USB microphone not working after latest updates
Hi,
I have a USB microphone which used to work perfectly. Since the first (august 17th) stable Pahvo release, however, it has not been detected by my system and doesn’t show up anywhere. I know the mic itself is fine because it works perfectly in Windows regardless of the usb port it’s plugged in, so I think something got broken with the Pahvo update.
When plugged in, this shows up with lsusb
Bus 001 Device 009: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec
and the mic’s led does turn on. It doesn’t seem to be detectable with commands like pacmd list-sources or pulseaudio-ctl (their output doesn’t change regardless of the mic being plugged in). I have also updated all my packages a few minutes ago so everything should be up to date.
I don’t know which other commands I could use to diagnose this, so any help is appreciated
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
As @Fabby suggests, your system information can help greatly.
With that said, a recent update completely borked my audio on my netbook. Turns out the update to kernel 5.10 (LTS) triggered it.
Out of curiosity, I installed kernel 5.13, and my audio was working normally again.
Without changing anything related to pulse, alsa, etc, simply booting into kernel 5.13 resolves this issue. It’s concerning to me, since 5.10 is supposed to have greater support and fewer incidents due to being an “LTS” kernel.
fab-user@fab-manjaro:~
$ uname --kernel-release
5.10.60-1-MANJARO
Sound works here @winnie so I’m pretty sure it’s not the kernel: It’s you! :joy: :wink:
Perhaps! Or maybe it’s kernel + hardware.
Rebooting into 5.10 re-introduces the audio issues. Rebooting into 5.13, audio is back to normal. Started happening after a recent update via Pamac that I pulled on August 27. (I will provided specific package information once I can access the laptop, but I don’t want to divert this thread either; especially if it is an upstream bug.)
Package history and story follows.
:question: Updated kernel 5.10 (5.10.56-1 → 5.10.59-1). No issues with sound yet. None that I recall. (It may in fact have started here!)
  • [2021-08-25T15:16:58] upgraded linux510 (5.10.56-1 → 5.10.59-1)
:no_entry_sign: Updated kernel 5.10 (5.10.59-1 → 5.10.60-1), sound does not work properly (unusable!)
  • [2021-08-29T00:42:10 upgraded linux510 (5.10.59-1 → 5.10.60-1)
:white_check_mark: Installed kernel 5.13 (via mhwd-kernel GUI), sound works normally again when booting with kernel 5.13.
  • [2021-08-29T11:23:52] installed linux513 (5.13.12-1)
NOTE: There’s a discrepency of the “real” update’s date/time due to using Timeshift to “revert” and “try again”. This was before I knew that the update to kernel 5.10 was the culprit.
UPDATE: After reviewing this, the problem may in fact have started with kernel 5.10.59, and I only noticed it with 5.10.60 due to not using the netbook as often and the small window between updates.
As it stands now, I must boot into kernel 5.13 in order to have working sound, until a regression is identified and fixed with upstream kernel development (in regards to kernel 5.10). If I boot into kernel 5.10.60-1, my sound does not work properly. If I yet again reboot into kernel 5.13.12-1, sound works normally again.
Relevant system information for a session with broken, non-working audio:
  Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: ASUSTeK product: T100TAM v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: T100TAM v: 1.0 serial: <filter>
  UEFI: American Megatrends v: T100TAM.400 date: 03/07/2016
  Info: Quad Core model: Intel Atom Z3775 bits: 64 type: MCP arch: Silvermont
  family: 6 model-id: 37 (55) stepping: 8 microcode: 838 cache: L2: 1024 KiB
  bogomips: 11738
  Device-1: bytcr-rt5640 driver: bytcr-rt5640
  message: bus/chip ids unavailable
  Device-2: Intel HDMI/DP LPE Audio driver: HdmiLpeAudio
  Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
  Processes: 207 Uptime: 15m wakeups: 3 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 993 lib: 321 Shell: Bash v: 5.1.8
  running-in: xfce4-terminal inxi: 3.3.06
Must indeed be a bug in 5.10.60-1… Also: I have never seen a machine with a bytcr-rt5640 before: most of the time it’s Intel or AMD.
