I have a Dell XPS 9370 laptop. It only has USB-C ports.
If I only use WiFi, networking is fine, but if I use a USB ethernet adapter, the system always hangs after some time of inactivity. I have tried with 3 different ethernet adapters: the powered Dell dock, a Belkin dongle and a noname USB-A adapter connected through a combined HDMI-USB dongle from Satechi.
Inxi and relevant journal excerpt below.
When the system ‘hangs’, I can still log back in from the lockscreen, I can still open/close most applications, I can switch to another TTY, but… the system hangs (except for moving the mouse pointer) when I click the network icon in the system tray or when I try to shut the laptop down (both through the GUI and from the command line).
Any ideas how to proceed? I have been thinking maybe it is a power management issue?
Inxi
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Cinnamon 4.8.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 13 7390 v: N/A serial: <filter>
Mobo: Dell model: 0G2D0W v: A00 serial: <filter> UEFI: Dell v: 1.7.0 date: 10/22/2020
Battery: ID-1: BAT0 charge: 51.2 Wh condition: 51.2/52.0 Wh (99%) model: SMP DELL G8VCF6C status: Full
Device-1: hid-98:fd:b4:7a:93:66-battery model: ThinkPad Bluetooth Laser Mouse charge: N/A status: Discharging
CPU: Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake rev: C L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36812
Speed: 700 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 735 2: 736 3: 782 4: 742 5: 746 6: 746 7: 746 8: 796
Graphics: Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:2
Display: x11 server: X.Org 1.20.10 driver: modesetting resolution: 1: 1920x1080~60Hz 2: 3840x2160~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.3 direct render: Yes
Audio: Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus ID: 5-2.3.3:6
Device-3: Realtek USB Audio type: USB driver: snd-usb-audio bus ID: 5-2.3.4:7
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 vendor: Bigfoot Networks driver: iwlwifi v: kernel port: efa0 bus ID: 02:00.0
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus ID: 6-2.4:4
IF: ens4u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 281.08 GiB (58.9%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC601 NVMe 512GB size: 476.94 GiB
Partition: ID-1: / size: 467.01 GiB used: 280.92 GiB (60.2%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 968.3 MiB used: 122.2 MiB (12.6%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: file size: 16.00 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors: System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Info: Processes: 266 Uptime: 27m Memory: 15.46 GiB used: 2.13 GiB (13.8%) Init: systemd Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: 1550 Shell: Bash v: 5.0.18 inxi: 3.1.08
Journal extract
dec 26 15:52:25 shaun kernel: INFO: task kworker/5:1:9485 blocked for more than 122 seconds.
dec 26 15:52:25 shaun kernel: Not tainted 5.9.11-3-MANJARO #1
dec 26 15:52:25 shaun kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
dec 26 15:52:25 shaun kernel: task:kworker/5:1 state:D stack: 0 pid: 9485 ppid: 2 flags:0x00004080
dec 26 15:52:25 shaun kernel: Workqueue: events rtl_work_func_t [r8152]
dec 26 15:52:25 shaun kernel: Call Trace:
dec 26 15:52:25 shaun kernel: __schedule+0x292/0x830
dec 26 15:52:25 shaun kernel: schedule+0x46/0xf0
dec 26 15:52:25 shaun kernel: rpm_resume+0x189/0x820
dec 26 15:52:25 shaun kernel: ? wait_woken+0x80/0x80
dec 26 15:52:25 shaun kernel: rpm_resume+0x2fe/0x820
dec 26 15:52:25 shaun kernel: __pm_runtime_resume+0x3b/0x60
dec 26 15:52:25 shaun kernel: usb_autopm_get_interface+0x18/0x50
dec 26 15:52:25 shaun kernel: rtl_work_func_t+0x69/0x2d0 [r8152]
dec 26 15:52:25 shaun kernel: ? __schedule+0x29a/0x830
dec 26 15:52:25 shaun kernel: process_one_work+0x1da/0x3d0
dec 26 15:52:25 shaun kernel: worker_thread+0x4d/0x3d0
dec 26 15:52:25 shaun kernel: ? rescuer_thread+0x410/0x410
dec 26 15:52:25 shaun kernel: kthread+0x142/0x160
dec 26 15:52:25 shaun kernel: ? __kthread_bind_mask+0x60/0x60
dec 26 15:52:25 shaun kernel: ret_from_fork+0x1f/0x30
dec 26 15:54:27 shaun kernel: INFO: task NetworkManager:668 blocked for more than 122 seconds.
