Touchpad isn't found
I’m completely new in using Linux. I’ve installed Manjaro Gnome with which I have a problem.
The synaptics touchpad isn’t detected and not working.
My laptop Lenovo Ideapad s145 15IIL 81w8
Please help me it’s so uncomfortable to use mouse. thank you in advance
How to increase your chances of solving your issue:
Please provide Information:
how can I see information about my laptop?
It’s in the two links - specifically in the second one.
in a terminal:
export LANG=C
inxi --admin --verbosity=7 --filter --width
lspci
lsusb
and/or
lsusb -t
and some more, mentioned in the first post of the second link
According to the Touchpad Synaptics article from the ArchWiki you could try to install the Synaptics driver you be might missing via
sudo pacman -S xf86-input-synaptics
   ~  export LANG=C                                                    ✔
    ~  inxi --admin --verbosity=7 --filter --width                      ✔
  Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=a2d0d5b6-7216-4818-aa36-0717d3cfcb60 rw quiet splash apparmor=1
    security=apparmor resume=UUID=e95609de-4776-4162-bd1f-43176f6e2400
    udev.log_priority=3
  Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: LENOVO product: 81W8 v: Lenovo IdeaPad S145-15IIL
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15IIL
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: DKCN53WW date: 05/31/2021
  ID-1: BAT0 charge: 16.7 Wh (65.5%) condition: 25.5/30.0 Wh (85.1%)
    volts: 7.6 min: 7.6 model: LGC L17L2PF1 type: Li-poly serial: <filter>
    status: Discharging cycles: 246
  RAM: total: 11.49 GiB used: 2.39 GiB (20.8%)
  RAM Report:
  Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
    L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 3402 high: 3409 min/max: 400/3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3402 2: 3400 3: 3400
    4: 3409 bogomips: 9524
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-5:2 chip-ID: 04f2:b624 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: no
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 3000
    bus-ID: 01:00.0 chip-ID: 10ec:c82f class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-10:4 chip-ID: 0bda:c02f class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 10.88 GiB (1.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
    type: HDD rpm: 5400 serial: <filter> rev: 1A05 scheme: GPT
  ID-1: / raw-size: 918.58 GiB size: 903.08 GiB (98.31%)
    used: 10.88 GiB (1.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: a2d0d5b6-7216-4818-aa36-0717d3cfcb60
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 1B90-93A6
  ID-1: swap-1 type: partition size: 12.64 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: e95609de-4776-4162-bd1f-43176f6e2400
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Chicony Integrated Camera type: Video
  Device-2: 1-9:3 info: Microsoft Nano Transceiver v1.0 for Bluetooth
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
  Device-3: 1-10:4 info: Realtek Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 41.0 C mobo: N/A
  Processes: 191 Uptime: 1h 10m wakeups: 1 Init: systemd v: 250
  tool: systemctl Compilers: gcc: N/A Packages: 1151 pacman: 1141 lib: 306
  flatpak: 0 snap: 10 Shell: Zsh v: 5.8 running-in: gnome-terminal
  inxi: 3.3.12
    ~  lspci                                                     ✔  3s 
00:00.0 Host bridge: Intel Corporation Device 8a02 (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Iris Plus Graphics G1 (Ice Lake) (rev 07)
00:04.0 Signal processing controller: Intel Corporation Device 8a03 (rev 03)
00:14.0 USB controller: Intel Corporation Ice Lake-LP USB 3.1 xHCI Host Controller (rev 30)
00:14.2 RAM memory: Intel Corporation Ice Lake-LP DRAM Controller (rev 30)
00:15.0 Serial bus controller: Intel Corporation Ice Lake-LP Serial IO I2C Controller #0 (rev 30)
00:15.1 Serial bus controller: Intel Corporation Ice Lake-LP Serial IO I2C Controller #1 (rev 30)
00:16.0 Communication controller: Intel Corporation Ice Lake-LP Management Engine (rev 30)
00:17.0 SATA controller: Intel Corporation Ice Lake-LP SATA Controller [AHCI mode] (rev 30)
00:1d.0 PCI bridge: Intel Corporation Ice Lake-LP PCI Express Root Port #9 (rev 30)
00:1f.0 ISA bridge: Intel Corporation Ice Lake-LP LPC Controller (rev 30)
00:1f.3 Audio device: Intel Corporation Ice Lake-LP Smart Sound Technology Audio Controller (rev 30)
00:1f.4 SMBus: Intel Corporation Ice Lake-LP SMBus Controller (rev 30)
00:1f.5 Serial bus controller: Intel Corporation Ice Lake-LP SPI Controller (rev 30)
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
    ~  lsusb                                                            ✔
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 002: ID 04f2:b624 Chicony Electronics Co., Ltd Integrated Camera
Bus 001 Device 004: ID 0bda:c02f Realtek Semiconductor Corp. Bluetooth Radio
    ~  lsusb -t                                                         ✔
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
    |__ Port 5: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 5: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 9: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 9: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 9: Dev 3, If 2, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 10: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
    |__ Port 10: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
sudo pacman -S xf86-input-synaptics                              ✔
warning: xf86-input-synaptics-1.9.1-3 is up to date -- reinstalling
resolving dependencies...
Packages (1) xf86-input-synaptics-1.9.1-3
Total Installed Size:  0,13 MiB
Net Upgrade Size:      0,00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring                     [######################] 100%
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) checking available disk space                [######################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling xf86-input-synaptics            [######################] 100%
>>> xf86-input-synaptics driver is on maintenance mode and
    xf86-input-libinput driver must be prefered over.
(1/1) Arming ConditionNeedsUpdate...
Can you please format all that as “code” using this button in the editor window
highlight everything, then use that button
It’s pretty unreadable as it is …
Yes, I’ve corrected it.
I cannot identify your touchpad in any of the output.
I do not know how to look for it.
I cannot even find it on my own laptop - even though it clearly is there and functional. :wink:
Each of these shows some evidence that it is there - and where:
sudo dmesg | grep input
sudo dmesg | grep seri
sudo dmesg | grep touch
sudo dmesg | grep Touch
sudo dmesg | grep Syn
I cannot help further. Sorry!