:sob:
@Fabby
Audio codec RT5640 bytcr-rt5640 is more common on ARM systems
This audio codec might be better supported by a later kernel version and/or patches for alsa-ucm
But it is not relevant to OP issue with USB device
PCM2902 Audio Codec is very common and usually works well with driver snd_usb_audio
IMO a later kernel is unlikely to resolve an audio issue
(but it could be a Million-to-one chance )
Looks like we have the same bug with the Texas Instruments PCM2902 Audio Codec in kernel 5.10-59-1.
I tried the kernel 5.12, 5.13 and 5.4: no changes.
I installed pipewire: no changes.
I wish I could restore the 5.10-42-1 kernel.
https://forum.manjaro.org/t/audio-interface-disappeared-from-sound-panel/79570/3
OP mentions using a USB microphone rather than a USB interface
A microphone might only have input capture enabled as a mono capture input
If device does not have a jack socket for headphone monitoring, audio playback might be disabled within the audio codec
PCM2902 audio codec has been around for many years and is used by many manufacturers for low-budget audio devices
I checked my kernel and I am using 5.13 :neutral_face:
I tried to clear that database and I also switched to kernel 5.10, but they both didn’t work
Sorry, as I said I didn’t know of which diagnostic command I should post the output.
Inxi returned this:
  root=UUID=66a7f010-8005-47a5-9bfd-30036ca637a3 ro quiet splash apparmor=1
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
  serial: <filter> UEFI: American Megatrends v: 2.10 date: 07/01/2020
  RAM: total: 15.62 GiB used: 1.94 GiB (12.4%)
  Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
  L2: 3 MiB bogomips: 86434
  Speed: 2264 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 2264 2: 2116 3: 2080 4: 3949 5: 2346 6: 2055 7: 2055 8: 3599 9: 2587
  10: 1947 11: 2092 12: 2079
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
  vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
  xsaveopt xsaves
  conditional, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 2b:00.0
  chip-ID: 1002:67df class-ID: 0300
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0
  5.10.60-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 2b:00.1
  chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 2d:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Sound Server-4: PipeWire v: 0.3.33 running: no
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
  v: kernel bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
  vendor: Micro-Star MSI driver: r8168 v: 8.049.02-NAPI modules: r8169
  port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp42s0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-9:4 chip-ID: 8087:0aa7 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
  Local Storage: total: 1.36 TiB used: 509.68 GiB (36.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
  type: HDD rpm: 7200 serial: <filter> rev: 1A02 scheme: GPT
  ID-1: / raw-size: 400 GiB size: 392.72 GiB (98.18%) used: 116.8 GiB (29.7%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
  uuid: 66a7f010-8005-47a5-9bfd-30036ca637a3
  used: 27.3 MiB (28.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: AC09-3488
  ID-3: /mnt/Backup raw-size: 300 GiB size: 300 GiB (100.00%)
  used: 195.83 GiB (65.3%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 72A0F0BF04BD84F6
  ID-4: /mnt/Solaio raw-size: 631.51 GiB size: 620.53 GiB (98.26%)
  used: 197.02 GiB (31.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Solaio
  uuid: 18fbe533-b191-4167-b69b-852f29e2d566
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 65.15 GiB fs: ntfs label: N/A
  uuid: 78280CCB280C89F8
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 507 MiB fs: ntfs label: N/A
  uuid: 4CC247E7C247D3BC
  Hub-2: 1-7:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-8:3 info: Micro Star MYSTIC LIGHT type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 1462:7c95 class-ID: 0300 serial: <filter>
  Device-2: 1-9:4 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-1:2 info: SHARKOON Keyboard type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 1ea7:0907 class-ID: 0300 serial: <filter>
  Device-2: 3-2:3 info: Microsoft Comfort Mouse 4500 type: Mouse
  driver: microsoft,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
  chip-ID: 045e:076c class-ID: 0301
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 61.5 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 765
  Processes: 363 Uptime: 2m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1724 note: see --pkg
  pacman: 1717 lib: 462 flatpak: 0 snap: 7 Shell: Zsh v: 5.8 running-in: tilix
  inxi: 3.3.06
If the command to clear databases and PulseAudio cookie did not work did terminal respond with any error messages?
