Hi all,
Recently the Wifi connection has been quite unstable, even the signals of the two Wifies I connect are strong. Previously I thought it was the wifi’s problem, but I realised that when my PC failed to connect to the internet, my phone connected with the same wifi worked normally.
If I switch to another wifi, it works sometimes. So the safer way is to disable the wifi and enable it again, but it won’t last long. So I usually connect my phone’s hotspot.
Best,
Wei
Some information:
KDE Plasma Version: 5.27.11
KDE Frameworks Version: 5.115.0
Qt Version: 5.15.12
$ uname -a
Linux mBio 6.6.19-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Mar 1 18:16:16 UTC 2024 x86_64 GNU/Linux
$ sudo lshw -c network
*-network
description: Wireless interface
product: QCNFA765 Wireless Network Adapter
vendor: Qualcomm Technologies, Inc
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0
version: 01
serial: 04:7b:cb:b2:4e:10
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath11k_pci driverversion=6.6.19-1-MANJARO firmware=N/A ip=10.255.27.178 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:91 memory:98000000-981fffff
Hi @shenwei356 ,
I see this is not your first post, so why didn’t you provide the required information:
From the tutorial: [HowTo] Provide System Information :
Regardless of your problem, always do the following:
Go to the Manjaro forum home page
Choose the correct category
Create a new topic
Describe the symptoms of your issue succinctly simply and shortly.
Go to a terminal by pressing Ctrl +Alt +T , or by going to your start menu and look for something called Konsole
or Console
or xterm
and click on it.
Maximise that black screen (that’s “the terminal”)
If you’re on a non-English version of Manjaro, copy-paste the following:
export LANG=C
and then press Enter
Copy-paste the following:
inxi --full --admin --filter --width
* Please note that by hovering over the above text, a small icon will appear at the end of a single line or at the top right of multiple lines of text.
* Clicking that icon takes care of the copy part already, so you just have to paste it into the terminal by right-clicking on it and choosing <kbd>Paste</kbd>.
* Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command.
Press Enter to execute the command
Now go back to your question and type 3 backticks `
Select, and copy-paste the full output of the inxi
command FROM the terminal TO BELOW those 3 backticks
End the output with another set of 3 backticks.
(your output is now correctly formatted to allow us to help you more efficiently)
text
End your post with an actual question like:
What should I do now?
How should I proceed?
So please, we need the information specified there, starting with:
Sorry, I didn’t know that rule. Here are more details:
$ inxi --full --admin --filter --width
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=3e1bd41d-01aa-436b-a9d0-6b5b401365b4 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped
2: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 21CMA001CD v: ThinkPad X13 Gen 3
Mobo: LENOVO model: 21CMA001CD v: ThinkPad serial: <superuser required>
part-nu: LENOVO_MT_21CM_BU_Think_FM_ThinkPad X13 Gen 3
uuid: <superuser required> UEFI: LENOVO v: R22ET49W (1.19 )
date: 06/24/2022
ID-1: BAT0 charge: 49.8 Wh (100.0%) condition: 49.8/54.7 Wh (91.0%)
volts: 17.3 min: 15.4 model: Sunwoda LNV-5B10W51855�� type: Li-poly
serial: <filter> status: full cycles: 76
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: discharging
Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 836 high: 1400 min/max: 400/4768 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
4: 1397 5: 1400 6: 400 7: 1397 8: 1397 9: 400 10: 1397 11: 400 12: 1397
13: 400 14: 400 15: 400 16: 1397 bogomips: 86284
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6 bus-ID: 33:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 39.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 5986:2148
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 res: 2560x1440 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
rembrandt LLVM 16.0.6 DRM 3.54 6.6.19-1-MANJARO) device-ID: 1002:1681
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 33:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 33:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 33:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 17cb:1103 class-ID: 0280
Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-3.1:3 chip-ID: 10ab:9309 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.82 TiB used: 477.49 GiB (25.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.74%) used: 39.64 GiB (50.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 1.72 TiB size: 1.69 TiB (98.37%)
used: 437.85 GiB (25.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (rpm): fan-1: 0
Memory: total: 16 GiB note: est. available: 14.4 GiB used: 5.75 GiB (39.9%)
Processes: 386 Power: uptime: 1h 9m states: freeze,mem,disk suspend: s2idle
image: 5.75 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1918 libs: 514 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: yakuake inxi: 3.3.33
According to Qualcomm QCNFA765 Wireless Network Adapter :
The device is supported by kernel versions 5.14 and newer according to the LKDDb
So I don’t know what to suggest, except perhaps trying a different kernel, perhaps 6.1:
sudo mhwd-kernel --install linux61
And reboot into it :
All available kernels installed on your system will be presented upon booting up. GNU GRUB is visible with a couple of options. Choose “Advanced Options for Manjaro Linux” by using the arrow keys ↑ ↓ on your keyboard and then ↵ Enter .
On the next screen (as illustrated) are backup copies of each kernel version installed (which will also be automatically removed if or when a kernel version is deleted). To select a kernel, simply use the arrow keys ↑ ↓ to highlight the desired version, and then press ↵ Enter .
Unfortunately, it does not help. It might be still the wifi’s problem. The Wifi is weak but stable at home (sorry I forgot to mention this.).
Then I can honestly think of nothing further to do, especially if it works even with a weaker signal elsewhere. Makes me think it’s not your Manjaro or even your PC.
Have you tried a different channel, if possible? It could be bluetooth interference (I think.)
Good point, but they are two public WIFIs, which I can’t configure the channel. I reported this to the IT colleagues days ago, while it’s not helpful.
I appreciate your help.
It could also be a poor quality interface; it seems to be an Atheros chipset which is generally good, but it could also be from the lower end of their product line.
Apart from that possibility, and as @Mirdarthos suggests, the cause likely falls back to your environment; which we can’t help much with.
