Update 05/05/2025: USB tethering not working
Greetings from Poland.
My equipment: FUJITSU LIFEBOOK E751
My system: Manjaro, Gnome 48, Wayland, Linux kernel 6.6.88-1-MANJARO
Problem:
Today I performed a system update. I restarted the system and saw that USB therating does not work. I always used a fast connection from my smartphone and now I only have slow WiFi.
Please help me fix the USB therating function.
Thank you for your help.
sudo inxi --verbosity=8 --filter                                 ✔
[sudo] hasło użytkownika cenart:
  Kernel: 6.6.88-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=635d0a93-9414-4181-b844-1050f45fbccd rw quiet splash apparmor=1
  Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: FUJITSU product: LIFEBOOK E751 v: 10601398455
    serial: <filter> Chassis: type: 10 v: LIFEBOOK E751 serial: <filter>
  Mobo: FUJITSU model: FJNB223 v: F3 serial: <filter>
    uuid: ebdc0c4a-7178-e011-8b14-5c9ad8d98341 UEFI: FUJITSU // Phoenix
    v: Version 1.22 date: 04/26/2013
  ID-1: CMB1 charge: 52.9 Wh (79.0%) condition: 67.0/67.0 Wh (100.0%)
    volts: 11.9 min: 10.8 model: Fujitsu CP483691-01 type: Li-ion
    serial: <filter> status: not charging
  System RAM: total: 6 GiB available: 5.68 GiB used: 3.78 GiB (66.6%)
    igpu: 64 MiB
  Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Kinston part-no: HP16D3LS1KBGH/4G serial: <filter>
  Device-2: DIMM2 type: DDR3 detail: synchronous size: 2 GiB
    manufacturer: SK-Hynix part-no: HMT325S6CFR8A-PB serial: <filter>
  Slot: 0 type: PCIe status: unknown info: ExpressCard length: other
    volts: 3.3 bus-ID: 00:00.0
  Info: model: Intel Core i5-2410M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 799 min/max: 800/2900 base/boost: 2300/2300 scaling:
    driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz
    cores: 1: 799 2: 799 3: 799 4: 799 bogomips: 18367
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Fujitsu driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: DP-1, DP-2,
    DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0116 class-ID: 0300
  Device-2: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6:4 chip-ID: 04f2:b240
    class-ID: 0e02
  Display: unspecified server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-size: <missing: xdpyinfo>
  Monitor-1: LVDS-1 model: Lenovo 0x40b1 built: 2009 res: mode: 1600x900
    hz: 60 scale: 100% (1) dpi: 116 gamma: 1.2 chroma: red: x: 0.612 y: 0.349
    green: x: 0.318 y: 0.588 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 350x190mm (13.78x7.48") diag: 396mm (15.6") ratio: 16:9
    modes: 1600x900
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: x11: xprop,xrandr
    vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  API: ALSA v: k6.6.88-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cat,pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
    with: 1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
    tools: pacat,pactl
  Device-1: Intel 82579V Gigabit Network vendor: Fujitsu . LIFEBOOK E752
    driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:1503
    class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter vendor: Fujitsu
    driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 0a:00.0 chip-ID: 168c:002e class-ID: 0280
  IF: wlp10s0 state: up mac: <filter>
  Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 698.65 GiB used: 131.97 GiB (18.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
    family: Micron Client SSDs size: 232.89 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 023 temp: 47 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 103d 12h cycles: 3625
    written: 6.26 TiB
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD5000BPKT-75PK4T0 family: Scorpio Black (AF) size: 465.76 GiB
    block-size: physical: 4096 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 33 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 265d 4h cycles: 12132
    read: 22.05 TiB written: 13.69 TiB Old-Age: g-sense error rate: 137669
  ID-1: / raw-size: 76 GiB size: 74.51 GiB (98.04%) used: 34.48 GiB (46.3%)
    fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 635d0a93-9414-4181-b844-1050f45fbccd
  ID-2: /boot/efi raw-size: 101 MiB size: 99.4 MiB (98.45%)
    used: 301 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: DB00-7338
  ID-3: /home raw-size: 133.79 GiB size: 130.63 GiB (97.64%)
    used: 97.49 GiB (74.6%) fs: ext4 block-size: 4096 B dev: /dev/sda4
    maj-min: 8:4 label: N/A uuid: c8934d8a-4ed3-4855-b9d8-de89ac7f3c19
  ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: a6ab1809-6648-4599-bb3a-1d9966aa340f
  ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
    uuid: 1EE0-B1CA
  ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-3: /dev/sdb3 maj-min: 8:19 size: 160 GiB fs: ntfs label: N/A
    uuid: 32C2E25CC2E22437
  ID-4: /dev/sdb4 maj-min: 8:20 size: 305.15 GiB fs: ntfs label: Data
    uuid: 867A54977A548639
  ID-5: /dev/sdb5 maj-min: 8:21 size: 509 MiB fs: ntfs label: N/A
    uuid: 7CB464D4B4649306
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-3: 1-1.3:3 info: O2 Micro Oz776 1.1 Hub ports: 4 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 2mA chip-ID: 0b97:7761
  Device-1: 1-1.3.2:4 info: O2 Micro OZ776 CCID Smartcard Reader
    type: smart card driver: N/A interfaces: 1 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0b97:7772
    class-ID: 0b00
  Hub-4: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.3:15 info: Motorola PCS XT1541 [Moto G 3rd Gen]
    type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.0
    chip-ID: 22b8:2e82 class-ID: 0000 serial: <filter>
  Device-2: 2-1.5:3 info: Logitech M185 compact wireless mouse type: mouse
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 046d:c542 class-ID: 0301
  Device-3: 2-1.6:4 info: Chicony FJ Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b240 class-ID: 0e02
  System Temperatures: cpu: 61.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1814 pm: pacman pkgs: 1798 libs: 509 tools: gnome-software,pamac
    pm: flatpak pkgs: 3 pm: snap pkgs: 13
    1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    3: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    5: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    6: http://manjaro.grena.ge/stable/$repo/$arch
    7: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 255
  1: cpu: 10.7% command: gnome-shell pid: 1595 mem: 284.9 MiB (4.9%)
  2: cpu: 9.6% command: chromium pid: 2436 mem: 399.2 MiB (6.8%)
  3: cpu: 8.0% command: chromium pid: 2513 mem: 221.2 MiB (3.8%)
  4: cpu: 7.9% command: gnome-terminal-server pid: 4961 mem: 60.1 MiB (1.0%)
  5: cpu: 7.2% command: chromium pid: 4436 mem: 254.1 MiB (4.3%)
  Memory top: 5 of 255
  1: mem: 452.2 MiB (7.7%) command: thunderbird pid: 3491 cpu: 2.3%
  2: mem: 399.2 MiB (6.8%) command: chromium pid: 2436 cpu: 9.6%
  3: mem: 284.9 MiB (4.9%) command: gnome-shell pid: 1595 cpu: 10.7%
  4: mem: 273.8 MiB (4.7%) command: chromium pid: 2612 cpu: 2.3%
  5: mem: 254.1 MiB (4.3%) command: chromium pid: 4436 cpu: 7.2%
  Processes: 255 Power: uptime: 59m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.26 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: gnome-terminal inxi: 3.3.38
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
    :footprints:
When connecting my Android phone
I get presented with a menu
from which I can choose USB tethering
I can also access this via other ways.
But I have to explicitly allow USB tethering, to share the Network connection of the phone with my laptop - it appears as a Ethernet connection in NetworkManager
It’s not automatic.
So:
check the steps you take to find what you might have missed
Hello.
I have always done as you write, but the update from 05.05.2025 causes it to no longer work.
That is why I am asking for help.
as nachlese says i would also say it is a wrong setting on the mobile phone. according to the info driver: usbfs, i would say it is mounted as filesystem.
But when I connect my phone, a window pops up and I can choose USB tethering.
Before the update, I did this, tethering turned on and I had a fast connection. And now I don’t have it. It doesn’t work.
did you do the same before running inxi?
Yes. I’ve been using Manjaro for over 6 years. I’ve always started USB tethering this way and it worked. After today’s update, it doesn’t work anymore.
I found a post on the GNOME 48 forum where they write that there is such a problem and suggest downgrading the kernel version, but I can’t paste that post here.
Downgrading the kernel is a bit abnormal.
i can’t test it myself right now to see if it works for me. but i also have the testing branch active and the 6.14 kernel installed.
maybe an upgrade to the 6.12 kernel will help you?
There is no better solution for now.
I’ll try to switch to kernel 6.12 LTS. I’ll write if it helped.
No need to do that.
Just use a different kernel.
You don’t have to use the most recent one.
There are several LTS versions available.
But you can.
Just format your post or the address as
“blockquote” or “preformatted text” (easily accessible from the top row of the edit window here)
It could be a problem with your phone …
open a terminal and have:
journalctl -f
running in it
the continuous live output will tell you what happens …
[type or paste code here](https://discourse.gnome.org/t/no-more-android-tethering-from-usb-6-14-2-kernel-issue/28395)
you mean this:
No more android tethering from usb (6.14.2 kernel issue) - Desktop - GNOME Discourse
I haven’t read it yet.
now I have read it
It doesn’t look pertinent.
