[Unstable Update] January 2025
Welcome to the new monthly unstable branch thread.
Recent News
Notable Package Changes
Known Issues
Critical rsync security release 3.4.0
2025-01-16 - Robin Candau
We’d like to raise awareness about the rsync security release version 3.4.0-1 as described in our advisory ASA-202501-1.
An attacker only requires anonymous read access to a vulnerable rsync server, such as a public mirror, to execute arbitrary code on the machine the server is running on. Additionally, attackers can take control of an affected server and read/write arbitrary files of any connected client. Sensitive data can be extracted, such as OpenPGP and SSH keys, and malicious code can be executed by overwriting files such as ~/.bashrc or ~/.popt.
We highly advise anyone who runs an rsync daemon or client prior to version 3.4.0-1 to upgrade and reboot their systems immediately. As Arch Linux mirrors are mostly synchronized using rsync, we highly advise any mirror administrator to act immediately, even though the hosted package files themselves are cryptographically signed.
All infrastructure servers and mirrors maintained by Arch Linux have already been updated.
– Arch Linux - News: Critical rsync security release 3.4.0
Additional Info
Info about AUR packages
Plasma 6.2.5 was released today.
Full change log here
I switched from stable to unstable (sudo pacman-mirrors --api --set-branch unstable and sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syu) and got this message:
/usr/lib/sysusers.d/nvidia-utils.conf:1: Unknown modifiers in command '!u'.
less /usr/lib/sysusers.d/nvidia-utils.conf:
!u nvidia-persistenced 143 'NVIDIA Persistence Daemon'
How can I fix the error? Many thanks in advance
Not sure how to fix, but looking at other files in that directory, it looks like the !u may be a mistake and should be u!
fix incoming
update solved the problem
mhwd-nvidia-565.77-5-any
nvidia-utils-565.77-5-x86_64
Had massive problems during December updates & nvidia drivers.
Now everything works smoothly, no bugs on desktop, updates work instantly.
Thanks to Manjaro Team! :wink:
3 posts were split to a new topic: I’m not sure whether i’ve a partial update
New security item added to Known Issues :point_up:
Unless you followed any of the guides on here telling you to remove those SigLevel lines. :wink:
Huh? :thinking:
This one.
Used to suggest
SigLevel    = Optional DatabaseNever
But has since been edited to suggest
SigLevel    = Required DatabaseNever
But there are still an untold number of threads and users with the suggestion in one way or another to disable the signatures.
Such as here:
I just meant that anyone who has followed such advice or for whatever reason has lesser SigLevel options applied would be vulnerable to an exploited mirror.
For a while at least one of the most common responses to ‘Trouble syncing packages, errors about keys’ on the forums was to augment the SigLevel options to something more permissive. That always meant lesser security, but this news makes a tangible argument for why not to.
Ah, I see. Thank you for providing helpful context. :+1:
2 posts were merged into an existing topic: [Testing Update] 2025-01-15 - Kernels, KDE Frameworks, Calamares, Cosmic, Firefox, Gambas, Steam
There is a new nvidia driver.
I’m aware:
❯ pacman -Qi nvidia-utils | grep Version
Version         : 570.86.16-1
:wink:
Coming soon :tm:
