USB devices not accessible if not present at boot
Hi – please have patience with a newbie!
I’ve just bought a new laptop – a GPD Win Max 2 and installed Manjaro on it.
The issue I’m facing is that no USB device – webcams, USB drives, mice, keyboards, etc. – work if at least one device is connected when the laptop is booted or restarted. If any USB device is connected to one USB type A port during start-up all the USB type A ports work as expected. I believe the same appears to apply separately to the USB type C ports.
I’ve tried distro hopping a little and get the same results on everything I’ve tried. I’ve also tried using every kernel version from 5.15.76-rt53-2 up to 6.0.8-1 with no affect.
The temporary fix I’m employing is to leave a small dongle connected to one of the USB A ports all the time, which means the other USB A ports work.
Running ‘sudo lsusb -v’ also causes all devices to be detected and function properly (only if run with ‘sudo’). I did think about setting this command to run at startup, but of course it only detects the devices that are connected at the time the command runs, so any newly connected devices following the command aren’t detected and it has to be run again.
I’d be most grateful for any help/advice. I’m happy to post any logs that might be helpful and run any commands that might help make sense of what’s happening.
Thanks in advance!
Hi and welcome to the forum :+1:
Do you happen to have “fast-boot” enabled in your BIOS?
If so try disable that to see if that helps…
To help others help you better you need to provide detailed info about your hardware see:
Hi, thanks for getting back to me. I did have fast boot enabled and have now disabled it, but it doesn’t seem to have made any difference.
It’s quite late at night here, so I’ll post the necessary hardware information tomorrow.
  Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64
    root=UUID=7d0b0f7d-24e2-42b6-8ae7-2fe29aef81cc rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
  Type: N/A System: GPD product: G1619-04 v: Ver.1.0
    serial: <superuser required>
  Mobo: GPD model: G1619-04 v: Ver.1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: 1.04 date: 10/27/2022
  ID-1: BAT0 charge: 68.8 Wh (100.0%) condition: 68.8/67.1 Wh (102.4%)
    volts: 17.5 min: 15.4 model: Standard SR Real Battery type: Li-ion
    serial: <filter> status: full
  RAM: total: 13.4 GiB used: 2.19 GiB (16.4%)
  Info: model: AMD Ryzen 7 6800U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 643 high: 2670 min/max: 400/4768 boost: enabled scaling:
    driver: amd-pstate governor: schedutil cores: 1: 400 2: 400 3: 400 4: 400
    5: 1186 6: 400 7: 400 8: 400 9: 400 10: 1234 11: 400 12: 400 13: 400
    14: 400 15: 2670 16: 400 bogomips: 86280
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 73:00.0 chip-ID: 1002:1681
    class-ID: 0300
  Device-2: Tripath USB Camera type: USB driver: uvcvideo bus-ID: 5-1.1:3
    chip-ID: 058e:3864 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
    compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: GPD1001H serial: <filter> built: 2022
    res: 2560x1600 dpi: 73 gamma: 1.2 size: 217x135mm (8.54x5.31")
    diag: 1021mm (40.2") ratio: 16:9 modes: max: 2560x1600 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (rembrandt
    LLVM 14.0.6 DRM 3.48 6.0.8-1-MANJARO) direct render: Yes
  Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 73:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
    v: kernel
    alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 73:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Conexant Systems
    bus-ID: 73:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IP v6: <filter> type: noprefixroute scope: global
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
    chip-ID: 8087:0032 class-ID: e001
  Local Storage: total: 953.87 GiB used: 166.43 GiB (17.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: BIWIN model: CNF80V51G00-1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 52BFU4MA temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 166.43 GiB (17.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 7d0b0f7d-24e2-42b6-8ae7-2fe29aef81cc
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: B801-A063
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-3:2 info: Microsoft Xbox360 Controller type: <vendor specific>
    driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 045e:028e class-ID: ff00 serial: <filter>
  Device-2: 1-4:3 info: Mouse for Windows type: Mouse,Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 2f24:0135 class-ID: 0300
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 3 rev: 2.0
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 3-1.1:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-3:3 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-6: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
    chip-ID: 05e3:0625 class-ID: 0900
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 5-1.1:3 info: Tripath USB Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 058e:3864
    class-ID: 0e02
  Device-2: 5-1.3:4 info: Chipsailing CS9711Fingprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 2541:9711 class-ID: 0000
  Hub-9: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
    speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-10: 7-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-11: 8-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  Hub-12: 9-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-13: 10-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 37.2 C mobo: N/A
  Processes: 485 Uptime: 10h 0m wakeups: 5 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1642 pm: pacman pkgs: 1593 libs: 472
  tools: gnome-software,pamac,yay pm: flatpak pkgs: 41 pm: snap pkgs: 8
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.23
Maybe it might help others to also see the output of the following command when you boot without the USB devices being recognized:
journalctl --no-pager --priority=4 --grep=usb
Okay, thank you! Here it is:
 journalctl --priority=4 --grep=usb         ✔
Nov 25 09:40:19 wmax2 /usr/lib/gdm-wayland-session[845]: dbus-daemon[845]: [session uid=120 pid=845] Activating service name='org.gnome.Scr>
Nov 25 09:40:19 wmax2 gsd-usb-protect[985]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The>
Nov 25 09:40:39 wmax2 gsd-usb-protect[1690]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 09:55:14 wmax2 gsd-usb-protect[1690]: Failed to fetch USBGuard rules list: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 6d947cea25ea44b4a87504ce65817ee3 --
Nov 25 09:56:02 wmax2 /usr/lib/gdm-wayland-session[841]: dbus-daemon[841]: [session uid=120 pid=841] Activating service name='org.gnome.Scr>
Nov 25 09:56:03 wmax2 gsd-usb-protect[967]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The>
Nov 25 09:56:23 wmax2 gsd-usb-protect[1646]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 10:39:57 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
-- Boot f40f048f39864796a21dd0596783c31a --
Nov 25 10:48:40 wmax2 /usr/lib/gdm-wayland-session[1014]: dbus-daemon[1014]: [session uid=120 pid=1014] Activating service name='org.gnome.>
Nov 25 10:48:41 wmax2 gsd-usb-protect[1142]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 10:52:30 wmax2 gsd-usb-protect[1822]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 85a86470dba9405e8eaca48080df8dc7 --
Nov 25 11:10:12 wmax2 /usr/lib/gdm-wayland-session[1023]: dbus-daemon[1023]: [session uid=120 pid=1023] Activating service name='org.gnome.>
Nov 25 11:10:13 wmax2 gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 11:10:29 wmax2 gsd-usb-protect[1817]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 81c97dddf1cd4fd785ca26be049ffe53 --
Nov 25 11:18:31 wmax2 /usr/lib/gdm-wayland-session[996]: dbus-daemon[996]: [session uid=120 pid=996] Activating service name='org.gnome.Scr>
Nov 25 11:18:32 wmax2 gsd-usb-protect[1117]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 11:18:49 wmax2 gsd-usb-protect[1796]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 11:35:48 wmax2 kernel: Modules linked in: exfat uas usb_storage rfcomm ccm cmac algif_hash qrtr ns algif_skcipher af_alg bnep intel_>
Nov 25 11:42:10 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 25 11:57:11 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 25 11:57:12 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
-- Boot 5bd06693fcb84d39ae881a5606f465b6 --
Nov 25 12:06:18 wmax2 /usr/lib/gdm-wayland-session[985]: dbus-daemon[985]: [session uid=120 pid=985] Activating service name='org.gnome.Scr>
Nov 25 12:06:19 wmax2 gsd-usb-protect[1108]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 12:06:35 wmax2 gsd-usb-protect[1800]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot f8fcfb66a2f743baa0bbd7a99beeb5a6 --
Nov 25 12:16:14 wmax2 /usr/lib/gdm-wayland-session[1027]: dbus-daemon[1027]: [session uid=120 pid=1027] Activating service name='org.gnome.>
Nov 25 12:16:15 wmax2 gsd-usb-protect[1155]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 12:16:32 wmax2 gsd-usb-protect[1826]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 42f5132b29f8444da07b3adf6bd12918 --
Nov 25 13:19:11 wmax2 /usr/lib/gdm-wayland-session[1006]: dbus-daemon[1006]: [session uid=120 pid=1006] Activating service name='org.gnome.>
Nov 25 13:19:12 wmax2 gsd-usb-protect[1118]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 13:19:31 wmax2 gsd-usb-protect[1820]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot aa8b7cd187094e3c889c7c1d9da94730 --
Nov 25 17:02:13 wmax2 /usr/lib/gdm-wayland-session[1060]: dbus-daemon[1060]: [session uid=120 pid=1060] Activating service name='org.gnome.>
Nov 25 17:02:13 wmax2 gsd-usb-protect[1174]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 17:02:24 wmax2 gsd-usb-protect[1853]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot abcdef54eaef4a1cb7ad40c3e8f39364 --
Nov 25 17:06:10 wmax2 /usr/lib/gdm-wayland-session[1024]: dbus-daemon[1024]: [session uid=120 pid=1024] Activating service name='org.gnome.>
Nov 25 17:06:10 wmax2 gsd-usb-protect[1161]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 17:06:22 wmax2 gsd-usb-protect[1855]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 17:06:23 wmax2 gsd-usb-protect[1161]: Error releasing name org.gnome.SettingsDaemon.UsbProtection: The connection is closed
-- Boot 2f5ca9ec8caa47da81fcc5f19aeaebd5 --
Nov 25 22:08:49 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 25 22:08:55 wmax2 /usr/lib/gdm-wayland-session[1033]: dbus-daemon[1033]: [session uid=120 pid=1033] Activating service name='org.gnome.>
Nov 25 22:08:56 wmax2 gsd-usb-protect[1145]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 22:09:05 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 25 22:09:20 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 25 22:09:36 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
-- Boot 50537a3d83f74b8ea261a0e9b552257b --
Nov 25 22:10:23 wmax2 /usr/lib/gdm-wayland-session[1055]: dbus-daemon[1055]: [session uid=120 pid=1055] Activating service name='org.gnome.>
Nov 25 22:10:23 wmax2 gsd-usb-protect[1179]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 25 22:10:41 wmax2 gsd-usb-protect[1856]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 45a4473e9a5445d6aae083364dccaefa --
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:73:00.3/usb1/>
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) config/udev: Adding input device USB Camera: USB Camera (/dev/input/event17)
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) USB Camera: USB Camera: Applying InputClass "evdev keyboard catchall"
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) USB Camera: USB Camera: Applying InputClass "libinput keyboard catchall"
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) USB Camera: USB Camera: Applying InputClass "system-keyboard"
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) Using input driver 'libinput' for 'USB Camera: USB Camera'
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) USB Camera: USB Camera: always reports core events
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) event17 - USB Camera: USB Camera: is tagged by udev as: Keyboard
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) event17 - USB Camera: USB Camera: device is a keyboard
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) event17 - USB Camera: USB Camera: device removed
