I don’t know what happened but only the 0th battery are used.
So when the battery “dies” the laptop turns of and when i turn it on the other battery is in full.
I use TLP and powertop (to monitor and set auto tune).
Output of : inxi --full --verbosity=7 --filter --no-host
Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET67W (1.42 )
date: 11/17/2021
ID-1: BAT0 charge: 15.4 Wh (82.8%) condition: 18.6/23.9 Wh (77.6%)
volts: 12.1 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
status: N/A cycles: 70
ID-2: BAT1 charge: 15.7 Wh (81.3%) condition: 19.3/24.0 Wh (80.3%)
volts: 12.8 min: 11.5 model: SMP 01AV452 type: Li-poly serial: <filter>
status: Charging cycles: 164
RAM: total: 7.52 GiB used: 3.17 GiB (42.1%)
RAM Report:
Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP
smt: enabled arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
Speed (MHz): avg: 3487 high: 3600 min/max: 400/3600 cores: 1: 3600
2: 3001 3: 3600 4: 3600 5: 3600 6: 3300 7: 3600 8: 3600 bogomips: 30409
fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-8:4 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa resolution: 1920x1080 s-dpi: 96
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 238.47 GiB used: 55.39 GiB (23.2%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKKF256G8L size: 238.47 GiB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: L14P temp: 29.9 C
scheme: GPT
ID-1: / size: 116.5 GiB used: 55.37 GiB (47.5%) fs: ext4
dev: /dev/nvme0n1p5 label: N/A uuid: cc7be21e-d9d4-4881-841a-b047d2a1253a
ID-2: /boot/efi size: 96 MiB used: 25.3 MiB (26.3%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: 2EAD-1B08
ID-1: swap-1 type: file size: 8 GiB used: 2.2 MiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 size: 118.93 GiB fs: ntfs label: N/A
uuid: 3648B0CC48B08C5D
ID-3: /dev/nvme0n1p4 size: 509 MiB fs: ntfs label: N/A
uuid: 1804C52004C5022C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:4 info: Chicony Integrated Camera (1280x720@30) type: Video
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-2: 1-9:5 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 58.0 C pch: 50.0 C mobo: N/A
Processes: 263 Uptime: 2h 0m wakeups: 26 Init: systemd v: 250 Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1192 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.12
output of: cat /etc/tlp.conf
# /etc/tlp.conf - TLP user configuration (version 1.4)
# See full explanation: https://linrunner.de/tlp/settings
# Settings are read in the following order:
# 1. Intrinsic defaults
# 2. /etc/tlp.d/*.conf - Drop-in customization snippets
# 3. /etc/tlp.conf - User configuration (this file)
# Notes:
# - In case of identical parameters, the last occurence has precedence
# - This also means, parameters enabled here will override anything else
# - However you may append values to a parameter already defined as intrinsic
# default or in a previously read file: use PARAMETER+="add values"
# - IMPORTANT: all parameters here are disabled; remove the leading '#' if you
# like to enable a feature without default or have a value different from the
# default
# - Default *: intrinsic default that is effective when the parameter is missing
# or disabled by a leading '#'; use PARAM="" to disable an intrinsic default
# - Default <none>: do nothing or use kernel/hardware defaults
# tlp - Parameters for power saving
# Set to 0 to disable, 1 to enable TLP.
# Default: 1
#TLP_ENABLE=1
# Control how warnings about invalid settings are issued:
# 0=disabled,
# 1=background tasks (boot, resume, change of power source) report to syslog,
# 2=shell commands report to the terminal (stderr),
# 3=combination of 1 and 2
# Default: 3
#TLP_WARN_LEVEL=3
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
# Default: <none>
TLP_DEFAULT_MODE="BAT"
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Note: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
# Default: 0
#TLP_PERSISTENT_DEFAULT=0
# Power supply classes to ignore when determining operation mode: AC, USB, BAT.
# Separate multiple classes with spaces.
# Note: try on laptops where operation mode AC/BAT is incorrectly detected.
# Default: <none>
#TLP_PS_IGNORE="BAT"
