I am running Manjaro on an AMD CPU with integrated GPU. The problem I encountered is that I cannot change the brightness of my screen by dragging the brightness bar in gnome.
However, value of /sys/class/backlight/acpi_video0/brightness changed from 1 to 49 when I tried to adjust the brightness from the smallest to the biggest.
Things I tried
- install
acpilight - add
amdgpu.enable_dpcd_backlight=0to grub config as This post mentioned.
Some information
inxi -Fxxz:
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.1 tk: GTK 3.24.23
wm: gnome-shell dm: GDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.00 date: 06/04/2020
CPU: Info: 6-Core model: AMD Ryzen 5 PRO 4400G with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88826
Speed: 1768 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 3498 2: 1766 3: 1570 4: 2694 5: 1678
6: 1840 7: 1527 8: 3560 9: 3949 10: 1848 11: 1653 12: 1597
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel bus ID: 30:00.0 chip ID: 1002:1636
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.2.3 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 30:00.1
chip ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 30:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel bus ID: 29:00.0
chip ID: 8086:24fb
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus ID: 2a:00.0 chip ID: 10ec:8168
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.38 TiB used: 101.57 GiB (7.2%)
ID-1: /dev/nvme0n1 vendor: Colorful model: CN600 512GB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 78.24 GiB used: 25.77 GiB (32.9%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home size: 97.93 GiB used: 50.78 GiB (51.9%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 7.63 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p9
Sensors: System Temperatures: cpu: 32.5 C mobo: N/A gpu: amdgpu temp: 25.0 C
Info: Processes: 337 Uptime: 12m Memory: 14.64 GiB used: 2.11 GiB (14.4%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1438 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.08
ls /sys/class/backlight:
➜ ~ ls /sys/class/backlight
acpi_video0
➜ ~ ls /sys/class/backlight/acpi_video0
actual_brightness bl_power brightness device max_brightness power scale subsystem type uevent
Any idea how to fix this?
