After last update material shell not working
uname -a
Linux 6.0.5-3-rt14-MANJARO #1 SMP PREEMPT_RT Wed Jan 18 08:17:56 UTC 2023 x86_64 GNU/Linux
any idea to fixe this issue ?
thank u
uname -a
thank u
Heya,
Switching to material shell using the layout switcher on the stable branch seems to work for me in a VM. Since Material shell is a extension some conflict could be the cause, that would be my first step, disable extensions not directly needed. Posting more then your kernel version could shed some light on your specific setup and encourage others to help you solve the issue.
@Hanzel i am using last version of material shell and of course i already select materiall shel layout type
but didn t work !!
I tested the 22.0.2 ISO which includes all stable branch updates. On that ISO it works just fine.
We know it does not work for you, that was clear from the first post. Read the linked post and provide data that can be used to help you. The journal would be a good start, it is linked in the post above.
@Hanzel sorry for that, and this is error journal:
journalctl --boot=-1 --priority=3 --catalog --no-pager ξ² β
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: swapper/1/0/0x00010002
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: swapper/5/0/0x00010002
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/362/0x00010001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/365/0x00010001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/360/0x00010001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/364/0x00010001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: swapper/5/0/0x7fff0000
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: swapper/1/0/0x7fff0000
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/365/0x7fff0001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/364/0x7fff0001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/362/0x7fff0001
Feb 04 19:34:14 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: apparmor_parser/360/0x7fff0001
Feb 04 19:34:14 kamal-20hjs1c700 systemd[1]: Failed to start Load AppArmor profiles.
Feb 04 19:34:17 kamal-20hjs1c700 bluetoothd[958]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 04 19:34:17 kamal-20hjs1c700 bluetoothd[958]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 04 19:34:17 kamal-20hjs1c700 bluetoothd[958]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 04 19:34:20 kamal-20hjs1c700 systemd[1]: Failed to start Service for snap application anbox.container-manager.
ββ Subject: A start job for unit snap.anbox.container-manager.service has failed
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit snap.anbox.container-manager.service has finished with a failure.
ββ
ββ The job identifier is 1601 and the job result is failed.
Feb 04 19:34:23 kamal-20hjs1c700 kernel:
Feb 04 19:34:38 kamal-20hjs1c700 rtkit-daemon[2825]: Failed to make ourselves RT: Operation not permitted
Feb 04 19:34:44 kamal-20hjs1c700 gdm-password][3165]: gkr-pam: unable to locate daemon control file
Feb 04 19:34:47 kamal-20hjs1c700 systemd[3179]: Failed to start Application launched by gnome-session-binary.
ββ Subject: A start job for unit UNIT has failed
ββ
ββ A start job for unit UNIT has finished with a failure.
ββ
ββ The job identifier is 209 and the job result is failed.
ββ
ββ
ββ The job identifier is 205 and the job result is failed.
ββ
ββ
ββ The job identifier is 201 and the job result is failed.
Feb 04 19:34:49 kamal-20hjs1c700 rtkit-daemon[2825]: Failed to make ourselves RT: Operation not permitted
Feb 04 19:34:51 kamal-20hjs1c700 konsole[3651]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 04 19:34:51 kamal-20hjs1c700 konsole[3651]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 04 19:34:54 kamal-20hjs1c700 gdm-launch-environment][2410]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Feb 04 19:35:50 kamal-20hjs1c700 systemd-coredump[6154]: [π‘] Process 5870 (gnome-character) of user 1000 dumped core.