# Seconds laptop mode has to wait after the disk goes idle before doing a sync.
# Non-zero value enables, zero disables laptop mode.
# Default: 0 (AC), 2 (BAT)
#DISK_IDLE_SECS_ON_AC=0
#DISK_IDLE_SECS_ON_BAT=2
# Dirty page values (timeouts in secs).
# Default: 15 (AC), 60 (BAT)
#MAX_LOST_WORK_SECS_ON_AC=15
#MAX_LOST_WORK_SECS_ON_BAT=60
# Select a CPU frequency scaling governor.
# Intel processor with intel_pstate driver:
# performance, powersave(*).
# Intel processor with intel_cpufreq driver (aka intel_pstate passive mode):
# conservative, ondemand, userspace, powersave, performance, schedutil(*).
# Intel and other processor brands with acpi-cpufreq driver:
# conservative, ondemand(*), userspace, powersave, performance, schedutil(*).
# Use tlp-stat -p to show the active driver and available governors.
# Important:
# Governors marked (*) above are power efficient for *almost all* workloads
# and therefore kernel and most distributions have chosen them as defaults.
# You should have done your research about advantages/disadvantages *before*
# changing the governor.
# Default: <none>
CPU_SCALING_GOVERNOR_ON_AC="performance"
CPU_SCALING_GOVERNOR_ON_BAT="powersave"
# Set the min/max frequency available for the scaling governor.
# Possible values depend on your CPU. For available frequencies see
# the output of tlp-stat -p.
# Notes:
# - Min/max frequencies must always be specified for both AC *and* BAT
# - Not recommended for use with the intel_pstate scaling driver, use
# CPU_MIN/MAX_PERF_ON_AC/BAT below instead
# Default: <none>
#CPU_SCALING_MIN_FREQ_ON_AC=0
#CPU_SCALING_MAX_FREQ_ON_AC=0
#CPU_SCALING_MIN_FREQ_ON_BAT=0
#CPU_SCALING_MAX_FREQ_ON_BAT=0
# Set Intel CPU energy/performance policies HWP.EPP and EPB:
# performance, balance_performance, default, balance_power, power.
# Values are given in order of increasing power saving.
# Notes:
# - HWP.EPP: requires kernel 4.10, intel_pstate scaling driver and Intel Core i
# 6th gen. or newer CPU
# - EPB: requires kernel 5.2 or module msr and x86_energy_perf_policy from
# linux-tools, intel_pstate or intel_cpufreq scaling driver and Intel Core i
# 2nd gen. or newer CPU
# - When HWP.EPP is available, EPB is not set
# Default: balance_performance (AC), balance_power (BAT)
CPU_ENERGY_PERF_POLICY_ON_AC="performance"
#CPU_ENERGY_PERF_POLICY_ON_BAT=balance_power
# Set Intel CPU P-state performance: 0..100 (%).
# Limit the max/min P-state to control the power dissipation of the CPU.
# Values are stated as a percentage of the available performance.
# Requires intel_pstate or intel_cpufreq driver and Intel Core i 2nd gen. or
# newer CPU.
# Default: <none>
#CPU_MIN_PERF_ON_AC=0
#CPU_MAX_PERF_ON_AC=100
#CPU_MIN_PERF_ON_BAT=0
#CPU_MAX_PERF_ON_BAT=30
# Set the CPU "turbo boost" (Intel) or "turbo core" (AMD) feature:
# 0=disable, 1=allow.
# Note: a value of 1 does *not* activate boosting, it just allows it.
# Default: <none>
CPU_BOOST_ON_AC="1"
CPU_BOOST_ON_BAT="1"
