philm
17 September 2021 10:07
1
Hello community,
Another unstable branch update with some usual updates for you.
Get the lastes KDE Software with our Daily Builds
Most of our Kernels got updated
Pipewire is now at 0.3.36
The current version of LibreOffice is now at 7.2.1
rhvoice got added
gstreamer is now at 1.18.5
KDE Framewors got updated to 5.86.0 , which brings enhancements to Wayland-Support for Nvidia drivers
Other regular upstream updates
Get our latest daily developer images now from Github: Plasma , Gnome , XFCE . You get the latest stable releases of Manjaro from CDN77 .
Our current supported kernels
linux44 4.4.283
linux49 4.9.282
linux414 4.14.246
linux419 4.19.206
linux54 5.4.147
linux510 5.10.66
linux512 5.12.19 [EOL]
linux513 5.13.18
linux514 5.14.5
linux510-rt 5.10.52_rt47
Package Updates (Fri Sep 17 10:57:34 CEST 2021)
unstable community x86_64: 417 new and 381 removed package(s)
unstable core x86_64: 21 new and 18 removed package(s)
unstable extra x86_64: 331 new and 333 removed package(s)
unstable kde-unstable x86_64: 239 new and 239 removed package(s)
unstable multilib x86_64: 9 new and 9 removed package(s)
A detailed list of package changes can be found here .
No issue, everything went smoothly
Yes there was an issue. I was able to resolve it myself.(Please post your solution)
Yes i am currently experiencing an issue due to the update. (Please post about it)
pux
17 September 2021 08:11
2
I guess i have some questions regarding packagekit changes.
Since Manjaro ships it’s own version, gnome-software is unable to make any system package updates as it doesn’t seem to be noticing that there are updates. Furthermore basically every mirror sync on unstable followed by pacman -Syyuu or similar pamac update with enabled downgrade, wants to downgrade just updated packages . Is somebody else experiencing this or is aware that there is a problem?
For example, just updated package was:
[2021-09-17T09:50:03+0200] [ALPM] upgraded pacman (6.0.1-1 -> 6.0.1-2)
now running pamac update -a - it wants to downgrade again…
Warning: pacman: downgrading from version 6.0.1-2 to version 6.0.1-1
It’s like there is either only one up to date mirror and by refreshing the mirrors i always get the outdated one or something i didn’t think of yet. However that does not explain why gnome-software is now unable to see packagekit updates.
alven
17 September 2021 13:11
3
@pux , I have no such issue.
Does the
sudo pacman-mirrors -B unstable -c Germany -P https -a
sudo pacman -Syyu
sudo pamac update --force-refresh
operations are not solving the issue of to get rid of pacman downgrade suggestion?
pux
17 September 2021 13:54
4
Well it is a recurring issue since a few weeks or so, but maybe your suggestion to use https mirrors will solve it, I give it a try thanks!
I do normally use sudo pacman-mirrors -g -f 3 , which always worked fine since years until recently it seems.
It’s not possible to update timeshift as usual.:
Error: The operation could not be performed (Conflicting files)
timeshift: /usr/lib/system/system/grub-btrfs.path exists in the file system (belongs to grub-btrfs)
Errors occurred, no packages were updated.
@Yochanan
What do you mean, “as usual?”
I reverted the change and replaced 20.11.1+28+gefed117-2. with 20.11.1+28+gefed117-1 again.
pux
20 September 2021 07:37
7
It seems that i found the issue with my mirror list, which is like i thought.
Output of:
sudo pacman-mirrors --country Germany --api --set-branch unstable
0.084 Germany : https://manjaro.re/
only one mirror was found and, this one is not up to date even if the the status says otherwise.
So, because i updated my packages seconds before on a up to date mirror, by changing to manjaro.re
it want to downgrade my packages.
Output of:
sudo pacman-mirrors --geoip
0.131 Germany : https://manjaro.re/
Output of:
0.079 Germany : https://manjaro.re/
@philm this mirror is somehow out of date even if it says otherwise.