Stack trace of thread 5870:
#0 0x00007f3c90b8e64c n/a (libc.so.6 + 0x8864c)
#1 0x00007f3c90b3e938 raise (libc.so.6 + 0x38938)
#2 0x00007f3c90b2853d abort (libc.so.6 + 0x2253d)
#3 0x00007f3c9119306a n/a (libglib-2.0.so.0 + 0x1d06a)
#4 0x00007f3c911eea90 g_assertion_message_expr (libglib-2.0.so.0 + 0x78a90)
#5 0x00007f3c8791703c n/a (libgtk-4.so.1 + 0x40d03c)
#6 0x00007f3c91137114 g_object_unref (libgobject-2.0.so.0 + 0x22114)
#7 0x00007f3c9130f71e n/a (libgjs.so.0 + 0x5a71e)
#8 0x00007f3c91311be0 n/a (libgjs.so.0 + 0x5cbe0)
#9 0x00007f3c91377f36 n/a (libgjs.so.0 + 0xc2f36)
#10 0x00007f3c9130f935 n/a (libgjs.so.0 + 0x5a935)
#11 0x00007f3c903a89ca n/a (libmozjs-102.so + 0x169e9ca)
#12 0x00007f3c903a7077 n/a (libmozjs-102.so + 0x169d077)
#13 0x00007f3c90770032 n/a (libmozjs-102.so + 0x1a66032)
#14 0x00007f3c9076ed57 n/a (libmozjs-102.so + 0x1a64d57)
#15 0x00007f3c9022dd01 n/a (libmozjs-102.so + 0x1523d01)
#16 0x00007f3c9022a203 n/a (libmozjs-102.so + 0x1520203)
#17 0x00007f3c90225276 n/a (libmozjs-102.so + 0x151b276)
#18 0x00007f3c90223f64 n/a (libmozjs-102.so + 0x1519f64)
#19 0x00007f3c903dcd76 n/a (libmozjs-102.so + 0x16d2d76)
#20 0x00007f3c91332837 n/a (libgjs.so.0 + 0x7d837)
#21 0x00007f3c911cc052 n/a (libglib-2.0.so.0 + 0x56052)
#22 0x00007f3c911cb82b g_main_context_dispatch (libglib-2.0.so.0 + 0x5582b)
#23 0x00007f3c91222cc9 n/a (libglib-2.0.so.0 + 0xaccc9)
#24 0x00007f3c911ca0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#25 0x00007f3c9102576e g_application_run (libgio-2.0.so.0 + 0xde76e)
#26 0x00007f3c90ae04f6 n/a (libffi.so.8 + 0x74f6)
#27 0x00007f3c90adcf5e n/a (libffi.so.8 + 0x3f5e)
#28 0x00007f3c90adfb73 ffi_call (libffi.so.8 + 0x6b73)
#29 0x00007f3c91303408 n/a (libgjs.so.0 + 0x4e408)
#30 0x00007f3c91303b28 n/a (libgjs.so.0 + 0x4eb28)
#31 0x00007f3c8ffa96f6 n/a (libmozjs-102.so + 0x129f6f6)
#32 0x00007f3c902ff88b n/a (libmozjs-102.so + 0x15f588b)
#33 0x00007f3c903dd858 n/a (libmozjs-102.so + 0x16d3858)
#34 0x00007f3c90590187 n/a (libmozjs-102.so + 0x1886187)
#35 0x00007f3c9133dd27 n/a (libgjs.so.0 + 0x88d27)
#36 0x00007f3c91340bb8 gjs_context_eval (libgjs.so.0 + 0x8bbb8)
#37 0x00005640379e3b3d n/a (gjs-console + 0x2b3d)
#38 0x00007f3c90b29290 n/a (libc.so.6 + 0x23290)
#39 0x00007f3c90b2934a __libc_start_main (libc.so.6 + 0x2334a)
#40 0x00005640379e3f05 n/a (gjs-console + 0x2f05)
Stack trace of thread 5878:
#0 0x00007f3c90c0137f __poll (libc.so.6 + 0xfb37f)
#1 0x00007f3c91222c2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007f3c911ca0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007f3c911ca132 n/a (libglib-2.0.so.0 + 0x54132)
#4 0x00007f3c911f8db5 n/a (libglib-2.0.so.0 + 0x82db5)
#5 0x00007f3c90b8c8fd n/a (libc.so.6 + 0x868fd)
#6 0x00007f3c90c0ed20 n/a (libc.so.6 + 0x108d20)
Stack trace of thread 5889:
#0 0x00007f3c90b894b6 n/a (libc.so.6 + 0x834b6)
#1 0x00007f3c90b8bcd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
#2 0x00007f3c902982b1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x158e2b1)
#3 0x00007f3c902981a3 n/a (libmozjs-102.so + 0x158e1a3)
#4 0x00007f3c9044aeae n/a (libmozjs-102.so + 0x1740eae)