# Set the Intel CPU HWP dynamic boost feature:
# 0=disable, 1=enable.
# Requires intel_pstate scaling driver in 'active' mode and Intel Core i
# 6th gen. or newer CPU.
# Default: <none>
#CPU_HWP_DYN_BOOST_ON_AC=1
#CPU_HWP_DYN_BOOST_ON_BAT=0
# Minimize number of used CPU cores/hyper-threads under light load conditions:
# Default: 0 (AC), 1 (BAT)
#SCHED_POWERSAVE_ON_AC=0
#SCHED_POWERSAVE_ON_BAT=1
# Kernel NMI Watchdog:
# 0=disable (default, saves power), 1=enable (for kernel debugging only).
# Default: 0
#NMI_WATCHDOG=0
# Select platform profile:
# performance, balanced, low-power.
# Controls system operating characteristics around power/performance levels,
# thermal and fan speed. Values are given in order of increasing power saving.
# Note: check the output of tlp-stat -p to determine availability on your
# hardware and additional profiles such as: balanced-performance, quiet, cool.
# Default: <none>
PLATFORM_PROFILE_ON_AC="performance"
PLATFORM_PROFILE_ON_BAT="balanced"
# Define disk devices on which the following DISK/AHCI_RUNTIME parameters act.
# Separate multiple devices with spaces.
# Devices can be specified by disk ID also (lookup with: tlp diskid).
# Default: "nvme0n1 sda"
#DISK_DEVICES="nvme0n1 sda"
# Disk advanced power management level: 1..254, 255 (max saving, min, off).
# Levels 1..127 may spin down the disk; 255 allowable on most drives.
# Separate values for multiple disks with spaces. Use the special value 'keep'
# to keep the hardware default for the particular disk.
# Default: 254 (AC), 128 (BAT)
#DISK_APM_LEVEL_ON_AC="254 254"
#DISK_APM_LEVEL_ON_BAT="128 128"
# Exclude disk classes from advanced power management (APM):
# sata, ata, usb, ieee1394.
# CAUTION: USB and IEEE1394 disks may fail to mount or data may get corrupted
# with APM enabled. Be careful and make sure you have backups of all affected
# media before removing 'usb' or 'ieee1394' from the denylist!
# Default: "usb ieee1394"
#DISK_APM_CLASS_DENYLIST="usb ieee1394"
# Hard disk spin down timeout:
# 0: spin down disabled
# 1..240: timeouts from 5s to 20min (in units of 5s)
# 241..251: timeouts from 30min to 5.5 hours (in units of 30min)
# See 'man hdparm' for details.
# Default: <none>
#DISK_SPINDOWN_TIMEOUT_ON_AC="0 0"
#DISK_SPINDOWN_TIMEOUT_ON_BAT="0 0"
# Select I/O scheduler for the disk devices.
# Multi queue (blk-mq) schedulers:
# mq-deadline(*), none, kyber, bfq
# Single queue schedulers:
# deadline(*), cfq, bfq, noop
# (*) recommended.
# to keep the kernel default scheduler for the particular disk.
# Notes:
# - Multi queue (blk-mq) may need kernel boot option 'scsi_mod.use_blk_mq=1'
# and 'modprobe mq-deadline-iosched|kyber|bfq' on kernels < 5.0
# - Single queue schedulers are legacy now and were removed together with
# the old block layer in kernel 5.0
# Default: keep
#DISK_IOSCHED="mq-deadline mq-deadline"
# AHCI link power management (ALPM) for SATA disks:
# min_power, med_power_with_dipm(*), medium_power, max_performance.
# (*) Kernel 4.15 (or newer) required, then recommended.
# Multiple values separated with spaces are tried sequentially until success.
# Default:
# - "med_power_with_dipm max_performance" (AC)
# - "med_power_with_dipm min_power" (BAT)
#SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
#SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
# Exclude SATA links from AHCI link power management (ALPM).
# SATA links are specified by their host. Refer to the output of
# tlp-stat -d to determine the host; the format is "hostX".
# Separate multiple hosts with spaces.
# Default: <none>
#SATA_LINKPWR_DENYLIST="host1"
# Runtime Power Management for NVMe, SATA, ATA and USB disks
# as well as SATA ports:
# on=disable, auto=enable.
# Note: SATA controllers are PCIe bus devices and handled by RUNTIME_PM further
# down.
# Default: on (AC), auto (BAT)
#AHCI_RUNTIME_PM_ON_AC=on
#AHCI_RUNTIME_PM_ON_BAT=auto
# Seconds of inactivity before disk is suspended.
# Note: effective only when AHCI_RUNTIME_PM_ON_AC/BAT is activated.
# Default: 15
#AHCI_RUNTIME_PM_TIMEOUT=15
# Power off optical drive in UltraBay/MediaBay: 0=disable, 1=enable.
# Drive can be powered on again by releasing (and reinserting) the eject lever
# or by pressing the disc eject button on newer models.
# Note: an UltraBay/MediaBay hard disk is never powered off.
# Default: 0
#BAY_POWEROFF_ON_AC=0
#BAY_POWEROFF_ON_BAT=0
# Optical drive device to power off
# Default: sr0
#BAY_DEVICE="sr0"
