Unknown devices in hardware detection tool
Hi all
i have a problem with my manjaro installation.
I have a Clevo laptop (model NS50PU) with intel i7 1260P and intel Iris XE graphics. I installed the latest version of Manjaro Gnome from scratch and everything seems to work fine with audio, wifi and also the display. The strange thing tough is that under the hardware detection tool almost every hardware components is listed as unknown device as you can see from the screen shots
It is as if manjaro can’t recognize the hardware. I thought that maybe is due to the kernel and so i installed the newest 5.18.17 kernel but even that didn’t change anything.
Can someone help solve this issue ?
Here is the output of the lspci -v
00:00.0 Host bridge: Intel Corporation Device 4621 (rev 02)
	Subsystem: CLEVO/KAPOK Computer Device 7716
	Flags: bus master, fast devsel, latency 0, IOMMU group 0
	Capabilities: <access denied>
	Kernel driver in use: igen6_edac
	Kernel modules: igen6_edac
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P Integrated Graphics Controller (rev 0c) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 165, IOMMU group 1
	Memory at 601c000000 (64-bit, non-prefetchable) [size=16M]
	Memory at 4000000000 (64-bit, prefetchable) [size=256M]
	I/O ports at 4000 [size=64]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Kernel driver in use: i915
	Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Alder Lake Innovation Platform Framework Processor Participant (rev 02)
	Flags: bus master, fast devsel, latency 0, IRQ 147, IOMMU group 2
	Memory at 601d140000 (64-bit, non-prefetchable) [size=128K]
	Kernel driver in use: proc_thermal_pci
	Kernel modules: processor_thermal_device_pci
00:07.0 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 02) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 3
	Bus: primary=00, secondary=01, subordinate=29, sec-latency=0
	I/O behind bridge: 5000-5fff [size=4K] [16-bit]
	Memory behind bridge: 76000000-821fffff [size=194M] [32-bit]
	Prefetchable memory behind bridge: 6000000000-601bffffff [size=448M] [32-bit]
	Kernel driver in use: pcieport
00:08.0 System peripheral: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator (rev 02)
	Flags: bus master, fast devsel, latency 0, IRQ 255, IOMMU group 4
	Memory at 601d186000 (64-bit, non-prefetchable) [size=4K]
00:0a.0 Signal processing controller: Intel Corporation Platform Monitoring Technology (rev 01)
	Flags: fast devsel, IOMMU group 5
	Memory at 601d170000 (64-bit, non-prefetchable) [size=32K]
	Kernel driver in use: intel_vsec
	Kernel modules: intel_vsec
00:0d.0 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller (rev 02) (prog-if 30 [XHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 127, IOMMU group 6
	Memory at 601d160000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:0d.2 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 (rev 02) (prog-if 40 [USB4 Host Interface])
	Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 6
	Memory at 601d100000 (64-bit, non-prefetchable) [size=256K]
	Memory at 601d185000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: thunderbolt
	Kernel modules: thunderbolt
00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01) (prog-if 30 [XHCI])
	Flags: medium devsel, IRQ 128, IOMMU group 7
	Memory at 82600000 (64-bit, non-prefetchable) [size=64K]
00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
	Flags: bus master, fast devsel, latency 0, IOMMU group 7
	Memory at 601d17c000 (64-bit, non-prefetchable) [size=16K]
	Memory at 601d184000 (64-bit, non-prefetchable) [size=4K]
00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 8
	Memory at 4017000000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: intel-lpss
	Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 (rev 01)
	Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 8
	Memory at 4017001000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
	Flags: bus master, fast devsel, latency 0, IRQ 129, IOMMU group 9
	Memory at 601d181000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:1c.0 PCI bridge: Intel Corporation Device 51bc (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 10
	Bus: primary=00, secondary=2a, subordinate=2a, sec-latency=0
	I/O behind bridge: [disabled] [16-bit]
	Memory behind bridge: 82500000-825fffff [size=1M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
00:1c.5 PCI bridge: Intel Corporation Device 51bd (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 11
	Bus: primary=00, secondary=2b, subordinate=2b, sec-latency=0
	Memory behind bridge: 82400000-824fffff [size=1M] [32-bit]
00:1c.7 PCI bridge: Intel Corporation Alder Lake PCH-P PCI Express Root Port #9 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 12
	Bus: primary=00, secondary=2c, subordinate=2c, sec-latency=0
	I/O behind bridge: 3000-3fff [size=4K] [16-bit]
	Memory behind bridge: 82300000-823fffff [size=1M] [32-bit]
00:1d.0 PCI bridge: Intel Corporation Device 51b0 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 126, IOMMU group 13
	Bus: primary=00, secondary=2d, subordinate=2d, sec-latency=0
	Memory behind bridge: 82200000-822fffff [size=1M] [32-bit]
00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
	Flags: bus master, fast devsel, latency 0, IOMMU group 14
00:1f.3 Audio device: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01) (prog-if 80)
	Flags: bus master, fast devsel, latency 32, IRQ 183, IOMMU group 14
	Memory at 601d178000 (64-bit, non-prefetchable) [size=16K]
	Memory at 601d000000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
	Flags: medium devsel, IRQ 16, IOMMU group 14
	Memory at 601d180000 (64-bit, non-prefetchable) [size=256]
	I/O ports at efa0 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
	Flags: fast devsel, IOMMU group 14
	Memory at 74800000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: intel-spi
	Kernel modules: spi_intel_pci
2a:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
	Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
	Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 15
	Memory at 82500000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
2b:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01) (prog-if 01)
	Flags: bus master, fast devsel, latency 0, IRQ 146, IOMMU group 16
	Memory at 82401000 (32-bit, non-prefetchable) [size=4K]
	Memory at 82400000 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: sdhci-pci
	Kernel modules: sdhci_pci
2c:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Flags: bus master, fast devsel, latency 0, IRQ 182, IOMMU group 17
	I/O ports at 3000 [size=256]
	Memory at 82304000 (64-bit, non-prefetchable) [size=4K]
	Memory at 82300000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: r8168
	Kernel modules: r8169, r8168
2d:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd Device a801
	Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0, IOMMU group 18
	Memory at 82200000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
	Kernel modules: nvme
Let me know if you need the outputn of some other command
Thanks
My Intel display controller also appears as “unknown”, however the correct kernel drivers are indeed installed. I wouldn’t worry about it.