Please post ALSA information
sudo alsa-info.sh --upload
Not directly related to your problem, but please read this…
:+1:
Nope
!!ALSA Information Script v 0.5.0
!!Script ran on: Tue Aug 31 15:59:17 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Micro-Star International Co., Ltd.
Product Name:      MS-7C95
Product Version:   1.0
Firmware Version:  2.10
System SKU:        To be filled by O.E.M.
Board Vendor:      Micro-Star International Co., Ltd.
Board Name:        B550M PRO-VDH WIFI (MS-7C95)
!!ACPI Device Status Information
/sys/bus/acpi/devices/AMDI0030:00/status 	 15
/sys/bus/acpi/devices/AMDIF030:00/status 	 15
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0501:00/status 	 15
/sys/bus/acpi/devices/PNP0A08:00/status 	 15
/sys/bus/acpi/devices/PNP0C01:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:01/status 	 15
/sys/bus/acpi/devices/PNP0C02:03/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:01/status 	 11
/sys/bus/acpi/devices/PNP0C0F:02/status 	 11
/sys/bus/acpi/devices/PNP0C0F:03/status 	 11
/sys/bus/acpi/devices/PNP0C0F:04/status 	 11
/sys/bus/acpi/devices/PNP0C0F:05/status 	 11
/sys/bus/acpi/devices/PNP0C0F:06/status 	 11
/sys/bus/acpi/devices/PNP0C0F:07/status 	 11
/sys/bus/acpi/devices/device:12/status 	 15
!!Kernel Information
Kernel release:    5.10.60-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.10.60-1-MANJARO
Library version:    1.2.5.1
Utilities version:  1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xfce60000 irq 76
 1 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xfca00000 irq 78
!!PCI Soundcards installed in the system
2b:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
	Subsystem: Sapphire Technology Limited Device [1da2:aaf0]
2d:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
	DeviceName: Realtek ALC1220
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
	dmic_detect : Y
	enable_msi : -1
	pm_blacklist : Y
	power_save : 0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Converter: stream=0, channel=0
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=1, device=0
  Control: name="IEC958 Playback Pro Mask", index=1, device=0
  Control: name="IEC958 Playback Default", index=1, device=0
  Control: name="IEC958 Playback Switch", index=1, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=2, device=0
  Control: name="IEC958 Playback Pro Mask", index=2, device=0
  Control: name="IEC958 Playback Default", index=2, device=0
  Control: name="IEC958 Playback Switch", index=2, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=3, device=0
  Control: name="IEC958 Playback Pro Mask", index=3, device=0
  Control: name="IEC958 Playback Default", index=3, device=0
  Control: name="IEC958 Playback Switch", index=3, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=4, device=0
  Control: name="IEC958 Playback Pro Mask", index=4, device=0
  Control: name="IEC958 Playback Default", index=4, device=0
  Control: name="IEC958 Playback Switch", index=4, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital: Enabled
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=5, device=0
  Control: name="IEC958 Playback Pro Mask", index=5, device=0
  Control: name="IEC958 Playback Default", index=5, device=0
  Control: name="IEC958 Playback Switch", index=5, device=0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0c
Node 0x0e [Audio Output] wcaps 0x221: Stereo Digital Stripe
  Digital:
Node 0x0f [Pin Complex] wcaps 0x400381: Stereo Digital
  Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0e
