Timed out waiting for device disk, dependency failed, and emergency mode
Hello, I’ve seen some similar topics here about this problem, but mine is a bit more complicated. It’s my fresh install of Manjaro (latest stable) and on boot it throws errors, asks for pressing enter and then do absolutely nothing.
[ TIME ] Timed out waiting for device /dev/disk/by-uuid/DOBA-5038
[DEPEND] Dependency failed File N /dev/disk/by-uuid/DOBA-5038
[DEPEND] Dependency failed for /boot/efi
[DEPEND] Dependency failed for Local File Systems.
You are in emergency mode. After logging in, type "journalctl - xb" to view system logs, "systemctl reboot" to reboot, "systemctl default" or "exit" to boot into default mode.
Cannot open access to the console, root account is blocked. More information on guide page sulogin(8).
Please press enter to continue.
Reloading system manager configuration
Starting default target
And after pressing enter, I see blinking underscore forever.
Since it’s a fresh install, you can try reinstalling right away. Or you can try digging a bit and learn some stuff. :wink:
Okay so I don’t want to reinstall it because installation took about 5 hours. I’m dual booting with windows 10 on another drive. I’ve did manual partition while installing, boot loader set to target drive, MBR, 4 GB for /boot/efi, and all space left to /, no swap because I have 16 GB RAM
that sounds a little strange - but you probably know what you are doing and why
… since you installed alongside Windows - did you disable secure boot and fast startup?
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. Boot the Manjaro USB stick again and provide the output of an inxi --admin --verbosity=7 --filter --no-host --width (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text
  3. Because this:
    sounds wrong and the above provides us with full system information to help you further.
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
I was looking for tutorial for installing update able manjaro on USB stick and I’ve found. I’ve followed this guide…
My PC is Asus B150 Motherboard, GPU is GT 710 Msi Edition, CPU is Intel Pentium G4400
Wanted to install XFCE Edition
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  misobasedir=manjaro misolabel=MANJARO_XFCE_2021 quiet systemd.show_status=1
  apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
  radeon.modeset=1
  Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: B150 PRO GAMING/AURA v: Rev X.0x
  serial: <filter> UEFI [Legacy]: American Megatrends v: 3805 date: 05/16/2018
  RAM: total: 15.58 GiB used: 1.57 GiB (10.1%)
  Info: Dual Core model: Intel Pentium G4400 bits: 64 type: MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
  L2 cache: 3 MiB bogomips: 13205
  Speed: 800 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 800 2: 800
  Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_perfmon art bts
  clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
  dtes64 dtherm dts ept ept_ad erms est flexpriority flush_l1d fpu fsgsbase
  fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap ss ssbd
  sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
  driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:128b
  Display: x11 server: X.Org 1.20.10 driver: nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: VGA-1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
  diag: 686mm (27")
  OpenGL: renderer: NV106 v: 4.3 Mesa 20.3.1 direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0e0f
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
  IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 471.04 GiB used: 103.1 MiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT120BX500SSD1
  size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: R013
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3250318AS
  size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  serial: <filter> rev: HP35
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SP1213C size: 111.82 GiB
  block size: physical: 512 B logical: 512 B speed: 1.5 Gb/s serial: <filter>
  rev: 0-34
  ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Verbatim model: STORE N GO
  size: 14.55 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1100
  ID-1: / raw size: N/A size: 11.69 GiB used: 103.1 MiB (0.9%) fs: overlay
  source: ERR-102 label: N/A uuid: N/A
  ID-1: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs
  label: Zastrze\xc5\xbcone przez system uuid: B064452E6444F89C
  ID-2: /dev/sda2 maj-min: 8:2 size: 110.74 GiB fs: ntfs label: N/A
  uuid: 80C04C89C04C877E
  ID-3: /dev/sda3 maj-min: 8:3 size: 520 MiB fs: ntfs label: N/A
  uuid: 6C963E0C963DD6F4
  ID-4: /dev/sdb1 maj-min: 8:17 size: 232.4 GiB fs: ntfs label: N/A
  uuid: FA0452120451D1ED
  ID-5: /dev/sdc1 maj-min: 8:33 size: 111.81 GiB fs: ntfs label: Danw
  uuid: 7C8CD8ED8CD8A346
  ID-6: /dev/sdd1 maj-min: 8:49 size: 2.73 GiB fs: iso9660
  label: MANJARO_XFCE_2021 uuid: 2021-01-03-08-16-14-00
  ID-7: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: C274-6DF3
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Device-1: 1-1:2 info: Verbatim Flash Drive type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
  chip ID: 18a5:0302 serial: <filter>
  Device-2: 1-7:3 info: Cooler Master Masterkeys Lite L Combo RGB Mouse
  type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s chip ID: 2516:0044
  Device-3: 1-8:4 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
  type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s chip ID: 2516:0042
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003
  Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
  Processes: 187 Uptime: 2m wakeups: 0 Init: systemd v: 247 Compilers:
  gcc: N/A Packages: pacman: 1203 lib: 370 flatpak: 0 Shell: Bash v: 5.1.0
  running in: xfce4-terminal inxi: 3.2.01
output of inxi --admin --verbosity=7 --filter --no-host --width
  1. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    (as that makes both our lives much easier)
  2. No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
  3. Kernel 5.9 is EOL please install both 5.4 and 5.10 LTS (Long Time Support) and see which one troubles you least.
  4. If you plan on playing games, use the proprietary (non-free) drivers
  5. By this point, I agree with @maycne.sonahoz : Re-install is going to be easier.
    Please read this if that makes you :frowning:
    [HowTo] become a Manjaro power user when you're a wizard at Windows but a N00b at Manjaro / Linux
:crossed_fingers:
So, what I need to do? I want a Live USB stick of Manjaro that I can store data and they will stay after reboot. Also,
I’ve downloaded Manjaro ISO yesterday and it embedded 5.9
Close this question and ask a new question: we have a USB expert that’ll butt in. (It might even become a tutorial)
Don’t shoot at the pianist… :sob:
