How can my network controller in hardware configuration is nothing?
Anyone can help me?
Please read and post full inxi output:
Wow I have just known this forum has some rules… sorry…
I will reply you later, I Will read some rules that you share to me first…
sorry late to reply…
this is inxi output
CPU: dual core Intel Celeron N4020 (-MCP-) speed/min/max: 1576/800/2800 MHz
Kernel: 5.15.12-1-MANJARO x86_64 Up: 26m Mem: 2063.8/7764.4 MiB (26.6%)
Storage: 223.57 GiB (3.8% used) Procs: 175 Shell: Zsh inxi: 3.3.11
and
and this one of
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6faeb691-d4e8-4791-a0ce-b9f51c28a70c rw quiet apparmor=1
security=apparmor resume=UUID=bc304f54-ddfe-4041-9a99-cb34831edc8e
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Axioo product: Mybook 14H v: N/A
serial: Chassis: type: 10 serial:
Mobo: N/A model: PN1305P serial:
UEFI: American Megatrends v: GN10BV104 date: 06/23/2021
ID-1: BAT0 charge: 28.9 Wh (95.1%) condition: 30.4/30.4 Wh (100.0%)
volts: 8.1 min: 7.6 model: Intel SR 1 SR Real Battery type: Unknown
serial: status: Discharging
RAM: total: 7.58 GiB used: 1.75 GiB (23.1%)
RAM Report:
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x1A
Topology: cpus: 1x cores: 2 smt: cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1152 high: 1471 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 833 2: 1471
bogomips: 4378
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Microdia Sonix USB 2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0c45:6310 class-ID: 0e02 serial:
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
bus-ID: 1-7.2:5 chip-ID: 0bda:8152 class-ID: 0000 serial:
IF: enp0s21f0u7u2 state: down mac:
IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Realtek 802.11n WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0bda:d723 class-ID: e001 serial:
Local Storage: total: 223.57 GiB used: 8.43 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 model: 240GB size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial:
rev: 8A0 scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 8.28 GiB (8.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6faeb691-d4e8-4791-a0ce-b9f51c28a70c
ID-2: /boot/efi raw-size: 532 MiB size: 530.9 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: F992-F6C5
ID-3: /home raw-size: 120.05 GiB size: 117.61 GiB (97.96%)
used: 151.3 MiB (0.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: c0a8f060-7230-4b21-a5ff-480b284ef0af
ID-1: swap-1 type: partition size: 3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: bc304f54-ddfe-4041-9a99-cb34831edc8e
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-5:2 info: Microdia Sonix USB 2.0 Camera type: Video
Device-2: 1-6:3 info: Realtek 802.11n WLAN Adapter type: Bluetooth
driver: btusb interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 1-7:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-7.2:5 info: Realtek RTL8152 Fast Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 0bda:8152 class-ID: 0000 serial:
Hub-3: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 174 Uptime: 39m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1192 lib: 329 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
I just want to connect to wifi (wireless)
can I?