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:74:00.0/usb5/>
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) XINPUT: Adding extended input device "USB Camera: USB Camera" (type: KEYBOARD, id >
Nov 26 14:25:51 wmax2 /usr/lib/gdm-x-session[1045]: dbus-daemon[1045]: [session uid=120 pid=1045] Activating service name='org.gnome.Screen>
Nov 26 14:25:52 wmax2 gsd-usb-protect[1178]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 26 14:26:06 wmax2 /usr/lib/gdm-x-session[1033]: (II) event17 - USB Camera: USB Camera: device removed
-- Boot d4872e4636984df2b302d3e40d2da65c --
Nov 26 14:26:56 wmax2 /usr/lib/gdm-wayland-session[1031]: dbus-daemon[1031]: [session uid=120 pid=1031] Activating service name='org.gnome.>
Nov 26 14:26:56 wmax2 gsd-usb-protect[1151]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 26 14:27:15 wmax2 gsd-usb-protect[1835]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 26 15:19:31 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:20:02 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:20:47 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:21:27 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:21:28 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:22:21 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:23:05 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 26 15:23:06 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
-- Boot bca9eba48c1442fa989f663131c31e32 --
Nov 26 15:24:43 wmax2 /usr/lib/gdm-wayland-session[1016]: dbus-daemon[1016]: [session uid=120 pid=1016] Activating service name='org.gnome.>
Nov 26 15:24:43 wmax2 gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 26 15:25:09 wmax2 gsd-usb-protect[1845]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot e043eb744fcc4d10befa2cac96fc16a5 --
-- Boot fefc25b620fd4c40bb19e33f5fc9eae8 --
Nov 26 19:21:22 wmax2 /usr/lib/gdm-wayland-session[1007]: dbus-daemon[1007]: [session uid=120 pid=1007] Activating service name='org.gnome.>
Nov 26 19:21:22 wmax2 gsd-usb-protect[1137]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 26 19:21:33 wmax2 gsd-usb-protect[1833]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 42dd25bfc29b402baf313e0745949dd4 --
Nov 26 22:22:11 wmax2 /usr/lib/gdm-wayland-session[1040]: dbus-daemon[1040]: [session uid=120 pid=1040] Activating service name='org.gnome.>
Nov 26 22:22:11 wmax2 gsd-usb-protect[1157]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 26 22:22:21 wmax2 gsd-usb-protect[1864]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot c332f74dd2f448aab6680d85c7553451 --
Nov 27 11:03:28 wmax2 /usr/lib/gdm-wayland-session[1020]: dbus-daemon[1020]: [session uid=120 pid=1020] Activating service name='org.gnome.>
Nov 27 11:03:28 wmax2 gsd-usb-protect[1148]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 11:03:49 wmax2 gsd-usb-protect[1838]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot a4246a8ee6224f99a7032dce8853b7e6 --
Nov 27 11:56:05 wmax2 /usr/lib/gdm-wayland-session[1045]: dbus-daemon[1045]: [session uid=120 pid=1045] Activating service name='org.gnome.>
Nov 27 11:56:05 wmax2 gsd-usb-protect[1156]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 11:56:16 wmax2 gsd-usb-protect[1855]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 13:49:00 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
-- Boot 4f60fb9cd0424ebca71acedc1c8725ff --
Nov 27 13:54:52 wmax2 /usr/lib/gdm-wayland-session[1002]: dbus-daemon[1002]: [session uid=120 pid=1002] Activating service name='org.gnome.>
Nov 27 13:54:52 wmax2 gsd-usb-protect[1135]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 13:55:10 wmax2 gsd-usb-protect[1842]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 8c6cf17c0b174e538e44580a89e11a90 --
Nov 27 23:08:06 wmax2 /usr/lib/gdm-wayland-session[973]: dbus-daemon[973]: [session uid=120 pid=973] Activating service name='org.gnome.Scr>
Nov 27 23:08:06 wmax2 gsd-usb-protect[1099]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 23:08:18 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 27 23:08:34 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 27 23:08:49 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 27 23:09:05 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 27 23:09:05 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
-- Boot ec8058dad2c54fcaa7ed16485f182eef --
Nov 27 23:09:22 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 27 23:09:22 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 27 23:09:22 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 27 23:09:25 wmax2 /usr/lib/gdm-wayland-session[1027]: dbus-daemon[1027]: [session uid=120 pid=1027] Activating service name='org.gnome.>
Nov 27 23:09:25 wmax2 gsd-usb-protect[1170]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 23:09:36 wmax2 gsd-usb-protect[1872]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 27 23:18:14 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 27 23:18:14 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 27 23:18:14 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 27 23:18:14 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 27 23:18:14 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 08:57:06 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 28 08:57:06 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 28 08:57:06 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 08:57:06 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 08:57:06 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
-- Boot 54c768527ef34180b227ba96691231dc --
Nov 28 09:45:23 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 09:45:23 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 09:45:23 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 09:45:32 wmax2 /usr/lib/gdm-wayland-session[1071]: dbus-daemon[1071]: [session uid=120 pid=1071] Activating service name='org.gnome.>
Nov 28 09:45:32 wmax2 gsd-usb-protect[1187]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 09:45:49 wmax2 gsd-usb-protect[1871]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 29e9272de1ff4640896ad9f642dac35b --
Nov 28 09:55:02 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 09:55:02 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 09:55:02 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 09:55:05 wmax2 /usr/lib/gdm-wayland-session[1029]: dbus-daemon[1029]: [session uid=120 pid=1029] Activating service name='org.gnome.>
Nov 28 09:55:05 wmax2 gsd-usb-protect[1167]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 09:55:17 wmax2 gsd-usb-protect[1871]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 10:05:09 wmax2 kernel: Modules linked in: rfcomm ccm intel_rapl_msr intel_rapl_common cmac algif_hash algif_skcipher af_alg qrtr bne>
-- Boot 4d7c84d8567041519d4e1572ff1af21b --
Nov 28 10:10:42 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 10:10:42 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 10:10:42 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 10:10:43 wmax2 kernel: Modules linked in: acpi_cpufreq(-) amd64_edac(-) snd_acp6x_pdm_dma snd_sof_amd_renoir snd_sof_amd_acp snd_sof>
Nov 28 10:10:46 wmax2 /usr/lib/gdm-wayland-session[1079]: dbus-daemon[1079]: [session uid=120 pid=1079] Activating service name='org.gnome.>
Nov 28 10:10:46 wmax2 gsd-usb-protect[1221]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 10:11:01 wmax2 gsd-usb-protect[2045]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 9d1f3d70e122469cb8686117a65cc0ea --
Nov 28 10:45:50 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 10:45:50 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 10:45:50 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 10:45:51 wmax2 kernel: Modules linked in: pcc_cpufreq(-) amd64_edac(-) snd_soc_acp6x_mach fjes(-) snd_soc_dmic uvcvideo(+) videobuf2>
Nov 28 10:45:54 wmax2 /usr/lib/gdm-wayland-session[1100]: dbus-daemon[1100]: [session uid=120 pid=1100] Activating service name='org.gnome.>
Nov 28 10:45:54 wmax2 gsd-usb-protect[1216]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 10:49:54 wmax2 gsd-usb-protect[2084]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 11:31:31 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 28 11:31:31 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 28 11:31:31 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 11:31:31 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 11:31:31 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
-- Boot 94f1c81f49e4489fb7c067647cbca4ff --
Nov 28 12:24:07 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 12:24:07 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 12:24:07 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 12:24:08 wmax2 kernel: Modules linked in: uvcvideo(+) videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 snd_acp6x_pdm_dma snd_soc_dm>
Nov 28 12:24:11 wmax2 /usr/lib/gdm-wayland-session[1099]: dbus-daemon[1099]: [session uid=120 pid=1099] Activating service name='org.gnome.>
Nov 28 12:24:11 wmax2 gsd-usb-protect[1209]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 12:24:24 wmax2 gsd-usb-protect[2127]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 12:24:25 wmax2 gsd-usb-protect[1209]: Error releasing name org.gnome.SettingsDaemon.UsbProtection: The connection is closed
Nov 28 12:36:47 wmax2 kernel: usbhid 7-1.2.2:1.2: couldn't find an input interrupt endpoint
Nov 28 13:51:41 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 28 13:51:41 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
-- Boot 79a8d8cff54f4833a044b625c48b3b22 --
Nov 28 15:21:02 wmax2 kernel: Modules linked in: videobuf2_memops snd_sof videobuf2_v4l2 iwlmvm(+) snd_hda_codec_conexant videobuf2_common >
-- Boot 3c7d46b404ce4a94b85db03c356cc23f --
Nov 28 15:21:57 wmax2 kernel: Modules linked in: btbcm edac_mce_amd snd_hda_codec_conexant snd_sof btintel snd_hda_codec_generic vfat video>
-- Boot 2b7b822746e64640b11b802ee39dabe2 --
Nov 28 15:23:06 wmax2 kernel: Modules linked in: btrtl(+) videobuf2_common(+) snd_hda_codec_generic btbcm amd64_edac(-) ledtrig_audio btint>
-- Boot 366d90b253464b798b44e8dc4030bd26 --
Nov 28 15:25:05 wmax2 /usr/lib/gdm-wayland-session[1042]: dbus-daemon[1042]: [session uid=120 pid=1042] Activating service name='org.gnome.>
Nov 28 15:25:05 wmax2 gsd-usb-protect[1165]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 15:25:15 wmax2 gsd-usb-protect[1870]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 15:25:17 wmax2 gsd-usb-protect[1165]: Error releasing name org.gnome.SettingsDaemon.UsbProtection: The connection is closed
Nov 28 17:11:32 wmax2 kernel: Modules linked in: ntfs3 uas usb_storage rfcomm ccm cmac algif_hash algif_skcipher af_alg intel_rapl_msr inte>
Nov 28 17:14:16 wmax2 kernel: usbhid 7-1.2.2:1.2: couldn't find an input interrupt endpoint
-- Boot 4ce4ddb569164f3e9aa09eeaeab46847 --
Nov 28 20:43:21 wmax2 /usr/lib/gdm-wayland-session[982]: dbus-daemon[982]: [session uid=120 pid=982] Activating service name='org.gnome.Scr>
Nov 28 20:43:21 wmax2 gsd-usb-protect[1104]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 20:43:32 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 28 20:43:48 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 28 20:44:03 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 28 20:44:19 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
-- Boot e28ec42db2c44437ac4869b49707dbd3 --
Nov 28 20:44:39 wmax2 /usr/lib/gdm-wayland-session[1054]: dbus-daemon[1054]: [session uid=120 pid=1054] Activating service name='org.gnome.>
Nov 28 20:44:40 wmax2 gsd-usb-protect[1164]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 20:44:51 wmax2 gsd-usb-protect[1883]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot faa590513d2940839613abe758025cdd --
Nov 28 21:07:28 wmax2 /usr/lib/gdm-wayland-session[1044]: dbus-daemon[1044]: [session uid=120 pid=1044] Activating service name='org.gnome.>
Nov 28 21:07:28 wmax2 gsd-usb-protect[1152]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 6ff42a9e069b481db53d3297125d3664 --
Nov 28 21:08:50 wmax2 /usr/lib/gdm-wayland-session[1033]: dbus-daemon[1033]: [session uid=120 pid=1033] Activating service name='org.gnome.>
Nov 28 21:08:50 wmax2 gsd-usb-protect[1148]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 21:09:01 wmax2 gsd-usb-protect[1867]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 28 21:26:35 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 28 21:26:35 wmax2 kernel: usb 5-1.3: device descriptor read/all, error 8