Codec: Realtek ALC892
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0892
Subsystem Id: 0x14629c95
Revision Id: 0x100302
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC892 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
  Amp-Out vals:  [0x37 0x37]
  Converter: stream=5, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Amp-Out vals:  [0x00 0x00]
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
  Amp-In vals:  [0x2e 0x2e]
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=1, device=0
  Control: name="Capture Switch", index=1, device=0
  Device: name="ALC892 Alt Analog", type="Audio", device=2
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Rear Mic Playback Volume", index=0, device=0
  Control: name="Rear Mic Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000010: OUT
  Pin Default 0x4037c040: [N/A] CD at Ext N/A
    Conn = Analog, Color = UNKNOWN
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x01014010: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=05, enabled=1
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Pincap 0x00000036: IN OUT Detect Trigger
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Switch", index=0, device=0
  Control: name="Rear Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00003736: IN OUT Detect Trigger
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19030: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0x21: IN VREF_50
  Unsolicited: tag=03, enabled=1
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Amp-In vals:  [0x02 0x02]
  Pincap 0x0000373e: IN OUT HP Detect Trigger
  Pin Default 0x02a19040: [Jack] Mic at Ext Front
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Control: name="Line Boost Volume", index=0, device=0
  Pin Default 0x0181303f: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x3, Sequence = 0xf
  Pin-ctls: 0x20: IN VREF_HIZ
  Unsolicited: tag=04, enabled=1
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x02214020: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Unsolicited: tag=01, enabled=1
  Connection: 5
     0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
  Pincap 0x00000024: IN Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x4028c66b: [N/A] HP Out at Ext N/A
    Conn = DIN, Color = UNKNOWN
    DefAssociation = 0x6, Sequence = 0xb
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 12
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Amp-Out vals:  [0x40 0x40]
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116,  9 Aug 31 16:29 /dev/snd/controlC0
crw-rw----  1 root audio 116, 14 Aug 31 16:29 /dev/snd/controlC1
crw-rw----  1 root audio 116,  8 Aug 31 16:29 /dev/snd/hwC0D0
crw-rw----  1 root audio 116, 13 Aug 31 16:29 /dev/snd/hwC1D0
crw-rw----  1 root audio 116,  6 Aug 31 16:30 /dev/snd/pcmC0D10p
crw-rw----  1 root audio 116,  7 Aug 31 16:30 /dev/snd/pcmC0D11p
crw-rw----  1 root audio 116,  2 Aug 31 16:30 /dev/snd/pcmC0D3p
crw-rw----  1 root audio 116,  3 Aug 31 16:30 /dev/snd/pcmC0D7p
crw-rw----  1 root audio 116,  4 Aug 31 16:30 /dev/snd/pcmC0D8p
crw-rw----  1 root audio 116,  5 Aug 31 16:30 /dev/snd/pcmC0D9p
crw-rw----  1 root audio 116, 11 Aug 31 16:30 /dev/snd/pcmC1D0c
crw-rw----  1 root audio 116, 10 Aug 31 16:30 /dev/snd/pcmC1D0p
crw-rw----  1 root audio 116, 12 Aug 31 16:29 /dev/snd/pcmC1D2c
crw-rw----  1 root audio 116,  1 Aug 31 16:29 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Aug 31 16:29 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Aug 31 16:30 .
drwxr-xr-x 3 root root 360 Aug 31 16:30 ..