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: CLEVO/KAPOK
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: DP-1 off: eDP-1 empty: DP-2,DP-3,DP-4 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
Please post your system info as outlined here:
Hi
thanks for the reply.
I was surprised that the display controller is not listed as Intel Iris because i saw several posts in the forum where the output of lspci contains the Iris gpu but not mine. Anyway if you say is normal then that’s ok.
Here are the information about my system:
Global information
  Kernel: 5.18.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.18-x86_64
    root=UUID=bddfc1d6-68aa-4696-8b6a-e452b99ab03d rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor
    resume=UUID=c79e25ee-876c-4894-874b-f6187828f700 udev.log_priority=3
  Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: PCSpecialist product: Lafite Pro II 15 v: N/A
    serial: <superuser required> Chassis: No Enclosure type: 10
  Mobo: Notebook model: NS5x_NS7xPU serial: <superuser required>
    UEFI: INSYDE v: 1.07.07TPCS date: 06/08/2022
  ID-1: BAT0 charge: 11.6 Wh (16.0%) condition: 72.7/73.9 Wh (98.4%)
    volts: 7.5 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
    status: charging
  RAM: total: 31.06 GiB used: 3.8 GiB (12.2%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
    arch: Alder Lake built: 2021 process: Intel 7 (10nm ESF) family: 6
    model-id: 0x9A (154) stepping: 3 microcode: 0x421
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
    L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 1401 high: 4704 min/max: 400/4700:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 796 2: 3217 3: 4700
    4: 4704 5: 502 6: 1003 7: 465 8: 1000 9: 449 10: 949 11: 434 12: 954
    13: 498 14: 985 15: 932 16: 841 bogomips: 79888
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
    vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
    xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
  Device-2: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 3-7:2
    chip-ID: 04f2:b6f9 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x07d8 built: 2018 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.6
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.18.17-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 2a:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IF: wlp42s0 state: up mac: <filter>
    vendor: CLEVO/KAPOK driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 2c:00.0
  IF: enp44s0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 3-10:3 chip-ID: 8087:0032 class-ID: e001
  Local Storage: total: 465.76 GiB used: 9.63 GiB (2.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 431.3 GiB size: 431.3 GiB (100.00%) used: 9.62 GiB (2.2%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: bddfc1d6-68aa-4696-8b6a-e452b99ab03d
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB
    (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: E849-A89E
  ID-3: /home raw-size: 431.3 GiB size: 431.3 GiB (100.00%) used: 9.62 GiB
    (2.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  ID-4: /var/cache raw-size: 431.3 GiB size: 431.3 GiB (100.00%) used: 9.62
    GiB (2.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  ID-5: /var/log raw-size: 431.3 GiB size: 431.3 GiB (100.00%) used: 9.62
  ID-1: swap-1 type: partition size: 34.17 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: c79e25ee-876c-4894-874b-f6187828f700
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 20 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Chicony USB2.0 Camera type: Video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6f9
  Device-2: 3-10:3 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 448 Uptime: 7h 41m wakeups: 11526 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
  Packages: pacman: 1198 lib: 306 flatpak: 0 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.20
Drivers
Installed:
Installed PCI configs:
           video-linux            2018.05.04                true            PCI
         network-r8168            2016.04.20                true            PCI
Available:
0000:2c:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
> 0000:00:02.0 (0300:8086:46a6) Display controller Intel Corporation:
Kernels
Currently running: 5.18.17-1-MANJARO (linux518)
   * linux515
   * linux518
That’s the open source Intel driver included in the kernel which was automatically loaded, so you’re fine. You can see our outputs are just about identical. You’ll also see we have the same vendor. :wink:
That’s great !! :smiley:
Do you also see the other hardware components (bridge, serial bus controller, etc…) as “unknown” ?
Yes, but the chipset drivers are included in the kernel.
ok thanks a lot for the help and clarification.
