I am newbie to Linux (2 months). Last month my father gave me his thinkpad t495 with dockstation. I tried to install any distributive with Kde (yea, I love it with all my heart)
Results:
Kubuntu have big with sddm and usb’s
Fedora 32 didn’t autoinstalled Grub and not mounted /home
Installing Ubuntu and then changing from gnome to Kde had less problems, but 3 days after when I entered from sddm I saw dark screen (I was able to use yakuake terminal but I was not able to see mouse pointer.)
Manjaro. I love it because I have it on pc, so I tried to install it firstly, BUT:
a) Micro sd port mount Micro sd card only when boots
b) every time I turn on/turn off/reboot laptop it freezes and on screen there is “failed to start load/save ness of backlight:acpi_video0”
c) USB devices don’t work
d) advantage of manjaro for me is that it worked without troubles with screen
b) i have a thinkpad e495 and had a kernel error about acpi and display as well. there are helpful tips in the arch wiki. you can try the tips listed for the e485, e585, and e595: https://wiki.archlinux.org/index.php/ThinkPad#E_series
setting amd_iommu=pt ivrs_ioapic[32]=00:14.0 as kernel parameter solved this problem for me.