Nov 28 21:26:44 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 21:26:44 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 21:26:44 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 28 21:26:44 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 28 21:26:44 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 28 22:53:42 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 28 22:53:42 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 28 22:53:42 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 28 22:53:42 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 28 22:53:42 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 29 09:36:08 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 29 09:36:08 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 29 09:36:08 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 29 09:36:08 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 29 09:36:08 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 29 11:51:49 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 29 11:51:49 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 29 11:51:49 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 29 11:51:49 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 29 11:51:49 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 29 13:34:34 wmax2 kernel: xpad 1-3:1.0: xpad_irq_in - usb_submit_urb failed with result -1
Nov 29 13:43:23 wmax2 kernel: xpad 1-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Nov 29 13:54:31 wmax2 systemd-coredump[25489]: [🡕] Process 24729 (winedevice.exe) of user 1000 dumped core.
                                               Module /usr/bin/wine64 with build-id f8255b9195204fa01554ed03e9644a0cbdbaf9c2
                                               Module /usr/lib/wine/x86_64-unix/win32u.so with build-id 48964dbc6a3b5a710c06bfc2bdc90c39e22>
                                               Module /usr/lib/libgpg-error.so.0.33.1 with build-id 470d76ceb1e53cb017f78c08936e9bafaeb4058b
                                               Module /usr/lib/libzstd.so.1.5.2 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                               Module /usr/lib/libgcrypt.so.20.4.1 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                               Module /usr/lib/libsystemd.so.0.34.0 with build-id 1c1489e575197ffbf417c79f926e572421f3692f
                                               Module /usr/lib/libdbus-1.so.3.32.1 with build-id 6d6e4846c8e56903b4fe7d992ae6bb30c8a20a9c
                                               Module /usr/lib/libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
                                               Module /usr/lib/libSDL2-2.0.so.0.2400.2 with build-id 699b2717ad696268b06d810c2f8d54ed51b9be>
                                               Module /usr/lib/wine/x86_64-unix/libwine.so.1.0 with build-id 8e6d119556ea03ce10739c036d3d3b>
                                               Module /usr/lib/liblz4.so.1.9.4 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
                                               Module /usr/lib/libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
                                               Module /usr/lib/libudev.so.1.7.4 with build-id 817401b9b452ca6689f50bafeab2db7288536a5e
                                               Module /usr/lib/libusb-1.0.so.0.3.0 with build-id 98d3b69176fc359d2c574759c2064f83e5cdf8ed
                                               Module /usr/lib/gconv/UTF-16.so with build-id 6b53b621a4e5b90fe43fcb3831d955bca310e34e
                                               Module /usr/lib/wine/x86_64-unix/winebus.so with build-id 14be08ef214f0247853ddba409bda35882>
                                               Module /usr/lib/liblzma.so.5.2.7 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
                                               Module /usr/lib/libunwind.so.8.0.1 with build-id e7f3b22127b00d8b14b2560df707cbbeb0134861
                                               Module /usr/lib/wine/x86_64-unix/ntdll.so with build-id 9811bf90b679408ef949f0f72a2dc9864625>
                                               Module /usr/lib/libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
                                               Module /usr/lib/libcap.so.2.66 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
                                               Module /usr/lib/libatomic.so.1.2.0 with build-id 30d6c8e955af99c57aa98b4d7c3f80196e82f174
                                               Module /usr/lib/wine/x86_64-unix/wineusb.so with build-id fd1978824e0936206b1b485cd2f5ba38c2>
                                               Module /usr/lib/ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
                                               Module linux-vdso.so.1 with build-id 4c401cb13195aeea26415c88e112cbc06f615d11
                                               Stack trace of thread 24735:
                                               #0  0x00007f0432761ad7 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x41ad7)
                                               #1  0x00007f04327620be n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x420be)
                                               #2  0x00007f043281fa00 n/a (/usr/lib/libc.so.6 + 0x38a00)
                                               Stack trace of thread 24733:
                                               #0  0x00007f043287b2ba n/a (/usr/lib/libc.so.6 + 0x942ba)
                                               #1  0x00007f043287dba3 __libc_free (/usr/lib/libc.so.6 + 0x96ba3)
                                               #2  0x00007f043287dc92 n/a (/usr/lib/libc.so.6 + 0x96c92)
                                               #3  0x00007f043286d783 n/a (/usr/lib/libc.so.6 + 0x86783)
                                               #4  0x00007f04328efa60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 24734:
                                               #0  0x00007f04328de79a __close (/usr/lib/libc.so.6 + 0xf779a)
                                               #1  0x00007f0432778e00 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e00)
                                               #2  0x00007f043275d619 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3d619)
                                               #3  0x00007f0432778ddb n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58ddb)
                                               #4  0x00007f043286d8fd n/a (/usr/lib/libc.so.6 + 0x868fd)
                                               #5  0x00007f04328efa60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 24752:
                                               #1  0x00007f0432778e0b n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e0b)
                                               Stack trace of thread 24739:
                                               Stack trace of thread 24738:
                                               #1  0x00007f0432778e16 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e16)
                                               Stack trace of thread 24747:
                                               #0  0x00007f04328e20bf __poll (/usr/lib/libc.so.6 + 0xfb0bf)
                                               #1  0x00007f04325a1757 n/a (/usr/lib/libusb-1.0.so.0.3.0 + 0x10757)
                                               #2  0x00007f04325a3438 libusb_handle_events_timeout_completed (/usr/lib/libusb-1.0.so.0.3.0 >
                                               #3  0x00007f04325a34b4 libusb_handle_events (/usr/lib/libusb-1.0.so.0.3.0 + 0x124b4)
                                               #4  0x00007f0431416064 n/a (/usr/lib/libSDL2-2.0.so.0.2400.2 + 0x51064)
                                               #5  0x00007f04314f54cb n/a (/usr/lib/libSDL2-2.0.so.0.2400.2 + 0x1304cb)
                                               #6  0x00007f043286d8fd n/a (/usr/lib/libc.so.6 + 0x868fd)
                                               #7  0x00007f04328efa60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 24751:
                                               Stack trace of thread 24736:
                                               #1  0x00007f043259da95 n/a (/usr/lib/libusb-1.0.so.0.3.0 + 0xca95)
                                               #2  0x00007f043286d8fd n/a (/usr/lib/libc.so.6 + 0x868fd)
                                               #3  0x00007f04328efa60 n/a (/usr/lib/libc.so.6 + 0x108a60)
Nov 29 13:54:43 wmax2 systemd-coredump[25681]: [🡕] Process 25542 (winedevice.exe) of user 1000 dumped core.
                                               Stack trace of thread 25550:
                                               #0  0x00007f67cf685ad7 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x41ad7)
                                               #1  0x00007f67cf6860be n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x420be)
                                               #2  0x00007f67cf743a00 n/a (/usr/lib/libc.so.6 + 0x38a00)
                                               Stack trace of thread 25549:
                                               #0  0x00007f67cf79ef04 n/a (/usr/lib/libc.so.6 + 0x93f04)
                                               #1  0x00007f67cf7a1ba3 __libc_free (/usr/lib/libc.so.6 + 0x96ba3)
                                               #2  0x00007f67cf7a1c92 n/a (/usr/lib/libc.so.6 + 0x96c92)
                                               #3  0x00007f67cf791783 n/a (/usr/lib/libc.so.6 + 0x86783)
                                               #4  0x00007f67cf813a60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 25548:
                                               #0  0x00007f67cf80279a __close (/usr/lib/libc.so.6 + 0xf779a)
                                               #1  0x00007f67cf69ce16 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e16)
                                               #2  0x00007f67cf681619 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3d619)
                                               #3  0x00007f67cf69cddb n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58ddb)
                                               #4  0x00007f67cf7918fd n/a (/usr/lib/libc.so.6 + 0x868fd)
                                               #5  0x00007f67cf813a60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 25552:
                                               #0  0x00007f67cf79f3c3 n/a (/usr/lib/libc.so.6 + 0x943c3)
                                               Stack trace of thread 25562:
                                               Stack trace of thread 25553:
                                               #1  0x00007f67cf69ce21 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e21)
                                               Stack trace of thread 25554:
                                               #1  0x00007f67cf69ce0b n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e0b)
                                               Stack trace of thread 25563:
                                               #0  0x00007f67cf80204c read (/usr/lib/libc.so.6 + 0xf704c)
                                               #1  0x00007f67cf67e259 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3a259)
                                               #2  0x00007f67cf680d5f n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3cd5f)
                                               #3  0x00007f67cf680df5 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3cdf5)
                                               #4  0x00007f67cf690a88 NtWaitForMultipleObjects (/usr/lib/wine/x86_64-unix/ntdll.so + 0x4ca8>
                                               #5  0x00007f67cf68179d __wine_syscall_dispatcher_prolog_end (/usr/lib/wine/x86_64-unix/ntdll>
                                               #6  0x000000017000ec24 n/a (n/a + 0x0)
                                               #7  0x00000000010a0330 n/a (n/a + 0x0)
                                               #8  0x0000000000000001 n/a (n/a + 0x0)
Nov 29 14:02:57 wmax2 systemd-coredump[30732]: [🡕] Process 29970 (winedevice.exe) of user 1000 dumped core.