dec 26 15:54:27 shaun kernel: Not tainted 5.9.11-3-MANJARO #1
dec 26 15:54:27 shaun kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
dec 26 15:54:27 shaun kernel: task:NetworkManager state:D stack: 0 pid: 668 ppid: 1 flags:0x00000080
dec 26 15:54:27 shaun kernel: Call Trace:
dec 26 15:54:27 shaun kernel: __schedule+0x292/0x830
dec 26 15:54:27 shaun kernel: schedule+0x46/0xf0
dec 26 15:54:27 shaun kernel: schedule_preempt_disabled+0x14/0x20
dec 26 15:54:27 shaun kernel: __mutex_lock.constprop.0+0x180/0x530
dec 26 15:54:27 shaun kernel: nl80211_dump_scan+0x4a/0x790 [cfg80211]
dec 26 15:54:27 shaun kernel: ? netlink_dump+0xba/0x3e0
dec 26 15:54:27 shaun kernel: ? kmalloc_large_node+0x7f/0x90
dec 26 15:54:27 shaun kernel: ? __kmalloc_node_track_caller+0x2a7/0x340
dec 26 15:54:27 shaun kernel: ? __alloc_skb+0x95/0x1f0
dec 26 15:54:27 shaun kernel: netlink_dump+0x186/0x3e0
dec 26 15:54:27 shaun kernel: __netlink_dump_start+0x1b9/0x2d0
dec 26 15:54:27 shaun kernel: genl_family_rcv_msg_dumpit+0xf4/0x190
dec 26 15:54:27 shaun kernel: ? genl_rcv_msg+0x310/0x310
dec 26 15:54:27 shaun kernel: ? nl80211_dump_survey+0x320/0x320 [cfg80211]
dec 26 15:54:27 shaun kernel: ? genl_family_rcv_msg_dumpit+0x190/0x190
dec 26 15:54:27 shaun kernel: genl_rcv_msg+0x287/0x310
dec 26 15:54:27 shaun kernel: ? genl_family_rcv_msg_attrs_parse.isra.0+0xd0/0xd0
dec 26 15:54:27 shaun kernel: netlink_rcv_skb+0x75/0x140
dec 26 15:54:27 shaun kernel: genl_rcv+0x24/0x40
dec 26 15:54:27 shaun kernel: netlink_unicast+0x242/0x340
dec 26 15:54:27 shaun kernel: netlink_sendmsg+0x243/0x480
dec 26 15:54:27 shaun kernel: sock_sendmsg+0x5e/0x60
dec 26 15:54:27 shaun kernel: ____sys_sendmsg+0x25a/0x2a0
dec 26 15:54:27 shaun kernel: ? copy_msghdr_from_user+0x6e/0xa0
dec 26 15:54:27 shaun kernel: ___sys_sendmsg+0x97/0xe0
dec 26 15:54:27 shaun kernel: __sys_sendmsg+0x81/0xd0
dec 26 15:54:27 shaun kernel: do_syscall_64+0x33/0x40
dec 26 15:54:27 shaun kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
dec 26 15:54:27 shaun kernel: RIP: 0033:0x7f67655bfddd
dec 26 15:54:27 shaun kernel: Code: Unable to access opcode bytes at RIP 0x7f67655bfdb3.
dec 26 15:54:27 shaun kernel: RSP: 002b:00007ffd835f2100 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
dec 26 15:54:27 shaun kernel: RAX: ffffffffffffffda RBX: 00007ffd835f21d0 RCX: 00007f67655bfddd
dec 26 15:54:27 shaun kernel: RDX: 0000000000000000 RSI: 00007ffd835f2140 RDI: 000000000000000b
dec 26 15:54:27 shaun kernel: RBP: 000055b827a2ff00 R08: 0000000000000000 R09: 0000000000000021
dec 26 15:54:27 shaun kernel: R10: 0000000000000020 R11: 0000000000000293 R12: 000055b8279b16c0
dec 26 15:54:27 shaun kernel: R13: 000055b8279b16c0 R14: 000055b8278d4800 R15: 0000000000000000
dec 26 15:54:27 shaun kernel: INFO: task nmbd:1404 blocked for more than 122 seconds.
