Hello,
I recently bought a tp-link UB500 dongle. It does not work on my pc. I travel the web to find the solution but I don’t find it. I have however found sometimes about a compiling of a modules from the kernel but I did not succeed to do it.
Thank’s for everyone who try to help me ![]()
Here is the system informations:
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=a8cf814c-98fa-4659-99da-6571a4783adf rw quiet splash apparmor=1
security=apparmor resume=UUID=cf5926ac-a580-45b6-b87b-c88a03b7ca5a
udev.log_priority=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: Latitude E6410 v: 0001
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0667CC v: A00 serial: <superuser required> BIOS: Dell
v: A04 date: 07/08/2010
ID-1: BAT0 charge: N/A condition: N/A volts: 5.1 min: 11.1
model: SMP DELL TX28306 type: Li-ion serial: <filter> status: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M560
status: discharging
RAM: total: 3.69 GiB used: 2.43 GiB (65.7%)
RAM Report:
Info: model: Intel Core i5 M 520 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 2 microcode: 0x11
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1475 high: 1621 min/max: 1199/2400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1415 2: 1621
3: 1520 4: 1344 bogomips: 19157
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority
flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr
mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni popcnt
pse pse36 pti rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics
vendor: Dell Latitude E6410 driver: i915 v: kernel ports: active: VGA-1
off: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: VGA-1 pos: primary model: Samsung S24F350 serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 note: disabled model: LG Display 0x0257 built: 2009
res: 1920x1080 dpi: 120 gamma: 1.2 size: 304x190mm (11.97x7.48")
diag: 358mm (14.1") ratio: 16:10 modes: 1440x900
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Dell Latitude E6410 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6410
driver: e1000e v: kernel port: 7040 bus-ID: 00:19.0 chip-ID: 8086:10ea
class-ID: 0200
Device-2: Broadcom BCM43224 802.11a/b/g/n
vendor: Dell Wireless 1520 Half-size Mini PCIe Card driver: wl v: kernel
modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 14e4:4353 class-ID: 0280
Device-3: Dell F3607gw v2 Mobile Broadband Module type: USB
driver: cdc_acm,cdc_ether,cdc_wdm bus-ID: 2-1.6:6 chip-ID: 413c:8184
class-ID: 0202 serial: <filter>
IF: wwp0s29u1u6i6 state: down mac: <filter>
Device-1: TP-Link UB500 Adapter type: USB driver: N/A bus-ID: 2-1.1:10
chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 111.79 GiB used: 61.79 GiB (55.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 0005 scheme: MBR
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A3S rev: KD02
dev-links: cdrom
Features: speed: 8 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 103.65 GiB size: 101.46 GiB (97.89%)
used: 61.57 GiB (60.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: a8cf814c-98fa-4659-99da-6571a4783adf
ID-1: swap-1 type: partition size: 8.14 GiB used: 220.1 MiB (2.6%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: cf5926ac-a580-45b6-b87b-c88a03b7ca5a
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:10 info: TP-Link UB500 Adapter type: Bluetooth driver: N/A
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 2357:0604
Device-2: 2-1.2:4 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-5: 2-1.3:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-6: 2-1.3.2:8 info: Apple Hub in Aluminum Keyboard ports: 3 rev: 2.0
speed: 480 Mb/s power: 300mA chip-ID: 05ac:1006 class-ID: 0900
Device-1: 2-1.3.2.2:9 info: Apple Aluminum Keyboard (ISO)
type: Keyboard,HID driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s power: 20mA chip-ID: 05ac:0221 class-ID: 0300
Device-2: 2-1.6:6 info: Dell F3607gw v2 Mobile Broadband Module
type: Communication,Abstract (modem),CDC-Data,Mobile Direct Line
driver: cdc_acm,cdc_ether,cdc_wdm interfaces: 11 rev: 2.0 speed: 480 Mb/s
power: 20mA chip-ID: 413c:8184 class-ID: 0202 serial: <filter>
Device-3: 2-1.8:7 info: Broadcom BCM5880 Secure Applications Processor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
System Temperatures: cpu: 49.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 319 Uptime: 21h 38m wakeups: 26 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1573
pacman: 1559 lib: 404 flatpak: 5 snap: 9 Shell: Zsh v: 5.8.1
running-in: gnome-terminal inxi: 3.3.15