Show journalctl -f
while you connect your phone
to see what happens vs. what you expect to happen
to have us see what your system sees when you are activating usb tethering on your phone
usb tethering has NEVER failed me, so far
journalctl -f                                                    ✔
maj 05 22:16:36 manjaro colord-sane[3890]: io/hpmud/pp.c 627: unable to read device-id ret=-1
maj 05 22:16:36 manjaro kernel: usb 2-1.3: new high-speed USB device number 15 using ehci-pci
maj 05 22:16:36 manjaro kernel: usb 2-1.3: New USB device found, idVendor=22b8, idProduct=2e82, bcdDevice= 5.04
maj 05 22:16:36 manjaro kernel: usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
maj 05 22:16:36 manjaro kernel: usb 2-1.3: Product: motorola edge 30 neo
maj 05 22:16:36 manjaro kernel: usb 2-1.3: Manufacturer: motorola
maj 05 22:16:36 manjaro kernel: usb 2-1.3: SerialNumber: ZY22GPNPH5
maj 05 22:16:36 manjaro gvfsd[3898]: Error 1: Get Storage information failed.
maj 05 22:16:36 manjaro gnome-shell[1617]: Failed to query filesystem: method Gio.File.query_filesystem_info_async: At least 4 arguments required, but only 3 passed
maj 05 22:16:36 manjaro colord-sane[3897]: io/hpmud/pp.c 627: unable to read device-id ret=-1
maj 05 22:16:41 manjaro kernel: usb 2-1.3: USB disconnect, device number 15
maj 05 22:16:41 manjaro gvfsd[3898]: PTP: reading event an error 0x05 occurred
maj 05 22:16:41 manjaro kernel: usb 2-1.3: new high-speed USB device number 16 using ehci-pci
maj 05 22:16:41 manjaro kernel: usb 2-1.3: New USB device found, idVendor=22b8, idProduct=2e24, bcdDevice= 5.04
maj 05 22:16:41 manjaro kernel: usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
maj 05 22:16:41 manjaro kernel: usb 2-1.3: Product: motorola edge 30 neo
maj 05 22:16:41 manjaro kernel: usb 2-1.3: Manufacturer: motorola
maj 05 22:16:41 manjaro kernel: usb 2-1.3: SerialNumber: ZY22GPNPH5
maj 05 22:16:41 manjaro kernel: rndis_host 2-1.3:1.0 wwan0: register 'rndis_host' at usb-0000:00:1a.0-1.3, Mobile Broadband RNDIS device, de:d9:60:29:c2:0d
maj 05 22:16:41 manjaro kernel: rndis_host 2-1.3:1.0 wwp0s26u1u3: renamed from wwan0
maj 05 22:16:42 manjaro ModemManager[861]: <wrn> [plugin-manager] task 7: port context already scheduled
maj 05 22:16:42 manjaro gvfsd[3932]: LIBMTP PANIC: Unable to find interface & endpoints of device
maj 05 22:16:42 manjaro gnome-shell[1617]: Unable to mount volume motorola edge 30 neo: Gio.IOErrorEnum: Nie można otworzyć urządzenia MTP „002,016”
maj 05 22:16:42 manjaro colord-sane[3926]: io/hpmud/pp.c 627: unable to read device-id ret=-1
maj 05 22:16:43 manjaro gvfsd[3932]: Device 0 (VID=22b8 and PID=2e24) is a Motorola X 2nd edition XT1097 (MTP).
maj 05 22:16:43 manjaro gvfsd[3898]: Device 0 (VID=22b8 and PID=2e82) is a Motorola Moto E/G/Z (ID2) (MTP).
maj 05 22:16:43 manjaro gvfsd[3898]: Android device detected, assigning default bug flags
maj 05 22:16:45 manjaro ModemManager[861]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1.3': not supported by any plugin
Kernel changed to 6.12: USB tethering doesn’t work.
I think the latest update is the problem.
There were a lot of updates before and tethering always worked.
More about this: USB tethering not working after updating to latest kernel (Page 2) / Newbie Corner / Arch Linux Forums
It will be fixed in kernel 6.14.6.
I have read this thread. I am not an IT expert. From this post I understand that I have to wait for a fix.
There is currently no kernel 6.14.6 in Manjaro.
For now, there will be no fast internet from the mobile phone.
Hmmm, it was nice to work at 300 Mb/s.
But maybe there’s a solution…
You can downgrade to a working kernel version. Note, that it does not help using the 6.1 or 6.12 lts versions. They received the same faulty patch.
Yes, I noticed that too. Following the advice of my colleague napcok, I downgraded the kernel to 5.15 LTS: USB tethering works fine.
I can say that the problem has been solved.
However, I think that going back to an older kernel is not a good solution.
There is a question: until when is support for 5.15 LTS?
Support for kernel 5.15 LTS is expected to end in December, 2026:
The Linux Kernel Archives - Releases:
Version Maintainer Released Projected EOL
6.12 Greg Kroah-Hartman & Sasha Levin 2024-11-17 Dec, 2026
6.6 Greg Kroah-Hartman & Sasha Levin 2023-10-29 Dec, 2026
6.1 Greg Kroah-Hartman & Sasha Levin 2022-12-11 Dec, 2027
5.15 Greg Kroah-Hartman & Sasha Levin 2021-10-31 Dec, 2026
5.10 Greg Kroah-Hartman & Sasha Levin 2020-12-13 Dec, 2026
5.4 Greg Kroah-Hartman & Sasha Levin 2019-11-24 Dec, 2025