lrwxrwxrwx 1 root root  12 Aug 31 16:29 pci-0000:2b:00.1 -> ../controlC0
lrwxrwxrwx 1 root root  12 Aug 31 16:29 pci-0000:2d:00.4 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC892 Analog [ALC892 Analog]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 2: ALC892 Alt Analog [ALC892 Alt Analog]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card HDMI
Card sysdefault:0 'HDMI'/'HDA ATI HDMI at 0xfce60000 irq 76'
  Mixer name	: 'ATI R6xx HDMI'
  Components	: 'HDA:1002aa01,00aa0100,00100700'
  Controls      : 42
  Simple ctrls  : 6
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'IEC958',5
  Mono: Playback [on]
!!-------Mixer controls for card Generic
Card sysdefault:1 'Generic'/'HD-Audio Generic at 0xfca00000 irq 78'
  Mixer name	: 'Realtek ALC892'
  Components	: 'HDA:10ec0892,14629c95,00100302'
  Controls      : 39
  Simple ctrls  : 20
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 64
  Mono: Playback 55 [86%] [-9.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 64 [100%] [0.00dB] [on]
  Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Mono:
  Front Left: Playback 64 [100%] [0.00dB] [off]
  Front Right: Playback 64 [100%] [0.00dB] [off]
Simple mixer control 'Front Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 2 [67%] [20.00dB]
  Front Right: 2 [67%] [20.00dB]
Simple mixer control 'Surround',0
  Mono:
  Front Left: Playback 0 [0%] [-64.00dB] [off]
  Front Right: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'Center',0
  Mono: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 46
  Front Left: Capture 46 [100%] [30.00dB] [on]
  Front Right: Capture 46 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-16.00dB] [off]
  Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Channel Mode',0
  Capabilities: enum
  Items: '2ch' '4ch' '6ch'
  Item0: '2ch'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Front Mic' 'Rear Mic' 'Line'
  Item0: 'Front Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
!!Alsactl output
--startcollapse--
state.HDMI {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=11 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 5
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 5
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 11
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.38 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.39 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.40 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.41 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.42 {
		iface PCM
		device 11
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
state.Generic {
	control.1 {
		iface MIXER
		name 'Channel Mode'
		value '2ch'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '2ch'
			item.1 '4ch'
			item.2 '6ch'
	control.2 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.3 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.4 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
			dbvalue.1 -6400
	control.5 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.6 {
		iface MIXER
		name 'Center Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
	control.7 {
		iface MIXER
		name 'LFE Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
	control.8 {
		iface MIXER
		name 'Center Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'LFE Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.10 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.11 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.12 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.13 {
		iface MIXER
		name 'Front Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.14 {
		iface MIXER
		name 'Front Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.15 {
		iface MIXER
		name 'Rear Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.16 {
		iface MIXER
		name 'Rear Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.17 {
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.18 {
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.19 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.20 {
		iface MIXER
		name 'Input Source'
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Front Mic'
			item.1 'Rear Mic'
			item.2 Line
	control.21 {
		iface MIXER
		name 'Input Source'
		index 1
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Front Mic'
			item.1 'Rear Mic'
			item.2 Line
	control.22 {
		iface MIXER
		name 'Capture Volume'
		value.0 46
		value.1 46
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 46'
			dbmin -1600
			dbmax 3000
			dbvalue.0 3000
			dbvalue.1 3000
	control.23 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.24 {
		iface MIXER
		index 1
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 46'
			dbmin -1600
			dbmax 3000
			dbvalue.0 -1600
			dbvalue.1 -1600
	control.25 {
		iface MIXER
		index 1
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.26 {
		iface MIXER
		name 'Front Mic Boost Volume'
		value.0 2
		value.1 2
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 2000
			dbvalue.1 2000
	control.27 {
		iface MIXER
		name 'Rear Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.28 {
		iface MIXER
		name 'Line Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.29 {
		iface MIXER
		name 'Master Playback Volume'
		value 55
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -900
	control.30 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.31 {
		iface CARD
		name 'Front Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface CARD
		name 'Rear Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.33 {
		iface CARD
		name 'Line Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.34 {
		iface CARD
		name 'Line Out Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.35 {
		iface CARD
		name 'Front Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.37 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.38 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.39 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_cpufreq
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
amdgpu
bluetooth
bnep
br_netfilter
bridge
btbcm
btintel
btrtl
btusb
ccm
ccp
cec
cfg80211
cmac
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
edac_mce_amd
ext4
fat
fb_sys_fops
ff_memless
fuse
ghash_clmulni_intel
glue_helper
gpio_amdpt
gpio_generic
gpu_sched
hid_microsoft
i2c_algo_bit
i2c_piix4
ip_tables
iptable_filter
iptable_nat
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libarc4
libcrc32c
llc
loop
mac80211
mac_hid
mbcache
mc
mousedev
nf_conntrack
nf_conntrack_netlink
nf_defrag_ipv4
nf_defrag_ipv6
nf_nat
nfnetlink
overlay
pcspkr
pinctrl_amd
r8168
rapl
rfcomm
rfkill
rng_core
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_rawmidi
snd_seq_device
snd_soc_core
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sp5100_tco
squashfs
stp
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
uinput
usbhid
vfat
wmi
wmi_bmof
x_tables
xhci_pci
xt_MASQUERADE
xt_addrtype
xt_conntrack
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x185600f0
0x09 0x185600f0
0x0b 0x185600f0
0x0d 0x185600f0
0x0f 0x585600f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x11 0x4037c040
0x12 0x411111f0
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19030
0x19 0x02a19040
0x1a 0x0181303f
0x1b 0x02214020
0x1c 0x411111f0
0x1d 0x4028c66b
0x1e 0x411111f0
0x1f 0x411111f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[    0.282575] ACPI: Added _OSI(Linux-Dell-Video)
[    0.282576] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.282577] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    3.685813] EDAC amd64: Node 0: DRAM ECC disabled.
