Hi
I have a laptop with Nvidia/AMD GPU (below more details/logs)
If I set discrete mode (only NVIDIA) the brightness works (* adding nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1
to the kernel cmdline)
If I set Hybrid mode (AMD default and NVIDIA on demand), I can’t adjust brightness no matter what I’ve tried
Things didn’t worked for me (kernel cmdline):
amdgpu.backlight=0
acpi_backlight=video
acpi_backlight=vendor
acpi_backlight=native
acpi_backlight=none
Right now I’m running in discrete mode to have brightness control, but I would like to run in hybrid mode
Do you know what I’ve missed to try? or there’s a bug in the current driver with this board?
I’ve checked this post (haven’t tried it yet), but is just a workaround and last resort. It shouldn’t be that way.
Thanks in advance
Details/Logs
(all of them were made in hybrid mode, unless defined otherwise)
/etc/X11/mhwd.d
$ ls /etc/X11/mhwd.d
nvidia.conf nvidia.conf.nvidia-xconfig-original
both are empty
## Generated by mhwd - Manjaro Hardware Detection
sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.07.28 false PCI
inxi --admin --verbosity=7 --filter --width
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=2b15ea37-9ae0-4da7-a5a0-09668b8f67d6 rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 82B1 v: Lenovo Legion 5 15ARH05H
serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15ARH05H
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R33126 WIN serial: <filter>
UEFI: LENOVO v: FSCN14WW date: 08/26/2020
ID-1: BAT0 charge: 48.3 Wh (59.0%) condition: 81.8/80.0 Wh (102.2%)
volts: 15.3 min: 15.4 model: SMP L19M4PC1 type: Li-poly serial: <filter>
status: Unknown cycles: 10
RAM: total: 15.01 GiB used: 1.65 GiB (11.0%)
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 cache: L2: 4 MiB bogomips: 92660
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1396 7: 1396 8: 1397 9: 1397
10: 1397 11: 1397 12: 1397 13: 1401 14: 1400 15: 1397 16: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-3:3
chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati,intel,modesetting,nouveau,nvidia,radeon display-ID: :0
screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 167.03 GiB (35.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
lanes: 4 type: SSD serial: <filter> rev: BL2QFXV7 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 27.94 GiB size: 27.33 GiB (97.83%) used: 16.6 GiB (60.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 2b15ea37-9ae0-4da7-a5a0-09668b8f67d6
used: 103.2 MiB (20.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 67F5-ADB7
ID-3: /home raw-size: 310.63 GiB size: 304.75 GiB (98.11%)
used: 150.33 GiB (49.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 9f4d64e7-b524-4294-be65-0674b55dc1b3
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 137.85 GiB fs: ntfs label: N/A
uuid: AA202AB2202A8603
Hub-1: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-2: 3-3:3 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6c2
Device-3: 3-4:4 info: Integrated Express ITE Device(8295) type: Keyboard,HID
power: 100mA chip-ID: 048d:c955 class-ID: 0300
Hub-2: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 5-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
Device-1: 5-1.1:4 info: Trust Yvi Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 145f:0238 class-ID: 0301
Device-2: 5-3:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 5-4:5 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c100 class-ID: 0301
Hub-5: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 6-1:2 info: Genesys Logic USB3.2 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 44.6 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 345 Uptime: 5m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1148 pacman: 1126 lib: 308 flatpak: 22
Shell: Bash v: 5.1.8 running-in: terminator inxi: 3.3.08
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
Subsystem: Lenovo Device 3804
Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
Subsystem: Lenovo Device 3803
Flags: bus master, fast devsel, latency 0, IRQ -2147483648
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: d0000000-d10fffff [size=17M]
Prefetchable memory behind bridge: 000001ffa0000000-000001ffb20fffff [size=289M]
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 2
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: d1800000-d18fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 3
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 4
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: d1700000-d17fffff [size=1M]
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 5
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: d1600000-d16fffff [size=1M]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 6
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 6
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: d1200000-d15fffff [size=4M]
Prefetchable memory behind bridge: 000001ffc0000000-000001ffd01fffff [size=258M]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 6
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: d1100000-d11fffff [size=1M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Subsystem: Lenovo Device 3831
Flags: 66MHz, medium devsel, IOMMU group 7
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Lenovo Device 3830
Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 7
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
Flags: fast devsel, IOMMU group 8
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU106M [GeForce RTX 2060 Mobile] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 3a47
Flags: bus master, fast devsel, latency 0, IRQ 94, IOMMU group 9
Memory at d0000000 (32-bit, non-prefetchable) [size=16M]
Memory at 1ffa0000000 (64-bit, prefetchable) [size=256M]
Memory at 1ffb0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 3000 [size=128]
Expansion ROM at d1080000 [virtual] [disabled] [size=512K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
Subsystem: NVIDIA Corporation TU106 High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 91, IOMMU group 9
Memory at d1000000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a809 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device a801
Flags: bus master, fast devsel, latency 0, IRQ 34, NUMA node 0, IOMMU group 10
Memory at d1800000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
DeviceName: Realtek RTL8111E Ethernet LOM
Subsystem: Lenovo Device 38fa
Flags: bus master, fast devsel, latency 0, IRQ 71, IOMMU group 11
I/O ports at 2000 [size=256]
Memory at d1704000 (64-bit, non-prefetchable) [size=4K]
Memory at d1700000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Flags: bus master, fast devsel, latency 0, IRQ 50, IOMMU group 12
Memory at d1600000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 61, IOMMU group 6
Memory at 1ffc0000000 (64-bit, prefetchable) [size=256M]
Memory at 1ffd0000000 (64-bit, prefetchable) [size=2M]
I/O ports at 1000 [size=256]
Memory at d1500000 (32-bit, non-prefetchable) [size=512K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Subsystem: Lenovo Device 381c
Flags: bus master, fast devsel, latency 0, IRQ 71, IOMMU group 6
Memory at d1400000 (32-bit, non-prefetchable) [size=1M]
Memory at d15c8000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI])
Subsystem: Lenovo Device 3811
Flags: bus master, fast devsel, latency 0, IRQ 52, IOMMU group 6
Memory at d1300000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI])
Memory at d1200000 (64-bit, non-prefetchable) [size=1M]
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
Subsystem: Lenovo Device 3823
Flags: fast devsel, IRQ 93, IOMMU group 6
Memory at d1580000 (32-bit, non-prefetchable) [size=256K]
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
Subsystem: Lenovo Device 3824
Flags: bus master, fast devsel, latency 0, IRQ 92, IOMMU group 6
Memory at d15c0000 (32-bit, non-prefetchable) [size=32K]
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
Subsystem: Lenovo Device 382d
Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 6
Memory at d1101000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 6
Memory at d1100000 (32-bit, non-prefetchable) [size=2K]
ls /sys/class/backlight
in discrete mode
nvidia_0
in hybrid mode
amdgpu_bl1 nvidia_0
glxinfo (hybrid mode)
$ glxinfo | grep 'OpenGL renderer'
OpenGL renderer string: AMD RENOIR (DRM 3.42.0, 5.14.10-1-MANJARO, LLVM 12.0.1)
$ prime-run glxinfo | grep 'OpenGL renderer'
OpenGL renderer string: NVIDIA GeForce RTX 2060/PCIe/SSE2
