archlinux-keyring manjaro-keyring
Architecture = auto
CheckSpace
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
[archlinuxfr]
SigLevel = Never
Server = http://repo.archlinux.fr/$arch
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
[multilib]
Thanks for taking the time to read this! If I can provide any more details please let me know
Anaconda as far as I know does not use the system libs, therefore you’re missing something in your environment. Maybe install what you need with conda install <package>?
Hmm, do you know what I might install? I just tried conda install libgcc but ran into the same error. It seemed to work for some other people based on some stackoverflow post askubuntucom/a/786944
Ahh, sorry to hear I THINK mine is related to conda, but I’m not sure… I wish I could be more help but I’m also really not sure what to do. I for one am just trying to figure out how to get conda to use my system’s libgcc or whatever
my issue is also related to conda, the application cq-editor was installed through conda, I run it in a conda enviornment. I also get a missing GLIBCXX error even though I have it in /usr/lib64
next time? just making an educated guess, it might also have worked idk. just leaving this here if anyone else has this problem wants to try this way instead.
I tried running the tests on this project: SymSpellCppPy and even though I installed the requirements using poetry I got the following error:
ImportError: /home/user/miniconda3/bin/../lib/libstdc++.so.6: version 'GLIBCXX_3.4.29' not found (required by /home/user/repos/other/SymSpellCppPy/SymSpellCppPy.cpython-39-x86_64-linux-gnu.so)
Weird that it looked for this file in my miniconda3 directory…