[    3.699625] snd_hda_intel 0000:2b:00.1: Handle vga_switcheroo audio client
[    3.699627] snd_hda_intel 0000:2b:00.1: Force to non-snoop mode
[    3.699837] snd_hda_intel 0000:2d:00.4: enabling device (0000 -> 0002)
[    3.797185] EDAC amd64: F17h_M70h detected (node 0).
[    3.797233] EDAC amd64: Node 0: DRAM ECC disabled.
[    3.798648] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:2b:00.1/sound/card0/input3
[    3.798679] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:2b:00.1/sound/card0/input4
[    3.798703] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:2b:00.1/sound/card0/input5
[    3.798727] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:2b:00.1/sound/card0/input6
[    3.798750] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:2b:00.1/sound/card0/input7
[    3.798772] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:2b:00.1/sound/card0/input8
[    3.867106] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    3.867108] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.867109] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.867109] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    3.867110] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    3.867110] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[    3.867111] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    3.867112] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[    3.893260] EDAC amd64: F17h_M70h detected (node 0).
[    3.893311] EDAC amd64: Node 0: DRAM ECC disabled.
[    3.893961] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:2d:00.4/sound/card1/input9
[    3.894012] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:2d:00.4/sound/card1/input10
[    3.894043] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:2d:00.4/sound/card1/input11
[    3.894093] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:2d:00.4/sound/card1/input12
[    3.894127] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:2d:00.4/sound/card1/input13
[    3.894382] [drm] amdgpu kernel modesetting enabled.
[    3.985094] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.986070] snd_hda_intel 0000:2b:00.1: bound 0000:2b:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[    3.990714] enp42s0: 0xffffb2fc802ed000, 2c:f0:5d:82:cb:29, IRQ 73
[   48.278152] mc: Linux media interface: v0.10
[   48.398942] usbcore: registered new interface driver snd-usb-audio
[   54.944271] usb 1-4: USB disconnect, device number 5
!!Packages installed
Thanks, I’ve never really thought about swaps, I’ll give it a look
If there were no error messages the command must have successfully deleted the files as intended
and PulseAudio probably restored the files after reboot
ALSA data shows only card 1 (onboard audio ALC892) detected as 2 audio capture inputs
card 0 only has playback outputs for HDMI
USB device would be shown as card 2 if detected correctly
But there is only one mention for a USB device at the end of !!ALSA/HDA dmesg
The audio device was listed in OP as device 009
I suggest you check detailed information about USB devices
lsusb -v
to see if there is any connection between device 5 and device 9
Here’s the output:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         3
  bMaxPacketSize0         9
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0003 3.0 root hub
  bcdDevice            5.13
  iManufacturer           3 Linux 5.13.13-1-MANJARO xhci-hcd
  iProduct                2 xHCI Host Controller
  iSerial                 1 0000:2d:00.3
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
        bMaxBurst               0
Bus 003 Device 003: ID 045e:076c Microsoft Corp. Comfort Mouse 4500
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x045e Microsoft Corp.