dec 26 15:54:27 shaun kernel: task:nmbd state:D stack: 0 pid: 1404 ppid: 1 flags:0x00000080
dec 26 15:54:27 shaun kernel: rpm_resume+0x189/0x820
dec 26 15:54:27 shaun kernel: ? wait_woken+0x80/0x80
dec 26 15:54:27 shaun kernel: rpm_resume+0x2fe/0x820
dec 26 15:54:27 shaun kernel: __pm_runtime_resume+0x3b/0x60
dec 26 15:54:27 shaun kernel: usb_autopm_get_interface+0x18/0x50
dec 26 15:54:27 shaun kernel: rtl8152_get_link_ksettings+0x27/0x80 [r8152]
dec 26 15:54:27 shaun kernel: ethtool_get_settings+0xa7/0x1e0
dec 26 15:54:27 shaun kernel: dev_ethtool+0x10f4/0x2a40
dec 26 15:54:27 shaun kernel: ? inet_ioctl+0xdd/0x210
dec 26 15:54:27 shaun kernel: ? netdev_name_node_lookup_rcu+0x68/0x80
dec 26 15:54:27 shaun kernel: dev_ioctl+0x304/0x580
dec 26 15:54:27 shaun kernel: sock_do_ioctl+0xe3/0x180
dec 26 15:54:27 shaun kernel: sock_ioctl+0x272/0x3e0
dec 26 15:54:27 shaun kernel: __x64_sys_ioctl+0x83/0xb0
dec 26 15:54:27 shaun kernel: RIP: 0033:0x7f3ace7d8f6b
dec 26 15:54:27 shaun kernel: Code: Unable to access opcode bytes at RIP 0x7f3ace7d8f41.
dec 26 15:54:27 shaun kernel: RSP: 002b:00007ffcfe0d0448 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
dec 26 15:54:27 shaun kernel: RAX: ffffffffffffffda RBX: 000055f2343e7e10 RCX: 00007f3ace7d8f6b
dec 26 15:54:27 shaun kernel: RDX: 00007ffcfe0d0480 RSI: 0000000000008946 RDI: 0000000000000019
dec 26 15:54:27 shaun kernel: RBP: 0000000000000019 R08: 0000000000000000 R09: 003475327534736e
dec 26 15:54:27 shaun kernel: R10: 0000000000000015 R11: 0000000000000246 R12: 000055f2343e8170
dec 26 15:54:27 shaun kernel: R13: 000055f2343e776c R14: 000055f2343e76c8 R15: 00007ffcfe0d0480
dec 26 15:54:27 shaun kernel: INFO: task kworker/7:0:5569 blocked for more than 122 seconds.
dec 26 15:54:27 shaun kernel: task:kworker/7:0 state:D stack: 0 pid: 5569 ppid: 2 flags:0x00004080
dec 26 15:54:27 shaun kernel: Workqueue: ipv6_addrconf addrconf_verify_work
dec 26 15:54:27 shaun kernel: ? __switch_to_asm+0x36/0x70
dec 26 15:54:27 shaun kernel: addrconf_verify_work+0xa/0x20
dec 26 15:54:27 shaun kernel: process_one_work+0x1da/0x3d0
dec 26 15:54:27 shaun kernel: worker_thread+0x4d/0x3d0
dec 26 15:54:27 shaun kernel: ? rescuer_thread+0x410/0x410
dec 26 15:54:27 shaun kernel: kthread+0x142/0x160
dec 26 15:54:27 shaun kernel: ? __kthread_bind_mask+0x60/0x60
dec 26 15:54:27 shaun kernel: ret_from_fork+0x1f/0x30
dec 26 15:54:27 shaun kernel: INFO: task Qt bearer threa:5813 blocked for more than 122 seconds.
dec 26 15:54:27 shaun kernel: task:Qt bearer threa state:D stack: 0 pid: 5813 ppid: 1682 flags:0x00000080
dec 26 15:54:27 shaun kernel: __netlink_dump_start+0xca/0x2d0
dec 26 15:54:27 shaun kernel: ? rtnl_fill_ifinfo+0x1410/0x1410
dec 26 15:54:27 shaun kernel: rtnetlink_rcv_msg+0x288/0x390
dec 26 15:54:27 shaun kernel: ? rtnl_calcit.isra.0+0x120/0x120
dec 26 15:54:27 shaun kernel: __sys_sendto+0x120/0x180
dec 26 15:54:27 shaun kernel: __x64_sys_sendto+0x25/0x30
dec 26 15:54:27 shaun kernel: RIP: 0033:0x7f029d9cf77c
dec 26 15:54:27 shaun kernel: Code: Unable to access opcode bytes at RIP 0x7f029d9cf752.
dec 26 15:54:27 shaun kernel: RSP: 002b:00007f0285b2b920 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
dec 26 15:54:27 shaun kernel: RAX: ffffffffffffffda RBX: 0000000000000016 RCX: 00007f029d9cf77c
dec 26 15:54:27 shaun kernel: RDX: 0000000000000020 RSI: 00007f0285b2b9c0 RDI: 0000000000000016
dec 26 15:54:27 shaun kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
dec 26 15:54:27 shaun kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007f0285b2ba88
dec 26 15:54:27 shaun kernel: R13: 0000559dec745ee0 R14: 00007f027403d318 R15: 0000000000000000
dec 26 15:54:27 shaun kernel: INFO: task DNS Res~ver #13:9535 blocked for more than 122 seconds.
dec 26 15:54:27 shaun kernel: task:DNS Res~ver #13 state:D stack: 0 pid: 9535 ppid: 1682 flags:0x00000080
dec 26 15:54:27 shaun kernel: ? rtnl_fill_link_ifmap+0x90/0x90
dec 26 15:54:27 shaun kernel: RIP: 0033:0x7f7acb6b48e4
dec 26 15:54:27 shaun kernel: Code: Unable to access opcode bytes at RIP 0x7f7acb6b48ba.
dec 26 15:54:27 shaun kernel: RSP: 002b:00007f7aabbfafd0 EFLAGS: 00000293 ORIG_RAX: 000000000000002c
dec 26 15:54:27 shaun kernel: RAX: ffffffffffffffda RBX: 00007f7aabbfc100 RCX: 00007f7acb6b48e4
dec 26 15:54:27 shaun kernel: RDX: 0000000000000014 RSI: 00007f7aabbfc100 RDI: 0000000000000067
dec 26 15:54:27 shaun kernel: RBP: 0000000000000000 R08: 00007f7aabbfc0a4 R09: 000000000000000c
dec 26 15:54:27 shaun kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007f7aabbfc0a4
dec 26 15:54:27 shaun kernel: R13: 00000000a5ae84a8 R14: 0000000000000067 R15: 0000000000000000
dec 26 15:54:27 shaun kernel: INFO: task kworker/5:1:9485 blocked for more than 245 seconds.
dec 26 15:54:27 shaun kernel: task:kworker/5:1 state:D stack: 0 pid: 9485 ppid: 2 flags:0x00004080
dec 26 15:54:27 shaun kernel: Workqueue: events rtl_work_func_t [r8152]
dec 26 15:54:27 shaun kernel: rtl_work_func_t+0x69/0x2d0 [r8152]
dec 26 15:54:27 shaun kernel: ? __schedule+0x29a/0x830
dec 26 15:56:30 shaun kernel: INFO: task NetworkManager:668 blocked for more than 245 seconds.
dec 26 15:56:30 shaun kernel: Not tainted 5.9.11-3-MANJARO #1
dec 26 15:56:30 shaun kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
dec 26 15:56:30 shaun kernel: task:NetworkManager state:D stack: 0 pid: 668 ppid: 1 flags:0x00000080
dec 26 15:56:30 shaun kernel: Call Trace:
dec 26 15:56:30 shaun kernel: __schedule+0x292/0x830
dec 26 15:56:30 shaun kernel: schedule+0x46/0xf0
dec 26 15:56:30 shaun kernel: schedule_preempt_disabled+0x14/0x20
dec 26 15:56:30 shaun kernel: __mutex_lock.constprop.0+0x180/0x530
dec 26 15:56:30 shaun kernel: nl80211_dump_scan+0x4a/0x790 [cfg80211]
dec 26 15:56:30 shaun kernel: ? netlink_dump+0xba/0x3e0
dec 26 15:56:30 shaun kernel: ? kmalloc_large_node+0x7f/0x90
dec 26 15:56:30 shaun kernel: ? __kmalloc_node_track_caller+0x2a7/0x340
dec 26 15:56:30 shaun kernel: ? __alloc_skb+0x95/0x1f0
dec 26 15:56:30 shaun kernel: netlink_dump+0x186/0x3e0
dec 26 15:56:30 shaun kernel: __netlink_dump_start+0x1b9/0x2d0
dec 26 15:56:30 shaun kernel: genl_family_rcv_msg_dumpit+0xf4/0x190
dec 26 15:56:30 shaun kernel: ? genl_rcv_msg+0x310/0x310
dec 26 15:56:30 shaun kernel: ? nl80211_dump_survey+0x320/0x320 [cfg80211]
dec 26 15:56:30 shaun kernel: ? genl_family_rcv_msg_dumpit+0x190/0x190
dec 26 15:56:30 shaun kernel: genl_rcv_msg+0x287/0x310
dec 26 15:56:30 shaun kernel: ? genl_family_rcv_msg_attrs_parse.isra.0+0xd0/0xd0
dec 26 15:56:30 shaun kernel: netlink_rcv_skb+0x75/0x140
dec 26 15:56:30 shaun kernel: genl_rcv+0x24/0x40
dec 26 15:56:30 shaun kernel: netlink_unicast+0x242/0x340
dec 26 15:56:30 shaun kernel: netlink_sendmsg+0x243/0x480
dec 26 15:56:30 shaun kernel: sock_sendmsg+0x5e/0x60
dec 26 15:56:30 shaun kernel: ____sys_sendmsg+0x25a/0x2a0
dec 26 15:56:30 shaun kernel: ? copy_msghdr_from_user+0x6e/0xa0
dec 26 15:56:30 shaun kernel: ___sys_sendmsg+0x97/0xe0
dec 26 15:56:30 shaun kernel: __sys_sendmsg+0x81/0xd0
dec 26 15:56:30 shaun kernel: do_syscall_64+0x33/0x40
dec 26 15:56:30 shaun kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
dec 26 15:56:30 shaun kernel: RIP: 0033:0x7f67655bfddd
dec 26 15:56:30 shaun kernel: Code: Unable to access opcode bytes at RIP 0x7f67655bfdb3.
dec 26 15:56:30 shaun kernel: RSP: 002b:00007ffd835f2100 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
dec 26 15:56:30 shaun kernel: RAX: ffffffffffffffda RBX: 00007ffd835f21d0 RCX: 00007f67655bfddd
dec 26 15:56:30 shaun kernel: RDX: 0000000000000000 RSI: 00007ffd835f2140 RDI: 000000000000000b
dec 26 15:56:30 shaun kernel: RBP: 000055b827a2ff00 R08: 0000000000000000 R09: 0000000000000021
dec 26 15:56:30 shaun kernel: R10: 0000000000000020 R11: 0000000000000293 R12: 000055b8279b16c0
dec 26 15:56:30 shaun kernel: R13: 000055b8279b16c0 R14: 000055b8278d4800 R15: 0000000000000000
dec 26 15:56:30 shaun kernel: INFO: task nmbd:1404 blocked for more than 245 seconds.