                                               Stack trace of thread 29978:
                                               #0  0x00007fbe0e950ad7 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x41ad7)
                                               #1  0x00007fbe0e9510be n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x420be)
                                               #2  0x00007fbe0ea0ea00 n/a (/usr/lib/libc.so.6 + 0x38a00)
                                               Stack trace of thread 29977:
                                               #0  0x00007fbe0ea6a35c n/a (/usr/lib/libc.so.6 + 0x9435c)
                                               #1  0x00007fbe0ea6cba3 __libc_free (/usr/lib/libc.so.6 + 0x96ba3)
                                               #2  0x00007fbe0ea6cc92 n/a (/usr/lib/libc.so.6 + 0x96c92)
                                               #3  0x00007fbe0ea5c783 n/a (/usr/lib/libc.so.6 + 0x86783)
                                               #4  0x00007fbe0eadea60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 29980:
                                               #0  0x00007fbe0ea69f70 n/a (/usr/lib/libc.so.6 + 0x93f70)
                                               Stack trace of thread 29981:
                                               #0  0x00007fbe0ea6cc95 n/a (/usr/lib/libc.so.6 + 0x96c95)
                                               #1  0x00007fbe0ea5c783 n/a (/usr/lib/libc.so.6 + 0x86783)
                                               #2  0x00007fbe0eadea60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 29982:
                                               #0  0x00007fbe0eacd79a __close (/usr/lib/libc.so.6 + 0xf779a)
                                               #1  0x00007fbe0e967e21 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58e21)
                                               #2  0x00007fbe0e94c619 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3d619)
                                               #3  0x00007fbe0e967ddb n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x58ddb)
                                               #4  0x00007fbe0ea5c8fd n/a (/usr/lib/libc.so.6 + 0x868fd)
                                               #5  0x00007fbe0eadea60 n/a (/usr/lib/libc.so.6 + 0x108a60)
                                               Stack trace of thread 29990:
                                               Stack trace of thread 29991:
                                               #0  0x00007fbe0eacd04c read (/usr/lib/libc.so.6 + 0xf704c)
                                               #1  0x00007fbe0e949259 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3a259)
                                               #2  0x00007fbe0e94bd5f n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3cd5f)
                                               #3  0x00007fbe0e94bdf5 n/a (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3cdf5)
                                               #4  0x00007fbe0e95ba88 NtWaitForMultipleObjects (/usr/lib/wine/x86_64-unix/ntdll.so + 0x4ca8>
                                               #5  0x00007fbe0e94c79d __wine_syscall_dispatcher_prolog_end (/usr/lib/wine/x86_64-unix/ntdll>
Nov 29 15:51:50 wmax2 kernel: usb 5-1.3: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 29 15:51:50 wmax2 kernel: usb 5-1.3: PM: failed to resume async: error -5
Nov 29 15:51:50 wmax2 kernel: usb 5-1.3: config index 0 descriptor too short (expected 32, got 9)
Nov 29 15:51:50 wmax2 kernel: usb 5-1.3: config 1 has 0 interfaces, different from the descriptor's value: 1
Nov 29 15:51:50 wmax2 kernel: usb 5-1.3: can't set config #1, error -71
Nov 29 16:30:38 wmax2 kernel: Modules linked in: ufs hfsplus hfs cdrom minix msdos jfs xfs ext4 mbcache jbd2 tls snd_seq_dummy snd_seq snd_>
Nov 29 16:34:57 wmax2 kernel: usbhid 3-1.2.2:1.2: couldn't find an input interrupt endpoint
Nov 29 17:37:32 wmax2 kernel: usbhid 3-1.4.2:1.2: couldn't find an input interrupt endpoint
Nov 29 17:42:08 wmax2 kernel: usbhid 3-1.2.2:1.2: couldn't find an input interrupt endpoint
Nov 29 17:47:42 wmax2 kernel: usbhid 7-1.2.2:1.2: couldn't find an input interrupt endpoint
-- Boot 21080b05bee945c7967db9e0bcc5b814 --
Nov 30 12:18:36 wmax2 /usr/lib/gdm-wayland-session[1006]: dbus-daemon[1006]: [session uid=120 pid=1006] Activating service name='org.gnome.>
Nov 30 12:18:36 wmax2 gsd-usb-protect[1165]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 12:18:48 wmax2 gsd-usb-protect[1900]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 7a4b6e2ae9d64916b8cc6ba19b71bcf9 --
Nov 30 13:36:37 wmax2 /usr/lib/gdm-wayland-session[1014]: dbus-daemon[1014]: [session uid=120 pid=1014] Activating service name='org.gnome.>
Nov 30 13:36:37 wmax2 gsd-usb-protect[1138]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 13:36:49 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 13:37:05 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
-- Boot a6962c125a7b40c1b00d781984351b37 --
Nov 30 13:38:06 wmax2 /usr/lib/gdm-wayland-session[1000]: dbus-daemon[1000]: [session uid=120 pid=1000] Activating service name='org.gnome.>
Nov 30 13:38:06 wmax2 gsd-usb-protect[1136]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 13:38:18 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 13:38:34 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 13:38:49 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 13:39:05 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
-- Boot f1e469d4ff504f21a2de5059a7ab93bd --
Nov 30 13:39:25 wmax2 /usr/lib/gdm-wayland-session[1030]: dbus-daemon[1030]: [session uid=120 pid=1030] Activating service name='org.gnome.>
Nov 30 13:39:25 wmax2 gsd-usb-protect[1168]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 13:39:37 wmax2 gsd-usb-protect[1873]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot d555700c5c13414db3e5f8aaedd5622f --
Nov 30 13:41:07 wmax2 /usr/lib/gdm-wayland-session[1025]: dbus-daemon[1025]: [session uid=120 pid=1025] Activating service name='org.gnome.>
Nov 30 13:41:07 wmax2 gsd-usb-protect[1134]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 13:41:18 wmax2 gsd-usb-protect[1846]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 2fa85efebd17403ca2b1d525d5d2646b --
Nov 30 13:51:02 wmax2 /usr/lib/gdm-wayland-session[1020]: dbus-daemon[1020]: [session uid=120 pid=1020] Activating service name='org.gnome.>
Nov 30 13:51:02 wmax2 gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 13:51:13 wmax2 gsd-usb-protect[1862]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot e860db707e7a48a788e02f15f72905bd --
Nov 30 15:42:36 wmax2 kernel: Modules linked in: hid_logitech_dj(+) qrtr mousedev fjes(-) snd_soc_acp6x_mach snd_soc_dmic snd_acp6x_pdm_dma>
Nov 30 15:42:39 wmax2 /usr/lib/gdm-wayland-session[1061]: dbus-daemon[1061]: [session uid=120 pid=1061] Activating service name='org.gnome.>
Nov 30 15:42:39 wmax2 gsd-usb-protect[1234]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 15:42:50 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 15:43:06 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 15:43:22 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 15:43:38 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
-- Boot 07703b4b0b6245eeb7dbd952fd3c2c34 --
Nov 30 15:44:03 wmax2 kernel: Modules linked in: videobuf2_common snd_soc_acp6x_mach snd_soc_dmic videodev btusb snd_acp6x_pdm_dma btrtl mc>
Nov 30 15:44:06 wmax2 /usr/lib/gdm-wayland-session[1073]: dbus-daemon[1073]: [session uid=120 pid=1073] Activating service name='org.gnome.>
Nov 30 15:44:06 wmax2 gsd-usb-protect[1258]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 15:44:18 wmax2 gsd-usb-protect[1976]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 15:46:51 wmax2 kernel: usbhid 7-1.2.2:1.2: couldn't find an input interrupt endpoint
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2.5: PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -5
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2.5: PM: failed to resume async: error -5
Nov 30 18:18:44 wmax2 kernel: usb 5-1.3: device descriptor read/64, error -110
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2-port4: cannot reset (err = -71)
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2-port4: Cannot enable. Maybe the USB cable is bad?
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2-port4: cannot disable (err = -71)
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2-port2: cannot reset (err = -71)
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2-port2: Cannot enable. Maybe the USB cable is bad?