  idProduct          0x076c Comfort Mouse 4500
  bcdDevice            1.83
  iManufacturer           1 Microsoft
  iProduct                2 Microsoft® Comfort Mouse 4500
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength     364
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
Bus 003 Device 002: ID 1ea7:0907 SHARKOON Technologies GmbH Keyboard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x1ea7 SHARKOON Technologies GmbH
  idProduct          0x0907 Keyboard
  bcdDevice            3.00
  iManufacturer           1 SEMITEK
  iProduct                2 USB-HID Gaming Keyboard
  iSerial                 3 SN0000000001
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x005b
    bNumInterfaces          3
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      64
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      34
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength     203
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            5.13
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         3
  bMaxPacketSize0         9
  bcdDevice            5.13
  iSerial                 1 0000:02:00.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
Bus 001 Device 005: ID 8087:0aa7 Intel Corp. Wireless-AC 3168 Bluetooth
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          224 Wireless
  bDeviceSubClass         1 Radio Frequency
  bDeviceProtocol         1 Bluetooth
  bMaxPacketSize0        64
  idVendor           0x8087 Intel Corp.
  idProduct          0x0aa7 Wireless-AC 3168 Bluetooth
  bcdDevice            0.01
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x00b1
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       224 Wireless
      bInterfaceSubClass      1 Radio Frequency
      bInterfaceProtocol      1 Bluetooth
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            1
          Transfer Type            Isochronous
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0000  1x 0 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0009  1x 9 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0011  1x 17 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0019  1x 25 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0021  1x 33 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0031  1x 49 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
Bus 001 Device 004: ID 1462:7c95 Micro Star International MYSTIC LIGHT
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x1462 Micro Star International
  idProduct          0x7c95
  bcdDevice            0.01
  iManufacturer           1 MSI
  iProduct                2 MYSTIC LIGHT
  iSerial                 3 A02020051202
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength     154
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               5
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               5
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0608 Hub
  bcdDevice           60.70
  iManufacturer           0
  iProduct                1 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
Bus 001 Device 002: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x08bb Texas Instruments
  idProduct          0x2902 PCM2902 Audio Codec
  bcdDevice            1.00
  iManufacturer           1 C-Media Electronics Inc.
  iProduct                2 USB PnP Sound Device
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0099
    bNumInterfaces          3
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               1.00
        wTotalLength       0x0037
        bInCollection           1
        baInterfaceNr(0)        1
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             2
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bNrChannels             1
        wChannelConfig     0x0001
          Left Front (L)
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             7
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               8
        iTerminal               0
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      5 (SELECTOR_UNIT)
        bUnitID                 8
        bNrInPins               1
        baSourceID(0)          10
        iSelector               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                10
        bSourceID               2
        bControlSize            1
        bmaControls(0)       0x43
          Mute Control
          Volume Control
          Automatic Gain Control
        bmaControls(1)       0x00
        iFeature                0
        bLength                 9
        bDescriptorType        36
        bUnitID                13
        bSourceID               2
        bControlSize            1
        bmaControls(0)       0x03
          Mute Control
          Volume Control
        bmaControls(1)       0x00
        iFeature                0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           7
        bDelay                  1 frames
        wFormatTag         0x0001 PCM
        bLength                14
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            2 Discrete
        tSamFreq[ 0]        48000
        tSamFreq[ 1]        44100
        bLength                 9
        bDescriptorType         5
        bmAttributes            9
          Synch Type               Adaptive
          Usage Type               Data
        wMaxPacketSize     0x0064  1x 100 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           0
        AudioStreaming Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x01
            Sampling Frequency
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.00
          bNumDescriptors         1
          wDescriptorLength      60
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               2
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice            5.13
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Now it’s on Bus 001 Device 004: Are you plugging your Micro Star MYSTIC LIGHT into the same USB port every time you give info, because if not, you’re making this into a wild goose chase and we cannot compare your previous output to your current one.
If not, please:
  • ensure you’re not plugging your device into an external USB hub but straight into a computer port.
  • provide all of the information we requested before again but this time , don’t move that thing around, please?
:upside_down_face: :crazy_face:
