Similar OpenSUSE Bug 1083866 which was closed due to linking to firmware. Suggested fix is "in powertop, switching “Autosuspend for USB device USB 10/100/1000 LAN [Realtek]” from the default “GOOD” to “BAD”. Equivalent of “echo ‘on’ > ‘/sys/bus/usb/devices/4-1.4/power/control’” - going to try this and will report back .
This made no difference.
Similar Kernel Bug 200977 which Comment 28 suggests setting
usbcore.autosuspend=-1 pci_aspm=offkernel params. Also not tried until I get results from the above
This solved the problem. I’ve not seen the hang for the last few days since adding those kernel params and rebooting.
I have reported the scenario and workaround to Realtek linux nic maintainers <nic_swsd@realtek.com> listed in r8152.c « usb « net « drivers - kernel/git/torvalds/linux.git - Linux kernel source tree and also to the linux-usb mailing list: 'RTL8153 1G USB ethernet kernel hang bug' - MARC