Using 0.594 Global : https://mirrors.manjaro.org/repo/ seems to work fine.
Looking at Index of /unstable/
state 19-Sep-2021 21:51 276
which is one day behind.
yes ! very strange mirror
unstable is ok for manjaro and pacman, 16 update in community today
curl https://manjaro.re/unstable/state
date=2021-09-20T08:25:33Z
curl -s "https://manjaro.re/unstable/community/x86_64/" | grep -i "20-Sep-2021" | wc -l
16
but
curl -I https://manjaro.re/unstable/community/x86_64/community.db
HTTP/2 200
date: Mon, 20 Sep 2021 08:51:35 GMT
last-modified: Wed, 08 Sep 2021 23:10:24 GMT
cf-cache-status: HIT
server: cloudflare
new file since 20 Sep… but this file is same since 08 Sep
since 08 Sep this mirror send “old” database
it’s the only mirror with such an outdated “last-modified”
same for stable:
::https://manjaro.re/stable/community/x86_64/community.db
HTTP/2 200
date: Mon, 20 Sep 2021 09:24:23 GMT
last-modified: Tue, 07 Sep 2021 17:12:35 GMT
alven
20 September 2021 15:52
9
while installing linux515 (rc1):
==> WARNING: Possibly missing firmware for module: xhci_pci
details
uname -r
5.15.0-1-MANJARO
mhwd-kernel -li
Currently running: 5.15.0-1-MANJARO (linux515)
* linux515
pacman -Qi linux515 | grep -i version
Version : 5.15.rc1.210918.g6880fa6-1
sudo modinfo xhci_pci
filename: /lib/modules/5.15.0-1-MANJARO/kernel/drivers/usb/host/xhci-pci.ko.xz
license: GPL
description: xHCI PCI Host Controller Driver
firmware: renesas_usb_fw.mem
srcversion: B87B28FE5BF4DCA4779ED68
alias: pci:v*d*sv*sd*bc0Csc03i30*
alias: pci:v00001912d00000015sv*sd*bc*sc*i*
alias: pci:v00001912d00000014sv*sd*bc*sc*i*
depends: xhci-pci-renesas
retpoline: Y
intree: Y
vermagic: 5.15.0-1-MANJARO SMP preempt mod_unload
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 26:3F:36:FC:DC:F8:ED:04:1B:1C:0E:B2:CF:CF:19:EB:D4:BB:F5:A0
sig_hashalgo: sha512
signature: 27:E8:2F:24:E1:38:66:39:5A:13:23:89:D5:F2:92:C1:DD:3E:24:95:
63:0D:1F:0F:5A:D5:C5:ED:F4:FC:5F:D5:5E:CC:2A:40:8C:B8:E0:81:
BB:56:0B:8A:9B:83:00:11:A8:3E:30:62:0E:79:53:D1:43:3E:DD:35:
60:7D:8D:2A:ED:5A:FC:DA:C6:A9:4B:AB:D3:84:9D:60:E3:B6:CF:EB:
FE:30:EA:78:E2:75:C2:A6:F5:F3:74:29:A7:A6:EB:29:33:1A:13:49:
33:97:15:7B:21:2C:1F:AD:75:35:54:68:99:FA:0D:6D:16:AD:D2:F6:
2C:44:7E:01:F9:B3:21:8B:E0:03:B3:DB:62:9B:82:1E:6C:FC:DE:66:
81:AA:01:FE:9E:A4:04:F4:D2:1F:0D:66:6F:AA:E8:A4:62:73:5A:83:
B6:93:34:E0:45:34:2C:70:A7:F4:0E:B4:D4:0F:9A:3C:4C:F0:FA:48:
22:24:D1:32:83:E5:4C:6E:D4:35:ED:20:08:60:7B:41:23:37:A2:C3:
1E:DE:8A:11:0B:72:91:20:5A:EA:19:E5:1B:2C:3E:2E:2F:8D:D5:20:
90:34:9C:BF:F3:3A:3D:58:7D:72:18:22:92:2D:6E:19:26:DB:E5:B7:
4C:4A:89:48:D9:79:F7:A2:98:A3:BE:67:B7:81:A6:92:3A:FA:EC:A1:
3C:93:92:24:D7:C7:EA:20:33:57:CE:45:B5:01:70:75:2F:62:AA:5B:
31:0F:6F:86:E1:9A:1F:CE:36:72:E5:DA:26:43:D6:C0:C4:DF:95:F9:
16:B9:98:F9:7E:AA:17:6D:C1:67:24:F9:AA:AE:34:30:22:67:6A:39:
BD:4A:31:CC:CA:5E:1A:3E:ED:E1:B4:8F:DF:6C:49:0B:E6:3B:AE:BE:
21:6D:C6:55:0F:5D:79:D4:2A:7E:EC:E3:9F:40:F6:05:46:87:48:5E:
79:80:69:3E:DE:24:6A:FD:15:64:29:39:3F:B0:F0:91:38:99:37:8F:
EC:11:97:40:0D:3D:02:50:0E:17:D0:41:1A:D9:2B:CA:D2:CC:55:E5:
DA:EA:DC:32:B0:03:37:B2:4C:AD:62:53:25:2E:C7:01:81:4A:76:7E:
0D:00:26:C2:84:80:AB:56:6A:33:34:43:28:69:D0:F2:69:70:E8:3A:
C3:6F:70:4A:FD:A0:51:E4:27:5A:AA:63:87:8D:E5:EF:8E:E4:78:9A:
71:DB:FC:AF:86:76:E5:41:B5:46:60:C0:D1:BC:D2:2A:82:BD:77:41:
91:D2:77:F7:0F:0F:6A:24:C1:05:43:8D:30:ED:E2:D5:5D:C2:DB:52:
12:49:D9:AE:2E:97:90:D0:3F:B0:F6:9F
Prev. family (at least linux514) was fixed earlier: Xhci_pci Warning while building initramfs
ADDED:
The same warning for the rc2:
Package (1) Old Version New Version Net Change Download Size
core/linux515 5.15.rc1.210918.g6880fa6-1 5.15.rc2.210920.ge4e737b-1 -0.01 MiB 97.35 MiB
The patch needs to be updated for 5.15 but hey it’s just a warning
alven
20 September 2021 17:52
11
May be it is warning only cause “possibly missing” and if it could be determined as “missing” for sure, than it probably would be from an error category.
Also generally warnings are usually prevents further errors. Warnings need to be fixed to prevent future errors. That’s the general purpose of warnings and should not just ignore all warnings.
Yochanan
Split this topic
20 September 2021 19:05
12
Yes, but I think something was changed on the 5.15 kernel so it doesn’t apply to that?
committed 07:12AM - 02 Jul 21 UTC
Commit a66d21d7dba8 ("usb: xhci: Add support for Renesas controller with
memory"… ) added renesas_usb_fw.mem firmware reference to xhci-pci. Thus
modinfo indicates xhci-pci.ko has "firmware: renesas_usb_fw.mem". But
the firmware is only actually used with CONFIG_USB_XHCI_PCI_RENESAS. An
unusable firmware reference can trigger safety checkers which look for
drivers with unmet firmware dependencies.
Avoid referring to renesas_usb_fw.mem in circumstances when it cannot be
loaded (when CONFIG_USB_XHCI_PCI_RENESAS isn't set).
Fixes: a66d21d7dba8 ("usb: xhci: Add support for Renesas controller with memory")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Greg Thelen <gthelen@google.com>
Link: https://lore.kernel.org/r/20210702071224.3673568-1-gthelen@google.com
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
but nothing about the upstream patch itself
philm
20 September 2021 20:46
15