Stack trace of thread 5881:
#2 0x00007f3c911cad8f g_main_loop_run (libglib-2.0.so.0 + 0x54d8f)
#3 0x00007f3c91051aec n/a (libgio-2.0.so.0 + 0x10aaec)
Stack trace of thread 5890:
Stack trace of thread 5892:
Stack trace of thread 5894:
Stack trace of thread 5893:
Stack trace of thread 5891:
Stack trace of thread 5895:
Stack trace of thread 5896:
Stack trace of thread 5947:
#3 0x00007f3c7f761fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 5949:
#0 0x00007f3c90c06abd syscall (libc.so.6 + 0x100abd)
#1 0x00007f3c9121c3e3 g_cond_wait_until (libglib-2.0.so.0 + 0xa63e3)
#2 0x00007f3c91199893 n/a (libglib-2.0.so.0 + 0x23893)
#3 0x00007f3c91199a37 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23a37)
#4 0x00007f3c911fe4c6 n/a (libglib-2.0.so.0 + 0x884c6)
#5 0x00007f3c911f8db5 n/a (libglib-2.0.so.0 + 0x82db5)
#6 0x00007f3c90b8c8fd n/a (libc.so.6 + 0x868fd)
#7 0x00007f3c90c0ed20 n/a (libc.so.6 + 0x108d20)
ββ Subject: Process 5870 (gnome-character) dumped core
ββ Documentation: man:core(5)
ββ
ββ Process 5870 (gnome-character) crashed and dumped core.
ββ
ββ This usually indicates a programming error in the crashing program and
ββ should be reported to its vendor as a bug.
Feb 04 19:36:42 kamal-20hjs1c700 deepin-turbo-invoker[6546]: error: Failed to initiate connect on the socket for type dtkwidget.
Feb 04 19:36:42 kamal-20hjs1c700 deepin-turbo-invoker[6546]: error: Failed to initiate connect on the socket for type generic.
Feb 04 19:36:42 kamal-20hjs1c700 deepin-turbo-invoker[6546]: error: Start application /usr/bin/deepin-screenshot as a binary executable without launcher...
Feb 04 19:37:10 kamal-20hjs1c700 deepin-turbo-invoker[6700]: error: Failed to initiate connect on the socket for type dtkwidget.
Feb 04 19:37:10 kamal-20hjs1c700 deepin-turbo-invoker[6700]: error: Failed to initiate connect on the socket for type generic.
Feb 04 19:37:10 kamal-20hjs1c700 deepin-turbo-invoker[6700]: error: Start application /usr/bin/deepin-screenshot as a binary executable without launcher...
Feb 04 19:37:25 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: irq/145-s-nvidi/1635/0x00000002
Feb 04 19:37:25 kamal-20hjs1c700 kernel: BUG: scheduling while atomic: irq/145-s-nvidi/1635/0x00000000
Feb 04 19:40:01 kamal-20hjs1c700 rtkit-daemon[2825]: Failed to make ourselves RT: Operation not permitted
Feb 04 23:26:00 kamal-20hjs1c700 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Feb 04 23:26:28 kamal-20hjs1c700 systemd-coredump[8528]: [π‘] Process 3329 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 3329:
#0 0x00007fd4c3b2c83d n/a (libmutter-clutter-11.so.0 + 0x3583d)
#1 0x00007fd4c35d4e97 n/a (libst-1.0.so + 0x53e97)
#2 0x00007fd4c3b239f6 n/a (libmutter-clutter-11.so.0 + 0x2c9f6)
#3 0x00007fd4c3b2d574 n/a (libmutter-clutter-11.so.0 + 0x36574)
#4 0x00007fd4c35d4e97 n/a (libst-1.0.so + 0x53e97)
#5 0x00007fd4c3b239f6 n/a (libmutter-clutter-11.so.0 + 0x2c9f6)
#6 0x00007fd4c3b2d574 n/a (libmutter-clutter-11.so.0 + 0x36574)
#7 0x00007fd4c35d4e97 n/a (libst-1.0.so + 0x53e97)
#8 0x00007fd4c3b239f6 n/a (libmutter-clutter-11.so.0 + 0x2c9f6)
#9 0x00007fd4c3b2d574 n/a (libmutter-clutter-11.so.0 + 0x36574)
#10 0x00007fd4c3b239f6 n/a (libmutter-clutter-11.so.0 + 0x2c9f6)
#11 0x00007fd4c3b2cf1a n/a (libmutter-clutter-11.so.0 + 0x35f1a)
#12 0x00007fd4c394849b n/a (libmutter-11.so.0 + 0x11249b)
#13 0x00007fd4c3ba8204 n/a (libmutter-clutter-11.so.0 + 0xb1204)
#14 0x00007fd4c470f12c g_signal_emit_valist (libgobject-2.0.so.0 + 0x3212c)
#15 0x00007fd4c470f214 g_signal_emit (libgobject-2.0.so.0 + 0x32214)
#16 0x00007fd4c3b2d7f3 clutter_actor_hide (libmutter-clutter-11.so.0 + 0x367f3)
#17 0x00007fd4c3bad8c8 n/a (libmutter-clutter-11.so.0 + 0xb68c8)
#18 0x00007fd4c46ff261 g_object_run_dispose (libgobject-2.0.so.0 + 0x22261)
#19 0x00007fd4c3b2fec5 clutter_actor_destroy (libmutter-clutter-11.so.0 + 0x38ec5)
#20 0x00007fd4c389be2f n/a (libmutter-11.so.0 + 0x65e2f)
#21 0x00007fd4c46ff261 g_object_run_dispose (libgobject-2.0.so.0 + 0x22261)
#22 0x00007fd4c390e1a8 n/a (libmutter-11.so.0 + 0xd81a8)
#23 0x00007fd4c46ff261 g_object_run_dispose (libgobject-2.0.so.0 + 0x22261)
#24 0x00007fd4c3906eec meta_context_destroy (libmutter-11.so.0 + 0xd0eec)
#25 0x000055d09f03c4bb n/a (gnome-shell + 0x24bb)
#26 0x00007fd4c3650290 n/a (libc.so.6 + 0x23290)
#27 0x00007fd4c365034a __libc_start_main (libc.so.6 + 0x2334a)
#28 0x000055d09f03c715 n/a (gnome-shell + 0x2715)
Stack trace of thread 8417:
#0 0x00007fd4c372dabd syscall (libc.so.6 + 0x100abd)
#1 0x00007fd4c46443e3 g_cond_wait_until (libglib-2.0.so.0 + 0xa63e3)
#2 0x00007fd4c45c1893 n/a (libglib-2.0.so.0 + 0x23893)
#3 0x00007fd4c45c1a37 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23a37)
#4 0x00007fd4c46264c6 n/a (libglib-2.0.so.0 + 0x884c6)
#5 0x00007fd4c4620db5 n/a (libglib-2.0.so.0 + 0x82db5)
#6 0x00007fd4c36b38fd n/a (libc.so.6 + 0x868fd)
#7 0x00007fd4c3735d20 n/a (libc.so.6 + 0x108d20)
Stack trace of thread 7110:
#0 0x00007fd4c36b04b6 n/a (libc.so.6 + 0x834b6)
#1 0x00007fd4c36b2cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
#2 0x00007fd4c1e3f2b1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x158e2b1)
#3 0x00007fd4c1e3f1a3 n/a (libmozjs-102.so + 0x158e1a3)
#4 0x00007fd4c1ff1eae n/a (libmozjs-102.so + 0x1740eae)
#5 0x00007fd4c36b38fd n/a (libc.so.6 + 0x868fd)
#6 0x00007fd4c3735d20 n/a (libc.so.6 + 0x108d20)
Stack trace of thread 7095:
#0 0x00007fd4c372837f __poll (libc.so.6 + 0xfb37f)
#1 0x00007fd4c464ac2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007fd4c45f20e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007fd4c45f2132 n/a (libglib-2.0.so.0 + 0x54132)
#4 0x00007fd4c4620db5 n/a (libglib-2.0.so.0 + 0x82db5)
Stack trace of thread 7111:
Stack trace of thread 7098:
#3 0x00007fd4c4930fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 7109:
Stack trace of thread 7108:
Stack trace of thread 7112:
Stack trace of thread 7097:
#2 0x00007fd4c45f2d8f g_main_loop_run (libglib-2.0.so.0 + 0x54d8f)
#3 0x00007fd4c4848aec n/a (libgio-2.0.so.0 + 0x10aaec)
Stack trace of thread 7113:
Stack trace of thread 7114:
Stack trace of thread 7115:
ββ Subject: Process 3329 (gnome-shell) dumped core
ββ
ββ Process 3329 (gnome-shell) crashed and dumped core.
