philm
27 March 2021 11:56
1
Hello community,
Another unstable branch update with some usual updates for you.
Gnome 40 got released! Get our latest Developer ISO to test it out!
We updated Gnome to 40
Most of our Kernels got updated
We updated pipewire , Wine and AMDVLK
Other regular upstream updates including python and haskell
Get our latest daily developer images now from Github: Plasma , Gnome , XFCE . You get the latest stable releases of Manjaro from SourceForge.
Our current supported kernels
linux44 4.4.263
linux49 4.9.263
linux414 4.14.227
linux419 4.19.183
linux54 5.4.108
linux59 5.9.16 [EOL]
linux510 5.10.26
linux511 5.11.10
linux512 5.12-rc4
linux54-rt 5.4.106_rt54
linux59-rt 5.9.1_rt19
Packages Changes (Sat Mar 27 12:38:12 CET 2021)
A detailed list of all package changes may be found here .
No issue, everything went smoothly
Yes there was an issue. I was able to resolve it myself.(Please post your solution)
Yes i am currently experiencing an issue due to the update. (Please post about it)
The new version of pamac-gtk is okay, clearer than ever. (10.1.0beta-1)
I’ve got one minor issue on Gnome 40 where the dropdown-menu for setting the default web-application (and E-mail - but doesn’t matter) is greyed out. Is there any way to set the default apps manually via cli?
Old design of pamac-gtk was better.
It’s better with "gtk3-nocsd"
My first reaction to the updated pamac is quite favorable. i like the new interface and it even seems to run faster.
I’m running Plasma desktop.
Hello, I wanted to check on gnome and switched to unstable from testing but after doing the upgrade I got stuck when GDM was supposed to be loaded:
Mär 28 07:16:21 hk-01 dbus-daemon[854]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.25' (uid=974 pid=114>
Mär 28 07:16:21 hk-01 dbus-daemon[854]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Mär 28 07:16:21 hk-01 gnome-session[1138]: gnome-session-binary[1138]: WARNING: Failed to upload environment to systemd: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.fre>
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: WARNING: Failed to upload environment to systemd: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" do>
Mär 28 07:16:21 hk-01 gnome-session[1138]: gnome-session-binary[1138]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freed>
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does>
Mär 28 07:16:21 hk-01 gnome-session[1138]: gnome-session-binary[1138]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoO>
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freed>
Mär 28 07:16:21 hk-01 /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activating service name='org.gnome.ScreenSaver' requested by ':1.2' (uid=120 pid=1138>
Mär 28 07:16:21 hk-01 /usr/lib/gdm-wayland-session[1161]: /usr/bin/gjs: symbol lookup error: /usr/lib/libgjs.so.0: undefined symbol: sysprof_clock
Mär 28 07:16:21 hk-01 /usr/lib/gdm-wayland-session[1134]: dbus-daemon[1134]: [session uid=120 pid=1134] Activated service 'org.gnome.ScreenSaver' failed: Process org.gnome.ScreenSaver exite>
Mär 28 07:16:21 hk-01 NetworkManager[858]: <info> [1616908581.3333] device (wlp0s20f3): set-hw-addr: set MAC address to B2:E8:0F:51:AB:D3 (scanning)
Mär 28 07:16:21 hk-01 gnome-session[1138]: gnome-session-binary[1138]: CRITICAL: Unable to create a DBus proxy for GnomeScreensaver: Fehler beim Aufruf von StartServiceByName für org.gnome.>
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: CRITICAL: Unable to create a DBus proxy for GnomeScreensaver: Fehler beim Aufruf von StartServiceByName für org.gnome.ScreenSaver: Process >
Mär 28 07:16:21 hk-01 gnome-session[1138]: gnome-session-binary[1138]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
Mär 28 07:16:21 hk-01 org.gnome.Shell.desktop[1162]: /usr/bin/gnome-shell: symbol lookup error: /usr/lib/libgjs.so.0: undefined symbol: sysprof_clock
Mär 28 07:16:21 hk-01 gnome-session[1138]: gnome-session-binary[1138]: WARNING: App 'org.gnome.Shell.desktop' exited with code 127
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: WARNING: App 'org.gnome.Shell.desktop' exited with code 127
Mär 28 07:16:21 hk-01 gnome-session-binary[1138]: Unrecoverable failure in required component org.gnome.Shell.desktop
Mär 28 07:16:21 hk-01 audit[960]: USER_END pid=960 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pa>
Mär 28 07:16:21 hk-01 audit[960]: CRED_DISP pid=960 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=hk-01>
Mär 28 07:16:21 hk-01 gdm[930]: Gdm: GdmDisplay: Session never registered, failing
Mär 28 07:16:21 hk-01 systemd[1]: session-1.scope: Succeeded.
Mär 28 07:16:21 hk-01 systemd-logind[880]: Session 1 logged out. Waiting for processes to exit.
Mär 28 07:16:21 hk-01 systemd-logind[880]: Removed session 1.
Mär 28 07:16:21 hk-01 gdm[930]: Gdm: Child process -1117 was already dead.
I downgraded to “testing” again - not sure what the system wants to tell me except it could not run gnome but maybe its helping you folks.
Just a heads-up, there’s a current archlinux/less bug report on less v580 (beta). Here’s the original forum discussion .
Searching for less and systemd at manjaro.org/branch-compare shows v580 and v247.4 in Unstable . If less “568 or newer” isn’t required by systemd until 248, couldn’t Manjaro stay at less 563 at this time.
philm
28 March 2021 09:07
9
I’ll keep a note on this one. Let’s see if we update to systemd 248 series anytime soon.
Falav
28 March 2021 09:58
10
I quite like also the new Pamac interface.
I just find it more difficult to distinguish installed from non-installed packages in the list at first sight.
Yes there are specific icons, but a different background color could help.
Rinaldus:
Old design of …
Are You Too old? (<-> Avatar)…
Not really, but Extension: BaBar helps while waiting for DtD and DtT.
I do not see any difference - have I to clean my glasses?
On Gnome 40. Makes things ugly. But that is a matter of taste.
Switched over from Stable to Unstable for the latest version of Gnome. No issues so far!
Atm I’m using “Frippery Panel Favorites” which I found thanks to another user.
You should restart or at least restart the x server
Does it work with GNOME 40?
Yep, it does. Haven’t tried all of Frippery’s features, though.
Thanks very much! My waiting for dash to panel will be more comfortable, than earlier.
https://frippery.org/extensions/
There is a Gnome 40 version. Not yet in “gnome-extensions” but works.
