Did you entirely remove the manjaro-gdm-theme package?
Why?
I had absolutely no problem with it and now the highlighted user in GDM is in blue, which is the worst highlight color you can possibly get (even worse with a dark background). And it has nothing to do with Manjaro colors.
Could you please put it back as an optional dependency or something (if it causes problems for others)?
If not, how can I change it? Otherwise I will need to get rid of GDM.
Just want to say that I’ve been using Matcha dark theme even for libawaita apps and it works flawlessly, the setting looks a bit weird but I prefer these colors to the default gnome.
Manual snapshots are made, but don’t appear in the GUI, while scheduled ones error out.
Edit: CLI Timeshift doesn’t see the manual snapshot I just made…
Edit: Trying to create a new snapshot via CLI errors out, and removed the manual snapshot made via GUI
May be:
using Kernel 5.17.4-1 sometimes I got while rebooting:
Failed to send Watchdog=1 message: Transport endpoint is not connected
Machine reboots after 15 Minutes - using Kernel 5.15.35-1 not affected…
I’m on Testing so maybe it is not relevant, but I only use the GUI and do manual snapshots, and it works no problem this way (RSYNC with EXT4, no BTRFS here).
[demo@manjaro etc]$ sudo pacman -Syu
[sudo] password for demo:
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies...
:: installing nvidia-utils (510.68.02-1) breaks dependency 'nvidia-utils=510.60.02' required by linux516-nvidia
[demo@manjaro etc]$
Remove linux516-nvidia and install nvidia-dkms. Either that or install a supported kernel like 5.17 stable or 5.15 LTS and remove the 5.16 kernel altogether from Manjaro Settings Manager. It’s been EOL for a couple weeks now.