Nov 30 18:18:44 wmax2 kernel: usb 7-1.2-port2: cannot disable (err = -71)
Nov 30 18:20:50 wmax2 kernel: usbhid 7-1.2.2:1.2: couldn't find an input interrupt endpoint
-- Boot 3f3fe89422ab4eae9e89d8480fa7722b --
Nov 30 22:42:53 wmax2 /usr/lib/gdm-wayland-session[1046]: dbus-daemon[1046]: [session uid=120 pid=1046] Activating service name='org.gnome.>
Nov 30 22:42:53 wmax2 gsd-usb-protect[1158]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 22:43:02 wmax2 gsd-usb-protect[1866]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 1b1b2382905248dbb806e0dec38b60b8 --
Nov 30 22:43:47 wmax2 /usr/lib/gdm-wayland-session[1031]: dbus-daemon[1031]: [session uid=120 pid=1031] Activating service name='org.gnome.>
Nov 30 22:43:48 wmax2 gsd-usb-protect[1141]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 22:43:57 wmax2 gsd-usb-protect[1853]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 1354c5fb9b944039b5bbffe4289d1c54 --
Nov 30 22:48:31 wmax2 /usr/lib/gdm-wayland-session[1032]: dbus-daemon[1032]: [session uid=120 pid=1032] Activating service name='org.gnome.>
Nov 30 22:48:31 wmax2 gsd-usb-protect[1169]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Nov 30 22:48:41 wmax2 gsd-usb-protect[1877]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
-- Boot 49f023ba28cf403a8a263ada5d419fde --
Dec 01 09:09:26 wmax2 /usr/lib/gdm-wayland-session[1041]: dbus-daemon[1041]: [session uid=120 pid=1041] Activating service name='org.gnome.>
Dec 01 09:09:26 wmax2 gsd-usb-protect[1152]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
Dec 01 09:09:31 wmax2 kernel: Modules linked in: ccm intel_rapl_msr intel_rapl_common cmac algif_hash algif_skcipher af_alg qrtr bnep snd_s>
Dec 01 09:09:37 wmax2 gsd-usb-protect[1856]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: Th>
lines 620-652/652 (END)
Sorry i forgot to add --no-pager in that post, i fixed it, can you repost by editing your post with the output, because the lines are cut-off :wink:
You might pipe the output to a clipboard program like xclip for ease of pasting:
alias xclip='xclip -selection clipboard'
NP, here we are! :slight_smile:
journalctl --no-pager --priority=4 --grep=usb         ✔
Nov 25 09:40:19 wmax2 /usr/lib/gdm-wayland-session[845]: dbus-daemon[845]: [session uid=120 pid=845] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=985 comm="/usr/lib/gsd-usb-protection")
Nov 25 09:40:19 wmax2 gsd-usb-protect[985]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 09:40:39 wmax2 gsd-usb-protect[1690]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 09:55:14 wmax2 gsd-usb-protect[1690]: Failed to fetch USBGuard rules list: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 09:56:02 wmax2 /usr/lib/gdm-wayland-session[841]: dbus-daemon[841]: [session uid=120 pid=841] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=967 comm="/usr/lib/gsd-usb-protection")
Nov 25 09:56:03 wmax2 gsd-usb-protect[967]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 09:56:23 wmax2 gsd-usb-protect[1646]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 10:48:40 wmax2 /usr/lib/gdm-wayland-session[1014]: dbus-daemon[1014]: [session uid=120 pid=1014] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1142 comm="/usr/lib/gsd-usb-protection")
Nov 25 10:48:41 wmax2 gsd-usb-protect[1142]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 10:52:30 wmax2 gsd-usb-protect[1822]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 11:10:12 wmax2 /usr/lib/gdm-wayland-session[1023]: dbus-daemon[1023]: [session uid=120 pid=1023] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1149 comm="/usr/lib/gsd-usb-protection")
Nov 25 11:10:13 wmax2 gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 11:10:29 wmax2 gsd-usb-protect[1817]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 11:18:31 wmax2 /usr/lib/gdm-wayland-session[996]: dbus-daemon[996]: [session uid=120 pid=996] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1117 comm="/usr/lib/gsd-usb-protection")
Nov 25 11:18:32 wmax2 gsd-usb-protect[1117]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 11:18:49 wmax2 gsd-usb-protect[1796]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 11:35:48 wmax2 kernel: Modules linked in: exfat uas usb_storage rfcomm ccm cmac algif_hash qrtr ns algif_skcipher af_alg bnep intel_rapl_msr hid_logitech_dj uvcvideo videobuf2_vmalloc videobuf2_memops mousedev intel_rapl_common videobuf2_v4l2 iwlmvm videobuf2_common videodev joydev mac80211 edac_mce_amd vfat fat mc kvm_amd amdgpu libarc4 btusb snd_hda_codec_generic kvm snd_hda_codec_hdmi ledtrig_audio btrtl iwlwifi btbcm snd_hda_intel btintel snd_intel_dspcfg snd_intel_sdw_acpi bluetooth snd_hda_codec irqbypass ecdh_generic crct10dif_pclmul hid_multitouch snd_hda_core usbhid crc16 cfg80211 crc32_pclmul snd_hwdep ghash_clmulni_intel tpm_crb snd_pcm aesni_intel snd_pci_acp5x snd_rn_pci_acp3x xpad gpu_sched crypto_simd sp5100_tco snd_timer drm_ttm_helper cryptd tpm_tis ff_memless rapl pcspkr tpm_tis_core k10temp thunderbolt i2c_piix4 snd snd_pci_acp3x ttm ccp soundcore rfkill video tpm i2c_hid_acpi rng_core pinctrl_amd i2c_hid mac_hid acpi_cpufreq acpi_tad squashfs uinput dm_multipath loop dm_mod
Nov 25 12:06:18 wmax2 /usr/lib/gdm-wayland-session[985]: dbus-daemon[985]: [session uid=120 pid=985] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1108 comm="/usr/lib/gsd-usb-protection")
Nov 25 12:06:19 wmax2 gsd-usb-protect[1108]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 12:06:35 wmax2 gsd-usb-protect[1800]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 12:16:14 wmax2 /usr/lib/gdm-wayland-session[1027]: dbus-daemon[1027]: [session uid=120 pid=1027] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1155 comm="/usr/lib/gsd-usb-protection")
Nov 25 12:16:15 wmax2 gsd-usb-protect[1155]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 12:16:32 wmax2 gsd-usb-protect[1826]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 13:19:11 wmax2 /usr/lib/gdm-wayland-session[1006]: dbus-daemon[1006]: [session uid=120 pid=1006] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1118 comm="/usr/lib/gsd-usb-protection")
Nov 25 13:19:12 wmax2 gsd-usb-protect[1118]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 13:19:31 wmax2 gsd-usb-protect[1820]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 17:02:13 wmax2 /usr/lib/gdm-wayland-session[1060]: dbus-daemon[1060]: [session uid=120 pid=1060] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1174 comm="/usr/lib/gsd-usb-protection")
Nov 25 17:02:13 wmax2 gsd-usb-protect[1174]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 17:02:24 wmax2 gsd-usb-protect[1853]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 17:06:10 wmax2 /usr/lib/gdm-wayland-session[1024]: dbus-daemon[1024]: [session uid=120 pid=1024] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1161 comm="/usr/lib/gsd-usb-protection")
Nov 25 17:06:10 wmax2 gsd-usb-protect[1161]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 17:06:22 wmax2 gsd-usb-protect[1855]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 22:08:55 wmax2 /usr/lib/gdm-wayland-session[1033]: dbus-daemon[1033]: [session uid=120 pid=1033] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1145 comm="/usr/lib/gsd-usb-protection")
Nov 25 22:08:56 wmax2 gsd-usb-protect[1145]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 22:10:23 wmax2 /usr/lib/gdm-wayland-session[1055]: dbus-daemon[1055]: [session uid=120 pid=1055] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1179 comm="/usr/lib/gsd-usb-protection")
Nov 25 22:10:23 wmax2 gsd-usb-protect[1179]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 25 22:10:41 wmax2 gsd-usb-protect[1856]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:73:00.3/usb1/1-4/1-4:1.0/0003:2F24:0135.0003/input/input12/event12"
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:73:00.3/usb1/1-4/1-4:1.1/0003:2F24:0135.0004/input/input13/event13"
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:74:00.0/usb5/5-1/5-1.1/5-1.1:1.0/input/input32/event17"
Nov 26 14:25:48 wmax2 /usr/lib/gdm-x-session[1033]: (II) XINPUT: Adding extended input device "USB Camera: USB Camera" (type: KEYBOARD, id 11)
Nov 26 14:25:51 wmax2 /usr/lib/gdm-x-session[1045]: dbus-daemon[1045]: [session uid=120 pid=1045] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1178 comm="/usr/lib/gsd-usb-protection")
Nov 26 14:25:52 wmax2 gsd-usb-protect[1178]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 14:26:56 wmax2 /usr/lib/gdm-wayland-session[1031]: dbus-daemon[1031]: [session uid=120 pid=1031] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1151 comm="/usr/lib/gsd-usb-protection")
Nov 26 14:26:56 wmax2 gsd-usb-protect[1151]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 14:27:15 wmax2 gsd-usb-protect[1835]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 15:24:43 wmax2 /usr/lib/gdm-wayland-session[1016]: dbus-daemon[1016]: [session uid=120 pid=1016] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1149 comm="/usr/lib/gsd-usb-protection")