# Set the min/max/turbo frequency for the Intel GPU.
# Possible values depend on your hardware. For available frequencies see
# the output of tlp-stat -g.
# Default: <none>
#INTEL_GPU_MIN_FREQ_ON_AC=0
#INTEL_GPU_MIN_FREQ_ON_BAT=0
#INTEL_GPU_MAX_FREQ_ON_AC=0
#INTEL_GPU_MAX_FREQ_ON_BAT=0
#INTEL_GPU_BOOST_FREQ_ON_AC=0
#INTEL_GPU_BOOST_FREQ_ON_BAT=0
# AMD GPU power management.
# Performance level (DPM): auto, low, high; auto is recommended.
# Note: requires amdgpu or radeon driver.
# Default: auto
#RADEON_DPM_PERF_LEVEL_ON_AC=auto
#RADEON_DPM_PERF_LEVEL_ON_BAT=auto
# Dynamic power management method (DPM): balanced, battery, performance.
# Note: radeon driver only.
# Default: <none>
#RADEON_DPM_STATE_ON_AC=performance
#RADEON_DPM_STATE_ON_BAT=battery
# Graphics clock speed (profile method): low, mid, high, auto, default;
# auto = mid on BAT, high on AC.
# Note: radeon driver on legacy ATI hardware only (where DPM is not available).
# Default: default
#RADEON_POWER_PROFILE_ON_AC=default
#RADEON_POWER_PROFILE_ON_BAT=default
# Wi-Fi power saving mode: on=enable, off=disable.
# Default: off (AC), on (BAT)
#WIFI_PWR_ON_AC=off
#WIFI_PWR_ON_BAT=on
# Disable Wake-on-LAN: Y/N.
# Default: Y
#WOL_DISABLE=Y
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >= 1 enables power saving.
# Note: 1 is recommended for Linux desktop environments with PulseAudio,
# systems without PulseAudio may require 10.
# Default: 1
SOUND_POWER_SAVE_ON_AC="* empty"
SOUND_POWER_SAVE_ON_BAT="3"
# Disable controller too (HDA only): Y/N.
# Note: effective only when SOUND_POWER_SAVE_ON_AC/BAT is activated.
# Default: Y
#SOUND_POWER_SAVE_CONTROLLER=Y
# PCIe Active State Power Management (ASPM):
# default(*), performance, powersave, powersupersave.
# (*) keeps BIOS ASPM defaults (recommended)
# Default: <none>
PCIE_ASPM_ON_AC="performance"
PCIE_ASPM_ON_BAT="powersave"
# Runtime Power Management for PCIe bus devices: on=disable, auto=enable.
#RUNTIME_PM_ON_AC=on
#RUNTIME_PM_ON_BAT=auto
# Exclude listed PCIe device adresses from Runtime PM.
# Note: this preserves the kernel driver default, to force a certain state
# use RUNTIME_PM_ENABLE/DISABLE instead.
# Separate multiple addresses with spaces.
# Use lspci to get the adresses (1st column).
# Default: <none>
#RUNTIME_PM_DENYLIST="11:22.3 44:55.6"
# Exclude PCIe devices assigned to the listed drivers from Runtime PM.
# Separate multiple drivers with spaces.
# Default: "mei_me nouveau radeon", use "" to disable completely.
#RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
# Permanently enable/disable Runtime PM for listed PCIe device addresses
# (independent of the power source). This has priority over all preceding
# Runtime PM settings. Separate multiple addresses with spaces.
# Default: <none>
#RUNTIME_PM_ENABLE="11:22.3"
#RUNTIME_PM_DISABLE="44:55.6"
# Set to 0 to disable, 1 to enable USB autosuspend feature.
# Default: 1
#USB_AUTOSUSPEND=1
# Exclude listed devices from USB autosuspend (separate with spaces).
# Use lsusb to get the ids.
# Note: input devices (usbhid) and libsane-supported scanners are excluded
# automatically.
# Default: <none>
#USB_DENYLIST="1111:2222 3333:4444"
# Exclude audio devices from USB autosuspend:
# 0=do not exclude, 1=exclude.
# Default: 1
#USB_EXCLUDE_AUDIO=1
# Exclude bluetooth devices from USB autosuspend:
# Default: 0
USB_EXCLUDE_BTUSB="* empty"