dec 26 15:56:30 shaun kernel: task:nmbd state:D stack: 0 pid: 1404 ppid: 1 flags:0x00000080
dec 26 15:56:30 shaun kernel: rpm_resume+0x189/0x820
dec 26 15:56:30 shaun kernel: ? wait_woken+0x80/0x80
dec 26 15:56:30 shaun kernel: rpm_resume+0x2fe/0x820
dec 26 15:56:30 shaun kernel: __pm_runtime_resume+0x3b/0x60
dec 26 15:56:30 shaun kernel: usb_autopm_get_interface+0x18/0x50
dec 26 15:56:30 shaun kernel: rtl8152_get_link_ksettings+0x27/0x80 [r8152]
dec 26 15:56:30 shaun kernel: ethtool_get_settings+0xa7/0x1e0
dec 26 15:56:30 shaun kernel: dev_ethtool+0x10f4/0x2a40
dec 26 15:56:30 shaun kernel: ? inet_ioctl+0xdd/0x210
dec 26 15:56:30 shaun kernel: ? netdev_name_node_lookup_rcu+0x68/0x80
dec 26 15:56:30 shaun kernel: dev_ioctl+0x304/0x580
dec 26 15:56:30 shaun kernel: sock_do_ioctl+0xe3/0x180
dec 26 15:56:30 shaun kernel: sock_ioctl+0x272/0x3e0
dec 26 15:56:30 shaun kernel: __x64_sys_ioctl+0x83/0xb0
dec 26 15:56:30 shaun kernel: RIP: 0033:0x7f3ace7d8f6b
dec 26 15:56:30 shaun kernel: Code: Unable to access opcode bytes at RIP 0x7f3ace7d8f41.
dec 26 15:56:30 shaun kernel: RSP: 002b:00007ffcfe0d0448 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
dec 26 15:56:30 shaun kernel: RAX: ffffffffffffffda RBX: 000055f2343e7e10 RCX: 00007f3ace7d8f6b
dec 26 15:56:30 shaun kernel: RDX: 00007ffcfe0d0480 RSI: 0000000000008946 RDI: 0000000000000019
dec 26 15:56:30 shaun kernel: RBP: 0000000000000019 R08: 0000000000000000 R09: 003475327534736e
dec 26 15:56:30 shaun kernel: R10: 0000000000000015 R11: 0000000000000246 R12: 000055f2343e8170
dec 26 15:56:30 shaun kernel: R13: 000055f2343e776c R14: 000055f2343e76c8 R15: 00007ffcfe0d0480
dec 26 15:56:30 shaun kernel: INFO: task kworker/7:0:5569 blocked for more than 245 seconds.
dec 26 15:56:30 shaun kernel: task:kworker/7:0 state:D stack: 0 pid: 5569 ppid: 2 flags:0x00004080
dec 26 15:56:30 shaun kernel: Workqueue: ipv6_addrconf addrconf_verify_work
dec 26 15:56:30 shaun kernel: ? __switch_to_asm+0x36/0x70
dec 26 15:56:30 shaun kernel: addrconf_verify_work+0xa/0x20
dec 26 15:56:30 shaun kernel: process_one_work+0x1da/0x3d0
dec 26 15:56:30 shaun kernel: worker_thread+0x4d/0x3d0
dec 26 15:56:30 shaun kernel: ? rescuer_thread+0x410/0x410
dec 26 15:56:30 shaun kernel: kthread+0x142/0x160
dec 26 15:56:30 shaun kernel: ? __kthread_bind_mask+0x60/0x60
dec 26 15:56:30 shaun kernel: ret_from_fork+0x1f/0x30
dec 26 16:01:01 shaun CROND[9576]: (root) CMD (run-parts /etc/cron.hourly)
dec 26 16:07:29 shaun systemd-timesyncd[547]: Timed out waiting for reply from 94.198.159.10:123 (2.manjaro.pool.ntp.org).
dec 26 16:07:40 shaun systemd-timesyncd[547]: Timed out waiting for reply from 141.138.201.22:123 (2.manjaro.pool.ntp.org).
dec 26 16:07:50 shaun systemd-timesyncd[547]: Timed out waiting for reply from 80.127.119.186:123 (2.manjaro.pool.ntp.org).
dec 26 16:59:11 shaun wpa_supplicant[1034]: wlp2s0: CTRL-EVENT-BEACON-LOSS
This last 4 lines repeats about 90 times, then stop.