Nov 26 15:24:43 wmax2 gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 15:25:09 wmax2 gsd-usb-protect[1845]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 19:21:22 wmax2 /usr/lib/gdm-wayland-session[1007]: dbus-daemon[1007]: [session uid=120 pid=1007] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1137 comm="/usr/lib/gsd-usb-protection")
Nov 26 19:21:22 wmax2 gsd-usb-protect[1137]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 19:21:33 wmax2 gsd-usb-protect[1833]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 22:22:11 wmax2 /usr/lib/gdm-wayland-session[1040]: dbus-daemon[1040]: [session uid=120 pid=1040] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1157 comm="/usr/lib/gsd-usb-protection")
Nov 26 22:22:11 wmax2 gsd-usb-protect[1157]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 26 22:22:21 wmax2 gsd-usb-protect[1864]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 11:03:28 wmax2 /usr/lib/gdm-wayland-session[1020]: dbus-daemon[1020]: [session uid=120 pid=1020] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1148 comm="/usr/lib/gsd-usb-protection")
Nov 27 11:03:28 wmax2 gsd-usb-protect[1148]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 11:03:49 wmax2 gsd-usb-protect[1838]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 11:56:05 wmax2 /usr/lib/gdm-wayland-session[1045]: dbus-daemon[1045]: [session uid=120 pid=1045] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1156 comm="/usr/lib/gsd-usb-protection")
Nov 27 11:56:05 wmax2 gsd-usb-protect[1156]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 11:56:16 wmax2 gsd-usb-protect[1855]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 13:54:52 wmax2 /usr/lib/gdm-wayland-session[1002]: dbus-daemon[1002]: [session uid=120 pid=1002] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1135 comm="/usr/lib/gsd-usb-protection")
Nov 27 13:54:52 wmax2 gsd-usb-protect[1135]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 13:55:10 wmax2 gsd-usb-protect[1842]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 23:08:06 wmax2 /usr/lib/gdm-wayland-session[973]: dbus-daemon[973]: [session uid=120 pid=973] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1099 comm="/usr/lib/gsd-usb-protection")
Nov 27 23:08:06 wmax2 gsd-usb-protect[1099]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 23:09:25 wmax2 /usr/lib/gdm-wayland-session[1027]: dbus-daemon[1027]: [session uid=120 pid=1027] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1170 comm="/usr/lib/gsd-usb-protection")
Nov 27 23:09:25 wmax2 gsd-usb-protect[1170]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 27 23:09:36 wmax2 gsd-usb-protect[1872]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 09:45:32 wmax2 /usr/lib/gdm-wayland-session[1071]: dbus-daemon[1071]: [session uid=120 pid=1071] Activating service name='org.gnome.ScreenSaver' requested by ':1.11' (uid=120 pid=1187 comm="/usr/lib/gsd-usb-protection")
Nov 28 09:45:32 wmax2 gsd-usb-protect[1187]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 09:45:49 wmax2 gsd-usb-protect[1871]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 09:55:05 wmax2 /usr/lib/gdm-wayland-session[1029]: dbus-daemon[1029]: [session uid=120 pid=1029] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1167 comm="/usr/lib/gsd-usb-protection")
Nov 28 09:55:05 wmax2 gsd-usb-protect[1167]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 09:55:17 wmax2 gsd-usb-protect[1871]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 10:05:09 wmax2 kernel: Modules linked in: rfcomm ccm intel_rapl_msr intel_rapl_common cmac algif_hash algif_skcipher af_alg qrtr bnep uvcvideo snd_soc_acp6x_mach snd_soc_dmic videobuf2_vmalloc snd_acp6x_pdm_dma videobuf2_memops btusb videobuf2_v4l2 snd_sof_amd_renoir snd_sof_amd_acp btrtl hid_logitech_dj mousedev btbcm videobuf2_common snd_sof_pci btintel videodev snd_sof btmtk edac_mce_amd snd_hda_codec_conexant vfat mc fat joydev hid_multitouch iwlmvm snd_sof_utils snd_hda_codec_generic bluetooth kvm_amd ecdh_generic amdgpu crc16 usbhid mac80211 ledtrig_audio snd_soc_core snd_hda_codec_hdmi libarc4 snd_compress kvm snd_hda_intel snd_intel_dspcfg ac97_bus iwlwifi irqbypass snd_intel_sdw_acpi crct10dif_pclmul gpu_sched snd_pcm_dmaengine snd_hda_codec snd_rpl_pci_acp6x crc32_pclmul drm_buddy polyval_clmulni snd_acp_pci snd_hda_core polyval_generic snd_pci_acp6x gf128mul snd_hwdep drm_ttm_helper snd_pci_acp5x cfg80211 ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm ttm aesni_intel tpm_crb
Nov 28 10:10:43 wmax2 kernel: Modules linked in: acpi_cpufreq(-) amd64_edac(-) snd_acp6x_pdm_dma snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci uvcvideo(+) snd_sof hid_logitech_dj(+) videobuf2_vmalloc videobuf2_memops snd_sof_utils videobuf2_v4l2 videobuf2_common btusb snd_soc_core btrtl videodev btbcm snd_compress vfat mousedev mc fat btintel edac_mce_amd iwlmvm(+) ac97_bus snd_hda_codec_conexant btmtk kvm_amd amdgpu(+) mac80211 snd_hda_codec_generic snd_pcm_dmaengine ledtrig_audio bluetooth snd_hda_codec_hdmi libarc4 snd_hda_intel snd_rpl_pci_acp6x kvm snd_intel_dspcfg snd_acp_pci iwlwifi snd_intel_sdw_acpi gpu_sched irqbypass snd_pci_acp6x ecdh_generic joydev hid_multitouch snd_hda_codec drm_buddy snd_pci_acp5x crct10dif_pclmul crc16 usbhid snd_hda_core crc32_pclmul snd_rn_pci_acp3x drm_ttm_helper tpm_crb polyval_clmulni cfg80211 snd_hwdep ttm polyval_generic snd_acp_config snd_pcm gf128mul xpad tpm_tis snd_soc_acpi drm_display_helper sp5100_tco snd_timer ghash_clmulni_intel aesni_intel ff_memless
Nov 28 10:10:46 wmax2 /usr/lib/gdm-wayland-session[1079]: dbus-daemon[1079]: [session uid=120 pid=1079] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1221 comm="/usr/lib/gsd-usb-protection")
Nov 28 10:10:46 wmax2 gsd-usb-protect[1221]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 10:11:01 wmax2 gsd-usb-protect[2045]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 10:45:51 wmax2 kernel: Modules linked in: pcc_cpufreq(-) amd64_edac(-) snd_soc_acp6x_mach fjes(-) snd_soc_dmic uvcvideo(+) videobuf2_vmalloc snd_acp6x_pdm_dma videobuf2_memops snd_sof_amd_renoir videobuf2_v4l2 snd_sof_amd_acp videobuf2_common snd_sof_pci videodev snd_sof snd_hda_codec_conexant edac_mce_amd vfat hid_logitech_dj(+) btusb snd_hda_codec_generic snd_sof_utils kvm_amd mc fat iwlmvm btrtl mousedev joydev ledtrig_audio snd_soc_core snd_hda_codec_hdmi hid_multitouch(+) btbcm snd_compress btintel amdgpu(+) snd_hda_intel mac80211 kvm ac97_bus btmtk snd_intel_dspcfg irqbypass snd_pcm_dmaengine snd_intel_sdw_acpi libarc4 crct10dif_pclmul snd_rpl_pci_acp6x crc32_pclmul snd_hda_codec snd_acp_pci gpu_sched polyval_clmulni polyval_generic bluetooth iwlwifi snd_hda_core gf128mul snd_pci_acp6x drm_buddy ghash_clmulni_intel snd_pci_acp5x snd_hwdep drm_ttm_helper ecdh_generic snd_rn_pci_acp3x tpm_crb ttm snd_pcm crc16 aesni_intel usbhid snd_acp_config cfg80211 sp5100_tco drm_display_helper xpad
Nov 28 10:45:54 wmax2 /usr/lib/gdm-wayland-session[1100]: dbus-daemon[1100]: [session uid=120 pid=1100] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1216 comm="/usr/lib/gsd-usb-protection")
Nov 28 10:45:54 wmax2 gsd-usb-protect[1216]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 10:49:54 wmax2 gsd-usb-protect[2084]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 12:24:08 wmax2 kernel: Modules linked in: uvcvideo(+) videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 snd_acp6x_pdm_dma snd_soc_dmic snd_soc_acp6x_mach videobuf2_common snd_sof_amd_renoir snd_sof_amd_acp btusb videodev snd_sof_pci snd_hda_codec_conexant btrtl hid_logitech_dj(+) fjes(-) mousedev(+) mc snd_hda_codec_generic btbcm snd_sof ledtrig_audio iwlmvm(+) edac_mce_amd btintel joydev snd_hda_codec_hdmi snd_sof_utils vfat btmtk hid_multitouch(+) fat snd_soc_core bluetooth kvm_amd mac80211 snd_hda_intel ecdh_generic snd_compress snd_intel_dspcfg amdgpu(+) crc16 usbhid kvm snd_intel_sdw_acpi ac97_bus libarc4 snd_pcm_dmaengine snd_hda_codec irqbypass snd_rpl_pci_acp6x snd_acp_pci crct10dif_pclmul gpu_sched snd_hda_core snd_pci_acp6x crc32_pclmul drm_buddy polyval_clmulni iwlwifi snd_pci_acp5x snd_hwdep drm_ttm_helper polyval_generic snd_rn_pci_acp3x gf128mul ttm snd_pcm snd_acp_config ghash_clmulni_intel aesni_intel cfg80211 xpad snd_soc_acpi sp5100_tco drm_display_helper snd_timer tpm_crb
Nov 28 12:24:11 wmax2 /usr/lib/gdm-wayland-session[1099]: dbus-daemon[1099]: [session uid=120 pid=1099] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1209 comm="/usr/lib/gsd-usb-protection")
Nov 28 12:24:11 wmax2 gsd-usb-protect[1209]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 12:24:24 wmax2 gsd-usb-protect[2127]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 15:21:02 wmax2 kernel: Modules linked in: videobuf2_memops snd_sof videobuf2_v4l2 iwlmvm(+) snd_hda_codec_conexant videobuf2_common snd_sof_utils snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi snd_soc_core videodev btusb vfat snd_hda_intel btrtl mac80211 amd64_edac(-) hid_logitech_dj(+) snd_intel_dspcfg mc fat pcc_cpufreq(-) mousedev libarc4 btbcm acpi_cpufreq(-) snd_compress snd_intel_sdw_acpi edac_mce_amd btintel ac97_bus joydev hid_multitouch(+) amdgpu(+) btmtk iwlwifi snd_pcm_dmaengine kvm_amd snd_rpl_pci_acp6x snd_hda_codec bluetooth kvm snd_acp_pci gpu_sched snd_hda_core ecdh_generic snd_pci_acp6x drm_buddy irqbypass crc16 usbhid drm_ttm_helper crct10dif_pclmul snd_hwdep snd_pci_acp5x cfg80211 ttm crc32_pclmul snd_rn_pci_acp3x snd_pcm polyval_clmulni snd_acp_config polyval_generic tpm_crb sp5100_tco xpad drm_display_helper gf128mul snd_timer snd_soc_acpi tpm_tis ghash_clmulni_intel aesni_intel crypto_simd cryptd ff_memless rapl pcspkr tpm_tis_core k10temp thunderbolt snd i2c_piix4
