With The 5.4.0 update to cinnamon the Title Headers & Bordes Icon is missing in the theme in the settings. The org.cinnamon.desktop.wm.preferences still exists in the dconf but now has no effect.
@oberon & @Yochanan
Sounds like a theme issue. I see no icons missing in System Settings.
What options in /org/cinnamon/desktop/wm/preferences/ aren’t working?
No not theme related and it appears your screenshot has no headers or borders?
I see no icons missing in System Settings,. please show me, it’s missing in the theme section
Maybe do the other way around, show the problem yourself so it is clear.
unstable
There should be windows borders above the icons (five not four) see below
The windows borders is controlled from the above which now has no effect
The option is still there on testing branch so it’s definitely an issue introduced on unstable unless its just specific to your case
It’s a feature, not a bug. ![]()
What do you have to do to change a theme, or and which themes work properly with 5.4?
Some progress it is the Controls icon that now controls the headers that and the Desktop and the icons completely control the theme. only the dark ones really show up .
Now all we need is someone to make a Controls theme with colours?
Here we go sorted