# Exclude phone devices from USB autosuspend:
# 0=do not exclude, 1=exclude (enable charging).
# Default: 0
#USB_EXCLUDE_PHONE=0
# Exclude printers from USB autosuspend:
# Default: 1
USB_EXCLUDE_PRINTER="0"
# Exclude WWAN devices from USB autosuspend:
# Default: 0
#USB_EXCLUDE_WWAN=0
# Allow USB autosuspend for listed devices even if already denylisted or
# excluded above (separate with spaces). Use lsusb to get the ids.
# Default: 0
#USB_ALLOWLIST="1111:2222 3333:4444"
# Set to 1 to disable autosuspend before shutdown, 0 to do nothing
# Note: use as a workaround for USB devices that cause shutdown problems.
# Default: 0
#USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=0
# Restore radio device state (Bluetooth, WiFi, WWAN) from previous shutdown
# on system startup: 0=disable, 1=enable.
# Note: the parameters DEVICES_TO_DISABLE/ENABLE_ON_STARTUP/SHUTDOWN below
# are ignored when this is enabled.
# Default: 0
#RESTORE_DEVICE_STATE_ON_STARTUP=0
# Radio devices to disable on startup: bluetooth, nfc, wifi, wwan.
# Default: <none>
DEVICES_TO_DISABLE_ON_STARTUP="bluetooth nfc wwan"
# Radio devices to enable on startup: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_STARTUP="wifi"
# Radio devices to disable on shutdown: bluetooth, nfc, wifi, wwan.
# Note: use as a workaround for devices that are blocking shutdown.
# Default: <none>
#DEVICES_TO_DISABLE_ON_SHUTDOWN="bluetooth nfc wifi wwan"
# Radio devices to enable on shutdown: bluetooth, nfc, wifi, wwan.
# (to prevent other operating systems from missing radios).
# Default: <none>
#DEVICES_TO_ENABLE_ON_SHUTDOWN="wwan"
# Radio devices to enable on AC: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_AC="bluetooth nfc wifi wwan"
# Radio devices to disable on battery: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT="bluetooth nfc wifi wwan"
# Radio devices to disable on battery when not in use (not connected):
# bluetooth, nfc, wifi, wwan.
# Default: <none>
DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth nfc wwan"
# Battery Care -- Charge thresholds
# Charging starts when the charge level is below the START_CHARGE_THRESH value
# when the charger is connected. It stops when the STOP_CHARGE_THRESH value is
# reached.
# Required hardware: Lenovo ThinkPads and select other laptop brands are driven
# via specific plugins, the actual support status is shown by tlp-stat -b.
# For more explanations and vendor specific details refer to
# https://linrunner.de/tlp/settings/battery.html
# Notes:
# - ThinkPads may require external kernel module(s), refer to the output of
# tlp-stat -b
# - Vendor specific parameter value ranges are shown by tlp-stat -b
# - If your hardware supports a start *and* a stop threshold, you must
# specify both, otherwise TLP will refuse to apply the single threshold
# - If your hardware supports only a stop threshold, set the start value to 0
# BAT0: Primary / Main / Internal battery (values in %)
# Note: also use for batteries BATC, BATT and CMB0
# Default: <none>
START_CHARGE_THRESH_BAT0="80"
STOP_CHARGE_THRESH_BAT0="85"
# BAT1: Secondary / Ultrabay / Slice / Replaceable battery (values in %)
# Note: primary on some laptops
# Default: <none>
START_CHARGE_THRESH_BAT1="80"
STOP_CHARGE_THRESH_BAT1="85"
# Restore charge thresholds when AC is unplugged: 0=disable, 1=enable.
# Default: 0
#RESTORE_THRESHOLDS_ON_BAT=1
# Control battery care drivers: 0=disable, 1=enable.
# Default: 1 (all)
#NATACPI_ENABLE=1
#TPACPI_ENABLE=1
#TPSMAPI_ENABLE=1
# tlp-rdw - Parameters for the radio device wizard
# Possible devices: bluetooth, wifi, wwan.
# Separate multiple radio devices with spaces.
# Default: <none> (for all parameters below)
# Radio devices to disable on connect.
#DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
#DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
# Radio devices to enable on disconnect.
#DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
#DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT=""
#DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT=""
# Radio devices to enable/disable when docked.
#DEVICES_TO_ENABLE_ON_DOCK=""
#DEVICES_TO_DISABLE_ON_DOCK=""
# Radio devices to enable/disable when undocked.
#DEVICES_TO_ENABLE_ON_UNDOCK="wifi"
#DEVICES_TO_DISABLE_ON_UNDOCK=""