Nov 28 15:21:57 wmax2 kernel: Modules linked in: btbcm edac_mce_amd snd_hda_codec_conexant snd_sof btintel snd_hda_codec_generic vfat videodev snd_sof_utils fat mousedev(+) hid_logitech_dj(+) mc joydev(+) pcc_cpufreq(-) fjes(-) mac80211 hid_multitouch(+) snd_soc_core ledtrig_audio snd_hda_codec_hdmi btmtk kvm_amd libarc4 amdgpu(+) snd_compress snd_hda_intel snd_intel_dspcfg ac97_bus bluetooth iwlwifi snd_intel_sdw_acpi kvm snd_pcm_dmaengine snd_hda_codec gpu_sched snd_rpl_pci_acp6x snd_acp_pci drm_buddy ecdh_generic irqbypass drm_ttm_helper crc16 usbhid snd_pci_acp6x snd_hda_core crct10dif_pclmul snd_pci_acp5x cfg80211 snd_hwdep ttm snd_rn_pci_acp3x snd_pcm crc32_pclmul snd_acp_config polyval_clmulni drm_display_helper sp5100_tco snd_soc_acpi snd_timer xpad polyval_generic tpm_crb gf128mul ghash_clmulni_intel aesni_intel crypto_simd cryptd ff_memless rapl tpm_tis pcspkr thunderbolt snd cec rfkill ccp snd_pci_acp3x k10temp soundcore i2c_piix4 video i2c_hid_acpi tpm_tis_core i2c_hid tpm acpi_tad mac_hid
Nov 28 15:23:06 wmax2 kernel: Modules linked in: btrtl(+) videobuf2_common(+) snd_hda_codec_generic btbcm amd64_edac(-) ledtrig_audio btintel edac_mce_amd snd_compress snd_hda_codec_hdmi videodev ac97_bus btmtk snd_pcm_dmaengine mousedev(+) vfat snd_hda_intel mc joydev hid_multitouch(+) kvm_amd fat iwlmvm(+) bluetooth snd_rpl_pci_acp6x snd_intel_dspcfg fjes(-) snd_intel_sdw_acpi ecdh_generic kvm snd_acp_pci crc16 usbhid mac80211 amdgpu(+) irqbypass libarc4 snd_hda_codec snd_pci_acp6x crct10dif_pclmul snd_hda_core crc32_pclmul gpu_sched iwlwifi polyval_clmulni snd_pci_acp5x snd_hwdep drm_buddy polyval_generic snd_pcm drm_ttm_helper gf128mul snd_rn_pci_acp3x ghash_clmulni_intel snd_timer ttm snd_acp_config tpm_crb cfg80211 sp5100_tco xpad snd drm_display_helper snd_soc_acpi tpm_tis aesni_intel crypto_simd ff_memless cryptd rapl pcspkr tpm_tis_core thunderbolt soundcore ccp cec k10temp snd_pci_acp3x rfkill i2c_piix4 i2c_hid_acpi tpm video i2c_hid rng_core acpi_tad mac_hid squashfs loop uinput dm_multipath
Nov 28 15:25:05 wmax2 /usr/lib/gdm-wayland-session[1042]: dbus-daemon[1042]: [session uid=120 pid=1042] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1165 comm="/usr/lib/gsd-usb-protection")
Nov 28 15:25:05 wmax2 gsd-usb-protect[1165]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 15:25:15 wmax2 gsd-usb-protect[1870]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 17:11:32 wmax2 kernel: Modules linked in: ntfs3 uas usb_storage rfcomm ccm cmac algif_hash algif_skcipher af_alg intel_rapl_msr intel_rapl_common qrtr bnep snd_soc_acp6x_mach snd_soc_dmic snd_acp6x_pdm_dma uvcvideo videobuf2_vmalloc snd_sof_amd_renoir snd_sof_amd_acp videobuf2_memops videobuf2_v4l2 snd_sof_pci videobuf2_common snd_hda_codec_conexant snd_sof snd_hda_codec_generic btusb snd_sof_utils edac_mce_amd videodev btrtl vfat ledtrig_audio iwlmvm snd_hda_codec_hdmi mc hid_logitech_dj kvm_amd mousedev snd_soc_core btbcm joydev snd_hda_intel fat snd_compress amdgpu snd_intel_dspcfg btintel mac80211 ac97_bus hid_multitouch kvm snd_intel_sdw_acpi btmtk snd_pcm_dmaengine libarc4 irqbypass snd_hda_codec crct10dif_pclmul snd_rpl_pci_acp6x crc32_pclmul bluetooth iwlwifi snd_acp_pci snd_hda_core gpu_sched polyval_clmulni snd_pci_acp6x drm_buddy polyval_generic snd_hwdep ecdh_generic snd_pci_acp5x drm_ttm_helper gf128mul crc16 usbhid cfg80211 ttm ghash_clmulni_intel snd_pcm snd_rn_pci_acp3x xpad
Nov 28 20:43:21 wmax2 /usr/lib/gdm-wayland-session[982]: dbus-daemon[982]: [session uid=120 pid=982] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1104 comm="/usr/lib/gsd-usb-protection")
Nov 28 20:43:21 wmax2 gsd-usb-protect[1104]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 20:44:39 wmax2 /usr/lib/gdm-wayland-session[1054]: dbus-daemon[1054]: [session uid=120 pid=1054] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1164 comm="/usr/lib/gsd-usb-protection")
Nov 28 20:44:40 wmax2 gsd-usb-protect[1164]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 20:44:51 wmax2 gsd-usb-protect[1883]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 21:07:28 wmax2 /usr/lib/gdm-wayland-session[1044]: dbus-daemon[1044]: [session uid=120 pid=1044] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1152 comm="/usr/lib/gsd-usb-protection")
Nov 28 21:07:28 wmax2 gsd-usb-protect[1152]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 21:08:50 wmax2 /usr/lib/gdm-wayland-session[1033]: dbus-daemon[1033]: [session uid=120 pid=1033] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1148 comm="/usr/lib/gsd-usb-protection")
Nov 28 21:08:50 wmax2 gsd-usb-protect[1148]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 28 21:09:01 wmax2 gsd-usb-protect[1867]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
                                               Module /usr/lib/wine/x86_64-unix/win32u.so with build-id 48964dbc6a3b5a710c06bfc2bdc90c39e228b500
                                               Module /usr/lib/libSDL2-2.0.so.0.2400.2 with build-id 699b2717ad696268b06d810c2f8d54ed51b9be9a
                                               Module /usr/lib/wine/x86_64-unix/libwine.so.1.0 with build-id 8e6d119556ea03ce10739c036d3d3b64d9b6b75d
                                               Module /usr/lib/wine/x86_64-unix/winebus.so with build-id 14be08ef214f0247853ddba409bda35882eb9106
                                               Module /usr/lib/wine/x86_64-unix/ntdll.so with build-id 9811bf90b679408ef949f0f72a2dc9864625dee9
                                               Module /usr/lib/wine/x86_64-unix/wineusb.so with build-id fd1978824e0936206b1b485cd2f5ba38c21b9a8a
                                               #2  0x00007f04325a3438 libusb_handle_events_timeout_completed (/usr/lib/libusb-1.0.so.0.3.0 + 0x12438)
                                               #4  0x00007f67cf690a88 NtWaitForMultipleObjects (/usr/lib/wine/x86_64-unix/ntdll.so + 0x4ca88)
                                               #5  0x00007f67cf68179d __wine_syscall_dispatcher_prolog_end (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3d79d)
                                               #4  0x00007fbe0e95ba88 NtWaitForMultipleObjects (/usr/lib/wine/x86_64-unix/ntdll.so + 0x4ca88)
                                               #5  0x00007fbe0e94c79d __wine_syscall_dispatcher_prolog_end (/usr/lib/wine/x86_64-unix/ntdll.so + 0x3d79d)
Nov 29 16:30:38 wmax2 kernel: Modules linked in: ufs hfsplus hfs cdrom minix msdos jfs xfs ext4 mbcache jbd2 tls snd_seq_dummy snd_seq snd_seq_device rfcomm ccm cmac algif_hash algif_skcipher intel_rapl_msr intel_rapl_common af_alg bnep qrtr hid_logitech_dj uvcvideo videobuf2_vmalloc btusb videobuf2_memops snd_soc_acp6x_mach snd_soc_dmic snd_acp6x_pdm_dma videobuf2_v4l2 btrtl videobuf2_common btbcm btintel videodev btmtk snd_sof_amd_renoir vfat snd_hda_codec_conexant snd_sof_amd_acp iwlmvm mousedev mc joydev fat snd_sof_pci bluetooth snd_hda_codec_generic hid_multitouch ecdh_generic crc16 usbhid amdgpu mac80211 ledtrig_audio snd_sof snd_hda_codec_hdmi snd_sof_utils libarc4 snd_hda_intel snd_soc_core snd_intel_dspcfg snd_compress edac_mce_amd snd_intel_sdw_acpi ac97_bus snd_pcm_dmaengine snd_hda_codec kvm_amd iwlwifi gpu_sched snd_rpl_pci_acp6x snd_hda_core kvm snd_acp_pci drm_buddy snd_pci_acp6x cfg80211 drm_ttm_helper irqbypass snd_hwdep snd_pci_acp5x ttm crct10dif_pclmul snd_rn_pci_acp3x snd_pcm xpad
Nov 30 12:18:36 wmax2 /usr/lib/gdm-wayland-session[1006]: dbus-daemon[1006]: [session uid=120 pid=1006] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1165 comm="/usr/lib/gsd-usb-protection")
Nov 30 12:18:36 wmax2 gsd-usb-protect[1165]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 12:18:48 wmax2 gsd-usb-protect[1900]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:36:37 wmax2 /usr/lib/gdm-wayland-session[1014]: dbus-daemon[1014]: [session uid=120 pid=1014] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1138 comm="/usr/lib/gsd-usb-protection")
Nov 30 13:36:37 wmax2 gsd-usb-protect[1138]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:38:06 wmax2 /usr/lib/gdm-wayland-session[1000]: dbus-daemon[1000]: [session uid=120 pid=1000] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1136 comm="/usr/lib/gsd-usb-protection")
Nov 30 13:38:06 wmax2 gsd-usb-protect[1136]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:39:25 wmax2 /usr/lib/gdm-wayland-session[1030]: dbus-daemon[1030]: [session uid=120 pid=1030] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1168 comm="/usr/lib/gsd-usb-protection")
Nov 30 13:39:25 wmax2 gsd-usb-protect[1168]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:39:37 wmax2 gsd-usb-protect[1873]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:41:07 wmax2 /usr/lib/gdm-wayland-session[1025]: dbus-daemon[1025]: [session uid=120 pid=1025] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1134 comm="/usr/lib/gsd-usb-protection")
Nov 30 13:41:07 wmax2 gsd-usb-protect[1134]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:41:18 wmax2 gsd-usb-protect[1846]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:51:02 wmax2 /usr/lib/gdm-wayland-session[1020]: dbus-daemon[1020]: [session uid=120 pid=1020] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1149 comm="/usr/lib/gsd-usb-protection")
Nov 30 13:51:02 wmax2 gsd-usb-protect[1149]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 13:51:13 wmax2 gsd-usb-protect[1862]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 15:42:36 wmax2 kernel: Modules linked in: hid_logitech_dj(+) qrtr mousedev fjes(-) snd_soc_acp6x_mach snd_soc_dmic snd_acp6x_pdm_dma snd_sof_amd_renoir btusb snd_sof_amd_acp btrtl snd_sof_pci btbcm iwlmvm(+) btintel snd_sof btmtk vfat edac_mce_amd snd_sof_utils joydev fat hid_multitouch(+) bluetooth kvm_amd snd_hda_codec_conexant snd_soc_core mac80211 snd_hda_codec_generic ecdh_generic snd_compress crc16 usbhid amdgpu(+) libarc4 ledtrig_audio ac97_bus snd_hda_codec_hdmi kvm snd_pcm_dmaengine snd_hda_intel snd_rpl_pci_acp6x snd_intel_dspcfg snd_acp_pci irqbypass snd_intel_sdw_acpi crct10dif_pclmul snd_pci_acp6x crc32_pclmul iwlwifi snd_hda_codec xpad polyval_clmulni gpu_sched snd_pci_acp5x polyval_generic ff_memless snd_hda_core gf128mul drm_buddy snd_rn_pci_acp3x ghash_clmulni_intel cfg80211 drm_ttm_helper snd_hwdep aesni_intel ttm snd_pcm snd_acp_config crypto_simd drm_display_helper sp5100_tco snd_soc_acpi snd_timer cryptd tpm_crb rapl pcspkr tpm_tis thunderbolt snd cec ccp snd_pci_acp3x rfkill
Nov 30 15:42:39 wmax2 /usr/lib/gdm-wayland-session[1061]: dbus-daemon[1061]: [session uid=120 pid=1061] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1234 comm="/usr/lib/gsd-usb-protection")
Nov 30 15:42:39 wmax2 gsd-usb-protect[1234]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 15:44:03 wmax2 kernel: Modules linked in: videobuf2_common snd_soc_acp6x_mach snd_soc_dmic videodev btusb snd_acp6x_pdm_dma btrtl mc btbcm btintel btmtk qrtr snd_sof_amd_renoir pcc_cpufreq(-) snd_sof_amd_acp snd_sof_pci bluetooth snd_sof snd_sof_utils snd_hda_codec_conexant snd_hda_codec_generic vfat ecdh_generic snd_soc_core hid_multitouch(+) fat ledtrig_audio snd_hda_codec_hdmi usbhid(+) crc16 iwlmvm edac_mce_amd snd_hda_intel snd_compress snd_intel_dspcfg ac97_bus mac80211 kvm_amd snd_intel_sdw_acpi snd_pcm_dmaengine amdgpu(+) libarc4 snd_rpl_pci_acp6x snd_hda_codec snd_acp_pci xpad kvm snd_pci_acp6x snd_hda_core gpu_sched drm_buddy irqbypass ff_memless iwlwifi snd_pci_acp5x snd_hwdep crct10dif_pclmul drm_ttm_helper snd_rn_pci_acp3x crc32_pclmul ttm snd_pcm polyval_clmulni snd_acp_config cfg80211 polyval_generic drm_display_helper snd_soc_acpi tpm_crb snd_timer sp5100_tco gf128mul ghash_clmulni_intel aesni_intel crypto_simd snd cryptd rapl pcspkr tpm_tis thunderbolt soundcore snd_pci_acp3x
Nov 30 15:44:06 wmax2 /usr/lib/gdm-wayland-session[1073]: dbus-daemon[1073]: [session uid=120 pid=1073] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1258 comm="/usr/lib/gsd-usb-protection")
Nov 30 15:44:06 wmax2 gsd-usb-protect[1258]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 15:44:18 wmax2 gsd-usb-protect[1976]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 22:42:53 wmax2 /usr/lib/gdm-wayland-session[1046]: dbus-daemon[1046]: [session uid=120 pid=1046] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1158 comm="/usr/lib/gsd-usb-protection")
Nov 30 22:42:53 wmax2 gsd-usb-protect[1158]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 22:43:02 wmax2 gsd-usb-protect[1866]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 22:43:47 wmax2 /usr/lib/gdm-wayland-session[1031]: dbus-daemon[1031]: [session uid=120 pid=1031] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1141 comm="/usr/lib/gsd-usb-protection")
Nov 30 22:43:48 wmax2 gsd-usb-protect[1141]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 22:43:57 wmax2 gsd-usb-protect[1853]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 22:48:31 wmax2 /usr/lib/gdm-wayland-session[1032]: dbus-daemon[1032]: [session uid=120 pid=1032] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1169 comm="/usr/lib/gsd-usb-protection")
Nov 30 22:48:31 wmax2 gsd-usb-protect[1169]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 30 22:48:41 wmax2 gsd-usb-protect[1877]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Dec 01 09:09:26 wmax2 /usr/lib/gdm-wayland-session[1041]: dbus-daemon[1041]: [session uid=120 pid=1041] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=1152 comm="/usr/lib/gsd-usb-protection")
Dec 01 09:09:26 wmax2 gsd-usb-protect[1152]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Dec 01 09:09:31 wmax2 kernel: Modules linked in: ccm intel_rapl_msr intel_rapl_common cmac algif_hash algif_skcipher af_alg qrtr bnep snd_soc_acp6x_mach snd_soc_dmic snd_acp6x_pdm_dma snd_sof_amd_renoir uvcvideo snd_sof_amd_acp videobuf2_vmalloc snd_sof_pci videobuf2_memops videobuf2_v4l2 snd_sof btusb videobuf2_common btrtl snd_sof_utils iwlmvm videodev btbcm snd_hda_codec_conexant snd_soc_core btintel snd_hda_codec_generic vfat btmtk snd_compress ledtrig_audio snd_hda_codec_hdmi mc fat mousedev joydev hid_multitouch edac_mce_amd bluetooth mac80211 ac97_bus snd_hda_intel snd_intel_dspcfg snd_pcm_dmaengine snd_intel_sdw_acpi ecdh_generic snd_rpl_pci_acp6x crc16 usbhid kvm_amd amdgpu libarc4 snd_hda_codec snd_acp_pci kvm gpu_sched iwlwifi snd_pci_acp6x drm_buddy irqbypass crct10dif_pclmul snd_pci_acp5x snd_hda_core drm_ttm_helper crc32_pclmul snd_hwdep polyval_clmulni ttm snd_rn_pci_acp3x polyval_generic snd_pcm cfg80211 gf128mul snd_acp_config xpad snd_soc_acpi ghash_clmulni_intel tpm_crb sp5100_tco
Dec 01 09:09:37 wmax2 gsd-usb-protect[1856]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
-- Boot 7da4f14d7ed344f09911344abceffd72 --
Dec 01 09:15:35 wmax2 /usr/lib/gdm-wayland-session[1035]: dbus-daemon[1035]: [session uid=120 pid=1035] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=1172 comm="/usr/lib/gsd-usb-protection")
Dec 01 09:15:35 wmax2 gsd-usb-protect[1172]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Dec 01 09:15:45 wmax2 gsd-usb-protect[1886]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
-- Boot 55afbf0eb46947e9a8893fd888a43080 --
Dec 01 09:17:37 wmax2 /usr/lib/gdm-wayland-session[1028]: dbus-daemon[1028]: [session uid=120 pid=1028] Activating service name='org.gnome.ScreenSaver' requested by ':1.11' (uid=120 pid=1136 comm="/usr/lib/gsd-usb-protection")
Dec 01 09:17:37 wmax2 gsd-usb-protect[1136]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Dec 01 09:17:48 wmax2 gsd-usb-protect[1850]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
I see, especially at the end, errors for multiple different usb ports :thinking:
I have to go out due to real life again today, so hopefully in mean time others can figure out whats wrong here :woman_shrugging:
You’re very kind. I hope you have a good day! I’ll have a Google for the errors in the meantime.
Still no luck, unfortunately :frowning: I haven’t been able to find anything helpful so far.
I somehow feel it has todo with some BIOS settings but i have no clue at moment. :woman_shrugging:
This looks more like error when resuming from suspend rather than a fresh boot.
If so hopefully there’ll be a way around it in the OS; the BIOS options are very limited.
Ohhh indeed, that slipped my eyes :+1:
@MattMcHackit , could you please do a proper shutdown via the menu, and then try to boot without the drives connected, to see if they get accessible after you plug them back in?
That may be the case with that error, but the problem with USB device detection is still present even on a freshly booted system. If I reboot or power the system completely off and then on, then connect a USB device once Manjaro is up and running it’s not detected/usable unless something was connected to one of the other USB ports of the same type (type A or C) at boot.
I’ll try it to be sure, 2 mins…
Let me ping @spikerguy - he has more experience with GDP like devices …
Just did a complete shutdown from the menu and booted with no USB devices connected (other than those integrated into the laptop). I then plugged in a USB C hub with power pass through, an HDMI monitor, and 2 USB devices connected to it, and also plugged a USB pen drive directly into a USB type A port. The power pass through and HDMI worked, none of the USB devices did until I ran
sudo lsusb -v
which caused all USB devices connected at the time of the command to start working. Additional devices connected after the command are not detected.
N.B. running lsusb -v without sudo has no affect.
Thank you!