ββ
Feb 04 23:26:28 kamal-20hjs1c700 pulseaudio[3380]: Lost I/O connection in module "module-gsettings"
Feb 04 23:26:33 kamal-20hjs1c700 rtkit-daemon[2825]: Failed to make ourselves RT: Operation not permitted
Feb 04 23:26:36 kamal-20hjs1c700 gdm-password][8947]: gkr-pam: unable to locate daemon control file
Feb 04 23:26:38 kamal-20hjs1c700 systemd[3179]: Failed to start Application launched by gnome-session-binary.
ββ
ββ
ββ The job identifier is 1187 and the job result is failed.
ββ
ββ
ββ The job identifier is 1183 and the job result is failed.
ββ
ββ
ββ The job identifier is 1179 and the job result is failed.
Feb 04 23:26:40 kamal-20hjs1c700 rtkit-daemon[2825]: Failed to make ourselves RT: Operation not permitted
Feb 04 23:26:41 kamal-20hjs1c700 systemd-coredump[9535]: [π‘] Process 9470 (touchegg) of user 1000 dumped core.
Stack trace of thread 9470:
#0 0x00007f26e019064c n/a (libc.so.6 + 0x8864c)
#1 0x00007f26e0140938 raise (libc.so.6 + 0x38938)
#2 0x00007f26e012a53d abort (libc.so.6 + 0x2253d)
#3 0x00007f26e0491833 _ZN9__gnu_cxx27__verbose_terminate_handlerEv (libstdc++.so.6 + 0x9a833)
#4 0x00007f26e049dccc _ZN10__cxxabiv111__terminateEPFvvE (libstdc++.so.6 + 0xa6ccc)
#5 0x00007f26e049dd39 _ZSt9terminatev (libstdc++.so.6 + 0xa6d39)
#6 0x00007f26e049df9d __cxa_throw (libstdc++.so.6 + 0xa6f9d)
#7 0x000055cc8fcb3764 n/a (touchegg + 0x14764)
#8 0x000055cc8fcb58a4 main (touchegg + 0x168a4)
#9 0x00007f26e012b290 n/a (libc.so.6 + 0x23290)
#10 0x00007f26e012b34a __libc_start_main (libc.so.6 + 0x2334a)
#11 0x000055cc8fcb5f75 _start (touchegg + 0x16f75)
ββ Subject: Process 9470 (touchegg) dumped core
ββ
ββ Process 9470 (touchegg) crashed and dumped core.
ββ
Feb 04 23:26:41 kamal-20hjs1c700 konsole[9431]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 04 23:26:41 kamal-20hjs1c700 konsole[9431]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 04 23:26:44 kamal-20hjs1c700 gdm-launch-environment][8557]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Feb 04 23:26:52 kamal-20hjs1c700 systemd-coredump[10829]: Failed to connect to coredump service: Connection refused
Feb 04 23:26:52 kamal-20hjs1c700 gdm[2103]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Feb 04 23:26:52 kamal-20hjs1c700 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Feb 04 23:26:54 kamal-20hjs1c700 kernel: watchdog: watchdog0: watchdog did not stop!
Nothing in the log that to me seems to indicate that the switch to material shell does not function or can be activated. There are some entries that, if I where you, need some attention, but do not seem to me a cause for the extension to not function.
Please post the output of inxi -v7azy
To try to find why the extension does not work or cannot be activated, lets try this:
1 disable all extensions in the extension manager.
2 reboot & log in again
3 open a terminal window and run journalctl --follow (this will print log output to the terminal screen)
4 open layout manager and switch to material shell
5 stop the logging to the terminal with ctrl + c
6 Look through the log and see if there are errors/messages from gnome-shell / gnome / extension that might lead you to a solution.
If the layout switcher is able to enable material shell you know that there is a conflict with something that was enabled so you have to do some trail and error enabling extensions. The command to follow the log will help you with that.
If layout switcher is not able to enable material shell then the log will likely have some leads as to why so post it here for users to try and help you.
@Hanzel thank you for the response and i fixe after reset all settings of material-shell :
dconf reset -f /org/gnome/shell/extensions/materialshell/
